Audi A6 C7 4G front led headlight retrofit
m87a
Bosnia and Herzegovina
C?ID=156900
Hey people,
friend of mine has tried to retrofit full led headlights on his a6 which came with halogen lights, he bought lights with ballasts and adapter wire from kufatec, but there is no instructions from kufatec, and they are pointing to C6 bi xenon as guide :banghead:
on adapter there is left and right high beam wire which needs to be connected and also one more wire which goes to both headlights maybe LIN?!
any info on where to connect wires and coding, need help!
ignore climatronic errors, he tried to fit 4 zone digital climatronic to dual zone :D
Tuesday,12,April,2016,20:12:31:03082
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
Dealer/Shop Name: m87a
Workshop Code: 011 01357 012345
VIN: WAUZZZ4G7CN026365   License Plate:
Chassis Type: 4G (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 3B 42 44 46 52 53 56 5F 62
          72
VIN: WAUZZZ4G7CN026365   Mileage: 140507km-87307miles
Address 01: Engine (J623-CDUC)       Labels: 059-907-401-V2.clb
   Part No SW: 4G0 907 401 F    HW: 4G0 907 401
   Component: 3.0TDI EDC17  H37 0004
   Revision: 53H37---
   Coding: 0A254012040601020000
   Shop #: WSC 02311 785 00200
   ASAM Dataset: EV_ECM30TDI0114G0907401F 001004
   ROD: EV_ECM30TDI0114G0907401F.rod
   VCID: 2649B4DD59EB070E24-8072
Address 02: Auto Trans (J217)       Labels: 0B5-927-156.clb
   Part No SW: 4G1 927 156 B    HW: 0B5 927 156 F
   Component: 0B5 30 TDIRdW H10 0001
   Revision: --H10---    Serial number: 0000000958
   ASAM Dataset: EV_TCMDL501 A02087
   ROD: EV_TCMDL501.rod
   VCID: 2C5D46F547073D5EF2-8078
Address 03: ABS Brakes (J104)       Labels: 4G0-907-379-V1.clb
   Part No SW: 4G0 907 379 F    HW: 4G0 907 379 F
   Component: ESP PREMIUM   H09 0250
   Coding: 27A68701E465E180CB00
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESPPremiAU57X 004017
   ROD: EV_ESPPremiAU57X_AU57.rod
   VCID: 346D5E959F37659EAA-8060
   Part No SW: 4H0 907 064 BG    HW: 4H0 907 064 BG
   Component: BCM2 2.0      H31 0330
   Coding: 01A83006000000000000
   VCID: 6FE791F9BE91064697-803A
Address 08: Auto HVAC (J255)       Labels: 4G0-820-043-4Z.clb
   Part No SW: 4G0 820 043 K    HW: 4G0 820 043 K
   Component: KLIMA 4 ZONEN H11 0054
   Serial number: 25101000040012
   Coding: 3613007884
   Shop #: WSC 06765 128 28888
   ASAM Dataset: EV_AirCondiComfoUDS 002027
   ROD: EV_AirCondiComfoUDS.rod
   VCID: 2757B9D95EE11E061F-8072
20 Faults Found:
0020 - Motor for Fresh Air / Recirculated Air Flap
          B11AF 31 [009] - No Signal
                    Reset counter: 250
                    Mileage: 140507 km
                    Date: 2016.04.12
                    Time: 20:09:05
0021 - Motor for Fresh Air / Recirculated Air Flap
          B11AF 29 [009] - Signal Implausible
                    Reset counter: 250
                    Mileage: 140507 km
                    Date: 2016.04.12
                    Time: 20:09:04
0036 - Motor for Recirculation Flap
          B1092 31 [009] - No Signal
                    Reset counter: 250
                    Mileage: 140507 km
                    Date: 2016.04.12
                    Time: 20:09:05
0037 - Motor for Recirculation Flap
          B1092 29 [009] - Signal Implausible
                    Reset counter: 250
                    Mileage: 140507 km
                    Date: 2016.04.12
                    Time: 20:09:04
0053 - Motor for Left Side Vent Flap
          B10C9 29 [009] - Signal Implausible
                    Reset counter: 250
                    Mileage: 140507 km
                    Date: 2016.04.12
                    Time: 20:09:04
