I'm trying to setup my own "testbench" and I'm getting there. It's not done yet, but more and more ready
Installed gateway, BCM, cluster, door + passanger module and infotainment 5F system.
All modules are originally from my Touran where I have upgraded some modules except for 5F that I have borrowed from a friend. In the cluster I've took out the speaker. That's is causing the error related to "Internal Control Module Memory Check Sum Error".
My problem is with 09-BCM.
I've added wires to I can "open" driver and passanger door. Rear lid is currently open and hood is closed.
I can turn on ignition - 5F unit says it's on and I can operate it without any problems. Cluster does also turn on. Measuring values in driver door also says the doors are unlocked. Should I've just buy a "safety switch for central locking" eg. 5TA962125 ?
Address 09: Cent. Elect.
Sunday,04,April,2021,00:17:30:21529
VCDS Version: 21.3.0.0 (x64) HEX-V2 CB: 0.4543.4
VIN: WVGZZZ1TZHW03xxxx License Plate: TEST SETUP
Mileage: 64242km-39918mi Repair Order:
Chassis Type: 1T-VW37 (5Q0)
Scan: 09 17 19 42 52 5F
VIN: WVGZZZ1TZHW038734 Mileage: 64242km-39918miles
Part No SW: 5TA 920 750 A HW: 5TA 920 750 A
Component: KOMBI 302 9630
Coding: 078D01000080000801087F000400000000000000
ASAM Dataset: EV_DashBoardJCIMQBAB 009007
ROD: EV_DashBoardJCIMQBAB_009_VW37.rod
VCID: 42DD483DF40A908BD97-8016
7 Faults Found:
9453074 - Fuel Level Sensor 1
B103E 1B [009] - Resistance Too High
Reset counter: 100
Mileage: 64242 km
Date: 2019.11.09
Time: 00:12:58
10485828 - Internal Control Module Memory Check Sum Error
B2000 41 [009] - General checksum failure
[Steuergerät defekt (Fehler durch Selbsttest entdeckt)]
13639936 - Databus
[Steuergerät für BCM / Bordnetz / el. ZE: bitte Fehlerspeicher auslesen]
Reset counter: 100
Mileage: 64242 km
Date: 2019.11.09
Time: 00:12:38
16776962 - Databus
[Airbag_01 keine Kommunikation]
Reset counter: 100
Mileage: 64242 km
Date: 2019.11.09
Time: 00:12:39
16776968 - Databus
[ESP_24 keine Kommunikation]
Reset counter: 100
Mileage: 64242 km
Date: 2019.11.09
Time: 00:12:39
16776971 - Databus
[Motor_04 keine Kommunikation]
Reset counter: 100
Mileage: 64242 km
Date: 2019.11.09
Time: 00:12:38
16776988 - Databus
[TSK_07 keine Kommunikation]
Reset counter: 100
Mileage: 64242 km
Date: 2019.11.09
Time: 00:12:39
Part No SW: 5Q0 907 530 AM HW: 5Q0 907 530 F
Component: GW MQB High 128 1265
Revision: -------- Serial number: 0005350389
Coding: 000000343F085700FB00025C1C0F00010001050000000000000000000000
ROD: EV_GatewLear_013.rod
VCID: 7CA1F6C5D66E267BD3B-8028
131658 - Door Control Module - Driver's Door
U0199 00 [008] - No Communications
[Timeout Knoten 0x4A / 42 - Türsteuergerät Fahrerseite]
Reset counter: 140
Mileage: 64242 km
Date: 2019.11.09
Time: 00:03:36
Terminal 30 power supply: 13.5 V
Terminal 15: On
Component: TSG FS 020 0041
Serial number: 040318EC406273
Coding: 000001200000040100001000
VCID: 43D34D39EB109983D21-8016
7 Faults Found:
65620 - invalid data record
B2005 00 [009] - -
[Türelektronik: ungültiger Datensatz]
Reset counter: 100
65621 - Locking Module for Central Locking
B122F 29 [009] - Signal Implausible
Reset counter: 100
458752 - Databus
[Airbag_01 Datenbus fehlende Botschaft]
Reset counter: 100
458776 - Databus
[Gateway_71 Datenbus fehlende Botschaft]
Reset counter: 100
458788 - Databus
[Klemmen_Status_01 Datenbus fehlende Botschaft]
Reset counter: 140
458794 - Databus
[Kombi_02 Datenbus fehlende Botschaft]
Reset counter: 140
458803 - Databus
[Motor_14 Datenbus fehlende Botschaft]
Reset counter: 100
Component: TSG BFS 020 0041
Serial number: 020618EES23826
7 Faults Found:
65570 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Türelektronik Fahrer (J386)]
Reset counter: 140
Mileage: 64242 km
Date: 2019.11.09
Time: 00:03:34
B2005 00 [009] - -
Reset counter: 100
458752 - Databus
Reset counter: 100
458776 - Databus
Reset counter: 100
458788 - Databus
Reset counter: 140
458794 - Databus
Reset counter: 140
458803 - Databus
Reset counter: 100
Part No SW: 3Q0 035 874 A HW: 3Q0 035 874 A
Component: MU-S-ND-ER H24 0245
Serial number: VWZAZ2S0090741
Coding: 02620001BE00000051111101008808001F0100C401200100CF
Shop #: WSC 00788 648 00255
ROD: EV_MUStd4CTSAT_VW26.rod
VCID: 303912F54AA6121B3F3-8064
Subsystem 1 - Part No SW: 5G6 919 605 A HW: 5G6 919 605 A
Component: ABT_Std-2 H50 8130
Serial number: VWZ6ZJT3645383
Subsystem 2 - Part No SW: 5NA 919 866 BG HW: -----------
Component: ECE AS 2021 --- 1520
32 Faults Found:
B201A 00 [009] - -
Reset counter: 180
Voltage terminal 30: 13.7 V
Status_Software_Version_Management-module_name: D
15360768 - Component Protection
U1101 00 [009] - Active
[Anti-theft protection - component protection active (0xEA6300)]
Reset counter: 100
Mileage: 64242 km
Voltage terminal 30: 13.6 V
0512 - Rear Right Bass Speaker
B1067 13 [009] - Open Circuit
[Tieftonlautsprecher Kanal 1: Unterbrechung (DC-Diagnose)]
