I have changed the parking brake control unit. After I changed the parking brake control unit , the coding of ABS disapered.
I want the correct code to enter in ABS and parking brake
Wednesday,20,April,2016,18:43:14:44240
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
VIN: WVWZZZ3CZ7E012843 License Plate:
Mileage: 250580km-155703mi Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 15 16 17 19 22 25 37 42 44 46 52 53 55 56 62 72
76 7D
VIN: WVWZZZ3CZ7E012843 Mileage: 250580km-155703miles
7D-Aux. Heat -- Status: Malfunction 0010
Address 01: Engine Labels: 03G-906-018-BKP.clb
Part No SW: 03G 997 020 T HW: 03G 906 018 CE
Component: R4 2.0l PPD1.5 G 5159
Revision: --H25--- Serial number: VWZCZ000000000
Coding: 0000172
Shop #: WSC 64903 001 1048576
VCID: 3979C3ED70F542F679-806C
P1653 - 008 -
Fault Status: 11101000
Mileage: 250589 km
Date: 2016.04.17
Time: 15:03:35
Torque: 0.0 Nm
0.00 %
Voltage: 10.73 V
Bin. Bits: 00000100
Torque: 1016.0 Nm
049448 - No Communications with Parking Brake Control Module
U0128 - 009 - - Intermittent
Fault Status: 00000100
Mileage: 250589 km
Date: 2016.04.18
Time: 13:40:16
Torque: 0.0 Nm
0.00 %
Voltage: 11.98 V
Bin. Bits: 00001110
Bin. Bits: 00000000
Readiness: N/A
Address 03: ABS Brakes Labels: 3C0-614-095-C2.clb
Part No SW: 3C0 614 095 P HW: 3C0 614 095 P
Component: ESP 440 C2 H015 0004
Revision: H015 Serial number: 0667481265
Coding: 0013602
Shop #: WSC 05311 000 00000
VCID: 2F6DFDB5BEB19C46D7-807A
7 Faults Found:
01324 - Control Module for All Wheel Drive (J492)
Mileage: 250589 km
Date: 2016.04.18
Time: 17:33:09
Mileage: 250589 km
Date: 2016.04.18
Time: 17:33:09
Mileage: 250589 km
Date: 2016.04.18
Time: 17:33:09
Mileage: 250589 km
Date: 2016.04.18
Time: 17:33:09
Mileage: 250589 km
Date: 2016.04.18
Time: 17:33:09
Mileage: 250589 km
Date: 2016.04.18
Time: 17:33:09
Mileage: 250589 km
Date: 2016.04.18
Time: 17:33:09
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 AH HW: 3C0 907 044 AH
Component: ClimatronicPQ46 050 0505
Revision: 00050005 Serial number: 00000000000000
VCID: 67DD559556C10406DF-8032
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 J HW: 3C0 937 049 J
Component: Bordnetz-SG H37 1301
Revision: 00H37000 Serial number: 00000005605318
Coding: E78A8F0700041A00000A00000F000000000B5D435C0000
VCID: 306FFEC9A38F83BECE-8064
Subsystem 1 - Part No: 3C1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer VW461 012 0503
Coding: 00063445
Shop #: WSC 05311
Subsystem 2 - Part No: 1K0 955 559 T Labels: 1K0-955-559-AF.CLB
Component: RegenLichtSens 011 1110
Coding: 00208933
Shop #: WSC 05311
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 J HW: 3C0 909 605 J
Component: 04 AIRBAG VW8 029 2521
Revision: 09029000 Serial number: 003A2P8QNHD+
Coding: 0012340
VCID: 2D51E7BDB4BDEE56E5-8078
Subsystem 1 - Serial number: 6332MSME0F0B4C42
Subsystem 2 - Serial number: 6342MSME0E72401C
Subsystem 3 - Serial number: 6351HTS6QLL67LM2
Subsystem 4 - Serial number: 6361HTS6TLLIUK43
01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
009 - Open or Short to Ground - MIL ON
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 A HW: 3C0 953 549 A
Component: Lenksäulenmodul 005 0010
Revision: 00005000 Serial number: 3C9953507C
Coding: 0000014
VCID: 2A5BECA18553F96E00-807E
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 871 HW: 3C0 920 871
