Retrofit ACC VW Passat b7
vipers
Bucharest Romania
C?ID=28396
Hello, I am trying to retrofit the ACC for a 2011 Passat , I am trying to code the ACC from 0010000 to 0010100 but it is asking for security code.
Please advice me what to do , Thank you
This is the scan from the car
Monday,25,April,2016,10:15:57:10212
VCDS Version: 16.3.1.1 (x64)
Data version: 20160325
Dealer/Shop Name: Viper Alarms
VIN: WVWZZZ3CZBP324190   License Plate:
Chassis Type: 3C (7N0)
Scan: 01 03 08 09 10 13 15 16 17 19 25 2E 37 42 44 46 4F 52 53 55
          56 61 62 69 6C 72 77 A5
VIN: WVWZZZ3CZBP324190   Mileage: 99580km-61876miles
Address 01: Engine (J623-CFFB)       Labels: 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 BF    HW: 03L 907 309 N
   Component: R4 2,0L EDC   H24 9948
   Revision: 47H24---    Serial number: VWZCZ000000000
   Coding: 00190012043401080000
   Shop #: WSC 32546 001 104857
   ASAM Dataset: EV_ECM20TDI01103L906018BF 003006
   ROD: EV_ECM20TDI01103L906018BE.rod
   VCID: 6FE7AF05B6BAE8445D-803A
4332 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [167] - -
                    Mileage: 99587 km
                    Date: 2016.04.25
                    Time: 09:08:41
                    Engine speed: 0.00 /min
                    Coolant temperature: 42 °C
                    Intake air temperature: 19 °C
                    Voltage terminal 30: 11.860 V
                    ACC target acceleration: 0.000 m/s2
                    ACC control module received status-Bit 0: 00000100
                    Status of ACC/CCS acceleration interface-Bit 0: 00000011
                    Acceleration: 0.000 m/s2
                    Engine status: COENG_READY
                    Cruise Control System (CCS); status-Bit 0: 11001000
   Part No SW: 3AA 614 109 M    HW: 3AA 614 109 M
   Component: J104   C2 450M V457 0005
   Revision: --H07---    Serial number: 00000003675633
   Coding: 0002480
   Shop #: WSC 00028 790 00002
   VCID: 37775765466A608445-8062
   Part No SW: 3AA 907 044 AK    HW: 3AA 907 044 AK
   Component: Climatronic   H03 0303
   Revision: 00001K02
   Coding: 0011004803
   Shop #: WSC 00015 115 00000
   VCID: 79F3915DF8FEB6F4F3-802C
Address 09: Cent. Elect. (J519)       Labels: 3AA-937-087.clb
   Part No SW: 3AA 937 087 B    HW: 3AA 937 087 B
   Component: BCM PQ47 H+   413 0452
   Revision: BC413001
   Coding: 010800000000000000180080740029F423D50088677C8760E480C7240041
   VCID: 3973515DB07E76F4B3-806C
   Subsystem 1 - Part No SW: 3AB 955 419     HW: 3AB 955 419   Labels: 1KX-955-119.CLB
   Component: Wischer 04011  10  0603
   Coding: 00BF95
   Component: RLS 170111 05  54  0403
   Coding: 073028
Address 10: Park/Steer Assist (J791)       Labels: 1T0-919-475.clb
   Part No SW: 1T0 919 475 R    HW: 3T0 919 475 C
   Component: PARKHILFE PLA H08 0206
   Revision: --------    Serial number: 13901203200331
   Coding: 308207
   Shop #: WSC 27684 001 10485
   VCID: 4A911E91E598ED6C2A-801E
Address 13: Auto Dist. Reg        Labels: None
   Part No SW: 3AA 907 567 A    HW: 3AA 907 567
   Component: AC201  RDW A    036 0170
   Revision: 00036000    Serial number: 00000000527456
   Coding: 0010000
   Shop #: WSC 32546 001 1048576
   VCID: 387554594B746FFC4C-806C
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 87
                    Mileage: 99587 km
                    Date: 2016.04.25
                    Time: 10:01:01
                    Count: 3
                    Fault Status: 01100101
                    Reset counter: 87
                    Mileage: 99587 km
                    Date: 2016.04.25
                    Time: 10:01:01
                    Count: 2
                    Reset counter: 87
                    Mileage: 99587 km
                    Date: 2016.04.25
                    Time: 10:01:01
                    Count: 4
                    Reset counter: 87
                    Mileage: 99587 km
                    Date: 2016.04.25
                    Time: 10:01:01
                    Count: 4
   Part No SW: 5N0 959 655 R    HW: 5N0 959 655 R
   Component: J234__101 VW10 HI   1918
   Revision: 22014000    Serial number: 003K0P0RRS56
   Coding: 0012337
   VCID: 4C9D18892FECF35C18-8018
   Subsystem 1 - Serial number: 6332MTS632213520
   Subsystem 2 - Serial number: 6342MTS652983520
   Subsystem 3 - Serial number: 6351HTS65O14M9KJ
   Subsystem 4 - Serial number: 6361HTS6T024M9KJ
Address 16: Steering wheel (J527)       Labels: 3C0-953-569.clb
   Part No SW: 3C5 953 501 BM    HW: 5K0 953 569 T
   Revision: FF010040    Serial number: 20111218300165
   Coding: 298A250001
   VCID: 71E3A97DA08EFEB44B-8024
   Coding: E20000
0516 - Databus
                    Reset counter: 87
                    Mileage: 99587 km
                    Date: 2016.04.25
                    Time: 09:07:45
Address 17: Instruments (J285)       Labels: 3C8-920-xxx-17.clb
   Part No SW: 3C8 920 880 L    HW: 3C8 920 880 L
