- May 16, 2014
- 5,469
- 5,935
- Melbourne, Australia
- C?ID=194404
Vastech: hmm........ apropos of Uwe's suggestion - isn't T20 /14 on the CAN Gateway a T15 supply pin? As shown on your WD, it appears to be a T30 supply. Wired as per your picture, both the 2 x T30 and the T15 pins are energized together. I wonder whether this might be the problem - just guessing?
On the RNS300 in the car, the T15 rail is generated via an electromechanical relay (J329) via the BCM. Perhaps install a single throw, single pole switch in the T30 supply to simulate a T15 signal - maybe (i.e. allow the T30 circuits inside J533 to stabilize before sending the T15 signal)?
If this still doesn't work and as indicated previously, the module wake-up CAN message on the MQB model Golf is created from the ignition key action via the steering module. Not sure if this is the same for your car, but the WD for a mk5 (which uses the RNS300) has the ignition/starter switch directly connected to J527 (the sterring column module). So exactly the same as the Golf mk7.
