Audi q7 dpf regen
Chr15
C?ID=207693
Hi All
Ive a Q7 with a flashing coil light and DPF Codes.
I'm unable to achieve a regen on it and just hoping for someone to point out what i'm doing wrong.
BTW I've tried a few times without success
MVB 007.2 Oil Temp higher than 70deg each time
MVB 104.3 51.5
I've followed instructions for UDS and CAN protocols (just in case I was wrong in thinking it should be done CAN procedure)
UDS Method: Coding not accepted (end of that method)
CAN Method: Security access accepted. Basic settings, select dpf service regen and i get [1] [BRAKES] [10 TIMES] that changes to ABORT (Am I doing something wrong on this screen??)
Friday,08,April,2016,12:25:23:26527
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
VIN: WAUZZZ4LX8D055787   License Plate: MH08 JPU
Mileage: 171920km-106826mi   Repair Order:
Chassis Type: 4L (4L0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 18 19 42 46 47 4F 52 56 61
          62 6F 72 76 77
VIN: WAUZZZ4LX8D055787   Mileage: 171920km-106826miles
6F-Centr. Conv. II -- Status: Malfunction 0010
Address 01: Engine (CAS)       Labels: 059-907-401-CAT1.clb
   Part No SW: 4L1 910 401 D    HW: 4L0 907 401 A
   Component: 3.0TDI EDC17G100AG  0080
   Revision: --H01---    Serial number:
   Coding: 0121002C190F0168
   Shop #: WSC 03472 000 1048576
   VCID: 2447E8B6E7BC601E3A-8070
009263 - Diesel Particulate Filter (Bank 1)
               P242F - 001 - Restricted/Clogged - MIL ON
                    Fault Status: 11100001
                    Mileage: 171929 km
                    Date: 2016.04.08
                    Time: 11:21:12
                    RPM: 777 /min
                    (no units): 42.0
                    (no units): 51.0
                    Mileage: 460 km
                    (no units): 51.7
                    (no units): 27.0
008194 - Particulate Trap Bank 1
               P2002 - 008 - Efficiency Below Threshold
                    Fault Status: 01101000
                    Mileage: 171929 km
                    Date: 2016.04.08
                    Time: 11:21:12
                    RPM: 777 /min
                    (no units): 42.0
                    (no units): 51.0
                    Mileage: 460 km
                    (no units): 51.7
                    (no units): 27.0
Address 02: Auto Trans        Labels: 09D-927-750.lbl
   Part No SW: 09D 927 750 HT    HW: 09D 927 750 HT
   Component: AL 750 6A           1164
   Revision: 00H78000    Serial number:
   Coding: 0000504
   Shop #: WSC 31414 790 00001
   VCID: 071D9F3A764AAB063F-8052
Address 03: ABS Brakes        Labels: 4L0-910-517-V2.clb
   Part No SW: 4L0 910 517 B    HW: 4L0 614 517 D
   Component: ESP ALLRAD MK25E1   0010
   Revision: 00H30001
   Coding: 0099473
   VCID: 2959F982809EBD7609-807C
                    Reset counter: 36
                    Mileage: 171608 km
                    Date: 2016.03.10
                    Time: 10:25:23
                    Count: 2373
                    Count: 128
                    Count: 34560
            000 -  -  - Intermittent
                    Reset counter: 36
                    Mileage: 171608 km
                    Count: 192
                    Count: 2881
                    Count: 297
                    Count: 32000
Address 05: Acc/Start Auth.        Labels: 4F0-910-852.clb
   Part No SW: 4F0 910 852     HW: 4F0 905 852 B
   Component: FBSAUDIC6 ELV   H31 0230
   Revision: 09010701    Serial number: 10601501015181
   Coding: 0000147
   Shop #: WSC 00460 209 83954
   VCID: 63C5ABAAA232272603-8036
