Missing support for A5, 09 and 08.
GaSelle
Denmark
C?ID=266649
Hi.
Just upgraded VCDS to latest beta, and upgraded the firmware in my Micro-CAN.
Now it takes between 1-5 tries to connect to a module. It throws a "no response from controller" most of the time. It worked like a charm before the upgrade.
Anyway:
There is still no label file for 09 (BCM), 08 (HVAC), 36 (Seat mem.), 6D (trunk elect.) and A5 (front camera), even in the beta. Is this something you are working on? I sent you an e-mail with this information, but did not get any response.
Autoscan:
Saturday,09,April,2016,20:17:11:21896
VCDS Version: 15.7.4.1
Data version: 20160216
VIN: TMBJB7NP5G7066963   License Plate:
Mileage: 128km-79mi   Repair Order:
Chassis Type: NP (5Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 36 42 44 52 55 5F 6D A5
VIN: TMBJB7NP5G7066963   Mileage: 128km-79miles
Address 01: Engine (J623-CZEA)       Labels: 04E-907-309-V1.clb
   Part No SW: 04E 906 027 BT    HW: 04E 907 309 AB
   Component: R4 1.4l TFS   H23 9042
   Revision: R6H23---
   Coding: 01250032236419086000
   Shop #: WSC 33361 790 00063
   ASAM Dataset: EV_ECM14TFS01104E906027BT 001010
   ROD: EV_ECM14TFS01104E906027BT.rod
   VCID: 77D31055CE98CC864F-8022
   Part No SW: 0CW 300 040 J    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 0605
   Revision: 00005005    Serial number: CU501602126249
   ROD: EV_TCMDQ200021_SK25.rod
   VCID: 3B5BCC65B23028E66B-806E
   Revision: 00000000    Serial number: 60476000002068
   Coding: 1E076A9C342613720780060641C64978562CC8E0608292F51821F078C202
   ROD: EV_Brake1UDSContiMK100IPB_SK37.rod
   VCID: 7AD50961FD8AD1EE30-802E
Address 08: Auto HVAC (E87)       Labels: None
   Part No SW: 3V0 907 044 AG    HW: 3V0 907 044 AG
   Component: AC Automat    H32 3701
   Revision: 20K05000    Serial number: 00000B00070329
   Coding: 12010004000100011005100000101002
   Shop #: WSC 73430 790 00063
   ASAM Dataset: EV_ACClimaPrehVW37X 002012
   ROD: EV_ACClimaPrehVW37X_SK48.rod
   VCID: 79D7166DF88CDAF639-802C
   Slave 1:
   Part No SW: 5Q0 937 084 CL    HW: 5Q0 937 084 AN
   Serial number: 01061605302155
   Coding: 0C001B46C2C722FB57C44004001C57280000000000000000000000000000
   ROD: EV_BCMBOSCH_SK48.rod
   VCID: 042977998F4E971E5A-8050
   Slave 1:
   Subsystem 1 - Part No SW: 3V1 955 119     HW: 3V1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: 48x LL 160217  032 0121
   Serial number: 00000001602120308271
   Coding: 165DDD
   Slave 2:
   Component: RLHS  037 0059
   Serial number: S4Y16M02D24H17M13S00
   Coding: 00084D
Address 10: Park/Steer Assist (J446)       Labels: 5Q0-919-294.clb
   Part No SW: 5Q0 919 294 L    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0056
   Revision: --------    Serial number: 39391605101238
   Coding: 0071051851
   ROD: EV_EPHVA18AU3700000_SK48.rod
   VCID: 44A9B799CFCE571E1A-8010
Address 13: Auto Dist. Reg (J428)       Labels: 3Q0-907-572.clb
   Part No SW: 3Q0 907 572 B    HW: 3Q0 907 572 B
   Coding: 320067C211FFC428949C804D
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 3449E7599F6EE79EAA-8060
   Part No SW: 5Q0 959 655 AK    HW: 5Q0 959 655 AK
   Component: AirbagVW21    005 0130
   Serial number: 003Q5R1GMMLE
   Coding: 98CCC0C0000000005C5400CF004800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002146
   ROD: EV_AirbaVW20SMEVW37X_SK48.rod
   VCID: 093766ADA86CCA7629-805C
   Subsystem 1 - Part No SW: -----------    HW: 480 002 002 16
   Serial number: 35700000000B4969691R
   Subsystem 2 - Part No SW: -----------    HW: 480 002 002 16
   Serial number: 3580000000069099D91T
   Subsystem 3 - Part No SW: -----------    HW: 480 402 302 16
   Serial number: 3510002A51F93A31C374
   Subsystem 4 - Part No SW: -----------    HW: 480 402 302 16
   Serial number: 3520002A51F93A31733$
   Subsystem 5 - Part No SW: -----------    HW: 480 402 302 16
   Serial number: 3550002B31F93A35C1AC
Address 16: Steering wheel (J524)       Labels: 5Q0-953-549.clb
   Part No SW: 5Q0 953 521 GB    HW: 5Q0 953 569 A
   Component: Lenks.Modul   075 0195
