ABS Module Communication issue
jlarson
C?ID=274671
I recently had the abs module go in my 2012 VW Jetta SE or so I thought. I replaced the module with a used one. I went to try to activate the pump to bleed the brake lines and the VCDS gave a communication error. I then tried plugging in the old module to see if it was something that was wrong with the used module. Still no communication. As a test I tried plugging into my Mom's 2015 VW Jetta and everything worked fine, all modules connected without an issue. It sounds to me like there is a disconnect somewhere in the wires between the abs module and the computer access port. Does anyone have any thoughts?
Have you verified power and ground to the ABS modules in the 2012?
jlarson
C?ID=274671
Sorry for the long reply time, yes there is power and ground to the abs module in the 2012 jetta.
