Howdy
dc240969
C?ID=277533
After having numerous VW over the years, most not requiring diagnosing, l bought an Audi S3 the bought a HEX-CAN cable from a forum member of VAGOC. I used it mostly out of curiosity but just before the warranty run out l used it and found a fault with the ignition. Took the car to Audi and told them to fix it. l sold the Audi to buy a A45 AMG. Sold the HEXCAN unit, lost my job and sold the MErc. Now l have another Audi and borrowed a unit to do a scan. Found a couple of issues but fixed on the spot. Sweet motor 3.2 with only 13500 miles on the clock. Thinking of providing a diagnostic service round where l stay so thought it would be good to sign up here. Im Fife based.
dc240969
C?ID=277533
Seems lm not going to get verified at the moment as l mentioned its a loaned unit. But, as you can see from below is my scan on my daughters A1. So if lm told l cannot get help so be it. If its all fine then please feedback accordingly.
Saturday,23,April,2016,12:02:31:41967
VCDS Version: 15.7.4.1
Data version: 20160216
VIN: WAUZZZ8X5BB099020   License Plate: RACHEL
Mileage: 64050km-39798mi   Repair Order:
Chassis Type: 8X (8X0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 47 52 5F
VIN: WAUZZZ8X5BB099020   Mileage: 64050km-39798miles
Address 01: Engine (J623-CAXA)       Labels: 03C-906-016-CAX2.clb
   Part No SW: 03C 906 016 BG    HW: 03C 906 016 BG
   Component: 1.4l R4/4V TS H08 8929
   Revision: LEH08---    Serial number:
   Coding: 00190032000401000000
   Shop #: WSC 00046 790 00000
   ASAM Dataset: EV_ECM14TFS01103C906016BG 001006
   ROD: EV_ECM14TFS01103C906016BG.rod
   VCID: 65CA669764C22916ED-8030
4344 - Please Check Fault Codes in Control Module for HVAC (J301)
          U1025 00 [040] - -
                    Fault Frequency: 27
                    Mileage: 62532 km
                    Date: 2016.03.20
                    Time: 13:00:28
5673 - ROD - Unknown Error Code
          - 00 [096]
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 BB    HW: 6R0 907 379 AH
   Component: ESP8.2i front H07 0001
   Revision: --------
   Coding: 330448E9237600BBCC2512E4C4D100910E00
   Shop #: WSC 00046 000 00000
   VCID: 7F06D4FFEA5E93C607-802A
   Part No SW: 8X0 820 045 A    HW: 8X0 820 045 A
   Component: J255 Klima Manuell  0140
   Revision: 0000707S    Serial number: 03030004585584
   VCID: 346CCBD35798809EAA-8060
                    Fault Frequency: 28
                    Reset counter: 93
                    Mileage: 62263 km
                    Date: 2016.03.12
                    Time: 13:01:51
Address 09: Cent. Elect. (J519)       Labels: 8X0-907-063.clb
   Part No SW: 8X0 907 063 D    HW: 8X0 907 063 D
   Component: BCM PQ35  M   108 0621
   Revision: 00108 AC
   Coding: 0E000A2FA005F100201841E020000154530B6C0A01CF4922DC0887830045
   VCID: 3D7AEEF7A4D241D655-8068
   Subsystem 1 - Part No: 8X0 951 177
   Component: DWA-Sensor H0  H01 0020
Address 10: Park/Steer Assist (J446)       Labels: 8X0-919-475.clb
   Part No SW: 8X0 919 475     HW: 8X0 919 475
   Component: PARKHILFE 4K  H03 0011
   Revision: 11001001    Serial number: 37001111001888
   Coding: 000002
   ASAM Dataset: EV_AU210ParkAssis4K 002006
   ROD: EV_AU210ParkAssis4K.rod
   VCID: 030E580F8AB6F72663-8056
Address 15: Airbags (J234)       Labels: 8X0-959-655.clb
   Part No SW: 8X0 959 655 A    HW: 8X0 959 655 A
   Component: Airbag10.41   H04 0008
   Revision: --------    Serial number: 003JJ001ZFRX
   Coding: 30314539303330303034554A305238583053
   ASAM Dataset: EV_Airba1041BPAAU210 001015
   ROD: EV_Airba1041BPAAU210.rod
   VCID: 48948F23F310147EF6-801C
   Serial number: 3554VRB404R0FAMEA0BV
   Serial number: 3575HRB404R0HM78D1GM
   Serial number: 3585HRB40530H92248MN
   Rear Impact Crash Sensor:
   Serial number: 3515ZRB405R0H4DQB8PC
Address 16: Steering wheel (J527)       Labels: 8X0-953-569.clb
   Part No SW: 8X0 953 501 B    HW: 5K0 953 569 H
   Revision: FF010016    Serial number: 20110427200648
   Coding: 1184004000
   VCID: 3972FAE7B8FA7DF679-806C
   Subsystem 1 - Part No SW: 4G0 951 528 C    HW: 4G0 951 528 C
   Component: E221 - MFL  H07 0009
Address 17: Instruments (J285)       Labels: 8X0-920-xxx-17.clb
   Part No SW: 8X0 920 980     HW: 8X0 920 980
   Component: KOMBI         H07 0124
   Coding: 41DE00
   ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04086
   VCID: 7CFC23F3F74888DE22-8028
   Part No SW: 8X0 907 468 A    HW: 8X0 907 468 A
   Component: GAT 4CAN 1L M H04 0083
   Revision: 1C060023    Serial number: 2341C1141600A2
   Coding: FBCF0064000100010153
   VCID: 438E980FC236372623-8016
   Subsystem 1 - Part No SW: 8K0 915 181 H    HW: 8K0 915 181 H
   Component: J367-BDM  H07 0171
   Subsystem 2 - Part No SW: 8K0 959 663 B    HW: 8K0 959 663 B
   Component: IMMO          H07 0124
   Coding: 000002
   ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04008
   ROD: EV_Immo_UDS_VDD_AU10.rod
Address 42: Door Elect, Driver (J386)       Labels: 8X0-959-793.clb
   Part No SW: 8X0 959 793 D    HW: 8X0 959 793 D
   Component: TSG FA        H09 0409
   Coding: 011E02200101000100
   VCID: 4E98B93B1974CA4EBC-801A
   Part No: 6R0 423 156 B
   Coding: 11251
   Shop #: WSC 00046
   VCID: 2F66C4BFEABEA346D7-807A
Address 47: Sound System (J525)       Labels: Redir Fail!