Component: KOMBIINSTRUMENT VD1 1614
Revision: X0006000 Serial number: 00000000000000
Coding: 0007105
Shop #: WSC 51251 001 1048576
VCID: 61C94B8DB8E57A3611-8034
Address 19: CAN Gateway Labels: 3C0-907-530-V1.clb
Part No SW: 3C0 907 530 C HW: 3C0 907 951 A
Component: Gateway 007 0040
Revision: 00007000 Serial number: 0700C0651806D2
Coding: FDFD3C44C22002
VCID: 21490B8DF8653A3651-8074
Address 22: AWD Labels: 1K0-907-554.lbl
Part No: 1K0 907 554 H
Component: Haldex 4Motion 1116
Coding: 0000001
VCID: 326BF4C1AD83B1AEB8-8066
013 - Check DTC Memory
Part No SW: 3C0 959 433 R HW: 3C0 959 433 R
Component: IMMO 042 0383
Revision: 00042000 Serial number: VWZCZ000000000
Subsystem 1 - Part No: 3C0 905 861 D
Component: ELV 024 0370
3C0905861D ELV 024 0370
Address 37: Navigation Labels: 1K0-919-887-MFD2.lbl
Part No: 1K0 919 887 F
Component: Navigation 0028
Coding: 0000101
Shop #: WSC 05314 000 00000
VCID: 3C77DAF97FC777DE62-8068
Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1123
Revision: 12006001 Serial number: 00000025068517
Coding: 0000245
VCID: 3B75D9E57AC970E66B-806E
Fault Status: 01100101
Reset counter: 173
Mileage: 250589 km
Date: 2016.04.18
Time: 16:51:41
Part No: 1K1 909 144 K
Component: EPS_ZFLS Kl.5 D06 1701
VCID: 3365F1C55299B8A6B3-8066
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Component: KSG PQ46 ELV 042 0472
Coding: 0091020051030E763004941570084F0B607C00
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1123
Revision: 12006001 Serial number: 00000567968512
Coding: 0000244
Address 53: Parking Brake Labels: 3C0-907-801-53.clb
Part No SW: 3C0 907 801 G HW: 3C0 907 801 G
Component: EPB VD8HC005 013 0005
Revision: 013
Coding: 0010000
VCID: 26431891914BDD0E24-8072
Fault Status: 11101101
Reset counter: 173
Mileage: 250584 km
Date: 2016.04.18
Time: 13:45:33
Voltage: 11.90 V
Count: 236
000 - - - MIL ON
Fault Status: 11100000
Reset counter: 173
Voltage: 11.90 V
Count: 171
02443 - Control Head
008 - Implausible Signal - MIL ON
Fault Status: 11111000
Reset counter: 173
Voltage: 11.70 V
Count: 46
Address 55: Headlight Range Labels: 5M0-907-357-V1.lbl
Part No SW: 5M0 907 357 HW: 5M0 907 357
Component: AFS-Steuergeraet 0003
Revision: H09 Serial number:
Coding: 0000001
VCID: 71E93BCD6805CAB681-8024
Subsystem 1 - Part No: 7L6 941 329 Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l X018
Coding: 00000035
Subsystem 2 - Part No: 7L6 941 330
Component: AFS-Lst.-Modul r X018
Coding: 00000035
Address 56: Radio Labels: 1K0-035-095.lbl
Part No: 1K0 035 095 G
Component: Radio 0028
Coding: 0040402
VCID: 295913AD8055F27609-807C
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 P HW: 1K0 959 795 G
Component: J388 TUER-SG HL 1110
Revision: 11005001 Serial number: 00000000023310
Coding: 0000208
VCID: 3D71D7FD64DD7ED655-8068
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 P HW: 1K0 959 794 G
Component: J389 TUER-SG HR 1110
Revision: 11005001 Serial number: 00000000031456
Coding: 0000208
VCID: 3E73D0F169DB65CE4C-806A
Address 76: Park Assist Labels: 3C0-919-283.lbl
Part No SW: 3C0 919 283 B HW: 3C0 919 283 B
Component: Parkhilfe 8-Kan 004 0011
Revision: 00004000 Serial number: 82930611703511
Coding: 0000024
VCID: 285F16A99B5FCB7E16-807C
Component: PTC-Element 0404
00361 - Heater Element for Auxiliary Heater (Z35)
014 - Defective
End-------------------------(Elapsed Time: 02:12)--------------------------