   Subsystem 1 - Part No: 4F0 910 131 E
   Component: FBSAUDIC6 EZS   H46 0080
   Subsystem 2 - Part No: 4F0 910 220 D
   Component: FBSAUDIC6 IDG   H01 0040
01176 - Key
                    Reset counter: 36
                    Mileage: 171624 km
                    Date: 2016.04.01
                    Time: 09:32:59
                    Reset counter: 35
                    Mileage: 171606 km
                    Date: 2016.02.25
                    Time: 18:28:54
Address 07: Control Head        Labels: 4L0-910-7xx-07-H.lbl
   Part No SW: 4L0 910 732 F    HW: 4E0 035 729
   Component: Interfacebox    H43 5140
   Revision: 00000000    Serial number: 386BW087556622
   Coding: 0002002
   VCID: 2C5700968F6CA85EF2-8078
   Subsystem 1 - Part No: 4L0 910 609
   Component: E0380 BedienteilH01 0060
   Subsystem 2 - Serial number: 00000001005700
   Subsystem 3 - Serial number: 0125.02.080000000100010974ÿ
   Subsystem 4 - Serial number: 010974ÿ
   Part No SW: 4L0 910 043 B    HW: 4L0 820 043 K
   Component: KLIMABETAETIGUNGH07 0030
   Revision: 00---013    Serial number: 00000030084195
   Coding: 0001046
   VCID: 2345EBAAE2B2672643-8076
                    Reset counter: 36
                    Mileage: 171606 km
                    Date: 2016.02.25
                    Time: 20:03:09
                    Bin. Bits:    01111
                    Reset counter: 36
                    Mileage: 171606 km
                    Date: 2016.02.27
                    Time: 13:55:32
                    Voltage: 11.80 V
            003 - Mechanical Failure
                    Fault Status: 01100011
                    Fault Frequency: 70
                    Reset counter: 6
                    Mileage: 171636 km
                    Date: 2016.04.04
                    Time: 08:36:55
                    Voltage: 13.30 V
                    Temperature: 14.0°C
                    (no units): 174.0
                    (no units): 182.0
                    Temperature: 10.0°C
   Part No SW: 4F0 910 279 K    HW: 4F0 907 279
   Component: ILM Fahrer      H18 0250
   Coding: 0011101
   VCID: 316911E2A84EC5B6C1-8064
   Subsystem 1 - Part No: 4L2 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AU716   H11 0100
   Coding: 00064792
   Shop #: WSC 31414
   Subsystem 2 - Part No: 4E0 910 557 B  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH13 0100
   Coding: 00150059
   Shop #: WSC 31414
                    Reset counter: 36
                    Mileage: 171608 km
                    Date: 2016.03.09
                    Time: 19:21:00
                    Reset counter: 36
                    Mileage: 171608 km
                    Date: 2016.03.09
                    Time: 19:21:00
   Part No SW: 4L0 910 110 B    HW: 4L0 035 110
   Component: MP3-Changer     H45 0390
   Revision: 00045002    Serial number: AUZ5ZBH8324327
   VCID: 1E33DA5EC9D04ACE6C-804A
   Part No SW: 4L0 910 655 D    HW: 4L0 959 655 C
   Component: 71 AIRBAG AUDI8RH42 0230
   Revision: 03H42000    Serial number: 00399D046WG6
   Coding: 0014129
   VCID: 2E530A9EB970DA4EDC-807A
   Subsystem 1 - Serial number: 6332QSME5832221B9
   Subsystem 2 - Serial number: 6342QSME513B4271A
   Subsystem 3 - Serial number: 6352QSME57590A13H
   Subsystem 4 - Serial number: 6362QSME562F0E25R
   Subsystem 5 - Serial number: 63734SME5308401DZ
   Subsystem 6 - Serial number: 63834SME526F41350
   Part No SW: 4F0 910 549 A    HW: 4F0 953 549 D
   Component: J0527               0410
   Revision: 00H03000    Serial number: 90026080400021
   Coding: 0102142
   VCID: 275DFFBA968A8B061F-8072
