Q5 2011 immo v
Gavra
Melbourne/Belgrade
C?ID=240855
Is there option to add key with VCDS? I have PIN from dealer , I want to replace BCM2 and to recode old keys with same CS and PIN. Any information is helpful and appreciated.
autoscan
Monday,18,April,2016,14:27:52:48102
VCDS Version: 15.7.4.1
Data version: 20160216
Mileage: 187670km-116612mi   Repair Order: q5 goran lazarevac
Chassis Type: 8T0
Scan: 01 02 03 05 08 09 15 16 17 19 42 46 52 53 56 62 72
   Mileage: 187670km-116612miles
01-Engine -- Status: Cannot be reached 1100
02-Auto Trans -- Status: Cannot be reached 1100
04-Steering Angle -- Status: Cannot be reached 1100
15-Airbags -- Status: Cannot be reached 1100
Address 01: Engine
Address 02: Auto Trans
Address 03: ABS Brakes (J104)       Labels: 8R0-907-379-V1.clb
   Part No SW: 8R0 907 379 H    HW: 8R0 907 379 H
   Component: ESP8 quattro  H06 0100
   Coding: 0D5540
   Shop #: WSC 06335 000 00000
   VCID: 45816FDECC1A00160D-8010
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 21
                    Mileage: 187677 km
                    Date: 2016.03.28
                    Time: 21:42:04
                    Hex Value: 0x0000
                    Hex Value: 0x0782
                    Hex Value: 0x0016
                    Hex Value: 0x09A5
                    Hex Value: 0x00FF
                    Fault Status: 00101101
                    Reset counter: 61
                    Mileage: 187677 km
                    Date: 2016.03.31
                    Time: 16:24:59
                    Hex Value: 0x0000
                    Hex Value: 0x0782
                    Hex Value: 0x000A
                    Hex Value: 0x4693
                    Hex Value: 0x00FF
   Part No SW: 8K0 907 064 CP    HW: 8K0 907 064 CP
   Component: BCM2 2.0      H04 0430
   Coding: 010500
   VCID: 000FBECA93B8E53E7E-8054
   Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
   Component: FBSAUDIB8 IDG  H50 0071
02811 - Control Module for Electronic Steering Column Lock (J764)
                    Fault Status: 01100101
                    Reset counter: 21
                    Mileage: 187677 km
                    Date: 2016.03.28
                    Time: 21:41:59
02241 - Engine Control Module; Immobilizer Data not Adapted
            000 -  -
                    Reset counter: 21
                    Mileage: 187677 km
                    Date: 2016.03.28
                    Time: 21:42:03
                    Fault Status: 00100001
                    Reset counter: 61
                    Mileage: 187677 km
                    Date: 2016.03.29
                    Time: 00:13:44
                    Reset counter: 61
                    Mileage: 187677 km
                    Date: 2016.03.29
                    Time: 00:13:44
03026 - Enabling Terminal 15:
                    Fault Status: 00101001
                    Reset counter: 61
                    Mileage: 187677 km
                    Date: 2016.03.31
                    Time: 17:18:56
   Part No SW: 8T1 820 043 AM    HW: 8T1 820 043 AM
   Component: KLIMA 1 ZONE  H08 0180
   Revision: A0000000    Serial number: 01100720101223
   Coding: 34010000
   VCID: 7CF7CA3AFF5081DE22-8028
Address 09: Cent. Elect.        Labels: 8K0-907-063.clb
   Part No SW: 8K0 907 063 K    HW: 8K0 907 063 K
   Component: BCM1 1.0      H29 0392
   Coding: 690040B1003400010001000000005F5F001C460802000001000000
   VCID: 377D151686F662868F-8062
   Subsystem 1 - Part No: 8R1 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS416 100706
   Coding: 01DD13
   Subsystem 2 - Part No: 8K0 941 531 AK
   Component: E1 - LDS
No Faults Found
Address 15: Airbags
Address 16: Steering wheel
Address 17: Instruments (J285)       Labels: 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 900 P    HW: 8R0 920 900 P
   Component: KOMBIINSTR.   H11 0258
   Revision: 00200000    Serial number: EJV43277A
   Coding: 0F06220002000008040000
   VCID: 3E730032A9CC53CE4C-806A
                    Reset counter: 61
                    Mileage: 187677 km
                    Date: 2016.03.31
                    Time: 16:38:57
Address 19: CAN Gateway
Address 46: Central Conv.
Address 52: Door Elect, Pass.
Address 53: Parking Brake
Address 56: Radio (J503)       Labels: 8Tx-035-1xx-56.clb
   Part No SW: 8T1 035 186 P    HW: 8T1 035 186 P
   Component: Concert3      H07 0350
   Revision: 00000011    Serial number: AUZ5Z6J1438471
   Coding: 05000480040501000159070000
   VCID: 448772DAC720391E1A-8010
   Subsystem 1 - Part No SW: 8T0 919 603 F    HW: 8T0 919 603 F
   Component: Display
00849 - S-contact at Ignition/Starter Switch (D)
                    Reset counter: 61
                    Mileage: 187677 km
                    Date: 2016.03.31
                    Time: 16:38:55
Address 62: Door, Rear Left
Address 72: Door, Rear Right
End-------------------------(Elapsed Time: 02:23)--------------------------
I don't think so.
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
If you want to do immobilizer n this car you have to spend big money for it, only one tool ( AVDI), besides factory one ,works for this.
Gavra
Melbourne/Belgrade
C?ID=240855
Thanks for input, I do own AVDI, and can edit some BCM2 dumps what AVDI can't do........
