2.0 TDI CBE/CJA N276 adaptation
runonbeer
C?ID=38999
I am working on a 2009 Jetta TDI. It originally came in with a 000135/P0087 Fuel pressure too low fault (among other faults). I surmised that the fuel metering valve (N290) was at fault and installed a new one. It is now setting a P0088 Fuel pressure too HIGH fault and intermittently gives an implausible fault though sadly I do not have any instances of this fault saved anywhere.
I believe that I must re-adapt the fuel pressure sensor so that it will accept the new fuel pressure values that result from the healthy N290 but I am having trouble going about this task.
Here is an auto scan:
VCDS Version: Release 15.7.4 (x64) Running on Windows 7 x64
Data version: 20160216
Friday,22,April,2016,13:06:31:32736
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 56 62 65 72
VIN: 3VWRL71K09M085890   Mileage: 330140km-205139miles
Address 01: Engine (CBE)       Labels: 03L-906-022-CBE.clb
   Part No SW: 03L 997 016 P    HW: 03L 906 022 J
   Component: R4 2,0L EDC G000AG  8681
   Revision: 12H01---    Serial number: VWX7Z0HN24A1DF
   Coding: 0050078
   Shop #: WSC 00066 000 00000
   VCID: 3F87B7ED6E025CC647-806A
008201 - Intake Manifold Flap; Bank 1
               P2009 - 000 - Short to Ground
                    Mileage: 330139 km
                    Time: 12:05:21
                    RPM: 828 /min
                    Load: 5.1 %
                    Lambda: 99.4 %
                    Mass Air / Rev.: 285.0 mg/str
                    Temperature: 98.1°C
000136 - Fuel Rail/System Pressure
               P0088 - 000 - Too High
                    Mileage: 330139 km
                    Time: 12:05:47
                    RPM: 1610 /min
                    Inj. Quantity: 32.7 mg/str
                    (no units): 5.0
                    Pressure: 1088.0 bar
                    Pressure: 1416.0 bar
                    Temperature: 45.0°C
                    Tank Cont.: 21.3 l
001025 - EGR System
               P0401 - 000 - Insufficient Flow - Intermittent
                    Mileage: 330140 km
                    Time: 12:06:23
                    RPM: 1679 /min
                    Speed: 85.0 km/h
                    Voltage: 13.76 V
                    Load: 98.0 %
                    Load: 100.0 %
                    Mass Air / Rev.: 570.0 mg/str
                    Mass Air / Rev.: 555.0 mg/str
   Part No SW: 02E 300 052     HW: 02E 927 770 AJ
   Component: GSG DSG AG6     440 1913
   Revision: 05144002    Serial number: 00001008270639
   Shop #: WSC 04940 001 00001
   VCID: 51A38155C896DAB6A1-8004
Address 03: ABS Brakes (-----)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 AE    HW: 1K0 907 379 AE
   Component: ESP MK60EC1   H35 0106
   Revision: 00H35001
   Coding: 113B400D492A00FF881302ED92190042B100
   VCID: 75EB15C5DCBED6965D-8020
   Part No SW: 1K0 820 047 JM    HW: 1K0 820 047 JM
   Component: Climatic PQ35   142 1212
   Revision: 00142032    Serial number: 00000000000000
   VCID: 78F51CF10BACABFE46-802C
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-M.lbl
   Part No SW: 3C8 937 049 D    HW: 3C8 937 049 D
   Revision: 00H54000    Serial number: 00000001128531
   Coding: 04018E234004150007140000001400000008730B5C000120000000000000
   VCID: 3261EED9AD5081AEB8-8066
   Component: Wischer 211008 021  0501
   Coding: 00038805
   Shop #: WSC 00066
   Part No SW: 8E0 035 593 M    HW: 8E0 035 593 M
   Component: SDAR SIRIUS     H07 0150
   Revision: 00000000    Serial number: AUZ4Z7H0473349
   Coding: 0000100
   VCID: 336FEBDD524A88A6B3-8066
            000 -  -
                    Fault Frequency: 8
                    Reset counter: 126
                    Mileage: 328486 km
                    Time: 13:13:18
   Component: 6A AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6M07MY5O
   Coding: 0013889
   VCID: 6CDD30A14FF4175EB2-8038
   Subsystem 1 - Part No: 1K0 959 339 H
   Component: BF-Gewichtsens. 007 0006
   Subsystem 2 - Serial number: 6332MSME41414C096
