- May 13, 2014
- 51
- 9
- C?ID=214777
Hi,
Since few weeks ago I am getting a message about
001089 — EVAP Emission Control Sys
and
001674 — ECM Power Relay Load Circuit: (J271)
Since today I even got a yellow led on my dashboard.
The led is "Control system for exhaust"
I afraid that all of this are related to the LED. if not please advise regarding each....
Thanks!!
and
Friday,23,May,2014,18:34:05:40508
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
Dealer/Shop Name: Big-Byte
VIN: TMBBK61Z7B8022701 License Plate:
Chassis Type: 1Z (7N0)
Address 01: Engine (CDA) Labels: 06J-907-115-CDA.clb
Part No SW: 3T0 907 115 G HW: 1Z0 907 115 F
Component: 1.8l R4/4V TFSI 0030
Revision: AAH18--- Serial number:
Coding: 0203000C24070060
Shop #: WSC 64888 768 16448
VCID: 356136445CDF4AB6781-8060
001089 - EVAP Emission Control Sys
P0441 - 000 - Incorrect Flow - MIL ON
Fault Status: 11100000
Mileage: 65654 km
Date: 2001.14.26
Time: 15:56:53
RPM: 838 /min
Load: 19.2 %
Temperature: 96.0°C
Temperature: 51.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 13.589 V
001674 - ECM Power Relay Load Circuit: (J271)
P068A - 000 - De-Energized Performance Too Early - Intermittent
Date: 2047.15.31
Time: 31:63:63
Temperature: 96.0°C
Temperature: 60.0°C
Voltage: 9.144 V
Address 02: Auto Trans Labels: 0AM-300-04x.lbl
Part No SW: 0AM 300 050 E HW: 0AM 927 769 D
Component: GSG DSG AG7 431 2673
Revision: 00043014 Serial number: CU501307285442
Shop #: WSC 00029 730 29360
VCID: 2B55103C8A9B0C461E5-807E
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Coding: 113B401C092400FC881202E4901A0041350800
Shop #: WSC 73430 790 00000
VCID: 76E3F148C15901AEB1B-8023
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 3T0 907 044 AR HW: 3T0 907 044 AR
Component: Climatronic H15 0401
Revision: 00005001
Coding: 0000000002
Shop #: WSC 73430 790 00999
ROD: EV_ClimaAutoBasis_SE36.rod
VCID: 820B1D981591AD0E0D3-80D7
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 087 J HW: 1K0 937 087 J
Component: BCM PQ35 H 103 0615
Revision: 00103 AD
Coding: 40180AB8802100C0000A00810000810042E134FE505D89205C0648800040
VCID: 387F3F708BCDB7DE637-806D
Subsystem 1 - Part No: 1Z1 955 119 D Labels: 1KX-955-119.CLB
Component: Wischer 18101 26 0601
Coding: 00DFB7
Reset counter: 198
Mileage: 65604 km
Date: 2001.14.25
Time: 20:32:27
Voltage: 12.00 V
Term 50 Off
01503 - Bulb for 3rd Brake Light (M25)
Fault Status: 00100111
Fault Frequency: 16
Reset counter: 239
Mileage: 65604 km
Date: 2001.14.25
Time: 21:09:22
Voltage: 13.25 V
Term 50 Off
02661 - Wire for Speed Signal
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 198
Mileage: 65604 km
Date: 2001.14.25
Time: 21:09:36
Voltage: 13.40 V
Term 50 Off
Component: Q6 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PC212XEE
Coding: 0020790
VCID: 3D712E6464EF92F6B01-8068
Subsystem 1 - Serial number: 6332MSME583233702
Subsystem 2 - Serial number: 6342MSME583233679
Subsystem 3 - Serial number: 6351HSME24654321.
Subsystem 4 - Serial number: 6361HSME24635D078
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 521 AR HW: 5K0 953 569 A
Component: LENKS.MODUL 009 0136
Revision: FF010039 Serial number: 20101008301625
Coding: 1882004000
ASAM Dataset: EV_SMLSNGVOLWS A01004
ROD: EV_SMLSNGVOLWS.rod
VCID: 7CF7E360F7755BFEC7F-8029
Subsystem 1 - Part No SW: 3T0 959 537 HW: 3T0 959 537 Labels: 3C8-959-537.CLB
Component: E221__MFL-URO H07 0012
Coding: 800000
Part No SW: 1Z0 920 843 K HW: 1Z0 920 843 K
Component: KOMBI H20 0420
Coding: 110901
Shop #: WSC 73430 031 12345
ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
VCID: 408F5790DB1DFF1EDB7-8015
Address 19: CAN Gateway Labels: 7N0-907-530-V1.clb
Part No SW: 7N0 907 530 HW: 1K0 907 951
Component: J533 Gateway H27 5603
Revision: H27 Serial number: 161010F2002537
Coding: ED807F0600020200001302
VCID: EDD15E24F40F4276C01-80B8
Component: IMMO H20 0420
ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
VCID: EADB55380DE1554EA53-80BF
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1T0 959 701 AA HW: 1T0 959 701 AA
Component: Tuer-SG 009 2119
Coding: 0004342
VCID: 76E3F148015901AEB1B-8023
00131 - Outside Door Handle Illumination/mirror Light Driver Side
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 69 3001
Revision: 00H17000
VCID: 31690254A8B76696249-8064
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1T0 959 702 S HW: 1T0 959 702 S
Coding: 0004342
VCID: 489F4FB03B2DC75E137-801D
00132 - Outside Door Handle Illumination/mirror Light Passenger Side
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1Z0 035 161 F HW: 1Z0 035 161 F
Component: SWING 009 0065
Revision: 0I001001 Serial number: SKZ1Z2K8411072
Coding: 050004000004
VCID: 3169025468B76696249-8064
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 5K0 959 703 A HW: 5K0 959 703 A
Component: Tuer-SG 007 2101
Coding: 0000144
Shop #: WSC 73430 790 1012544
VCID: 326B0D58ADB15D8E5D3-8067
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 5K0 959 704 A HW: 5K0 959 704 A
Coding: 0000144
VCID: 3365085C52AB5486565-8066
End ---------------------------------------------------------------------
