Fault Frequency and Reset Counter
KarelM
CZ
C?ID=94707
Please, could you explain me items Fault Frequency: 94 and Reset counter: 104 in the some fault detected by VCDS?
And second question: What are values of Fault Frequency and Reset Counter when I clear fault code (after fixing the problem that caused the fault)? 0 and 0? Or these values remain in memory?
KarelM
CZ
C?ID=94707
I read Manual before asking, but I didn´t understand it. So, can you describe this by other words, by use of some typical example?
And also I didn´t find answer to my second question in this Manual. Thanks.
I don't know how to express it in a way that is more understandable than it already is in the manual, sorry.
When you clear faults, the data in question is gone.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
This is actually something I talk extensively about during training classes. Those values can be a great tool when trying to understand fault codes. :)
Control modules run tests for all sorts of components at least once during a drive cycle (a drive cycle usually starts with the ignition being switched on and ends with the ignition off AND the drivers door opened). Every time a one of those tests fails, the control module will increase the fault frequency by one. The reset counter works the opposite way, once a fault code is stored - every time one of those tests passes w/o an error being detected and the drive cycle is finished w/o a problem, the reset counter will decrease by one. Once it reaches zero (meaning there have been numerous drive cycles w/o problems), the DTC is automatically cleared from the control modules memory.
The idea behind both values is to help the technician understand how frequent the issue has come up and in cases where it was just a fluke, to not bother with it in the first place. In the US typical service intervals are only 5,000 miles but in Europe we have seen up to 60,000 km between oil changes (Audi A2 was one of those), effectively this means some cars will not have their fault codes read for up to 2 years and 60,000 km's - so in a worst case scenario, every code that may have come up would be stored forever - essentially overloading the fault memory and in the end the technician with information. Consider these values to help you filter what is important and what is not. :)
KarelM
CZ
C?ID=94707
Thanks for your clear and simple explanation and also for definition of drive cycle. One additional question: If the same fault is apeared e.g. five times during one cycle, it means that the value of the control module will increase the fault frequency by one or by five? From your text follows that by one. Am I right?
Sebastian: Notwithstanding the "tyranny of distance", if the relationship between Ross-Tech and Australia matures and expands (as hopefully it will) to the degree where you find yourself giving training classes in the Antipodes, please let me know - I will be your first student to enrol!!
PS: However, I will require a seat in the front row, but I promise to limit my questions to no more than 10 x A4 sheets (the font-size to be determined by me)!
Sebastian
Magdeburg, Germany
HN0-nnnnnn
@KarelM, every time a condition for a DTC is met it the fault frequency is increased by one - this may happen multiple times during a drive cycle. The other way around, the reset counter will only decrease by one per drive cycle.
@DV52, there is actually a plan for remote sessions - it will be an interesting year. :) From experience, there are no dumb questions - just dumb answers. ;)
SwissJetPilot
Switzerland
C?ID=317276
How would I determine how many times in the past a DTC was reported on a given address if all the DTCs have been cleared?