0061 - Motor for Right Side Vent Flap
          B10CA 29 [009] - Signal Implausible
                    Reset counter: 250
                    Mileage: 140507 km
                    Date: 2016.04.12
                    Time: 20:09:04
0076 - Motor for Right Footwell Flap
          B10BA 31 [009] - No Signal
                    Reset counter: 250
                    Mileage: 140507 km
                    Date: 2016.04.12
                    Time: 20:09:05
0077 - Motor for Right Footwell Flap
          B10BA 29 [009] - Signal Implausible
                    Reset counter: 250
                    Mileage: 140507 km
                    Date: 2016.04.12
                    Time: 20:09:04
0101 - Positioning Motor for Temperature Flap; Rear Left
          B1169 29 [009] - Signal Implausible
                    Reset counter: 250
                    Mileage: 140507 km
                    Date: 2016.04.12
                    Time: 20:09:04
0108 - Positioning Motor for Temperature Flap; Rear Right
          B116A 31 [009] - No Signal
                    Reset counter: 250
                    Mileage: 140507 km
                    Date: 2016.04.12
                    Time: 20:09:05
0109 - Positioning Motor for Temperature Flap; Rear Right
          B116A 29 [009] - Signal Implausible
                    Reset counter: 250
                    Mileage: 140507 km
                    Date: 2016.04.12
                    Time: 20:09:04
0164 - Motor for Left B-Pillar / Footwell Shut-Off Flap
          B10D1 31 [009] - No Signal
                    Reset counter: 250
                    Mileage: 140507 km
                    Date: 2016.04.12
                    Time: 20:09:05
0165 - Motor for Left B-Pillar / Footwell Shut-Off Flap
          B10D1 29 [009] - Signal Implausible
                    Reset counter: 250
                    Mileage: 140507 km
                    Date: 2016.04.12
                    Time: 20:09:04
0172 - Motor for Right B-Pillar / Footwell Shut-Off Flap
          B10D2 31 [009] - No Signal
                    Reset counter: 250
                    Mileage: 140507 km
                    Date: 2016.04.12
                    Time: 20:09:05
0173 - Motor for Right B-Pillar / Footwell Shut-Off Flap
          B10D2 29 [009] - Signal Implausible
                    Reset counter: 250
                    Mileage: 140507 km
                    Date: 2016.04.12
                    Time: 20:09:04
0192 - Position Sensor in Left Side Vent
          B10E3 15 [009] - Open or Short to Plus
                    Reset counter: 250
                    Mileage: 140507 km
                    Date: 2016.04.12
                    Time: 20:09:04
0194 - Position Sensor in Left Center Vent
          B10E1 15 [009] - Open or Short to Plus
                    Reset counter: 250
                    Mileage: 140507 km
                    Date: 2016.04.12
                    Time: 20:09:04
0196 - Position Sensor in Right Center Vent
          B10E2 15 [009] - Open or Short to Plus
                    Reset counter: 250
                    Mileage: 140507 km
                    Date: 2016.04.12
                    Time: 20:09:04
0198 - Position Sensor in Right Side Vent
          B10E4 15 [009] - Open or Short to Plus
                    Reset counter: 250
                    Mileage: 140507 km
                    Date: 2016.04.12
                    Time: 20:09:04
0272 - No Basic Setting
          B2010 00 [009] -  -
                    Reset counter: 250
                    Mileage: 140507 km
                    Date: 2016.04.12
                    Time: 20:09:04
