2017 Q7 (US), 3.0l V6 TFSI
   #41
spyderboyant
Australia
C?ID=65474
Hey Ant,
Appreciate you continuing to look into this. If there is anything else you need to assist, please let me know. I tried to look in Adaption Channels but couldnt see anything "obvious" to enable it. I'll take another look though
RE: Soft Power Close doors, sadly not... quite rare for a car to have them here in the UK as a pricey option. I'd love to retro-fit if someone could work out how.
No worries. It must be in the adaption channels so I'll look with ODIS over the next few days and post a screen capture.
Re soft close doors, I'm thinking of doing the retrofit as I believe our door controllers support this feature (as there are no PR variants in ETKA). Having said that, it is a little expensive as you need:
1. 4 x New door locks that have a connector that links down to the soft close motor. Front doors are LHD and RHD specific so you can't get ones from mainland Europe. I think however that the A8 ones from 2012 onwards are compatible as the non-soft close door locks are actually A8 ones. The soft close ones have a "4M0" part number but obviously as you are replacing the old ones which are A8 variants, the newer A8 ones should fit.
2. 4 x soft close motors. These are the A8 ones.
3. 4 x new black plastic trim that houses the soft close motor
4. 2 pin wire loom from the soft close motor to the door controller per door.
I'll check the exiting door controller with VCDS and see whether it accepts the coding for soft close doors. I wont do the mod if I have to replace them as well.
If door controllers are OK I will most probably do the mod and will write it up on one of the Audi forums.
cheers
ant
   #42
andyhud
C?ID=32695
Ant, very interesting... I was looking into the motor units also on ETKA ( I have a copy too) and trying to piece all the bits together but sometimes its not that clear.
Your comment about not getting parts from mainland Europe, surely I could just order the right ones for the UK version of the car as its a selectable option on the car? or do you mean something else?
Otherwise it seems pretty simple.
I was looking at retrofitting side assist, but apparently the door control units need replacing if you dont have side assist also for it so there is a probability the power door function could be the same. I'm trying to find someone localish to me with them so I can AutoScan the hell out their car :)
   #43
andyhud
C?ID=32695
Another scan on 16.6.0 with Hex-Net and latest firmware
Sunday,19,June,2016,11:24:34:50897
VCDS Version: 16.6.0.2 (x64)  HEX-NET CB: 0.4321.4
Data version: 20160602 DS251
VIN: WAUZZZ4MXGD0xxxxx   License Plate:
Chassis Type: 4M (4M2)
Scan: 01 02 03 06 08 09 13 15 16 17 19 28 29 2B 36 39 42 44 46 47
          50 52 5F 69 6C 6D 74 81 82 8B A5 AC BB BC CA D6 D7
50-Seat Adj. 3rd row -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CRTC)       Labels: None
   Part No SW: 4M0 907 401     HW: 059 907 309 B
   Component: 3.0TDI EDC17  H45 0004
   Revision: 91H45---
   Coding: 2A2A4032057E050335180000000000000000000000000000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_ECM30TDI0114M0907401 001008
   ROD: EV_ECM30TDI0114M0907401.rod
   VCID: 66807A9599A11C7343-8032
