transporter t6 folding mirrors on lock,
nickdaw
C?ID=180250
Just got my new Hex-Can from Marshalls industrial, a lot better than the £50 copy
( I've tried a copy cable years ago and they don't seem to work properly)
Is it possible to auto fold the mirrors when i press lock on the key,
also is it possible to turn carplay on with Ross-tech
thanks
Thursday,28,April,2016,13:50:31:10236
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(VirtualBox)
VCDS Version 15.7.4.1 (x64)
Data version: 20160216
VIN: WV1ZZZ7HZGH078350   License Plate:
Mileage: 2550km-1584mi   Repair Order:
Chassis Type: 7H (7E0)
Scan: 01 02 03 08 09 10 15 17 19 25 5F 61 69 0B
VIN: WV1ZZZ7HZGH078350   Mileage: 2550km-1584miles
Address 01: Engine (J623-CAAC)       Labels: 03L-906-022-CAA.clb
   Part No SW: 03L 906 019 JP    HW: 03L 907 309 L
   Component: R4 2.0l TDI   H38 9977
   Revision: 22H38---    Serial number: 00000000000000
   Coding: 01254012233401080000
   Shop #: WSC 02739 790 50316
   ASAM Dataset: EV_ECM20TDI01103L906019JP 004004
   ROD: EV_ECM20TDI01103L906019JN.rod
   VCID: 020BE76C9528ED2E68-8057
Address 02: Auto Trans (J743)       Labels: 0BH-927-711.clb
   Part No SW: 0BT 300 045 T    HW: 0BH 927 711 G
   Component: DSG DQ500-7F  H11 2411
   Revision: 00H11V01
   ROD: EV_TCMDQ500021_SE36.rod
   VCID: 46833B7CF980110E04-8013
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   Component: ESC           H05 0132
   Revision: 00000000    Serial number: 43275000001764
   Coding: 307E4098256984860C78027BA48221D3390000
   ROD: EV_Brake1ESCCONTIVN75XGP2.rod
   VCID: 3F8D2E98A65A40C647-806B
0397 - Display for Tire Pressure Monitoring
          C1146 02 [008] - Signal Failure
                    Reset counter: 48
                    Mileage: 299 km
                    Date: 2016.03.06
                    Time: 13:30:15
Address 08: Auto HVAC (J301)       Labels: None
   Part No SW: 7E0 907 047 S    HW: 7E0 907 047 S
   Component: Climatic-T5   H22 0607
   Revision: 00001002
   Coding: 0000000003
   Shop #: WSC 02737 790 50316
   ROD: EV_ClimaT5Basis_VN75.rod
   VCID: 3A7B5F8CBD7865EE70-806F
Address 09: Cent. Elect. (J519)       Labels: 7E0-937-BCM-V1.clb
   Part No SW: 7E0 937 090     HW: 7E0 937 090
   Component: BCM PQ25 Max4 H80 0733
   Revision: B9080001    Serial number: 0771 334150793
   Coding: A0F4793A0A61349193284F646CEB8EF48DA0718960CC6D603204003F0800
   Shop #: WSC 02737 534 1340757
   VCID: 68DFD5C49B54277ED6-803D
   Subsystem 1 - Part No: 5K7 955 559 B
   Component: RLS 071215 03  37  0059
   Coding: 0228EE
   Subsystem 2 - Part No SW: 7E0 959 801 L    HW: 7E0 959 801 L  Labels: 7E0-959-801.CLB
   Component: J386__TSG_FT  003 8654
   Coding: 1400B1
   Subsystem 3 - Part No SW: 7E0 959 802 L    HW: 7E0 959 802 L  Labels: 7E0-959-802.CLB
   Component: J387__TSG_BT  003 8654
   Coding: 0400A1
   Subsystem 4 - Part No: 7E1 951 172
   Subsystem 5 - Part No: 1K0 951 605 C
   Subsystem 6 - Part No: 7E1 951 172
   Subsystem 7 - Part No SW: 2H0 959 442     HW: 2H0 959 442
   Component: E221__MFL-DC1  H02 0103
   Coding: A4FFFF
Address 10: Park/Steer Assist (J446)       Labels: 7E0-919-475.clb
   Part No SW: 7E0 919 475 R    HW: 1Q0 919 475
   Component: PARKHILFE 4K  H03 0210
   Revision: --------    Serial number: 32931530200012
   Coding: 318108
   ASAM Dataset: EV_VW75XParkAssis4K 001012
   ROD: EV_VW75XParkAssis4K_VN75.rod
   VCID: 41892860D0AE363631-8015
   Part No SW: 7E0 959 655 D    HW: 7E0 959 655 D
   Component: VW10Airbag00J 008 0016
   Revision: --------    Serial number: 003PH001ZYYK
   Coding: 00000000000000000000000000000000304A
   Shop #: WSC 02734 790 50316
   ROD: EV_AirbaVW10BPAVN750_SE12.rod
   VCID: 377D46B88E6A78868F-8063
   Part No SW: 7E0 920 970 L    HW: 7E0 920 970 L
   Component: KOMBI         H05 1008
   Coding: 470B010100
   ROD: EV_Kombi_UDS_VDD_RM09_SE36.rod
   VCID: 336572A89A1294A6B3-8067
   Part No SW: 7E0 909 901     HW: 7E0 937 090
   Component: GW-K-CAN TP20 H80 0733
   Revision: B9080001
   Coding: 042307
   Component: IMMO          H05 1008
   VCID: 6ADBAFCC8D58156EC0-803F
Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD2.clb
   Part No SW: 5C0 035 680 C    HW: 5C0 035 680 C
   Component: MU-S-ND-ER    H22 0245
   Serial number: VWZAZ2R8077749
   Coding: 065700013C00000011111101008808001F010096002001004F
   ROD: EV_MUStd4CTSAT_SE25.rod
   VCID: 214988E030EE163651-8075
   Engine Control Module 2:
   Subsystem 1 - Part No SW: 3G0 919 866 M    HW: -----------
   Component: ECE 2016  --- 0521
   Part No SW: 7E0 907 534     HW: 7E0 937 090
   Component: Batt.regelung H80 0733
   Shop #: WSC 02739 790 00000
   Subsystem 1 - Part No SW: 7E0 915 181 G    HW: 7E0 915 181 G
   Component: J367-BDM  H08 0223
Address 69: Trailer (J345)       Labels: 1K0-907-383-MY8.lbl
   Part No SW: 1K0 907 383 H    HW: 1K0 907 383 G
   Component: Anhaenger     H12 0130
   Revision: 3B001001    Serial number: 00000388038346
   Coding: 410D000103000000
   VCID: 326B77AC6D089DAEB8-8067
End-------------------------(Elapsed Time: 03:05)--------------------------
