passat 2014 fault
mohamed
Egypt
C?ID=211960
Thiis passat not start , and this fault appear I want to know where is the control of fuel injector too , thanks in advance
Monday,25,April,2016,07:40:50:43156
VCDS Version: 15.7.3.0
Data version: 20151216
VIN: WVWZZZ3CZDP010109   License Plate:
Mileage: 79890km-49641mi   Repair Order:
Chassis Type: 3C (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 4F 52 53 56 62 72
VIN: WVWZZZ3CZDP010109   Mileage: 79890km-49641miles
Address 01: Engine (J623-CAXA)       Labels: 03C-906-016-CAX2.clb
   Part No SW: 03C 906 016 DH    HW: 03C 907 309 E
   Component: 1.4l R4 TSI   H18 7738
   Revision: L5H18---    Serial number: VWZCZ000000000
   Coding: 00250012002400000000
   Shop #: WSC 24287 001 1048576
   ASAM Dataset: EV_ECM14TFS01103C906016DH 001005
   ROD: EV_ECM14TFS01103C906016DH.rod
   VCID: 68DB5F7293DB4F7ED9-803C
4551 - Internal Control Module Fuel Injector Control Performance
          P062B 00 [167] - -
                    Mileage: 79893 km
                    Date: 2016.04.25
                    Time: 04:36:04
Readiness: 1110 0101
   Part No SW: 0AM 300 060 D    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 5273
   Revision: 00043014    Serial number: CU501206156064
   VCID: 2B51E07E8AADA466F4-807E
006224 - Powertrain Data Bus
               P1850 - 000 - Missing Message from ECU - Intermittent
                    Mileage: 79893 km
                    Date: 2016.04.25
                    Time: 10:07:26
006226 - Powertrain Data Bus
               P1852 - 004 - Implausible Message ECU - Intermittent
                    Reset counter: 10
                    Mileage: 79893 km
                    Date: 2016.04.25
                    Time: 10:07:27
   Part No SW: 3AA 614 109 AF    HW: 3AA 614 109 AF
   Component: J104   C2 450M V4AE 0024
   Revision: --H07---    Serial number: 00000005917603
   Coding: 0000363
   Shop #: WSC 00028 028 00001
   VCID: 71ED321668018EB68E-8024
                    Reset counter: 214
                    Mileage: 79893 km
                    Date: 2016.04.25
                    Time: 10:07:27
                    Hex Value: 0x0000
                    Bin. Bits: 00000000 00000000
                    Voltage: 9.50 V
                    Bin. Bits: 00011111
                    Count: 220
                    Hex Value: 0x0000
   Part No SW: 3AA 907 044 AF    HW: 3AA 907 044 AF
   Component: Climatronic   H03 0303
   Revision: 00001K02
   Coding: 0014002002
   Shop #: WSC 00028 028 00020
   VCID: 74E33B02DF13BB9E65-8020
          U1111 00 [008] - -
                    Reset counter: 214
                    Mileage: 79893 km
                    Date: 2016.04.25
                    Time: 00:09:43
Address 09: Cent. Elect. (J519)       Labels: 3AA-937-087.clb
   Part No SW: 3AA 937 087 G    HW: 3AA 937 087 G
   Component: BCM PQ47 H    421 0464
   Revision: BB421001
   Coding: 0008000000000000009802801400816403514E88406C8960648040200040
   VCID: 3E77D92AA9DF21CE43-806A
   Subsystem 1 - Part No SW: 3AB 955 419     HW: 3AB 955 419   Labels: 1KX-955-119.CLB
   Component: Wischer 30051  10  0603
   Coding: 00B795
   Component: RLS 220612 05  54  0403
   Coding: 02302A
                    Reset counter: 214
                    Mileage: 79893 km
                    Date: 2016.04.24
                    Time: 10:36:05
                        Term 15 Off
                    Voltage: 10.50 V
                    Reset counter: 214
                    Mileage: 79893 km
                    Date: 2016.04.25
                    Time: 10:07:40
                    Voltage: 9.30 V
                    Reset counter: 214
                    Mileage: 79893 km
                    Date: 2016.04.25
                    Time: 15:04:16
                    Voltage: 9.15 V
03678 - Coordinator for Start-Stop Operation
                    Reset counter: 214
                    Mileage: 79893 km
                    Date: 2016.04.25
                    Time: 10:07:41
                    Voltage: 9.10 V
   Component: J234__107 VW10 HI   2118
   Revision: 24017000    Serial number: 003L7PCHGB0Q
   Coding: 0012343
   VCID: 7CF313223F43F3DE2D-8028
   Subsystem 1 - Serial number: 6332MTS655581562
   Subsystem 2 - Serial number: 6342MTS642671572
   Subsystem 3 - Serial number: 6351HTS684B66BKR
   Subsystem 4 - Serial number: 6361HTS695EH4BKJ
                    Reset counter: 214
                    Mileage: 79893 km
                    Date: 2016.04.25
                    Time: 14:17:52
Address 16: Steering wheel (J527)       Labels: 3C0-953-569.clb
   Part No SW: 3C5 953 501 BG    HW: 5K0 953 569 T
   Revision: FF010041    Serial number: 20120624200373
   Coding: 0992250000
   VCID: 6BD1207E822D6466B4-803E
   Component: E221__MFL-TK6  H07 0022
   Coding: E30000
Address 17: Instruments (J285)       Labels: 3C8-920-xxx-17.clb
   Part No SW: 3AA 920 870 H    HW: 3AA 920 870 H
   Component: KOMBI         H05 0705
   Coding: 160F00
   VCID: 3779CC0E8EE5108680-8062
12648448 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 214
                    Mileage: 79893 km
                    Date: 2016.04.25
                    Time: 00:09:42
