AP mode not visible from Windows XP
invisiblewave
C?ID=208767
In access point mode my HEX-NET isn't visible from my XP netbook. It works fine in infrastructure mode, and in AP mode it's visible from both my Android phone and my Linux desktop. With Windows, it just doesn't appear in the list of visible networks. I don't think it's a problem with the laptop, it sees numerous other networks including the two in my house and half a dozen belonging to neighbours. Just to be absolutely sure I ran a Windows Update to no avail.
Any solutions or troubleshooting pointers would be welcome.
The only other issue I have yet to overcome is a speed problem. Running in wireless infrastructure mode and monitoring both coolant sensors, the connection appeared to be extremely slow. I've only tried once (my HEX-NET only arrived yesterday), so it might be a problem with either the laptop or the network.
Is this the Acer Aspire One that you listed on your order? How old is it? Can you give us the exact model number please? What is it using for a WiFi chipset, and are the drivers for that WiFi chipset up-to-date?
invisiblewave
C?ID=208767
Yes, the Acer Aspire One. It's a D250-1389, manufacture date says 0907. The chipset is Atheros AR5007EG and the driver version was 7.6.1.244, dated 2/25/2009. I've just updated it to 7.7.0.348 to no avail (it also has a 2009 date, but is apparently the latest). The same laptop when booted into Ubuntu can see the HEX-NET.
Yep, if it works when booted into Ubuntu, it's clearly not a hardware issue with the laptop/WiFi itself.
invisiblewave
C?ID=208767
Ok, I updated to that driver and it still doesn't see the HEX-NET. The driver version is now 10.0.0.260 7/18/2013.
Scratching head...
Santos
I was able to dig up an old netbook equipped with an Atheros AR5007EG card. I'll experiment and get back to you shortly.
Santos
I found a work around for direct wireless connect to the Atheros AR5007EG.
Create a profile in the HEX-NET for an AD-HOC network. The Atheros card can see the HEX-NET and allow you to connect. Its not as clean as AP-Mode, but should work for now. It sounds like a Windows driver issue.
invisiblewave
C?ID=208767
So you couldn't get your laptop to connect in AP mode either?
Santos
Correct. It appears the windows driver for the AR5007EG do not support "Access Point" mode networks.
thismember
C?ID=208399
I am also unable to connect my XP laptop in AP mode. Network card is an Atheros AR928X. I tried the AD-HOC network profile and just updated to the latest driver (10.0.0.255 Release Date: 2013-07-02) yet HEX-NET is still not visible...
Santos
Yep looks to be in the same family as the AR5007EG and uses the same driver package.
What kind of laptop is it?
thismember
C?ID=208399
It's an Asus EEE PC 1000HE - I'm the one who also can't connect to the "09-Central Elec" controller via wired USB.
invisiblewave
C?ID=208767
Mine won't see it in ad-hoc mode either. I tried Auto & DHCP.
Santos
Did you set the profile using the Java utility?
Once set, unplug and replug the HEX-NET. It will show up as an AD-HOC network. If you take too long, it will switch over to the next wifi profile.
