MK1 TT seatbelt chime
ma2kster
C?ID=109069
I can't figure this out. Original coding of Module [17, Instruments] is 21244. 19244 should disable the chime, but it doesn't go through (im using 8nx-920-xxx-17.lbl file). The code doesn't change, it just goes back to 21244. Is there something i'm missing? Thx.
additional details:
Part no: 8n1 920 980 E
coding 21244
shop #: WSC 09110
jakematic
NC USA
C?ID=129085
16 + 4 + 1 = 21 which is your original coding.
This suggests to me that the +2 is already lacking, or it would have been 23.
The only way you could get to 19, mathematically, would be:
+1 AWD
+2 Seat belt chime
+16 Secondary display
Post up a full scan and I'll take a deeper look.
ma2kster
C?ID=109069
Thanks. It is really weird. the seat-belt chime is already active and the code is 21244.
Monday,26,May,2014,08:31:30:29699
VCDS Version: 12.12.2.0
Data version: 20140212
VIN: TRUWT28N_________   License Plate:
Mileage: 64503   Repair Order:
Chassis Type: 8N (8N - Audi TT (1999 > 2007))
Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77
VIN: TRUWT28N___________
   Part No: 8N0 906 018 CL
   Component: 1.8L R4/5VT     G   0010
   Coding: 07710
   Shop #: WSC 01236
   VCID: 7DFAE1CF77856DF6F01-5120
   TRUWT28N__________     AUZ5Z0E0146124
Address 03: ABS Brakes        Labels: 8N0-907-379-MK60-A.lbl
   Part No: 8N0 907 379 H
   Component: ESP ALLRAD MK60     0101
   Coding: 0022544
   Shop #: WSC 01236 785 00200
   VCID: 41825D3F1BFDC916D49-5102
Address 08: Auto HVAC        Labels: 8N0-820-043.lbl
   Part No: 8N0 820 043 A
   Component: TT-KLIMAVOLLAUTOMAT D03
   Coding: 00140
   Shop #: WSC 01236
   VCID: 2854E09BC887185EF37-2566
Address 15: Airbags        Labels: 8N0-959-655.lbl
   Part No: 8N0 959 655 D
   Component: Airbag Front+Seite 1000
   Coding: 01103
   Shop #: WSC 01236
   VCID: 41825D3F4BFDC916D49-5120
Address 17: Instruments        Labels: 8Nx-920-xxx-17.lbl
   Part No: 8N1 920 980 E
   Component: KOMBI+WEGFAHRS. M73 D14
   Coding: 21244
   Shop #: WSC 09110
   VCID: 387430DB182788DE637-4ACE
Address 22: AWD        Labels: 02D-900-554.lbl
   Part No: 02D 900 554 D
   Component: HALDEX LSC  ECC     0011
   VCID: 2142FDBFABBDE916B49-4ACE
Address 35: Centr. Locks        Labels: 8Nx-962-267.lbl
   Part No: 8N8 962 267 F
   Component: Central Lock/Alarm  D09
   Coding: 15884
   Shop #: WSC 01236
   VCID: 448C542B54EFDC3EFFF-4ECA
Address 55: Xenon Range        Labels: 4B0-907-357-AUT.lbl
   Part No: 4B0 907 357
   Component: LEUCHTWEITEREGLER  D004
   Coding: 00010
   Shop #: WSC 01236
   VCID: E5CA29AF7F154536881-5196
Address 56: Radio        Labels: 8D0-035-1xx-56.lbl
   Part No: 4B0 035 186 L
   Component: concert II  PM6    0410
   Coding: 00302
   Shop #: WSC 08960
   VCID: 2952E59FD38D2156EC9-5072
jakematic
NC USA
C?ID=129085
Are you getting any message such as "Out of range" or anything else ?
The only thing I can suggest is change it to 23244, observe any changes, then back to 21244 and observe any changes.
ma2kster
C?ID=109069
I'll try tonight. No error messages were given when i changed it to 19, though i noticed the code didnt change when i came back to the module screen. I tried changing to 23, which it did. then i came back to 21, but chime was still there. maybe there is an ignition cyle, etc. that i need to do. I will try all combinations tonight. Thanks again.
That cluster uses the old KW1281 protocol; it's not smart enough to be able to say, "Out of range". The only way to tell if a new coding is accepted or rejected is to see if it "sticks".
ma2kster
C?ID=109069
Exactly, that's what happened. when i put in 19, it didn't stick. Then when i put in 23, it did stick. On its original coding (21) seatbelt chime was present. then on new code (23) it was still there. I'll try tonight with ignition off for few minutes before observing changes. Thx.
ma2kster
C?ID=109069
Tonight i tried again, but still no changes to seat-belt chime behavior. I started with 21244, then changed it to 23244. Closed all application windows and exited controller and VCDS, then removed key from ignition. did this a few times, changing code between 21244 and 23244. Nothing changes. There is still the chime and seatbelt light illuminates when i unbuckle. I also tied with the German cluster code setting. Miles changed to kilometers (21044), but still chime stayed. Weird. maybe there is a catch somewhere else, or it is not possible with this controller.
DrPeter
16.4905° S, 151.7375° W
Hi,
Can you PM me your full VIN number, that way I can see exactly what equipment is installed.
Thanks,
drp
DrPeter
Hi,
Looks like the coding from the factory would have been [07244]
07xxx equals -
[+01] - All-Wheel-Drive
[+02] - Seat-belt Warning active
[+04] - Manual Transmission
[+00] - NO Navigation (PR code = 7Q0-Without navigation device)
So if you change the coding to [05244] that would eliminate [+02] - Seat-belt Warning active and [+16] - Navigation from your original coding.
Try this coding [05244] and if you are having issues still, have a look at what you have stored in the Adaptations channels [60,61 and 62] and post the results.
Hope this helps,
drp
ma2kster
C?ID=109069
Awesome! makes a lot of sense. I'll try and report back. I'm not sure why the original coding is off. I promise that I've not altered it and I know that the original Owner didn't even know about possibility programming. I'm the second owner. Thanks again, and i will report back.
golfi_vend
Tartu, Estonia
C?ID=195131
I had a issue once on a MKIV, that cluster showed things that are not present. Like seatbelt and brakepads. Coding didn't help, only thing that helped was a battery terminal removal.
Hope this helps somebody.
ma2kster
C?ID=109069
It worked! Thanks so much DrPeter and everyone that made suggestions. 05244 works to remove the seatbelt chime. It is puzzling to me that Audi would setup original coding off, i.e. to setup with Navigation feature while there is no navigation installed. Glad we have you and a great product like VCDS.
