Hello all, I'm hoping I can get some help here on what I have to do after a valve body replacement on a 2007 Touareg V8 FSI. My original issue was a harsh, thud shift between 1st and 2nd after operating temp was reached. It was intermittant but enough to annoy me and my wife. The replacement was a unit from Revmax. I feel that I did good on the fluid refill getting about 9.25L using a Schwaben pump and monitoring transmission operating temp with VDCS looking for the slight drip at 35C. After the install, the shift seems cleaner but I still get the thud once in awhile, maybe not as frequent as before although I've only put 200 miles since the install. It seems to do it more when I go easy on the gas and not take off so hard.
I tried numerous different resets that I've found on different forums for Touaregs and VW products in general. Instructions that are posted are inconsistent with each other. The most common was ignition on, press gas for 10 sec, release gas, ignition off. But i'd see other variations like ignition on, press gas for 10 sec, ignition off, release gas. I've also seen on-line one procedure to shift trans to N then D, repeat 5 times, then do the same for N then to R, repeat 5 times. THen accel to 60, decel to a stop in no less than 60 sec, then repeat 10 times. I tired this but it was hard for me to find a stretch of road to get to 60 then come to a stop in 60 seconds.
In any case, Im wondering if any of these resets can be done using VCDS, what type of resets do I have to do after a valve body replacement? If it requires a variation of what I have above, which one is right? Is there something in VCDS that can tell me that the computer or whatever is in learning mode? Thanks in advance for any help. I do love the Treg, but this issue always has me wondering if I have to brace myself each time i take off from a stop. It gets annoying that I always have to think about it!
Wednesday,27,April,2016,18:36:24:26356
VCDS Version: 15.7.4.1
Data version: 20160216
VIN: WVGZB77L17D050298 License Plate:
Mileage: 152520km-94771mi Repair Order:
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGZB77L17D050298 Mileage: 152520km-94771miles
Address 01: Engine Labels: None
Part No SW: 7L0 910 560 F HW: 7L0 907 560
Component: 4.2l V8/4V 0020
Revision: 75H06--- Serial number: VWX3Z0F2526259
Coding: 04210009590F0960
Shop #: WSC 20504 444 84026
VCID: 2E536ED8BA71B14EDC-5140
Address 02: Auto Trans Labels: 09D-927-750.lbl
Part No SW: 09D 927 750 CR HW: 09D 927 750 CR
Component: AL 750 6A 0941
Revision: 00H51000 Serial number:
Coding: 0004200
Shop #: WSC 31414 790 00001
VCID: 000FE0605065F73E7E-5140
Address 03: ABS Brakes Labels: 7L0-907-379-MK25.lbl
Part No: 7L0 907 379 G
Component: ESP ALLRAD MK25 0203
Coding: 0014338
VCID: 3D71599460175AD655-8068
Address 05: Acc/Start Auth. Labels: None
Part No SW: 7L0 909 135 B HW: 5WK 485 16
Component: Kessy 6840
Revision: 68406418 Serial number: VWX3Z0F2526259
Coding: 0000232
VCID: 306F70A0A045A7BECE-5140
Component: ELV XXXX
Address 08: Auto HVAC Labels: 7L6-907-040.clb
Part No: 7L6 907 040 T
Component: CLIMAtronic R/L 4222
Coding: 0020030
VCID: 418925641BEF3E3631-5140
Address 09: Cent. Elect. Labels: 7Lx-937-049-V1.clb
Part No: 7L6 937 049 M
Component: 3003
Coding: 0100572
VCID: 4683367832C1190E04-5124
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 H