   Subsystem 3 - Serial number: 6342MSME3F637132C
   Subsystem 4 - Serial number: 6351HSME18712222Z
   Subsystem 5 - Serial number: 6361HSME185A59039
   Subsystem 6 - Serial number: 63727SME190861780
   Subsystem 7 - Serial number: 63827SME1908693FC
   Part No SW: 1K0 953 549 BS    HW: 1K0 953 549 BS
   Coding: 0012021
   VCID: 040D78014764FF1E5A-8050
   Part No SW: 1K0 920 974 N    HW: 1K0 920 974 N
   Component: KOMBIINSTRUMENT 3HL 2418
   Revision: V0003000    Serial number: VWX7Z0HN24A1DF
   Coding: 0023203
   VCID: 3973D9F5702672F679-806C
   Component: J533  Gateway   H07 5063
   Revision:   H07 01    Serial number: 200908F2000997
   Coding: ED807F070013021002
   VCID: 356BD5C55C3E96969D-8060
   Part No SW: 1K5 919 965 A    HW: 1K5 919 965 A
   Component: Kompass         005 0004
   Revision: 00005000    Serial number: 1293324T3JB504
   Coding: 0000003
   Component: IMMO            3HL 2418
   Part No SW: 1K0 959 701 AC    HW: 1K0 959 793 N
   Component: J386  TUER-SG FT    1519
   Revision: 72009005    Serial number: 00000771789028
   Coding: 0001205
   VCID: 6FE727AD7EE2EC4697-803A
01552 - Motor for Central Locking; Drivers Door (V56); Lock
                    Fault Status: 00101100
                    Reset counter: 235
                    Mileage: 324563 km
                    Fault Status: 00111000
                    Reset counter: 235
                    Mileage: 324563 km
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 70     2301
   Revision: 00H15000
   Shop #: WSC 02069 000 90108
   VCID: 2A51F6B98580C96E00-807E
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Coding: 12900F880186281B0904058FB0880F0488DC00
   Part No SW: 1K0 959 702 AC    HW: 1K0 959 792 N
   Component: J387  TUER-SG BT    1519
   Revision: 72009005    Serial number: 08081222154801
   Coding: 0001204
   VCID: 70E524D163DCF3BE8E-8024
   Part No SW: 1K0 035 180 L    HW: 1K0 035 180 L
   Component: Radio DE2       016 0020
   Revision: 00016000    Serial number: VWZ4Z7H2251041
   Coding: 0010400
   VCID: 295309B58086C27609-807C
            000 -  -
00003 - Control Module
            014 - Defective
   Part No SW: 1K0 959 703 AH    HW: 1K0 959 795 T
   Component: J388   TUER-SG HL   1401
   Revision: 12006001    Serial number: 00000003626623
   Coding: 0001168
   VCID: 76E912C901B8DD8E54-8022
                    Reset counter: 235
                    Mileage: 324563 km
                    Fault Status: 01111100
                    Fault Frequency: 8
                    Reset counter: 195
                    Mileage: 324563 km
   Coding: 0100101
   Part No SW: 1K0 959 704 AH    HW: 1K0 959 794 T
   Component: J389   TUER-SG HR   1401
   Revision: 12006001    Serial number: 00000003566334
   Coding: 0001168
   VCID: 77F71FCD06B2A4864F-8022
                    Reset counter: 235
                    Mileage: 324563 km
                    Fault Frequency: 8
                    Reset counter: 195
                    Mileage: 324563 km
End-------------------------(Elapsed Time: 02:11)--------------------------
Following the instructions in the Long adaptation balloon:
Nothing seems to happen when I enter the new test value, and the "save" button is grey:
The pop up balloon instructions seem to me somewhat circular so I'd just like a little bit of clarification on the exact chronological steps required.
I have tried this using both sets of security access login numbers and I have tried to go into Group 117 in basic settings but I get an error message (again, neither set of security logins make any difference in this error message)
I'm probably going to put in a call to tech support but I thought I might go ahead and put this info up while they're at lunch so he/she can refer to it if necessary.
Thanks!
runonbeer
C?ID=38999
I did note this information in the wiki:
VW
When found in Common Rail TDI engines, please see TSB 01-10-11 (TPI 2023624) for Contaminated fuel found in fuel system concerns.