Address 09: Cent. Elect. (J519)       Labels: 4H0-907-063-V1.clb
   Part No SW: 4H0 907 063 BA    HW: 4H0 907 063 A
   Component: BCM1 2.0      H12 0100
   Revision: 12012002    Serial number: 00000001122447
   Coding: 690000108034A7E00105008000005F5F0F9CC20826080101000004402001
   VCID: 68D5FAE59B7FD17ED6-803C
   Component: WWS57X 110620  H35 0051
   Coding: 0045F7
   Component: RLS  H04 0003
   Coding: 02512B
   Subsystem 3 - Part No SW: 4G0 941 531     HW: 4G0 941 531
   Component: E1 - LDS  H07 0044
   Subsystem 4 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
   Component: Humidity_Sens  H02 0002
                    Fault Status: 01101100
                    Reset counter: 250
                    Mileage: 140507 km
                    Date: 2016.04.12
                    Time: 20:09:00
                    Reset counter: 250
                    Mileage: 140507 km
                    Date: 2016.04.12
                    Time: 20:09:00
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 250
                    Mileage: 140507 km
                    Date: 2016.04.12
                    Time: 20:09:00
Address 10: Park/Steer Assist (J446)       Labels: 4H0-919-475-7X2.clb
   Part No SW: 4H0 919 475 L    HW: 4H0 919 475 C
   Component: PARKHILFE ACC H07 0043
   Revision: 11001001    Serial number: 55901119200312
   Coding: 080305
   ASAM Dataset: EV_EPHVA18AU57X0000 002005
   ROD: EV_EPHVA18AU57X0000.rod
   VCID: 3B7F75A9B269AAE66B-806E
Address 15: Airbags (J234)       Labels: 4H0-959-655.clb
   Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
   Component: Airbag10.43   H40 0040
   Revision: --------    Serial number: 003JG0037TNE
   Coding: 30323436313330303333554A304C34473053
   ROD: EV_AirbaAU10BPAAU64X_AU57.rod
   VCID: 3669649D894B778E94-8062
   Serial number: 3575HRB405P0INGS7G35
   Serial number: 3585HRB405R0IDFKAHE4
   Serial number: 3515JRB40670J7IAC8B1
   Serial number: 3525JRB40510JNPM21CE
   Serial number: 3554VRB405D0JNPM78A7
   Serial number: 3564VRB405H0JNPMBGES
Address 16: Steering wheel (J527)       Labels: 4H0-953-568.clb
   Part No SW: 4H0 953 568 E    HW: 4H0 953 568 E
   Revision: --------    Serial number: 90372KG40004J
   Coding: 000010
   VCID: 356B63919C4D7C969D-8060
   Subsystem 1 - Part No SW: 4G0 951 528 D    HW: 4G0 951 528 D
   Component: E221 - MFL  H07 0009
Address 17: Instruments (J285)       Labels: 4H0-920-xxx-17.clb
   Part No SW: 4G8 920 931 E    HW: 4G8 920 931 E
   Component: TDieRdw       H71 0375
   Revision: 26181114    Serial number: 658130711593028
   Coding: 0386090003010008040000
   ASAM Dataset: EV_RBD4K 004040
   ROD: EV_RBD4K.rod
   VCID: 306552856B2F59BECE-8064
   Part No SW: 4G0 907 468 D    HW: 4G0 907 468
   Component: J533--Gateway H08 0213
   Revision: --------    Serial number: 00000000190477
   Coding: 00CD077D00
   ROD: EV_GatewUDS_AU57.rod
   VCID: 31635781602550B6C1-8064
   Subsystem 1 - Part No SW: 8X0 915 181     HW: 8X0 915 181
   Component: J367-BDM  H07 0140
   Serial number: 00000000005650828983
   Voltage stabilizer:
   Part No SW: 4G0 907 637     HW: 4G0 907 637
   Component: SARA 3D       H02 0004
   Revision: --------    Serial number: EJ1BPA3200B7BS0
   ASAM Dataset: EV_SARA 006014
   ROD: EV_SARA.rod
   VCID: 6BDF85E98289FA66BB-803E
   Part No SW: 4G8 959 793 E    HW: 4G8 959 793 A
   Component: TSG FA        H05 0212
   Coding: 011C16205000620002080002
   VCID: 4281084DDD83DB2E28-8016
Address 44: Steering Assist (J500)       Labels: 8K0-909-144.clb
   Component: RCEPS         H33 0010
   Revision: 00001000    Serial number: 0004092581
   Coding: 101000010000
   Shop #: WSC 00839 264 186832