Component: 05 Airbag 8.4E++H01 0562
Revision: BB38727 Serial number: 0009594=
Coding: 0012341
VCID: 285F98C09B95EF7E16-807C
Subsystem 1 - Part No: 7L0 959 339 E
Component: BF-Gewichtsens. 007 0009
Reset counter: 39
Address 16: Steering wheel Labels: 7L6-953-549.lbl
Part No: 7L6 953 549 H
Component: Lenksäulenmodul 3401
Coding: 0010031
VCID: 44872C7004FD2B1E1A-5124
Address 17: Instruments Labels: 7L6-920-xxx-7LA.lbl
Part No: 7L6 920 981 P
Component: KOMBIINSTRUMENT RB8 3211
Coding: 0005131
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
Shop #: WSC 02134 444 53714
VCID: 70EFB0A060C5E7BE8E-5140
Address 1C: Position Sensing Labels: 7L6-919-879.lbl
Part No: 7L6 919 879 A
Component: JCI PathPoint 2200
VCID: 458131740FC712160D-5140
Address 22: AWD Labels: None
Part No: 0AD 927 755 BE
Component: TRANSFERCASE 0119
VCID: 7F0D639C2D9B88C607-5140
Part No: 7L0 959 760
Component: Sitzverstellung 0702
VCID: 77FD8BBC05ABB0864F-5140
Address 37: Navigation Labels: 7L6-919-887-DVD.lbl
Part No: 7L6 919 887 M
Component: Navigation 0047
Coding: 0000101
VCID: 50AF1020C085C7BEAE-5124
Address 46: Central Conv. Labels: 7L0-959-933.lbl
Part No: 7L0 959 933 H
Component: YM HSG 0400
Coding: 0000085
VCID: 418925641BEF3E3631-4B00
Subsystem 1 - Part No: 7L0 959 701 G
Component: Tuersteuergeraet FS 0201
Subsystem 2 - Part No: 7L0 959 702 G
Component: Tuersteuergeraet BF 0201
Subsystem 3 - Part No: 7L0 959 703 C
Component: Tuersteuergeraet HL 0201
Subsystem 4 - Part No: 7L0 959 704 C
Component: Tuersteuergeraet HR 0201
Address 47: Sound System Labels: 7Lx-035-4xx-47.lbl
Part No: 7L6 035 456
Component: 08K Audioverst. 0105
VCID: 70EFB0A060C5E7BE8E-5124
Subsystem 1 - Part No: 7L6 035 456
No Faults Found
Address 55: Headlight Range Labels: 7L6-907-357.lbl
Part No SW: 7L6 907 357 HW: 7L6 907 357
Component: AFS-Steuergeraet 0003
Revision: H09 Serial number:
Coding: 0000007
VCID: 78FF88800FB5BFFE46-802C
Subsystem 1 - Part No: 7L6 941 329 Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l X018
Coding: 00000034
Subsystem 2 - Part No: 7L6 941 330
Component: AFS-Lst.-Modul r X018
Coding: 00000034
Address 56: Radio Labels: 7L6-035-186-DVD.lbl
Part No: 7L6 035 186 E
Component: Radio 0047
Coding: 0014042
VCID: 356141B45F2782969D-5140
Address 68: Wiper Electr. Labels: 7L0-955-119-V2.clb
Part No: 7L0 955 119 K
Component: Front Wiper 4027
Coding: 0000341
Shop #: WSC 31414 790 376833
VCID: 3C7754907C0D53DE62-5124
Subsystem 2 - Part No: 1K0 955 559 AE Labels: 1K0-955-559-AF.CLB
Component: RLS 230906 014 1201
Coding: 00208933
Shop #: WSC 31414
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 7L6 907 441 HW: 7L6 907 441
Component: J772__Rearview 0051
Revision: 00H07000 Serial number: PA8 J690035
Coding: 0000201
VCID: 72EBBAA86EC9D5AE78-5140
Address 6D: Trunk Elect. Labels: Redir Fail!
Part No SW: 7L6 959 107 HW: 7L6 959 107
Component: J605 HECKKLAPPE 1110
Revision: --H05--- Serial number: --------006715
Coding: 0022110
VCID: 78FF888008B5BFFE46-5140
Address 6E: Ctrl Head Roof Labels: 7L6-919-044.lbl
Part No: 7L6 919 044 T
Component: DACHDISPLAY 0539
Revision: 00900539 Serial number: 2009289.07
VCID: 489F384038D50F7EF6-5140
Address 76: Park Assist Labels: Redir Fail!
Part No: 7L0 919 283 F
Component: 0E Einparkhilfe 1107
VCID: 39794D84733F66F679-5124
End-------------------------(Elapsed Time: 10:58)--------------------------