VCDS -- Windows Based VAG/VAS Emulator Running on Windows Vista x64
VCDS Version: 17.8.0.1 (x64)  HEX-V2 CB: 0.4401.4
VIN: TRUXXXXXXXXXXXX   License Plate:
Mileage: 84790km-52686mi   Repair Order:
Chassis Type: 8J (1K0)
Scan: 01 02 03 08 09 14 15 16 17 19 22 25 26 37 42 44 46 47 4C 52
          55 56 77
VIN: TRUXXXXXXXXXXXX   Mileage: 84790km-52686miles
37-Navigation -- Status: Malfunction 1010
Address 01: Engine        Labels: 022-906-032-BDB.lbl
   Part No SW: 022 906 032 HJ    HW: 022 906 032 GP
   Component: MOTRONIC ME7.1.1G   0672
   Revision: --H02---    Serial number: AUX7Z0FNFNO025
   Coding: 0000178
   Shop #: WSC 01236 785 00200
   VCID: 5AEC62511019F94775E-800E
   Part No SW: 02E 300 011 BL    HW: 02E 927 770 AD
   Component: GSG DSG         082 1397
   Revision: 05308020    Serial number: 00001101290813
   Shop #: WSC 44551 111 44551
Address 03: ABS Brakes        Labels: 8J0-614-517.clb
   Part No SW: 8J0 614 517     HW: 8J0 614 517
   Component: ESP MK60E1          0130
   Revision: 00H52001
   Coding: 0026177
   VCID: 6A8C3291C07969C7E5E-803E
   Part No SW: 8J0 820 043 S    HW: 8J0 820 043 S
   Component: J255  Klima 1 Zone  0060
   Revision: 00H07003    Serial number: 00000001024259
   Coding: 1048838
   VCID: 3634D6E1C441FD27B16-8062
Address 09: Cent. Elect.        Labels:. 8P0-907-279-23-H.lbl
   Part No SW: 8P0 907 279 H    HW: 8P0 907 279 H
   Component: Bordnetz-SG     H46 1802
   Revision: 00H46000    Serial number: 00000006498723
   Coding: 11060E8380141C0003180000180000000009EE075A250802
   VCID: 42DCBA31988951870DE-8016
   Subsystem 1 - Part No: 8J1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer AU354   H05 0060
   Coding: 00064784
   Shop #: WSC 01236
10 Faults Found:
03099 - Rear Right Turn Signal Lamps (M8)
                    Fault Status: 00101100
                    Reset counter: 83
                    Mileage: 84727 km
                    Date: 2017.09.16
                    Time: 09:59:00
                    Voltage: 11.75 V
                    Reset counter: 83
                    Mileage: 84530 km
                    Date: 2017.08.02
                    Time: 17:55:00
                    Voltage: 12.10 V
                    Reset counter: 83
                    Mileage: 84727 km
                    Date: 2017.09.16
                    Time: 09:56:00
                    Voltage: 12.10 V
00984 - Left Tail Light (M4)
                    Fault Frequency: 28
                    Reset counter: 83
                    Mileage: 73639 km
                    Date: 2016.09.07
                    Time: 15:46:00
                    Voltage: 13.40 V
00985 - Right Tail Light (M2)
                    Reset counter: 83
                    Mileage: 84727 km
                    Date: 2017.09.16
                    Time: 09:56:00
                    Voltage: 12.10 V
                    Reset counter: 83
                    Mileage: 84727 km
                    Date: 2017.09.16
                    Time: 12:17:00
                    Voltage: 11.85 V
                    Fault Status: 00101010
                    Reset counter: 83
                    Mileage: 84727 km
                    Date: 2017.09.11
                    Time: 18:29:00
                    Voltage: 11.90 V
                    Reset counter: 83
                    Mileage: 84727 km
                    Date: 2017.09.11
                    Time: 18:59:00
                    Voltage: 11.90 V
03098 - Rear Left Turn Signal Lamp (M6)
                    Reset counter: 83
                    Mileage: 84727 km
                    Date: 2017.09.16
                    Time: 09:59:00
                    Voltage: 11.75 V
                    Reset counter: 83
                    Mileage: 84727 km
                    Date: 2017.09.16
                    Time: 09:59:00
                    Voltage: 11.75 V
Address 14: Susp. Elect.        Labels: 8P0-907-376.lbl
   Part No SW: 8J0 910 376     HW: 8J0 907 376 A
   Component: J250 Raddaempfung   0050
   Revision: --H16---    Serial number: 190DPH 6286036