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS.rod
   VCID: 3261588D65236BAEB8-8066
Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.clb
   Revision: 00002001    Serial number: 0151568042
   Coding: 0100062000B9048083200804000100000000000000000000000000000000
   Part No SW: 4G8 959 792 E    HW: 4G8 959 792 A
   Component: TSG BF        H05 0212
   VCID: 41830741D885C03631-8014
   Part No SW: 4H0 907 801 E    HW: 4H0 907 801 A
   Component: EPB-4         H03 0012
   Revision: --------    Serial number: 00000000102462
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 2A5140ED4DF3236E00-807E
   Part No SW: 4G0 035 056 C    HW: 4G0 035 056
   Component: Radio U STD   H52 0079
   Revision: AB001007    Serial number: 051GX0B7523664
   Coding: 010003020100000001
   VCID: 2143A7C138C5E03651-8074
   Part No SW: 4G0 035 666 C    HW: 4G0 035 666
   Component: H-BN-EU       H47 0382
   Revision: --------    Serial number: 426G/0B7604486
   Coding: 050100000003A1ED05008B3E00000003E00101020000000000
   VCID: 2855BAE55BFF117E16-807C
   Subsystem 1 - Part No: 8R0 060 884 N
   Component: EUR 2011  1205
   Subsystem 2 - Part No SW: 4G0 919 605 A    HW: 4G0 919 605 A
   Component: DU8 C7 SV  H42 0021
   Subsystem 3 - Part No SW: 4G1 919 610 A    HW: 4G1 919 610 A
   Component: E380 BDT C7  H08 0203
   Component: CD-Database  3371
   Part No SW: 4G8 959 795 E    HW: 4G8 959 795 A
   Component: TSG HL        H04 0212
   Coding: 010814204000620002080002
   VCID: 448D0E55C797D51E1A-8010
   Component: TSG HR        H04 0212
End-------------------------(Elapsed Time: 03:51)--------------------------
m87a
C?ID=156900
Google translated from german, kufatec guide for anyone looking, might help ;)
LIN bus on pin 1 to 16 pin connector terminals (top left)
Pin 3 (A6 4G) or PIN 8 (A7 4G) LED Headlamp
connector (beige), Pin 12 (driver's side)  plug (red) Pin 2 (passenger side)
Pin 5 (A6 4G) or PIN 13 (A7 4G) LED headlights (only with 39807-2, 40190-1)
connector (beige), pin 8 (driver's side)  plug (red) Pin 8 (passenger side)
Adresse 09:
Byte 00 - HEX 09
Byte 01 - HEX 07
Byte 04 - HEX 09
Byte 14 - HEX 18
Byte 15 - HEX 00
Byte 21 - Bit 0 on 0
Byte 25 - HEX 01
Byte 27 - HEX 54
Byte 28 - Bit 0, 1, 2, 3
Adresse 20 (if any):
Byte 0 - HEX 04
Adresse 85 (if any):
Byte 0 - Bit 2 auf 0
Sub bus part number LED module (at address 09):
Byte 00 - HEX 11
Adjustment in address 09:
Channel 3 - 26
Security Code: 20113
m87a
C?ID=156900
replaced central electronic with 4H0 907 063 BG which support lin bus for headlights, old one BA didn't, I can access and code led modules only if light switch is at city light or low beam position otherwise there is no communication probably because of voltage.
it seems that adapter is not complete or more wires pins need to be swapped, also noticed fog lights are on as drl even if the led drl are coded.
at full led headlights fog is a part of headlight not independent, maybe wires needs to be re pined from fog to drl???
also high beams wire can't be put to these pins because its already occupied?
anybody any info about led drl pins or fog lights?
m87a
C?ID=156900
does anybody have access to diagrams of a6? need halogen and full led diagrams to compare
Audi1
C?ID=19191
Did you ever finish this retrofit?
m87a
C?ID=156900
no i didn't, i gave up, no diagram and no info but my friend has finished it, when asked how he didn't want to answer :(
Audi1
C?ID=19191
Ah, that sucks!
I May have the diagram you needed. I am doing the retrofit myself, but can't get the high beams to work.
m87a
C?ID=156900
post or send diagram :)
for high beams check if you physically have pins on bcm, he didn't so he had to replace bcm
