I have an MMI3GP bench setup with a NAR MU9498 J794, display, control console, CAN Gateway module, and diagnostics connector. It appears to work, mostly (the main unit, display, and control console all power up, I can run SD scripts, and log into the QNX system from a networked telnet connection) -- but VCDS cannot communicate with Address 5F over the MOST optical bus. VCDS sees the CAN Gateway at Address 19, but that's about it. Note that the J794 MOST LED is visible when it is powered on, but I see no LED lit from the CAN Gateway module when it is powered on.
In this configuration, the main unit shuts down after 10 - 15 minutes or so, regardless of any console activity, and I cannot initiate a software update from the Red Engineering Menu. My goals are to (1) run software updates from the REM and (2) keep the main unit running long enough to complete software updates initated in the REM.
Anyone here with recent experience with bench testing the older MMI3GP system that might offer direction to at least getting VCDS to find the running J794 over the MOST bus ? --g