   Component: KOMBI         H04 0408
   Coding: 160D01
   Shop #: WSC 10101 000 00000
   ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
   VCID: 356B5D6D9466929457-8060
12858113 - Invalid Data Received from Cruise Control Front Distance Range Sensor
          U0433 00 [008] - -
                    Fault Frequency: 13
                    Reset counter: 127
                    Mileage: 99587 km
                    Date: 2016.04.25
                    Time: 10:07:34
   Part No SW: 7N0 907 530 G    HW: 1K0 907 951
   Component: J533  Gateway H41 1614
   Revision:   H41       Serial number: 100111F2001667
   Coding: 461006
   VCID: 346D6069971C8B9C60-8060
   Part No SW: 3AA 959 433 F    HW: 3AA 959 433 F
   Component:    IMMO         048 0429
   Revision: 00048000    Serial number: VWZCZ000000000
   VCID: 3C7D48497F4C43DCA8-8068
   Part No SW: 5N0 035 342 D    HW: 5N0 035 342 D
   Revision: A1001003    Serial number: 7669016482
   Shop #: WSC 00028 028 00001
   VCID: 285584195BD4FF7CDC-807C
   Part No SW: 1T0 035 680 D    HW: 1T0 035 680 B
   Component: RNS-MID       H11 3810
   Revision: AB001001    Serial number: VWZ6Z7K5357014
   Coding: 0C000440040000842000
   VCID: 2F676F057E3AA8441D-807A
   Part No SW: 3AA 959 701 A    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0529
   Revision: 12110009    Serial number: 0002109503
   Coding: 0210FF
   Shop #: WSC 06335 000 00000
   ROD: EV_TSGFPQ35BRFVW46X.rod
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 703     HW: 3C0 959 795   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0408
   Serial number: 00000001897124
   Coding: 0000D8
   Part No SW: 5N1 909 144 L    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.309 0802
   Revision: 1AH03729    Serial number: 00103640171601
   Coding: 0000258
   VCID: 3B7F4B557A4244E4A1-806E
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Component:    KSG PQ47 ELV 048 0714
   Coding: 00910A0002860E7F340494157C08CF09607C01
   Component: EZE_2         H41 1614
   Coding: 00000008
   VCID: 6FE7AF05BEBAE8445D-803A
   Subsystem 1 - Part No SW: 3AA 919 204     HW: 3AA 919 204
   Component: Analoguhr  003 0003
   Part No SW: 3AA 959 702 A    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0529
   Revision: 14110009    Serial number: 0002099629
   Coding: 0210FE
   ROD: EV_TSGBPQ35BRFVW46X.rod
   VCID: 36695A618960998C5E-8062
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 704     HW: 3C0 959 794   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0408
   Serial number: 00000001899034
   Coding: 000098
   Part No SW: 3AA 907 801 E    HW: 3AA 907 801 E
   Component: J540 EPB4  VW-55183 0007
   Revision:   H18       Serial number: 00000000131836
   Coding: 0022067
   Shop #: WSC 10871 000 104857
   VCID: 336F637552128CA479-8066
Address 55: Headlight Range (J745)       Labels: 5M0-907-357-V3.clb
   Part No SW: 5M0 907 357 E    HW: 7L6 907 357 C
   Component: AFS-ECU       H04 0080
   Coding: 029200000B000200
   ASAM Dataset: EV_HeadlRegulVWAFSPt 002006
   ROD: EV_HeadlRegulVWAFSPt_VW46.rod
   Component: Batt.regelung H41 1614
   Coding: 030B115A
   VCID: 71E3A97DA88EFEB44B-8024
   Subsystem 1 - Part No SW: 1K0 915 181 F    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0150
Address 69: Trailer (J345)       Labels: 7N0-907-383.clb
   Part No SW: 7N0 907 383     HW: 7N0 907 383
   Component: Anhaenger     H09 0101
   Revision: 3I001002    Serial number: 00000164435907
   Coding: 4106040000000000
   Shop #: WSC 05314 000 00000
   VCID: 73EFA375D292CCA4B9-8026
   Part No SW: 3AE 907 441     HW: 3AE 907 441
   Component: J772__Rearview      0020
   Revision: 00H08000    Serial number: 525PA8-J0Y0837
   Coding: 0000006
   Shop #: WSC 00028 790 00211
   VCID: 72E1A6716D88C5ACB2-8026
Address 77: Telephone (J412)       Labels: 3C8-035-730-A.clb
   Part No SW: 3C8 035 730 E    HW: 3C8 035 730 E
   Component: Telefon       025 0983
   Revision: --------    Serial number: 35502105255527
   Coding: 020000010100010000000101
   Shop #: WSC 27684 001 1048576
   ASAM Dataset: EV_UHVPremi 002709
   ROD: EV_UHVPremi_VW32.rod
   VCID: 254B8D2D24C6E214E7-8070
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 3AA-980-654.clb
   Part No SW: 3AA 980 654 D    HW: 3AA 980 654 A
   Component: MFK_Gen1      H08 0300
   Serial number: 0164731636
   Coding: 01010200010202110200040001010000
   ASAM Dataset: EV_47X 001639
   ROD: EV_47X.rod
   VCID: 3973515DB87E76F4B3-806C
2621440 - Databus
                    Reset counter: 127
                    Mileage: 99587 km
                    Date: 2016.04.25
                    Time: 10:11:34
2686976 - Databus
                    Reset counter: 127
                    Mileage: 99587 km
                    Date: 2016.04.25
                    Time: 10:11:34
End-------------------------(Elapsed Time: 03:43)--------------------------