Address 02: Auto Trans (J217)       Labels: None
   Part No SW: 4M0 927 158 J    HW: 0D5 927 156 H
   Component: 0D5  30TDIRdW H03 1008
   Revision: --H03---
   Coding: 100000
   ASAM Dataset: EV_TCMALX52011 002010
   ROD: EV_TCMALX52011.rod
   VCID: 3B36FBE1B2A3719BCC-806E
   Part No SW: 4M0 907 379 K    HW: 4M0 907 379 K
   Component: ESP9 Premium  H08 0514
   Coding: 249830B230A30A9DD6A5589A187E52AAE6A6D2240C0C506B1A184A5567654B
   ASAM Dataset: EV_ESP9BOSCHAU736 011006
   ROD: EV_ESP9BOSCHAU736_AU73.rod
   VCID: 3FCE8FF1A6BB6DBBE0-806A
   Part No SW: 4M0 959 760 E    HW: 4M0 959 760 E
   Component: MEM-BFS       008 0014
   Serial number: 00000163424401
   Coding: 002010000000B0410000210101010000110000313100000000000000000000
   ASAM Dataset: EV_SCMPasseSideCONTIAU736 006007
   ROD: EV_SCMDriveSideCONTIAU736_AU73.rod
   VCID: 3A38FEE5BD994893D7-806E
Address 08: Auto HVAC (E87)       Labels: None
   Part No SW: 4M0 820 043 K    HW: 4M0 820 043 K
   Component: Klima Zone 4  H52 0071
   Coding: 6618083C5545451102220180800000000000000000000000000000000000
   ASAM Dataset: EV_AirCondiFrontBHTCAU736 001013
   ROD: EV_AirCondiFrontBHTCAU736.rod
   VCID: 2D12C5B97CD7EF2B42-8078
   Subsystem 1 - Part No SW: 4M2 820 021     HW: 4M2 820 021
   Component: J216 FLuftV  H05 0001
   Serial number: 00000000000000553567
   Part No SW: 8W0 907 063 G    HW: 8W0 907 063 G
   Component: BCM1 MLBevo   H12 0215
   Coding: 07501943C12900CD010D57195B3F08F9130331009000000000000000E00016810A4502AB32B60A
   ASAM Dataset: EV_BCM1BOSCHAU736 014003
   ROD: EV_BCM1BOSCHAU736_AU49.rod
   Subsystem 1 - Part No SW: 4M2 955 119 A    HW: 4H1 955 119 C
   Component: WWS536 150424  042 0792
   Serial number:         150617201146
   Coding: 1BC7F7
   Serial number: 20522486
   Coding: 0200FF
   Subsystem 3 - Part No SW: 4M0 941 531 P    HW: 4M0 941 531 P
   Component: E1 - LDS  H05 0007
   Serial number: 14 07 2015  00047313
   Subsystem 4 - Part No SW: 4M0 857 511 A    HW: 4M0 857 511 A
   Component: Y7_Innenspieg  H08 0002
   Serial number: GX1CE105081511520096
   Coding: 230000
   Interior Light Module:
   Subsystem 5 - Part No SW: 4M0 947 135 AB    HW: 4M0 947 135
   Component: J528-Dachele  H13 0080
   Serial number: Q00029636
   Subsystem 6 - Part No SW: 4M0 925 301 B    HW: 4M0 925 301 B
   Component: SL-Q7NF/AU736  H09 0006
   Serial number: 00000000000000011137
Address 13: Auto Dist. Reg (J428)       Labels: None
   Part No SW: 4M0 907 561 C    HW: 4M0 907 561
   Component: LRR4          H08 0160
   Coding: 3473FFEB58FFEC08949880A4
   ASAM Dataset: EV_ACCBOSCHAU736 001016
   ROD: EV_ACCBOSCHAU736.rod
   VCID: 302CDCCD6BE582C369-8064
Address 15: Airbags (J234)       Labels: None
   Part No SW: 4M0 959 655     HW: 4M0 959 655
   Component: Airbag10.44   H50 0084
   Serial number: 003L1000KE5L
   Coding: AACCF0D80C80000098F650F3C08C00000000
   ASAM Dataset: EV_AirbaAU10BPAAU736 005012
   ROD: EV_AirbaAU10BPAAU736_AU73.rod
   VCID: 78BC24EDC3159A83E1-802C
   Subsystem 1 - Part No SW: -----------    HW: 442 060 908 15
   Serial number: 3577Y00B11A19FC164B9
   Subsystem 2 - Part No SW: -----------    HW: 442 060 908 15
   Serial number: 3587Y00B11A19FC0D337
   Subsystem 3 - Part No SW: -----------    HW: 442 0B2 707 15
   Serial number: 35177009F1B9D76282EY
