2016 VW Up! ecofuel CPGA
NEtech
Denmark
C?ID=56995
Friday,29,April,2016,14:41:41:31678
VCDS Version: 16.3.1.1 (x64)
Data version: 20160325
VIN: WVWZZZAAZGD09xxxx   License Plate:
Chassis Type: AA (1S0)
Scan: 01 03 09 15 17 19 25 44 56 61 AD
VIN: WVWZZZAAZGD09xxxx   Mileage: 0km-0miles
AD-Brake Sensors -- Status: Malfunction 0010
Address 01: Engine (------CPGA)       Labels: None
   Part No SW: 04C 906 020 CP    HW: 04C 907 309 AF
   Component: R3 1.0l CPI   H12 2110
   Revision: U5H12---
   Coding: 00110010000401000000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_ECM10CPI01104C906020CP 001005
   ROD: EV_ECM10CPI01104C906020CP_VW12.rod
   VCID: 6B96066B82FE4E6471-803E
14690 - Loading Mode active
          P169A 00 [175] - -
                    Mileage: 4 km
                    Date: 2016.04.04
                    Time: 16:40:00
                    Engine speed: 0.00 /min
                    Coolant temperature: 72 °C
                    Intake air temperature: 40 °C
                    Voltage terminal 30: 12.415 V
                    Unlearning counter according OBD: 0
                    Mass flow through throttle valve: 0.0 kg/h
                    Engine operating condition: Idling
Address 03: ABS Brakes (J104)       Labels: 1S0-614-517.clb
   Part No SW: 1S0 614 517 L    HW: 1S0 614 517 L
   Component: EBC 460 ESP   H16 0023
   Serial number: A014YU4
   Coding: 12BF247129B602F148FD24F694AA40505FB100
   ASAM Dataset: EV_Brake1ESPEBC460TRW 002004
   ROD: EV_Brake1ESPEBC460TRW_VW12.rod
   VCID: 383CE927832835FC4C-806C
Address 09: Cent. Elect. (J519)       Labels: 1S0-937-08x-09.clb
   Part No SW: 1S0 937 090 D    HW: 1S0 937 090 D
   Component: PQ25 BCM      H59 0584
   Revision: -8------    Serial number: --------------
   Coding: 62B82B0000010000000001F42C2BAC807340424E7E031460200000460100
   VCID: 3424DD179740D19C60-8060
   Part No SW: 1S0 959 655 B    HW: 1S0 959 655 B
   Component: VW10Airbag01Q H03 0006
   Revision: --------    Serial number: 003MY00JB1VZ
   Coding: 000000000000000000000000000000003151
   ASAM Dataset: EV_AirbaVW10BPAVW12X 001001
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 3D32F833AC0A10D49F-8068
   Serial number: 3497ARB405J3U9U65H2T
   Serial number: 3507ARB405R3UHHSRGVA
   Serial number: 3557BRB404P3OMV2I16.
Address 17: Instruments (J285)       Labels: 1Sx-920-xxx-17.clb
   Part No SW: 1S0 920 861 K    HW: 1S0 920 861 K
   Component: KOMBI         H52 0405
   Revision: X0052001    Serial number: 00000000000000
   Coding: 1142010000
   ASAM Dataset: EV_KombiUDSMM9RM10 A05803
   ROD: EV_KombiUDSMM9RM10_VW12.rod
   VCID: 393AEC23B8222CF4B3-806C
   Part No SW: 1S0 909 901     HW: 1S0 937 090 D
   Component: GW-K-CAN TP20 H59 0584
   Revision: -8------
   Coding: 001600
   VCID: 70AC1107A3D8ADBC44-8024
   Part No SW: 5K0 953 234     HW: 1S0 920 861 K
   Component: IMMO          H52 0405
   ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
   ROD: EV_ImmoUDSMM9RM10_VW01.rod
   VCID: 6A98036F8D04576C0A-803E
Address 44: Steering Assist (J792)       Labels: 6Rx-909-144-V2.clb
   Part No SW: 6R1 909 144 AJ    HW: 6R1 909 144 E
   Component: EPS_TRW_ALow  312 3132
   Serial number: CG3P1319
   Coding: 000700
   ASAM Dataset: EV_SteerAssisUDSTRW 016029
   ROD: EV_SteerAssisUDSTRW_VW12.rod
   VCID: 7F4EC23BE686C2C4CD-802A
   Part No SW: 1S0 035 156 B    HW: 1S0 035 156 B
   Component: Radio         567 5543
   Revision: AA001001    Serial number: VWZ8Z1S2286133
   Coding: 0000020801
   VCID: 2A18C36F4584976CCA-807E
   Part No SW: 1S0 907 534     HW: 1S0 937 090 D
   Component: Batt-regelung H59 0584
   Coding: 032B7864
   Subsystem 1 - Part No SW: 1S0 915 181 B    HW: 1S0 915 181 B
   Component: J367-BDM  H08 0210
Address AD: Brake Sensors (J939)       Labels: 1S0-907-201.clb
   Part No SW: 1S0 907 201 A    HW: 1S0 907 201 A
   Component: CV-SENSOR     H07 0460
   ASAM Dataset: EV_CVSen 001001
   ROD: EV_CVSen.rod
   VCID: 281C39675388A57CDC-807C
12290 - Transport Mode Active
          U1105 00 [009] - -
                    Reset counter: 0
                    Mileage: 4 km
                    Date: 2016.04.04
                    Time: 16:53:45
End----------(Elapsed Time: 00:46, VBatt start/end: 15.0V/15.0V)-----------
Eric
HC800000
46 seconds, holy shit :)
NEtech
Denmark
C?ID=56995
Yes and with 1 controller scanned twice and error codes present :thumbs:
NEtech
Denmark
C?ID=56995
You know, what VCDS always does.
Eric
HC800000
Ah, with the hexnet, it should scan 17, then 19 and retrieve GVL at the same time, then scan the rest of them without scanning either 17 or 19 again. Did it not behave like that?
NEtech
Denmark
C?ID=56995
Yeah you are right, I thought I had seen VCDS did 17 or 01 twice.
Just tried on my Up, 43 sec. for a complete Autoscan.