   Component: E0221           H02 0030
                    Reset counter: 35
                    Mileage: 171608 km
                    Date: 2016.03.09
                    Time: 19:17:28
01426 - Controls in Steering Wheel (E221)
                    Reset counter: 35
                    Mileage: 171608 km
                    Date: 2016.03.09
                    Time: 19:17:34
Address 17: Instruments        Labels: 4L0-910-xxx-17.lbl
   Part No SW: 4F0 910 900 C    HW: 4L0 920 900 J
   Component: KOMBIINSTR. M73 H16 0240
   Revision: 00200000    Serial number: 66X15KW28
   Coding: 3585858
   Shop #: WSC 11111 111 11111
   VCID: 204FE4A6F3A47C3E5E-8074
                    Reset counter: 35
                    Mileage: 171608 km
                    Date: 2016.03.09
                    Time: 19:17:31
Address 18: Aux. Heat        Labels: None
   Part No SW: 4L0 910 105     HW: 4L0 815 071 E
   Component: Heizgeraet      H08 0090
   Revision: 0000000D    Serial number: 00000009014264
   Coding: 0000001
   VCID: 60CFA4A6B3243C3E1E-8034
00456 - Control Module for Access and Start Control (J518)
00664 - Fuel gauge
Address 19: CAN Gateway        Labels: 4L0-910-468.clb
   Part No SW: 4L0 910 468 A    HW: 4L0 907 468 B
   Component: J533__Gateway   H06 0060
   Revision: 00H06000    Serial number: 1100B08219806A
   Coding: F55B9E5730120200
   VCID: 2D510D92B476A156E5-8078
Address 42: Door Elect, Driver        Labels: 4L0-910-793-42.lbl
   Part No SW: 4L0 910 793 B    HW: 4L0 959 793 B
   Component: TSG FA          H12 0150
   Revision: 00-00000
   Coding: 0002651
   VCID: 2F6D179ABE7AD346D7-807A
02111 - Motor for Window Regulator
                    Fault Status: 00100101
                    Reset counter: 36
                    Mileage: 171608 km
                    Date: 2016.03.03
                    Time: 13:50:01
Address 46: Central Conv.        Labels: 4L0-910-289.lbl
   Part No SW: 4L0 910 289 F    HW: 4L0 907 289 C
   Component: Komfortgeraet   H08 0060
   Revision: 0060 ---    Serial number: 01094281140000
   Coding: 4202737
   VCID: 33651BEA5252F7A6B3-8066
   Subsystem 2 - Part No: 4F0 910 177
   Component: Innenraumueberw.H01 0020
   Part No SW: 4L0 910 223 K    HW: 4L0 035 223 C
   Component: DSP-AU716-RD  H07 0270
   Revision: S1000000
   Coding: 030000
   VCID: 2C5700964F6CA85EF2-8078
02246 - Loudspeaker; Center
                    Fault Status: 00101011
                    Reset counter: 45
                    Mileage: 171607 km
                    Date: 2016.02.29
                    Time: 19:27:14
                    Voltage: 11.10 V
                    Temperature: 2.0°C
                    Bin. Bits: 00000010
02558 - Rear Left Mid-Range/Woofer Loudspeaker (R159)
                    Reset counter: 45
                    Mileage: 171607 km
                    Date: 2016.02.29
                    Time: 19:27:14
                    Voltage: 11.10 V
                    Temperature: 2.0°C
                    Bin. Bits: 00000010
02559 - Rear Right Mid-Range/Woofer Loudspeaker (R160)
                    Reset counter: 45
                    Mileage: 171607 km
                    Date: 2016.02.29
                    Time: 19:27:14
                    Voltage: 11.10 V
                    Temperature: 2.0°C
                    Bin. Bits: 00000010
                    Reset counter: 36
                    Mileage: 171608 km
                    Date: 2016.03.09
                    Time: 12:36:11
                    Voltage: 10.80 V
                    Temperature: 9.0°C
