"This Function Requires a Licensed Interface" ??
PanEuropean
Toronto, Canada
C?ID=11844
Hello All:
I started to test the HEX-NET out on the Lamborghini Aventador today, and after connecting to the interface in Access Point mode, I began an Autoscan.
The VCDS beta application (14.5.2) polled the CAN controller, then the Instrument Cluster Controller, then presented the following application message to me:
I'm perplexed by this, because I have already registered this interface via "the Cloud", etc., as mentioned in a post I made a few days ago.
After the above message was presented, I couldn't do very much else with that car and this interface.
Michael
VCDS-Mobile along with Cloud registration and VCDS Licensing are two separate things. What do you see on the About screen of VCDS?
PanEuropean
Toronto, Canada
C?ID=11844
A rather long serial number, and Licence Status that says 'Valid/Activated'.
Michael
PanEuropean
Toronto, Canada
C?ID=11844
Ah, wait, my mistake: Although I was using the 14.x beta version for the work I was doing with the HEX-NET, I just went back and checked the headers of my log files, and saw that for that particular instance, I had launched the 12.x release version instead of the beta (this with the HEX-NET connected). So, the screen-shot above is of release 12.x, not release 14.x.
My apologies.
Michael
Zagor
Italy
C?ID=96696
Hi mates,
a few days ago I have the same problem, on my Golf MK5 can not change the long coding and adaptation, my interface is suddenly unregistered / unauthorized.
This is the screen of the about page:
This is instead the error message I get when I try to change long coding or adaptation of any module:
I use the vcds for many years and never happened this thing, my job is having problems due to this anomaly.
Someone can help me?
Mauro, check your e-mail.
Zagor
Italy
C?ID=96696
Very many thanks, Uwe, you are the best! Now all is working!
Finally three questions:
Why did it happen?
It can happen again?
If yes I can always use the file you sent me?
Why did it happen?
I don't know.
I can't rule it out.
Yes, it should work the same.
Zagor
Italy
C?ID=96696
Again, a huge thank you!
Eric
HC800000
Do let us know if happens again though.
Zagor
Italy
C?ID=96696
Sure.
CvTech
C?ID=211326
I am having a similar issue with my HEX-NET. I have reinstalled v14 but same error. I am pretty sure I am registered, etc. Any ideas?
How similar? Got a screen-shot from your About screen please?
CvTech
C?ID=211326
I will upload a screen shot soon, but similar meaning exactly the same.
Zagor
Italy
C?ID=96696
today on my vcds it happened again, but using the file provided by Uwe I solved also this time
Zagor
Italy
C?ID=96696
Maybe in the 14.10 release there's some bugs
Artvanpraag
C?ID=399122
Hello Uwe,
I have this same problem (license required) for some options in vcds.
Wenn the problem occures the icense is active. What i try to do is to raise the spoiler on my Aventador model 2014 via the Aerodynamics options on a Windows 10 laptop.
My license info is in the link:
https://www.dropbox.com/s/zwxrnwh2f1j72p7/License.png?dl=0
Would be nice if you could help me.
Arthur
