Hello I have a 2002 B5.5 passat v6 4motion with an automatic transmission.
I have swapped the engine and transmission for a AVF 1.9 tdi and a 01E 4motion manual transmission that I bought from Frans at dutch auto parts.
Before I did the swap the CCM worked as normal, after doing the swap the radio is in safe mode which would be expected because there is now a different ECU installed,
but now the CCM does not work or respond to vcds. I have central locking functionality from both the key and the buttons on the doors but the power windows and sunroof do not work, the horn also does not work.
I have inspected the wiring around the CCM, the can bus high splice (orange and purple) appeared slightly discolored so I reconnected those wires with a butt connector.
I also visually inspected the pcb of the CCM and it showed no signs of water damage.
In the auto scan log I got a 01044 - Control Module Incorrectly Coded in the CAN gateway.
From my understanding the can gateway is built into the dash cluster right?
the cluster is a B5 cluster which is now installed in a B5.5 car. Would this cause the CCM to not respond?