   Part No SW: 8X0 035 223 B    HW: 8X0 035 223 B
   Component: BOSE G3 A1Q3  H04 0040
   Revision: CK004200    Serial number: 00000000001181
   VCID: 3162C2C7688AB5B6C1-8064
Address 52: Door Elect, Pass. (J387)       Labels: 8X0-959-792.clb
   Part No SW: 8X0 959 792 D    HW: 8X0 959 792 D
   Component: TSG BF        H09 0409
   VCID: 4D9ABE371472F156C5-8018
   Part No SW: 8X0 035 182 F    HW: 8X0 035 182 F
   Component: RMC Cnct Plus H50 0647
   Coding: 01010001008053070023020103020100010000
   VCID: 3972FAE7B0FA7DF679-806C
   Subsystem 1 - Part No SW: 8X0 919 603     HW: 8X0 919 603
   Component: DU6 Basic  H42 0084
End-------------------------(Elapsed Time: 02:32)--------------------------
dc240969
C?ID=277533
So no advice then?
dc240969
C?ID=277533
Or is there only tumble weeds in here. Simple yes or no.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
The G65 (DTC in #08) is usually a bad sensor, Audi should be aware of this and have a new sensor/generation available. Other than that, I am not seeing any codes that are ignition related. :)
dc240969
C?ID=277533
Thanks. Just to add. l have just purchased a HEX-NET with Wifi interface. Do l need to do anything to get verified on this site.
dc240969
C?ID=277533
:thumbs: thanks
United States
Since you have a HEX-NET now please scan that vehicle with our Beta at some point: Current Beta
16.3.1 is currently online but the guys are working on another. You may want to refresh at on Saturday or Sunday morning to see of the latest/greatest is avail that time. Either way, if you still have the ROD - Unknown Error Code please post the new scan.
dc240969
C?ID=277533
Unfortunately l cleared the fault when l had the borrowed lead. Scanned with HEX-NET today and its not there. The only one lm now cocerned with is in 01-Engine, 4344. l will see about updating to beta in the next few days.
riday,06,May,2016,16:52:39:05494
VIN: WAUZZZ8X5BB099020   License Plate: LV11PKUHEXNET1
Mileage: 64730km-40221mi   Repair Order:
VIN: WAUZZZ8X5BB099020   Mileage: 64730km-40221miles
   VCID: 6582747A6474B016ED-8030
          U1025 00 [039] - -
                    Mileage: 64732 km
                    Date: 2016.05.06
                    Time: 16:48:05
Readiness: 1110 0101
   Revision: --------
   VCID: 7F4EC612EAE80AC607-802A
   VCID: 3424D93E572E199EAA-8060
                    Fault Status: 01100010
                    Fault Frequency: 45
                    Reset counter: 93
                    Mileage: 62263 km
                    Date: 2016.03.12
                    Time: 13:01:51
   Revision: 00108 AC
   VCID: 3D32FC1AA464D8D655-8068
   Coding: 000002
   VCID: 03464AE28A006E2663-8056
   VCID: 48DC9DCEF3A68D7EF6-801C
   Coding: 1184004000
   VCID: 393AE80AB84CE4F679-806C
   Coding: 41DE00
   VCID: 7CB4311EF7FE11DE22-8028
   VCID: 43C68AE2C280AE2623-8016
   Coding: 000002
   VCID: 4ED0ABD619C2534EBC-801A
   Coding: 11251
   Shop #: WSC 00046
   VCID: 2F2ED652EA083A46D7-807A
   VCID: 312AD02A683C2CB6C1-8064
   VCID: 4DD2ACDA14C46856C5-8018
   VCID: 393AE80AB04CE4F679-806C
End-------------------------(Elapsed Time: 01:27)--------------------------
Cant seem to post in any other threads yet.
