Does anyone know what sequence of events cause the P0106 code to set?
I'm getting it whenever I accelerate more than gently. The freeze frame data looks like this:
Address 01: Engine (CBT) Labels: 07K-906-055-CBT.clb
Part No SW: 07K 906 055 P HW: 07K 906 055 M
Component: 2,5l R5/4V G 3254
Revision: G6H02--- Serial number: VWX7Z0H93N27VW
Coding: 0000075
VCID: 3B5BCC697A012BE66B-806E
000262 - Manifold / Barometric Pressure Sensor (G71) / (F96)
P0106 - 000 - Implausible Signal - Intermittent
Mileage: 195585 km
Time: 11:11:48
RPM: 595 /min
Load: 22.0 %
Speed: 9.0 km/h
Temperature: 86.0°C
Temperature: 42.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 13.208 V
I don't know what is "implausible" about a reading of 1010 mbar manifold pressure. That's 14.6 psia or -0.1 psig which is not an unusual reading under acceleration. Especially at low RPM when the throttle has just opened. I've run logs and the MAP readings seem normal. They swing up and down with change in throttle position and RPM as one would expect.
I'm wondering if there is some combination of factors (MAP, throttle position, RPM) that the ECU considers "implausible" which might indicate a problem - like a vacuum leak into the manifold. Postings on VW Vortex indicate that a bad N80 or PCV valve can cause this. However there are also a few references to an ECU firmware update, indicating this might be a logic glitch.
Coding: 0000075
Mileage: 195585 km
Time: 11:11:48
RPM: 595 /min
Load: 22.0 %
Speed: 9.0 km/h
Temperature: 86.0°C
Temperature: 42.0°C
Voltage: 13.208 V