RoW (Rest of World) market
Audi
When found in Common Rail TDI 4 Cylinder Bosch engines, please see TPI 2026879 for Contaminated fuel found in fuel system concerns.
When found in Audi Common Rail V6, V8 and V12 TDI engines, please see TPI 2020693 for Contaminated fuel found in fuel system concerns. After mechanical all repairs are made N276 may need to be adapted and the EDC may need to be flash updated on the Audi Dealer level.
Nothing was found in the bore of the N290 except nice clean diesel fuel (no metal)
runonbeer
C?ID=38999
I have looked over the WD and it does not appear as though there are any common current carriers between any of the fuel system monitoring/control components the V157 which is clearly faulted out. So I ruled out the possiblilty that there is a wiring problem here on this end of things.
Hi Robbie, per our phone conversation I would try unplugging that IMRC to see if it runs any differently.
The RoW market V6 and larger engines support a reset after the latest dealer level flash updates are applied but a large majority of NAR engines do not support (or require) a diagnostic Adaptation reset. We are concerned about that used N290 though... I pinged Peter to make sure I wasn't having a brain fart and he confirmed those are only sold with the pump because they are calibrated to the pump.
Side note, this EDC is out of date at SWL 8681. Even though it isn't likely to resolve all of the issues SWL 9970 or newer should be flashed at some point.
ST?ID=66855
runonbeer
C?ID=38999
No resolution here.
Had a pleasant helpful call with Dana from Ross-tech but we were unable to reach any solid resolution. Evidently fuel pressure adaptation is not supported by this ECU or this particular software variety (she said a lot of stuff that shot right over my head).
In the end we went with a longshot super double secret "FMA" reset which involved entering 10008 into function 11 CodingII. This had the effect of shutting down and resetting some "fuel trim.." and other learned values in the ECU but it persistently faulted out P0088 fuel pressure to high while the second N290 was installed.
I went ahead put his original N290 back in and took it for a drive without incident.
The customer indicated that the instances of reduced power and flashing glow plug light were "very infrequent" I had to explain to him several times that the problem had nothing at all to do with the glow plugs even though he coincidentally had a faulted out plug/pressure sensor when he showed up this morning.
So it was fun but ultimately disappointing to not be able to offer a fix. I am still not sure why this problem (the low fuel pressure fault) is even happening. Like I said, underneath the N290 is nice and clean.
Here is some amazing information: I initially inspected the fuel filter (found no metal) and I asked him how long it had been in. He said it was brand new and in fact that the guy who installed it called him up while he was working on it to tell him that there was no filter installed previously. Customer told me he had put 100K miles on the car prior to this WITH NO FUEL FILTER INSTALLED. Amazing. I will not name the shop in San Antonio that last performed a fuel filter service on the car but I did see the service record which included a fuel filter change was perfomed 2 years ago.
runonbeer
C?ID=38999
ST?ID=66855
Thank Dana, I missed your reply before making my last post. Thank you for filling in the gaps there. I will advise the customer that he may want to pursue a dealer reflash. However I also advised him to await the potential buyback off and get out from underneath the car.
He pretty much jumped out of his skin when I told him how much it would cost to replace the torched DPF.
I am thankful that I have only seen this fault on this one car (once before a long time ago under the previous owner). As I said I had seen this car years ago with the same fault but the guy disappeared and this was long before there was an issue with the intake manifold.
dieselland
C?ID=81033
Dana -
Could you elaborate on what the FMA reset does?
I have a car in the shop which may benefit from this reset.