   Subsystem 4 - Part No SW: -----------    HW: 442 0B2 707 15
   Serial number: 3527700991B9D761E07P
   Subsystem 5 - Part No SW: -----------    HW: 442 0C2 807 15
   Serial number: 3557500991C3DEC2639W
   Front Sensor Passenger:
   Subsystem 6 - Part No SW: -----------    HW: 442 0C2 507 15
   Serial number: 3567500A91C3DEA5E12Y
   Pedestrian Protection Center:
   Subsystem 7 - Part No SW: -----------    HW: 442 0C2 507 15
   Serial number: 2307500A91C3DEA3A14L
   Subsystem 8 - Part No SW: -----------    HW: 442 420 508 15
   Component: PedPSensor_D2  21E 0887
   Serial number: I0M8U00B71989851C31O
   Subsystem 9 - Part No SW: -----------    HW: 442 420 508 15
   Component: PedPSensor_P2  21E 0887
   Serial number: I0N8U00B71989851D55W
   Central Sensor XY:
   Subsystem 10 - Part No SW: -----------    HW: 410 202 707 15
   Component: CentrSensorXY  1C8 0108
   Serial number: I0O7800C31BCC0E17056
Address 16: Steering wheel (J527)       Labels: None
   Part No SW: 4M0 907 129 JE    HW: 4M0 907 129 JE
   Component: Lenks.Modul   H11 0008
   ROD: EV_SMLSKLOAU736_AU49.rod
   VCID: 7CB438FDF72DB6A385-8028
Address 17: Instruments (J285)       Labels: None
   Part No SW: 4M0 920 790 A    HW: 4M0 920 790 A
   Component: FBenRDW       H12 0262
   Coding: 248D01D07C90060001A369603000600000000000
   ASAM Dataset: EV_DashBoardAU736 001020
   ROD: EV_DashBoardAU736.rod
Trying Address 19
   Part No SW: 4M2 907 468 A    HW: 4M2 907 468 A
   Component: Gateway       H13 0078
   Revision: 3C030052    Serial number: 5243C001115729
   Coding: 0301000100008F407F00000000590032D8920007180000000100000000000000
   ASAM Dataset: EV_GatewCONTIAU736 002040
   ROD: EV_GatewCONTIAU736.rod
   VCID: 3620EAD58981ACF333-8062
   Subsystem 1 - Part No SW: 4M0 951 523 A    HW: 4M0 951 523 A
   Component: J453 MFL  H06 0002
   Serial number: 20150723052256 RD031
   Subsystem 2 - Part No SW: 8S0 915 181     HW: 8S0 915 181
   Component: J367-BDMHella  H10 9052
   Serial number: 1194427103
Address 28: HVAC, Rear (E265)       Labels: None
   Part No SW: 4M0 919 158 C    HW: 4M0 919 158 C
   Component: Klima Zone 2  H52 0070
   Coding: 000000000000040100820080000000000000000000000000000000000000
   ASAM Dataset: EV_AirCondiFondBHTCAU736 001013
   ROD: EV_AirCondiFondBHTCAU736.rod
   VCID: 3522EDD99487A7EB3A-8060
Address 29: Left Light (J1018)       Labels: None
   Part No SW: 4M0 907 397 B    HW: 4M0 907 397 B
   Component: LCM_MLBevoH05 0011
   ASAM Dataset: EV_LCMLeftHELLAAU736 001006
   ROD: EV_LCMLeftHELLAAU736.rod
   Part No SW: 3Q0 905 861 A    HW: 3Q0 905 861 A
   Component: ELV-MLBevo    H05 0032
   Serial number: 15000000413006
   Coding: 8800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 3228D6C565E9B0D31F-8066
   Component: MEM-FS        008 0014
   Serial number: 00000163486575
   Coding: 00381B000000B0410000210101010000110000313100000000000000000000
   ASAM Dataset: EV_SCMDriveSideCONTIAU736 006007
Address 39: Right Light (J1023)       Labels: None
   ASAM Dataset: EV_LCMRightHELLAAU736 001006
   Part No SW: 4M0 959 593 D    HW: 4M0 959 593 C
   Component: TSG FS        005 0036
   Serial number: 0000159961174
   Coding: 005D9A015E01000000003082
   ROD: EV_DCU2DriveSideMAXHCONT.rod
   VCID: 3D32F5F9ACB77FABF2-8068