   Coding: 0000014
   VCID: 6C803489CA8D77F7972-8038
Address 15: Airbags        Labels: 8J0-959-655.lbl
   Part No SW: 8J0 959 655     HW: 8J0 959 655
   Component: -s Airbag 9.43  H02 0020
   Revision: 93H02002    Serial number: 0036K000LPMB
   Coding: 0011635
   VCID: 79AE1DDDB5DFD25F1C4-802C
   Subsystem 1 - Serial number: 6332DRB404784E12N
   Subsystem 2 - Serial number: 6342DRB4047DD29C1
   Subsystem 3 - Serial number: 63729RB401E3149CR
01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
                    Fault Status: 00101001
                    Reset counter: 64
                    Mileage: 81732 km
                    Date: 2017.05.20
                    Time: 19:02:22
Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
   Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
   Component: J0527           H36 0070
   Coding: 0013141
   VCID: 41DEB53D9D8F4A9F144-8014
   Component: E0221           H06 0030
Address 17: Instruments        Labels: 8J0-920-xxx-17-MY7.lbl
   Part No SW: 8J0 920 930 C    HW: 8J0 920 930 C
   Component: KOMBIINSTR. VDO H21 0070
   Revision: D0H21004    Serial number: 224NF004018275
   Coding: 0081018
   Shop #: WSC 30842 001 1048576
   VCID: 2C00F4890A0DB7F7D72-8078
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Component: J533__Gateway   H12 0170
   Revision:   H12       Serial number: 3300106B22025F
   Coding: FF0F23CA67005100
   VCID: 2F3AE3853B1BCCEFF20-807A
                    Reset counter: 64
                    Mileage: 81732 km
                    Date: 2017.05.20
                    Time: 13:51:20
01304 - Radio
                    Reset counter: 64
                    Mileage: 81732 km
                    Date: 2017.05.20
                    Time: 13:51:21
Address 22: AWD        Labels: 1K0-907-554.lbl
   Part No: 1K0 907 554 L
   Component: Haldex 4Motion      0116
   Coding: 0000001
   Revision: D0H21004    Serial number: AUX7Z0FNFNO025
Address 26: Auto Roof        Labels: 8J7-959-255.lbl
   Part No: 8J7 959 255 B
   Component: 256 VSG TT      H13 0100
   VCID: 3E24CEC1EC713567696-806A
Address 37: Navigation        Labels: 8E0-035-192-RNSE.clb
   Part No SW: 8J0 035 192     HW: 8J0 035 192
   Component: RNS-E HIGH EU   H10 0650
   Revision:      01S    Serial number: AUZBZ7G3500391
   Coding: 0619717
   Shop #: WSC 23321 823 59458
   VCID: 669446A1D4614DA7C16-8032
                    Fault Status: 00101011
                    Reset counter: 64
                    Mileage: 81732 km
                    Date: 2017.05.20
                    Time: 13:49:02
                    Mileage: 81730 km
                    Count: 2105
                    Clock: 12:08
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MAX1.lbl
   Part No: 8J7 959 801 C
   Component: Tuer-SG         H02 0060
   Coding: 0000053
   VCID: 3C20C4C9FA6D2777472-8068
   Part No: 8J1 909 143 B
   Component: EPS_ZFLS Kl.155 H07 1807
Address 46: Central Conv.        Labels:. 8J0-959-433.lbl
   Part No: 8J0 959 433
   Component:    KSG          H07 0070
   Coding: 9890300241182D098505488AD673
   VCID: 73B22FF597B3A80F568-8026
   Subsystem 2 - Part No: 8J0 951 177
   Component: DWA-Sensor      H03 0020
00955 - Key 1
Address 47: Sound System        Labels: 8J0-035-223.lbl
   Part No SW: 8J0 035 223 C    HW: 8J0 035 223 C
   Component: J525 Amp High   H04 0110
   Revision: PROD_01     Serial number: 00000000003111
   Coding: 0246126
   VCID: 24101CA962DD7FB71F2-8070
01304 - Radio
                    Reset counter: 66
                    Mileage: 81732 km
                    Date: 2017.05.20
                    Time: 19:02:23
Address 4C: Tire Pressure II        Labels: 8J0-907-274.lbl
   Part No SW: 8J0 907 274     HW: 8J0 907 274
   Component: J502  RKA+      H04 0130
   Coding: 0614100
   VCID: 6FBA2385FB9B8CEFB20-803A
Address 52: Door Elect, Pass.        Labels: 8P0-959-802-MAX1.lbl
   Part No: 8J7 959 802 C
   Coding: 0000053
   VCID: 3D26C9CDE1772E7F70C-8068
   Part No: 8P0 907 357 G
   Coding: 0000011
                    Fault Status: 11100101