Autoscan:
Tuesday,26,April,2016,19:24:36:37258
VCDS Version: 15.7.4.1 (x64)
VIN: 3VWRL71K79M028859   License Plate:
Mileage: 209790km-130357mi   Repair Order: jeskewitz codes
Scan: 01 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 56 62 65 72
VIN: 3VWRL71K79M028859   Mileage: 209790km-130357miles
1C-Position Sensing -- Status: Malfunction 0010
   Part No SW: 03L 997 016 N    HW: 03L 906 022 J
   Component: R4 2,0L EDC G000SG  8680
   Revision: 12H01---    Serial number: VWX7Z0H724214L
   Coding: 0050072
   VCID: 3D71F9B764E024D655-8068
008817 - Oxygen (Lambda) Sensor Signal B1 S2
               P2271 - 000 - too Rich
                    Mileage: 209688 km
                    Time: 12:42:09
                    RPM: 1840 /min
                    Speed: 65.0 km/h
                    Lambda: 37.1 %
                    Mass Air / Rev.: 405.0 mg/str
                    Voltage: 0.300 V
                    (no units): 0.01
                    Voltage: 0.975 V
000135 - Fuel Rail/System Pressure
               P0087 - 000 - Too Low - Intermittent
                    Mileage: 209770 km
                    Time: 17:58:35
                    RPM: 1564 /min
                    Inj. Quantity: 0.3 mg/str
                    (no units): 17.0
                    Pressure: 264.0 bar
                    Pressure: 112.0 bar
                    Temperature: 27.9°C
                    Tank Cont.: 17.1 l
   Part No SW: 1K0 907 379 AD    HW: 1K0 907 379 AD
   Component: ESP MK60EC1   H35 0104
   Revision: 00H35001
   Coding: 113B400D49240002881302E9922200423000
   Shop #: WSC 25018 444 85691
   VCID: 74E71C93D72AA59E6A-8020
                    Fault Status: 00100011
                    Reset counter: 19
                    Mileage: 209712 km
                    Count: 8
                    Count: 32768
                    Count: 4608
                    Count: 91
                    Count: 49934
                    Count: 257
                    Reset counter: 19
                    Mileage: 209712 km
                    Count: 8
                    Count: 32768
                    Count: 4608
                    Count: 75
                    Count: 49934
                    Count: 257
                    Reset counter: 238
                    Mileage: 209790 km
                    Count: 7
                    Count: 3
                    Count: 4096
                    Count: 128
                    Count: 28928
                    Count: 513
   Part No SW: 1K0 820 047 HS    HW: 1K0 820 047 HS
   VCID: 7CF734B33F7AEDDE22-8028
   Revision: 00H54000    Serial number: 00000001027735
   Coding: 14018E234004150007140000001400000008730B5C000120000000000000
   VCID: 326BDA8BADBEEBAEB8-8066
   Component: Wischer 070808 021  0501
   Coding: 00038805
   Shop #: WSC 00066
9 Faults Found:
                    Reset counter: 21
                    Mileage: 209768 km
                    Voltage: 10.85 V
                    Reset counter: 21
                    Mileage: 209586 km
                    Voltage: 14.15 V
                    Reset counter: 21
                    Mileage: 209768 km
                    Voltage: 11.30 V
                    Reset counter: 21
                    Mileage: 209665 km
                    Voltage: 12.15 V
01495 - Bulb for High-Beams; Left (M30)
                    Fault Status: 00111010
                    Reset counter: 21
                    Mileage: 209768 km
                    Voltage: 11.45 V
                    Reset counter: 21
                    Mileage: 209768 km
                    Voltage: 11.45 V
                    Reset counter: 21
                    Mileage: 209768 km
                    Voltage: 11.40 V
                    Reset counter: 21
                    Mileage: 209768 km
                    Voltage: 11.35 V
                    Fault Status: 01100010
                    Reset counter: 238
                    Mileage: 209768 km
                    Voltage: 9.40 V
   Revision: 00000000    Serial number: AUZ4Z7H0384796
   Coding: 0000100
   VCID: 3365DF8F52A4E2A6B3-8066
            000 -  -
                    Fault Frequency: 12
                    Reset counter: 207
                    Mileage: 207223 km
                    Time: 16:35:11
   Revision: 05034000    Serial number: 003B6M06DKD8
   Coding: 0013889
   VCID: 6CD704F34F1A7D5EB2-8038
   Subsystem 2 - Serial number: 6332MSME3B3404466
   Subsystem 3 - Serial number: 6342MSME37454B0DJ
   Subsystem 4 - Serial number: 6351HSME17004501S
   Subsystem 5 - Serial number: 6361HSME17004C2D7
