Unable to enter Security Access for Central Elect
nets
Singapore
Hi All,
Was trying to fix the Rear licence plate LED warning issue with the fixes mentioned in the forum: One of the fixes requires me to go into the Central Elect -> Security Access but it seemed code 31347 is not working for my Skoda Superb Mk2 Kombi.
The steps I'm trying is:
-> Controller 09 - Central Electronics > 16 - Security Access - enter 31347
-> 10 - Adaptations
Change the 2 channels listed below
(1)-Leuchte25KZL HA59-Lasttyp 25 - set to: 43 - allgemeine LED
(6) Leuchte25KZL HA59 - Dimmwert AB 25 - set to 127
(1)-Leuchte25KZL HA59-Lasttyp 25 ===== (41- LED Keinleistung)
The extract of the scan results as followed:
Saturday,30,April,2016,16:33:10:58760
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
VIN: TMBKH93T7B9056088   License Plate:
Mileage: 116880km-72625mi   Repair Order: Rear Licence Light
Chassis Type: 3T (7N0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 25 2B 2E 36 37 42 44 46 47
          4F 52 55 56 62 6D 72 77
VIN: TMBKH93T7B9056088   Mileage: 116880km-72625miles
   Part No SW: 1K0 937 087 P    HW: 1K0 937 087 P
   Component: BCM PQ35  H+  104 0615
   Revision: 00104 AE
   Coding: 48190ABBE80708C040080080310089E443F100AE776D89B05C814000A040
   Shop #: WSC 33361 790 00999
   VCID: 3E5DDFA9A9923DCE4C-806A
   Subsystem 1 - Part No: 3T2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer 15021  26  0602
   Coding: 00D7B7
   Component: RLS 070311 05  54  0403
   Coding: 0730ED
                    Fault Status: 00101110
                    Fault Frequency: 74
                    Reset counter: 89
                    Mileage: 115306 km
                    Date: 2016.04.09
                    Time: 10:51:29
                    Voltage: 13.40 V
                        Term 50 Off
Sebastian
Magdeburg, Germany
HN0-nnnnnn
The instructions you are using are for MQB based models, like the Superb (3V). Your's is the older generation Superb (3T). All you need for your car should be in the BCM coding, use the coding assist and you should be good to go.
nets
Singapore
Hi Sebastian, thanks for the advice. Could you guide me for the BCM settings? I have tried disabling the cold monitoring as well as checking the led option but the warning light will appear whenever the lights lit up as outside grows dark. Cheers!
Hi All .. Any experts advice :)
nets: I'm by no means an expert, but as a suggestion from a bog-amateur, have you considered the low-tech approach? How about fitting a by-pass resistor across the LED fitting to simulate an incandescent lamp? They do generate heat, but if placed appropriately, a resistor could be a worthwhile alternative - if a coding solution can't be found (IMO)
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Your coding is already set up for LED license plate lights. The problem is likely your BCM software level, later versions (I believe SW 0640+) manage some of the settings differently, or in otherwords - the settings don't seem to have the desired effect. Don't low tech approach should work - though I am not a fan of it due to the generated heat and burning power for no reason.