                    Bin. Bits: 00000011
                    Reset counter: 46
                    Mileage: 171608 km
                    Date: 2016.03.09
                    Time: 19:20:35
                    Voltage: 9.10 V
                    Temperature: 17.0°C
                    Bin. Bits: 00000011
   Part No SW: 4F0 910 280     HW: 4F0 907 280 E
   Component: ILM Beifahrer   H12 0100
   Revision:             Serial number: 00000000075229
   Coding: 0011101
   VCID: 5EB39A5E89500ACE2C-800A
                    Fault Status: 00110010
                    Reset counter: 36
                    Mileage: 171608 km
                    Date: 2016.03.12
                    Time: 11:54:00
                    Voltage: 6.900 V
                    Temperature: 11.0°C
Address 52: Door Elect, Pass.        Labels: 4L0-910-793-52.lbl
   Part No SW: 4L0 910 793 B    HW: 4L0 959 792 B
   Component: TSG BF          H12 0150
   Revision: 00-00000
   Coding: 0002651
   Part No SW: 4E0 910 541 Q    HW: 4E0 035 541 S
   Component: TUNER EU/US/RDW H42 0620
   Revision: 00000000    Serial number: 388B3087675686
   Coding: 0000001
                    Reset counter: 46
                    Mileage: 171608 km
                    Date: 2016.03.09
                    Time: 19:20:42
Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
   Part No SW: 4L0 910 181 A    HW: 4L0 915 181
   Component: J0644 BEM       H12 0690
   Revision: --------    Serial number: 00000000008440
   Shop #: WSC 00460 209 71808
   VCID: 2541F5B2EC8699162D-8070
   Subsystem 1 - Part No: 4F0 915 105 D
   Component: von VA0  2802201512
   Coding: 344630393135313035442056413032383032323031353132
                    Fault Frequency: 28
                    Mileage: 171606 km
                    Date: 2016.02.25
                    Time: 12:12:04
Address 62: Door, Rear Left        Labels: 4L0-910-795.lbl
   Part No SW: 4L0 910 795 B    HW: 4L0 959 795 B
   Component: TSG HL          H21 0150
   Coding: 0002058
Address 6F: Centr. Conv. II        Labels: 4L0-910-290.lbl
   Part No SW: 4L0 910 290     HW: 4L0 907 290
   Component: ILM HINTEN 2    H05 0060
   Revision: AAH05061    Serial number: 003510083-----
   Coding: 0000001
   VCID: 65C1B5B2AC065916ED-8030
                    Reset counter: 36
                    Mileage: 171608 km
                    Date: 2016.03.09
                    Time: 19:21:22
Address 72: Door, Rear Right        Labels: 4L0-910-795.lbl
   Part No SW: 4L0 910 795 B    HW: 4L0 959 794 B
   Component: TSG HR          H21 0150
   Coding: 0002058
   Part No SW: 4F0 910 283 J    HW: 4F0 919 283 J
   Component: Parkhilfe 4-Kan H09 0100
   Revision: 00H09000    Serial number: 69930804900275
   Coding: 0001146
   VCID: 2B55038A8A62AF66FB-807E
                    Reset counter: 36
                    Mileage: 171608 km
                    Date: 2016.03.12
                    Time: 11:54:11
   Part No SW: 4E0 910 336 K    HW: 4E0 862 335
   Component: Handyvorb2      H18 0950
   Revision: 00000000    Serial number: 00000005105471
   Coding: 0010920
   VCID: 2A5B068E8598B66E00-807E
End-------------------------(Elapsed Time: 02:39)--------------------------
Gone But Not Forgotten
Remove DPF filters and manually remediate............ or try a chemical cleaning beforehand.
Chr15
C?ID=207693
Any recommended cleaners.
I've used a a few different ones but non of them I would recommend as better than any other.
DPF cleaner..........Google and the search tab is your friend, I am not........ just an acquaintance.
Search Sodium Hydroxide........