Address 44: Steering Assist (J500)       Labels: None
   Part No SW: 4M0 909 144 E    HW: 4M0 909 144 B
   Component: EPS_MLBEVO1BS H17 0003
   Revision: --------    Serial number: 0000118290
   Coding: B0150101000101
   ASAM Dataset: EV_EPSVWBSAU736 006014
   ROD: EV_EPSVWBSAU736_AU49.rod
   VCID: 312AD9C960EF8BCB66-8064
Address 46: Central Conv. (J393)       Labels: None
   Part No SW: 8W0 907 064 AD    HW: 4M0 907 064 D
   Component: BCM2 MLBevo   015 0307
   Coding: 01351E006F110040630980006E00580203004004004702502F0400000504803F001F0001000000
   Shop #: WSC 37082 001 104857
   ASAM Dataset: EV_BCM2HellaAU736 010010
   ROD: EV_BCM2HellaAU736_AU49.rod
   VCID: 7EB032F5E131A4B3AB-802A
   Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY151821J5E
   Subsystem 2 - Part No SW: 5Q0 951 605     HW: 5Q0 951 605
   Serial number: 00000000000033093340
   Heated Windshield Control Module:
   Subsystem 3 - Part No SW: 4M0 907 133     HW: 4M0 907 133
   Component: J505-FSH  H03 0050
   Serial number: 00000000000000003568
   Subsystem 4 - Part No SW: 3AA 962 243 F    HW: 3AA 962 243 F
   Component: GEB.F.Heckoef  H16 0815
   Serial number: 94015250
   Part No SW: 4M0 035 223 A    HW: 4M0 035 223
   Component: MIB2_amp_PD   H02 0420
   Serial number: 00000000001999
   Coding: 0135060A008AF53AAF0000010000
   ASAM Dataset: EV_AMPMst16C4Gen2BOSE 001001
   ROD: EV_AMPMst16C4Gen2BOSE.rod
   VCID: 210A2989300F3B4BF6-8074
Address 50: Seat Adj. 3rd row (J857)       Labels: None
   Part No SW: 4M0 959 760 G    HW: 4M0 959 760 G
   Component: MEM-SR3       008 0014
   Serial number: 00000163698793
   Coding: FF201020F1000000000F000000000900000021210900000000000000440000
   ASAM Dataset: EV_SCM3rdRowCONTIAU736 005007
   ROD: EV_SCM3rdRowCONTIAU736.rod
   VCID: 3C34F8FDB7AD76A3C5-8068
   Part No SW: 4M0 959 592 D    HW: 4M0 959 592 C
   Component: TSG BFS       005 0036
   Serial number: 0000161932025
   Coding: 005D9A015E01000000003080
   ROD: EV_DCU2PasseSideMAXHCONT.rod
   Part No SW: 4M0 035 035 B    HW: 4M0 035 035 A
   Component: MU-P-LND-EU   050 0358
   Serial number: A649H0F7500568
   Coding: 013706010000000013111102000A00332F001BE7017001009E
   VCID: 230623812A13295BE4-8076
   Subsystem 1 - Part No SW: V03 959 801 FA    HW: -----------
   Component: ECE 2016  --- 0134
   Subsystem 2 - Part No SW: 4M0 919 605     HW: 4M0 919 605
   Component: AU536_DU_HIGH  H43 0008
   Serial number: AUZ8Z9FJ400KPG
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 4M0 919 615 D    HW: 4M0 919 615 D
   Component: ControlUnit_P  H14 0161
   Serial number: 31071500000000000006
   Compact Disc Database:
   Component: Gracenote2  --- 1011
Address 69: Trailer (J345)       Labels: None
   Part No SW: 4M0 907 383 D    HW: 4M0 907 383 B
   Component: Anhaenger     H20 0208
   Revision: 9A001003    Serial number: 0375642968
   Coding: 0110000202010000
   VCID: 3326D3C19AF3B9DB14-8066
428804 - Pitch Angle Sensor
          U115A 00 [009] - No Communications
                    Reset counter: 138
                    Mileage: 9110 km
                    Date: 2016.06.19
                    Time: 11:20:18
Address 6C: Back-up Cam. (J928)       Labels: None
   Part No SW: 4M0 907 428 B    HW: 4M0 907 428