                    Reset counter: 44
                    Mileage: 84792 km
                    Date: 2017.09.24
                    Time: 16:51:39
Address 56: Radio        Labels: 8E0-035-192-RNSE.clb
   Coding: 0619717
                    Reset counter: 64
                    Mileage: 81732 km
                    Date: 2017.05.20
                    Time: 13:49:02
                    Mileage: 81730 km
                    Count: 2105
                    Clock: 12:08
   Part No SW: 8P0 862 335 H    HW: 8P0 862 335 H
   Component: FSE_255x BT     H26 0290
   Revision: 00000000    Serial number: 00000005063935
   Coding: 0011401
   VCID: 3B22C7D5FF63204F4E8-806E
01304 - Radio
                    Reset counter: 64
                    Mileage: 81732 km
                    Date: 2017.05.20
                    Time: 19:02:24
End----(Elapsed Time: 01:28, VBatt start/end: 11.6V/11.6V. VIgn 11.6V)-----
VCDS Release 17.8.0:  SRI Reset
Control Module Part Number: 8J0 920 930 C       Labels:  8J0-920-xxx-17-MY7.lbl
Component:KOMBIINSTR. VDO H21 0070, Coding:0081018
Channel      Description                                           Unit          Current val.      New val.
02           Service Reminder Status                                             1                 ---
40           Mileage since Service                                 km x100       209               ---
41           Time since Service                                    Days          529               ---
42           Min Mileage to Service                                km x100       150               ---
43           Max Mileage to Service                                km x100       300               ---
44           Max Time to Service                                   Days          730               ---
45           Oil Quality                                                         2                 ---
47           Soot Quantity                                         km x100       0                 ---
48           Thermal Load                                          km x100       501               ---
49           Min Time to Service                                   Days          365               ---
Sunday,24,September,2017,17:52:02:26633
VIN: TRUZZZ8J071020399   License Plate:
          55 56 77
VIN: TRUZZZ8J071020399   Mileage: 84790km-52686miles
   Coding: 0000178
   Revision: 00H52001
   Coding: 0026177
   Coding: 1048838
   Coding: 00064784
   Shop #: WSC 01236
10 Faults Found:
                    Reset counter: 83
                    Mileage: 84727 km
                    Date: 2017.09.16
                    Time: 09:59:00
                    Voltage: 11.75 V
                    Reset counter: 83
                    Mileage: 84530 km
                    Date: 2017.08.02
                    Time: 17:55:00
                    Voltage: 12.10 V
                    Reset counter: 83
                    Mileage: 84727 km
                    Date: 2017.09.16
                    Time: 09:56:00
                    Voltage: 12.10 V
                    Fault Frequency: 28
                    Reset counter: 83
                    Mileage: 73639 km
                    Date: 2016.09.07
                    Time: 15:46:00
                    Voltage: 13.40 V
                    Reset counter: 83
                    Mileage: 84727 km
                    Date: 2017.09.16
                    Time: 09:56:00
                    Voltage: 12.10 V
                    Reset counter: 83
                    Mileage: 84727 km
                    Date: 2017.09.16
                    Time: 12:17:00
                    Voltage: 11.85 V
                    Reset counter: 83
                    Mileage: 84727 km
                    Date: 2017.09.11
                    Time: 18:29:00
                    Voltage: 11.90 V
                    Reset counter: 83
                    Mileage: 84727 km
                    Date: 2017.09.11
                    Time: 18:59:00
                    Voltage: 11.90 V