   Part No SW: 7N0 907 530 T    HW: 7N0 907 530 K
   Component: J533  Gateway H40 1632
   Revision:   H40       Serial number: 200612F1001581
   Coding: 461006
   VCID: 418DA2D6D8215E363E-8014
                    Fault Status: 00110100
                    Reset counter: 214
                    Mileage: 79893 km
                    Date: 2016.04.25
                    Time: 00:09:43
   Part No SW: 3AA 959 433     HW: 3AA 959 433
   Component:    IMMO         045 0400
   Revision: 00045000    Serial number: VWZCZ000000000
   VCID: 76E7010A016FA98E5B-8022
   Part No SW: 3AA 959 701 A    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0533
   Revision: 12110009    Serial number: 0005211616
   Coding: 0000B7
   ROD: EV_TSGFPQ35BRFVW46X.rod
   VCID: 3565C60694E9E29692-8060
   Slave Driver:
   Subsystem 1 - Part No SW: 3AA 959 703 A    HW: 3AA 959 795   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0502
   Serial number: 00000002997240
   Coding: 010090
67589 - Turn Signal in Exterior Mirror
          B11FD 01 [009] - Electrical Failure
                    Reset counter: 172
                    Mileage: 74272 km
                    Date: 2016.01.08
                    Time: 21:38:39
68108 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 214
                    Mileage: 79893 km
                    Date: 2016.04.25
                    Time: 00:09:42
   Part No SW: 5N1 909 144 N    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.308 1101
   Revision: 1AH03735    Serial number: 00121650059601
   Coding: 0000258
   VCID: 3D75DE2664D93AD65A-8068
                    Reset counter: 214
                    Mileage: 79893 km
                    Date: 2016.04.24
                    Time: 10:18:14
                    Voltage: 0.20 V
                    Voltage: 10.00 V
                    Voltage: 3.20 V
                        Not Occup.
                        Not Occup.
01288 - Terminal 30; Steering Assist
                    Fault Status: 00101011
                    Fault Priority: 9
                    Reset counter: 214
                    (no units): 2.0
                    Voltage: 11.00 V
                    Reset counter: 214
                    Mileage: 79893 km
                    Date: 2016.04.25
                    Time: 00:09:42
                    RPM: 1500 /min
                    (no units): 4.0
                    Voltage: 12.10 V
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Component:    KSG PQ47 ELV 045 0634
   Coding: 00910A0002860E763404941570084F0B605801
   Part No SW: 7N0 907 532     HW: 7N0 907 530 K
   Component: EZE_2         H40 1632
   Coding: 00000008
   VCID: 6FE9346EBE35984698-803A
   Subsystem 1 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
   Component: Analoguhr  004 0004
   Part No SW: 3AA 959 702 A    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0533
   Revision: 14110009    Serial number: 0005226911
   Coding: 0000B6
   ROD: EV_TSGBPQ35BRFVW46X.rod
   VCID: 3667C10A89EFE98E9B-8062
   Slave Passenger:
   Subsystem 1 - Part No SW: 3AA 959 704 A    HW: 3AA 959 794   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0502
   Serial number: 00000003000655
   Coding: 010090
          U1111 00 [008] - -
                    Reset counter: 214
                    Mileage: 79893 km
                    Date: 2016.04.25
                    Time: 00:09:42
   Revision:   H19       Serial number: 00000000277035
   Coding: 0022157
   VCID: 3667C10A41EFE98E9B-8062
                    Reset counter: 214
                    Mileage: 79893 km
                    Date: 2016.04.25
                    Time: 10:07:27
                    Voltage: 9.50 V
                    Count: 71
                    Hex Value: 0x1260
                    Hex Value: 0x0001
                    Hex Value: 0x0101
                    Fault Status: 00110010
                    Reset counter: 214
                    Mileage: 79893 km
                    Date: 2016.04.25
                    Time: 11:56:49
                    Voltage: 8.20 V
                    Count: 50
                    Hex Value: 0x0861
                    Hex Value: 0x0088
                    Hex Value: 0x0808
            000 -  -  - Intermittent
                    Reset counter: 214
                    Voltage: 9.60 V
                    Count: 110
                    Hex Value: 0x0171
                    Hex Value: 0x0082
                    Hex Value: 0x4040
   Part No SW: 1K0 035 186 AN    HW: 1K0 035 186 AN
   Component: Radio RCD310  042 0082
   Revision: 01000001    Serial number: VWZ1Z2M4396161
   Coding: 05000400040010
   VCID: 72EF3D1AAD07B5AE77-8026
03138 - Input AUX IN
                    Reset counter: 92
                    Mileage: 55678 km
                    Date: 2015.05.18
                    Time: 13:38:09
End-------------------------(Elapsed Time: 03:06)--------------------------
Gone But Not Forgotten
Please have a look at ecu supply terminal relays and ignition switch.
Don't forget the ground points.
Term 15 Off
Voltage: 10.50 V <<<<<<<<<<<<<<<<< Battery health POOR!
Right here...........
mohamed
Egypt
C?ID=211960
I have tried this things and nothing happend too