   Revision: FF033033    Serial number: 20160220400177
   Coding: 6410
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 78D11369C386C3FE46-802C
   Part No SW: 3V0 920 750     HW: 3V0 920 750
   Component: KOMBI         313 6422
   Coding: 07A5090A2F80000801883A011000000000000000
   Shop #: WSC 73430 031 00063
   ROD: EV_DashBoardVDDMQBAB_SK25.rod
   VCID: 70C12B49ABF69BBE8E-8024
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2246
   Revision: --------    Serial number: 19021610802558
   Coding: 030100047F085700FB00025A1C0F00010001070000000000000000000000
   ROD: EV_GatewConti.rod
   Subsystem 2 - Part No SW: 3V0 919 719 A    HW: 3V0 919 719 A
   Component: E221__MFL-PR6  H02 0150
   Serial number: 000000000B0503150216
   Serial number: 4589149303
Address 36: Seat Mem. Drvr (J810)       Labels: None
   Part No SW: 5Q0 959 760 A    HW: 5Q0 959 760 A
   Component: Sitzmemory    H06 0009
   Serial number: Y0006PB110055
   Coding: 001000000000010001A080808080000000008181000000D4
   ASAM Dataset: EV_SeatMemorDriveSide 001015
   ROD: EV_SeatMemorDriveSide_SK37.rod
   Serial number: 180116EAG11272
   Coding: 001D0920DE00040000001100
   ROD: EV_DCUDriveSideEWMAXCONT_SK37.rod
   VCID: 43ABB485CAC0502623-8016
Address 44: Steering Assist (J500)       Labels: 5Q0-909-143.clb
   Part No SW: 5Q0 909 143 M    HW: 5Q0 909 143 E
   Component: MQB_PP_APA    204 2041
   Revision: 00000000    Serial number: 0000625324
   Coding: 01000010005001
   ASAM Dataset: EV_SteerAssisVWBSMQBA 008028
   ROD: EV_SteerAssisVWBSMQBA_SK48.rod
   VCID: 3D5FC27DAC2426D655-8068
   Serial number: 150116EAE11088
   Coding: 001D0320DE00040000001100
   ROD: EV_DCUPasseSideEWMAXCONT_SK37.rod
   VCID: 42A5B181D5DA592E28-8016
   Coding: 06DA00003F000000
   ROD: EV_HeadlRegulVWAFS_SE26.rod
   VCID: 40A1BB89DBD64B3E3E-8014
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0006
   Coding: B20000
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0006
   Coding: B20000
Address 5F: Information Electr. (J794)       Labels: 3V0-035-MIB-STD2.clb
   Part No SW: 5Q0 035 842 A    HW: 5Q0 035 842 A
   Component: MU-S-D-ER     H24 0245
   Serial number: SKZAZ2S8233209
   Coding: 03840200FF0000001111120100880A002F0200C40120010002
   ROD: EV_MUStd4CTSAT_SE25.rod
   VCID: 2D7FF23D7C44B656E5-8078
   Media Player Position 1:
   Subsystem 1 - Part No SW: 3V0 919 605     HW: 3V0 919 605
   Component: ABT_Std-2  H46 1031
   Serial number: SKZ8Z9SFD002CW
Address 6D: Trunk Elect. (J605)       Labels: None
   Part No SW: 5Q0 959 107 J    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0253
   Revision: --------    Serial number: 30535386500000
   Coding: 0D00
   ASAM Dataset: EV_DeckLidCONTIAU736 001012
   ROD: EV_DeckLidCONTIAU736_SK48.rod
   VCID: 3FA3B875A62834C647-806A
Address A5: Frt Sens. Drv. Assist (R242)       Labels: None
   Part No SW: 3Q0 980 654 D    HW: 3Q0 980 654
   Component: MQB_B_MFK     H04 0024
   Serial number: 16021611K11208
   Coding: 0204080200000401002200448040A00000000E100020
   ROD: EV_MFKBoschMQBB_SK48.rod
   VCID: 3851D369830603FE86-806C
End-------------------------(Elapsed Time: 04:13)--------------------------
Eric
HC800000
I can't comment on the labels (other than you car is a 2016!), however on the connection issues: we haven't had any other report of such problems. Please set debug level to 1024, apply, and try an autoscan (as many times as required for you to get a gateway installation list and VCDS to start scanning). Send us the saved autoscan and the .DLM files from the Debug subfolder to support@ross-tech.com . I'll see if there's anything to help us solve your issue in there. Which PC are you running VCDS on? (CPU, memory).
GaSelle
Denmark
C?ID=266649
Where do I set the debug level? I´ll give it a go later. The last three attempts of an autoscan failed due to communication errors. It´s an older laptop (Intel Core2 Duo T7100 @ 1,8 Ghz, 2 Gb ram and Win10).
Eric
HC800000
Top right of the Protocol options:
GaSelle
Denmark
C?ID=266649
Solved the connection issues: bought a new laptop.