                    Reset counter: 83
                    Mileage: 84727 km
                    Date: 2017.09.16
                    Time: 09:59:00
                    Voltage: 11.75 V
                    Reset counter: 83
                    Mileage: 84727 km
                    Date: 2017.09.16
                    Time: 09:59:00
                    Voltage: 11.75 V
   Coding: 0000014
   Coding: 0011635
                    Reset counter: 64
                    Mileage: 81732 km
                    Date: 2017.05.20
                    Time: 19:02:22
   Coding: 0013141
   Coding: 0081018
                    Reset counter: 64
                    Mileage: 81732 km
                    Date: 2017.05.20
                    Time: 13:51:20
01304 - Radio
                    Reset counter: 64
                    Mileage: 81732 km
                    Date: 2017.05.20
                    Time: 13:51:21
   Coding: 0000001
   Coding: 0619717
                    Reset counter: 64
                    Mileage: 81732 km
                    Date: 2017.05.20
                    Time: 13:49:02
                    Mileage: 81730 km
                    Count: 2105
                    Clock: 12:08
00857 - CD Changer Unit (R41)
                    Reset counter: 84
                    Mileage: 84797 km
                    Date: 2017.09.24
                    Time: 17:48:41
   Coding: 0000053
00955 - Key 1
   Coding: 0246126
01304 - Radio
                    Reset counter: 66
                    Mileage: 81732 km
                    Date: 2017.05.20
                    Time: 19:02:23
   Coding: 0614100
                    Fault Status: 00101101
                    Reset counter: 84
                    Mileage: 84797 km
                    Date: 2017.09.24
                    Time: 17:47:40
                    Hex Value: 0x0000
                    Hex Value: 0x0000
                    Hex Value: 0x0005
                    Voltage: 10.50 V
                    Temperature: 22.0°C
                    (no units): 0.0
   Coding: 0000053
   Coding: 0000011
   Coding: 0619717
                    Reset counter: 64
                    Mileage: 81732 km
                    Date: 2017.05.20
                    Time: 13:49:02
                    Mileage: 81730 km
                    Count: 2105
                    Clock: 12:08
                    Reset counter: 84
                    Mileage: 84797 km
                    Date: 2017.09.24
                    Time: 17:48:41
   Coding: 0011401
01304 - Radio
                    Reset counter: 64
                    Mileage: 81732 km
                    Date: 2017.05.20
                    Time: 19:02:24
End----(Elapsed Time: 01:27, VBatt start/end: 11.8V/11.6V. VIgn 11.6V)-----
I don't know of any way to revive that data once they have been cleared.
morris39
Canada
C?ID=395084
Thanks. Definition of drive cycle is key. It is something (a definition) that cannot be deduced but must be stated up front. I find this often comes up for me as the definition seems too obvious to the narrator but can be a frustrating wall.
I have not seen drive clearly on R-T.
I would suppose it's defined somewhere in one one of the OBD-II/EOBD standards, but I don't know which one, nor do I know what the exact definition is. I'm reasonably confident that starting the engine from cold and driving it enough to get it properly warmed up would constitute a drive cycle. I'm not sure how much less that that would count.
Bruce
Near Philadelphia, PA, USA
  • Informative
morris39
Canada
C?ID=395084
Our friends at OPUS have a page on OBDII drive cycles:
https://www.nyvip.org/PublicSite/OBDII/universal-drive-cycle.html
It does not give a particular list of what must be performed and it suggests the information would be in the vehicle service information. That information would have to be in VAG's erWin data: Official Factory Repair Information
Does thhe NY state document apply specifically to emissions e.g. certain speeds for certain times.
My Service Manual search does not respond to "service cycle"
