AUDI A3 Sedan 2015 Tweaks
JIMENEZ
Columbia
C?ID=170890
This is the Auto scan from Audi A3 Sedan 2015 FWD, somebody has tweaks?
Chassis Type: 8V (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F
VIN: WAUZZZ8V0F1003840
Address 01: Engine (J623-CJSA)       Labels: 06K-907-425-V1.clb
   Part No SW: 8V0 906 264 B    HW: 06K 907 425 A
   Component: 1.8l R4 TFSI  H09 0003
   Revision: --H09---
   Coding: 0A191032240400082000
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM18TFS0218V0906264B 001003
   ROD: EV_ECM18TFS0218V0906264B_AU37.rod
   VCID: 3B75F72AB2E891C68E5-806E
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379.clb
   Revision: 00000000    Serial number: 6003400000195E
   Coding: 13F16AA234200A6F037F060441C329C8562C50C0608294B5004100080608
   VCID: 7BF5372AF26851C6CE5-802E
32928 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Fault Frequency: 12
                    Reset counter: 73
Address 08: Auto HVAC (E87)       Labels: 8V0-820-043.clb
   Part No SW: 8V0 820 043 C    HW: 8V0 820 043 C
   Component: AC Automat    H13 0052
   Revision: 20026000    Serial number: 00000000217502
   Coding: 03000004110000000000000000001400
   VCID: 326BDA0E65A2508E5D3-8067
   Part No SW: 5Q0 937 084 AE    HW: 5Q0 937 084 AE
   Component: BCM MQBAB H   H16 0124
   Serial number: 00011400400131
   Coding: 04040A42C04122FD03A04004B10807000000000000000000000000000000
   ROD: EV_BCMBOSCH_AU37.rod
   Subsystem 1 - Part No SW: 8V1 955 119 C    HW: 8V1 955 119 A
   Component: WWS371 140103  041 0585
   Serial number:         140110160433
   Coding: 0A47F7
   Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B
   Serial number: 22068443
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 L    HW: 8V0 941 531 L
   Serial number: 26 09 2013  00000011
   Serial number: 000000000ZY133301LGC
   Serial number: 00000000000028651154
135688 - Terminal S
          B11A5 12 [008] - Short to Plus
                    Reset counter: 68
                    Mileage: 475 km
                    Date: 2014.05.19
                    Time: 13:08:47
262936 - Sensor for Anti-Theft Alarm System
          B1330 29 [008] - Signal Implausible
                    Reset counter: 63
                    Mileage: 17 km
                    Date: 2014.05.06
                    Time: 12:41:39
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-283.clb
   Part No SW: 5Q0 919 283 B    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H09 0033
   Revision: --------    Serial number: 60831336001157
   Coding: 0000040001
   ASAM Dataset: EV_EPHVA14AU3700000 002018
   ROD: EV_EPHVA14AU3700000_AU37.rod
   VCID: 387FE82683DEBADE637-806D
   Part No SW: 5Q0 959 655 AB    HW: 5Q0 959 655 AB
   Serial number: 003MMR00N1AM
   Coding: 98CCC000000000005C540000004800000065
   VCID: 800FC0C61B8EB21E1B7-80D5
   Subsystem 1 - Part No SW: -----------    HW: 480 001 612 13
   Serial number: 3576700000037B69BD02
   Subsystem 2 - Part No SW: -----------    HW: 480 001 612 13
   Serial number: 35867000000C8B69BD0D
   Subsystem 3 - Part No SW: -----------    HW: 480 401 912 13
   Serial number: 3516502A711FBE9171CP
   Subsystem 4 - Part No SW: -----------    HW: 480 401 312 13
   Serial number: 3526502A111FBE94D0FV
   Subsystem 5 - Part No SW: -----------    HW: 480 402 012 13
   Serial number: 3556502C311FBE93C3BZ
   Part No SW: 8V0 953 521 BT    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 19121308491195
   Coding: 8008
   ROD: EV_SMLSKLOMQB_AU37.rod
   VCID: 8D11E9F25CDCEF76601-80D8
   Part No SW: 8V0 920 860 E    HW: 8V0 920 860 E
   Component: KOMBI         H02 2220
   Coding: 078419002A8000080500A800100000
   VCID: 3C77F436B7E696FE87F-8069
   Part No SW: 5Q0 907 530 Q    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2163
   Revision: --------    Serial number: 21121310800821
   Coding: 0101000820085A005B000208080B00000001000000000000000000000000
   ASAM Dataset: EV_GatewConti 010015
   ROD: EV_GatewConti_AU37.rod
   VCID: 3F8D833AA6F08DE6A2D-806A
   Subsystem 2 - Part No SW: 8U0 951 528     HW: 8U0 951 528
   Serial number: 26 11 2013  A1302203
   Part No SW: 5Q0 959 393 B    HW: 5Q0 959 393 B
   Serial number: 28121306071135
   Coding: 00100E204100040000001002
   ROD: EV_DCUDriveSideEWMAXKLO.rod
   VCID: 3E73FE3EA1FA84EEA9B-806B
   Subsystem 1 - Part No SW: 5Q0 959 811     HW: 5Q0 959 811
   Serial number: 00000000000001431111
   Coding: 110000
   Component: EPS_MQB_ZFLS  123 1043
   Coding: 0102
   ROD: EV_SteerAssisMQB.rod
   VCID: 418985C2D004FB16D49-8014
   Part No SW: 5Q0 959 392 B    HW: 5Q0 959 392 B
   Serial number: 02011404080661
   Coding: 001006204100040000001002
   ROD: EV_DCUPasseSideEWMAXKLO.rod
   VCID: 3D71F932ACFC9FF6B01-8068
   Subsystem 1 - Part No SW: 5Q0 959 812     HW: 5Q0 959 812
   Serial number: 00000000000001447017
   Coding: 090000
Address 55: Xenon Range (J431)       Labels: 5Q0-907-357.clb
   Coding: 011A000001000000
   VCID: F5E1A112544C87B6381-80A0
   Part No SW: 8V0 035 840 B    HW: 8V0 035 840 B
   Component: MU-S--ER      040 0420
   Serial number: A3E00701141177
   Coding: 01730100FF0A000021220001001A00002F0001440100010002
   ASAM Dataset: EV_MUStd6C3PASE 002020
   ROD: EV_MUStd6C3PASE.rod
   VCID: 3467DC169FB65EBE4FF-8061
   Seat Adjustment Driver Side:
   Subsystem 1 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
   Component: DU Std  H49 0013
   Serial number: AUZ8Z9DY300MZS
   Sound System:
   Subsystem 2 - Part No SW: 8V0 919 614 B    HW: 8V0 919 614 B
   Component: ControlUnit_B  H33 0037
   Serial number: C1000006111300010275
Thanks!
Andy's MQB Platform tweaks page should help. If you happen to notice any heated windscreen modifications, or if this car was factory equipped with that feature, please let him know in that thread!
Beta 14.6.0 should be used on that vehicle if you are attempting to modify anything.
