CAN: Not Ready with 2002 audi tt
GregCra
C?ID=274236
Hi - I bought the HEX-USB+CAN product as I have a 2013 audi S5 and 2002 Audi TT and the VIN app said this product would support both cars. I've successfully used the product with the S5.. but today I tried to use it with the 2002 TT and during the Options -> Test section I got a "CAN: Not Ready". I just got the hardware/software in the last month so it's pretty up to date. Am I doing something wrong? Thanks for your help.
Zenerdiode
Newcastle, England
C?ID=24330
I don't think so. The 2002 Audi TT doesn't use a CAN bus for diagnostics - so that's the expected results. You should be looking for K1:OK and K2:OK for this car.
When attempting an Auto-Scan on this car, please manually select the chassis code '8N' from the drop-down menu.
Have you tried [Select] > [Engine 01] to connect to the ECU manually/directly?
GregCra
C?ID=274236
Thank you Zenerdiode! That's exactly what I needed. I figured it was 'do able' as I see other post about TTs of the same era - but I had no idea what to do. By setting the code to 8N the auto scan worked just fine :)
Now..can you point me to the next step. I have attached the log to the bottom of this msg. There are 4 faults, the last 2 have to do with the alarm and I think I can just reset them as she (my wife's car) set of the alarm herself the other day. The first 2 faults are intermittent - but look more serious. Do I just start searching the internet?
Thank you for your help!
Greg
Sunday,24,April,2016,15:25:57:36890
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
Chassis Type: 8N (8N - Audi TT (1999 > 2007))
Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77
Address 01: Engine        Labels: 06A-906-032-AMU.lbl
   Part No: 8N0 906 018 AN
   Component: 1.8L R4/5VT     G   0004
   Coding: 06710
   Shop #: WSC 23048
   VCID: 7DF18A09776174D615-5124
     AUZ5Z0A7030162
17963 - Charge Pressure
            P1555 - 35-10 - Maximum Limit Exceeded - Intermittent
Address 03: ABS Brakes        Labels: 8N0-907-379-MK20-E.lbl
   Part No: 8N0 907 379 E
   Component: ESP     20    CAN  V005
   Coding: 18446
   Shop #: WSC 01236
   VCID: 3E734D053AE7AFCE4C-4B00
            57-10 - Electric Circuit Failure - Intermittent
Address 08: Auto HVAC        Labels: 8N0-820-043.lbl
   Part No: 8N0 820 043 A
   Component: TT-KLIMAVOLLAUTOMAT D03
   Coding: 00140
   Shop #: WSC 01236
   VCID: 285F8B5DC863017E16-257A
Address 15: Airbags        Labels: 8N0-959-655.lbl
   Part No: 8N0 959 655 A
   Component: Airbag Front+Seite 5000
   Coding: 01103
   Shop #: WSC 01236
   VCID: 3E734D053AE7AFCE4C-515E
Address 17: Instruments        Labels: 8Nx-920-xxx-17.lbl
   Part No: 8N1 920 980
   Component: KOMBI+WEGFAHRS. M73 D12
   Coding: 07244
   Shop #: WSC 23190
   VCID: 73E5AC31412532A673-4B00
Address 22: AWD        Labels: 02D-900-554.lbl
   Part No: 02D 900 554 D
   Component: HALDEX LSC  ECC     0011
   VCID: 21499679AB59F03651-4B00
Address 35: Centr. Locks        Labels: 8Nx-962-267.lbl
   Part No: 8N7 962 267 A
   Component: Central Lock/Alarm  D06
   Coding: 15900
   Shop #: WSC 23190
   VCID: 3E734D053AE7AFCE4C-4ECE
01572 - Alarm triggered by Door Contact Switch; Passenger Side
            35-00 -  -
01374 - Alarm triggered by Terminal 15
            35-00 -  -
Address 55: Headlight Range        Labels: 4B0-907-357-AUT.lbl
   Part No: 4B0 907 357
   Component: LEUCHTWEITEREGLER  D004
   Coding: 00010
   Shop #: WSC 01236
   VCID: 65C1C269FFF1DC16ED-51B6
   Part No: 4B0 035 186 H
   Component: concert II  NP2    0004
   Coding: 00202
   Shop #: WSC 01236
   VCID: 25418269BF711C162D-4E96
End-------------------------(Elapsed Time: 02:52)--------------------------