Reset counter: 180
0517 - Front Right Bass Speaker
B1062 13 [009] - Open Circuit
[Tieftonlautsprecher Kanal 2: Unterbrechung (DC-Diagnose)]
Reset counter: 180
0522 - Front Left Bass Speaker
B105F 13 [009] - Open Circuit
[Tieftonlautsprecher Kanal 3: Unterbrechung (DC-Diagnose)]
Reset counter: 180
0527 - Rear Left Bass Speaker
B1065 13 [009] - Open Circuit
[Tieftonlautsprecher Kanal 4: Unterbrechung (DC-Diagnose)]
Reset counter: 180
Mileage: 91882 km
Date: 2020.09.14
Time: 09:07:34
Voltage terminal 30: 11.7 V
0005 - Antenna Amplifier 1 for Radio
B126D 13 [009] - Open Circuit
Reset counter: 100
Status of antenna 1 for radio-Antenna current: 0 mA
Status of antenna 1 for radio-Connection between radio and antenna amplifier: electrically OK
Status of antenna 1 for radio-Connection between antenna amplifier and antenna: electrically OK
Status of antenna 1 for radio-Reception level antenna 1: 0 dBµV
0006 - Antenna Amplifier 2 for Radio
B126E 13 [009] - Open Circuit
Reset counter: 100
Mileage: 91882 km
Date: 2020.09.14
Time: 07:38:54
Voltage terminal 30: 11.1 V
Status of antenna 2 for radio-Antenna current: 0 mA
Status of antenna 2 for radio-Connection between radio and antenna amplifier: electrically OK
Status of antenna 2 for radio-Connection between antenna amplifier and antenna: electrically OK
Status of antenna 2 for radio-Reception level antenna 2: 0 dBµV
0013 - Antenna Amplifier 1 for Digital Radio
B1270 13 [009] - Open Circuit
Reset counter: 100
Status of digital radio antenna 1-Antenna current: 0 mA
Status of digital radio antenna 1-Connection between radio and antenna amplifier: electrically OK
Status of digital radio antenna 1-Connection between antenna amplifier and antenna: electrically OK
Status of digital radio antenna 1-DAB_Bit_Error_Rate_FIC: 0.000000
Status of digital radio antenna 1-DAB_Bit_Error_Rate_MSC: 0.000000
2565 - GPS Antenna
B1054 13 [009] - Open Circuit
[GPS aerial - open circuit]
Reset counter: 180
1564 - Microphone 1
B129B 13 [009] - Open Circuit
Reset counter: 180
6697 - Databus
[Airbag: no communication]
Reset counter: 100
Network diagnosis-Status: Enabled
6700 - Databus
[Dimming: no communication]
Reset counter: 140
6702 - Databus
[ESP: no communication]
Reset counter: 100
6705 - Databus
[Terminal_status: no communication]
Reset counter: 140
6706 - Databus
[Instrument cluster: no communication]
Reset counter: 140
6708 - Databus
[Engine: no communication]
Reset counter: 100
6714 - Databus
[VIN: no communication]
Reset counter: 140
6718 - Databus
[BCM: no communication]
Reset counter: 140
6927 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Trip computer setup (0x0F) - function restriction due to communication error - BapErr_timeout: heartbeat]
Reset counter: 140
Mileage: 64242 km
Date: 2019.11.09
Time: 00:01:08
6929 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Time/date (0x11) - function restriction due to communication error - BapErr_timeout: heartbeat]
Reset counter: 140
Mileage: 64242 km
Date: 2019.11.09
Time: 00:01:08
6930 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Service interval display + oil level display (0x12) - function restriction due to communication error - BapErr_timeout: heartbeat]
Reset counter: 140
Mileage: 64242 km
Date: 2019.11.09
Time: 00:01:08
6931 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Central unit master (0x13) - function restriction due to communication error - BapErr_timeout: heartbeat]
Reset counter: 140
Mileage: 64242 km
Date: 2019.11.09
Time: 00:01:08
7173 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[ACC (0x05) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 100
BAP-BAP_Function_ID: 02
U1111 00 [009] - -
[Tire pressure monitoring (0x07) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 100
7183 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Trip computer setup (0x0F) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 140
7185 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Time/date (0x11) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 140
7186 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Service interval display + oil level display (0x12) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 140
7187 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Central unit master (0x13) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 140
7195 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Brake assist system (0x1B) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 100
7206 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Brake (0x26) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 100
1637 - Interface for External Media
U11B8 00 [009] - No Communications
[USB - communication error]
Reset counter: 100
Interface for external media: status-Status: Open circuit
End----------(Elapsed Time: 00:19, VBatt start/end: 13.7V/13.7V)-----------