   Subsystem 6 - Serial number: 63727SME173B0234Y
   Subsystem 7 - Serial number: 63827SME173B0A2B6
   Coding: 0002021
   VCID: 04074C53478A951E5A-8050
00576 - Terminal 15
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
00885 - Ignition Switch (D) Terminal 50
   Revision: V0003000    Serial number: VWX7Z0H724214L
   Coding: 0023203
   VCID: 3979EDA770C818F679-806C
                    Reset counter: 23
                    Mileage: 209790 km
                    Time: 19:09:36
   Component: J533  Gateway   H07 0062
   Revision:   H07 01    Serial number: 160608F1000802
   Coding: E9807F070013021002
   VCID: 3561E1975CD0FC969D-8060
   Revision: 00005000    Serial number: 1293324T33QT04
   Coding: 0000003
00457 - Control Module for Network (J519)
                    Reset counter: 125
                    Reset counter: 174
                    Mileage: 6591 km
                    Time: 13:32:52
   Shop #: WSC 20156 444 999999
   Revision: 72009005    Serial number: 00000024288708
   Coding: 0001205
   VCID: 6FED13FF7E0C864697-803A
   Part No: 1K0 909 144 H
   Component: EPS_ZFLS Kl. 69     2901
   Revision: 00H17000
   VCID: 2F6DD3FFBE8CC646D7-807A
                    Fault Status: 00101101
                    Reset counter: 19
                    Mileage: 209712 km
                    Time: 13:11:46
                    Voltage: 13.88 V
                        DU
                    Temperature: 36.0°C
                    RPM: 1792 /min
                    Speed: 16.0 km/h
                    Speed: 16.0 km/h
   Coding: 13900F880186281B0904058FB0880F0488DC00
   Revision: 72009005    Serial number: 00000553888804
   Coding: 0001204
   VCID: 70EF1083633299BE8E-8024
00110 - Right Mirror Turn Signal Lamp (L132)
                    Reset counter: 21
   Component: Radio ZSW       019 0035
   Revision: 00019000    Serial number: VWZ5Z7H6079543
   Coding: 0040402
   VCID: 29593DE78068A87609-807C
                    Reset counter: 22
                    Mileage: 209790 km
                    Time: 19:09:39
   Revision: 12006001    Serial number: 00000003345543
   Coding: 0001168
   VCID: 76E3269B0156B78E54-8022
   Coding: 0100101
00625 - Vehicle Speed Signal
                    Fault Frequency: 8
                    Reset counter: 23
                    Mileage: 209790 km
                    Time: 19:22:23
   Revision: 12006001    Serial number: 00000003342620
   Coding: 0001168
   VCID: 77FD2B9F065CCE864F-8022
                    Reset counter: 21
                    Mileage: 202912 km
                    Fault Status: 00111100
                    Reset counter: 21
                    Mileage: 202912 km
End-------------------------(Elapsed Time: 02:02)--------------------------
NostraJackAss
All issues must be corrected before a full reset or adaptation can take place.
Recoding and full reboot are needed and not with the engine running.
Me and Eric did verify that sometimes this ecu will not allow an adaptation for specific tests such as this issue unless reflashed.
Hello Anuthee,
Thanks for joining the forum. Per your email concerns:
  1. This EDC is out of date (despite the dealer claiming there wasn't one)
    03L 997 016 N @ 8680 would update to 9970 or higher. I would have that completed and you may need to spoon feed them TSB # 01-14-14 -or- SVM code 3339 so they can find it this time :)
    Side note, I don't have any reason to believe the flash will help with that P0087/000135 - Fuel Rail/System Pressure - Too Low - Intermittent DTC but you mentioned the dealer may be covering something under Goodwill​
  2. The FMA (Fuel Mean Value Adaptation / Kraftstoffmengen-Mittelwertadaptation) probably won't help - but we had a dual EDC TDI Touareg (caller) not long ago with a persistent fuel trim issue after failed oxygen sensor replacement. The FMA reset worked in that vehicle FWIW.
    Key on, Engine Off > Login / Coding-II > 10008 > Do it! The controller will reboot kicking you out of the diagnostic session. After it does so I would patiently wait, cycle the ignition and try reconnecting after 30 seconds.
dieselland
C?ID=81033
Thanks DANA!
~THAT IS EXCELLENT INFORMATION!~
Will pursue & report back.
-anuthee
dieselland
C?ID=81033
Performed FMA reset on ECU w/ non-updated software version 8680. Unsuccessful. CEL returned within 60 miles.
After some hand wringing with the dealer (TSB 01-14-14 has expired), I was able to convince them to update the software version anyway.
Car is back in customer's possession. I'll report back as I have more information as to success of the software update.