   Component: Areaview 2    H11 0301
   Serial number: C854606JG000947
   Coding: 02370601BF0FA10008404480
   ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 004013
   ROD: EV_CamSysRVAV2CE2MLBEv_AU49.rod
Address 6D: Trunk Elect. (J605)       Labels: 5Q0-959-107.clb
   Part No SW: 4M0 959 107     HW: 4M0 959 107
   Component: HDSG-Modul    H12 0143
   Revision: --------    Serial number: 30165574600000
   Coding: 00F0
   ASAM Dataset: EV_DeckLidCONTIAU736 001010
   VCID: 70AC1CCDAB65C2C329-8024
Address 74: Chassis Control (J775)       Labels: None
   Part No SW: 4M0 907 777     HW: 4M0 907 777
   Component: Fahrwerk-SG   H10 0102
   Serial number: 2508150523
   Coding: 98505048F8
   ASAM Dataset: EV_ChassContrContiAU736 002013
   ROD: EV_ChassContrContiAU736_AU73.rod
   VCID: 76A02AD5C901ECF3F3-8022
   Air Suspension Compressor:
   Subsystem 1 - Part No SW: 4M0 907 589 B    HW: 4M0 907 589 B
   Component: V66LFKompOLV  H06 0012
   Serial number: 00000000004130021620
   Coding: 303030
   Part No SW: 4M2 713 041 D    HW: 4M2 713 041 D
   Component: GSM-LL        H07 0066
   Revision: 0L0D5012    Serial number: 20150701001139
   ASAM Dataset: EV_GSMWaehlZFAU736 001013
   ROD: EV_GSMWaehlZFAU736_AU49.rod
   VCID: 271E37915E2BC57BB8-8072
Address 82: Heads Up Display (J898)       Labels: None
   Part No SW: 4M0 919 617 A    HW: 4M0 919 617 A
   Component: HeadUpDisplay H26 1524
   Coding: 4F00C0
   ASAM Dataset: EV_HudNSEIKAU736 001012
   ROD: EV_HudNSEIKAU736.rod
Address 8B: Adaptive Cruise 2 (J850)       Labels: None
   Part No SW: 4M0 907 541 C    HW: 4M0 907 541
   ASAM Dataset: EV_ACC2BOSCHAU736 001016
   ROD: EV_ACC2BOSCHAU736_AU73.rod
   VCID: 2E10C2B571D194337B-807A
Address A5: Frt Sens. Drv. Assist (R242)       Labels: None
   Part No SW: 4M0 907 217 C    HW: 4M0 907 217 A
   Component: BVS           H12 0030
   Coding: 0407030600000402024023A5CD0000B4B0F0C020E280
   ASAM Dataset: EV_BVSMLBevKOSTAAU736 002022
   ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
Address AC: Reductant Control (J880)       Labels: None
   Part No SW: 4M0 907 355     HW: 4M0 907 355
   Component: SCR-Stg-G3H10 0003
   ASAM Dataset: EV_RDCMINERGAU736 005009
   ROD: EV_RDCMINERGAU736.rod
   VCID: 6E9002B5B151D4333B-803A
Address BB: Door Rear Drv (J388)       Labels: None
   Part No SW: 4M0 959 595 D    HW: 4M0 959 595 C
   Component: TSG HFS       005 0036
   Serial number: 0000161937048
   Coding: 004D98000001000000003080
   ROD: EV_DCU2RearDriveMAXHCONT.rod
Address BC: Door Rear Pass (J389)       Labels: None
   Component: TSG HBFS      005 0036
   Serial number: 0000161994529
   ROD: EV_DCU2RearPasseMAXHCONT.rod
Address CA: Sunroof (J245)       Labels: None
   Part No SW: 4M0 907 594     HW: 4M0 907 594
   Component: SAD_STG_1     011 0003
   Coding: 588000053602
   ROD: EV_SunRoofCONTIAU736_VW37.rod
   VCID: 73A613C1DA73F9DBD4-8026
Address D6: Light Ctrl Left 2 (A31)       Labels: None
   Part No SW: 7PP 941 592 CA    HW: 7PP 941 592 C
   Component: LED1L         H09 2002
   ROD: EV_LEDModLeftMELCOAU736_AU49.rod
   VCID: 197A0169185F638B3E-804C
Address D7: Light Ctrl Right 2 (A27)       Labels: None
   Component: LED1R         H09 2002
End----------(Elapsed Time: 02:22, VBatt start/end: 12.2V/12.2V)-----------
