I have a friend who mounted xenon headlights to 2011 Touran, everything in 09 seems coded OK, because it's based on second Touran with factory xenon.
The problem is high beams are not working and I cannot code the 55 module (message 31 request out of range).
Can somebody help me solve problem?? I have updated the BCM to newest SW but still no changes.
Also I should mention that cluster is swaped from Tiguan Color TFT.
Tuesday,05,April,2016,20:48:43:22573
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
Workshop Code: 444 00001 012345
VIN: WVGZZZ1TZBW043181 License Plate:
Mileage: 273170km-169739mi Repair Order:
Chassis Type: 1T (7N0)
Scan: 01 03 08 09 10 15 16 17 18 19 25 2E 37 42 44 46 52 55 56 61
62 72 77
VIN: WVGZZZ1TZBW043181 Mileage: 273170km-169739miles
Address 01: Engine (J623-CAYC) Labels: 03L-906-023-CAY.clb
Part No SW: 03L 906 023 AR HW: 03L 906 023 A
Component: 1,6l R4 CR td H23 9615
Revision: --H23--- Serial number: 00000000000000
Coding: 00194016032400080000
Shop #: WSC 01324 020 00200
ASAM Dataset: EV_ECM16TDI02103L906023AR 003007
ROD: EV_ECM16TDI02103L906023AQ.rod
VCID: 76E38EF2C99F108E54-8022
Readiness: 1110 1000
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Coding: 323B401609260EFD4C0C02EC901A7041310000
VCID: 76E38EF2C19F108E54-8022
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 5K0 907 044 DT HW: 5K0 907 044 DT
Component: Climatronic H17 1010
Revision: 00003001
Coding: 0000000002
VCID: 000FE82A9B5B2E3E7E-8054
9481988 - Air Quality Sensor
B10AF 04 [009] - Internal System Fault
Reset counter: 231
Mileage: 273177 km
Date: 2016.04.05
Time: 20:36:52
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 087 M HW: 5K0 937 087 M
Component: BCM PQ35 H 011 1048
Revision: BE011001
Coding: 40180A3888251AE0400800C0540011E44B559008626DA120E484C7000049
Shop #: WSC 04941 123 12345
VCID: 3F8D2BD6AE2591C647-806A
Subsystem 1 - Part No: 1T1 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer 25101 26 0512
Coding: 009795
Component: RLS 291010 05 54 0403
Coding: 0330ED
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 231
Mileage: 273177 km
Date: 2016.04.05
Time: 20:34:28
Voltage: 13.75 V
03384 - Windshield Washer Jet Heating
Reset counter: 231
Mileage: 273177 km
Date: 2016.04.05
Time: 20:34:29
Voltage: 13.75 V
Address 10: Park/Steer Assist (J446) Labels: 1Q0-919-475.clb
Part No SW: 5N0 919 475 D HW: 1Q0 919 475
Component: PARKHILFE 4K H02 0045
Revision: -------- Serial number: 65031030106567
Coding: 108001
ASAM Dataset: EV_EPHVA14VW3680000 001005
ROD: EV_EPHVA14VW3680000.rod
VCID: 3A7B5AC2BD07B4EE70-806E
Address 15: Airbags Labels: 1T0-909-605.lbl
Part No SW: 1T0 909 605 E HW: 1T0 909 605 E
Component: 02 AIRBAG VW8 022 0100
Revision: 02022000 Serial number: 003K4D017UPH
Coding: 0012338
VCID: 377D43F64615A9868F-8062
Subsystem 1 - Serial number: 6332QSME41754D12C
Subsystem 2 - Serial number: 6342QSME427514087
Subsystem 3 - Serial number: 6352QSME4F7B2814T
Subsystem 4 - Serial number: 6362QSME4B7A2E2C/
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 501 BH HW: 5K0 953 569 L
Component: LENKS.MODUL 009 0136
Revision: FF010039 Serial number: 20101109200011
Coding: 118A140000
VCID: 71E9BDEEA0F137B681-8024
Subsystem 1 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H07 0013
Coding: 820000
Part No SW: 5N0 920 883 C HW: 5N0 920 883 C
Component: KOMBI H04 0611
Coding: 181900
VCID: 346774FA9F63429EAA-8060
Address 18: Aux. Heat Labels: 1K0-815-071.clb
Part No: 7N0 963 271 A
Component: Zuheizer 051 2630
Revision: 00051000 Serial number: 09022126000000
Coding: 0000011
VCID: 326B72E2AD774CAEB8-8066
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 BA HW: 7N0 907 530 AL
Component: J533 Gateway H58 1663
Revision: H58 Serial number: 150714F2000023
Coding: 358002
Shop #: WSC 45655 001 104857
VCID: 70EFB8EAA3FB3EBE8E-8024
03406 - Control Module for Battery Monitoring
Reset counter: 231
Mileage: 273177 km
Date: 2016.04.05
Time: 20:32:56
Component: IMMO H04 0611
VCID: 6ADBAA828D27C46EC0-803E
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 C HW: 5N0 035 342 C
Revision: A1001003 Serial number: 7668842272
Coding: 020000
VCID: 275D93B656B539061F-8072
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 D HW: 1T0 035 680 D
Component: RNS-MID H55 3980
Revision: AB001001 Serial number: VWZ6Z7L4288563
Coding: 04000400030000910000
VCID: 2F6D7B967E456146D7-807A
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1T0 959 701 AA HW: 1T0 959 701 AA
Component: Tuer-SG 009 2121
Coding: 0004279
VCID: 76E38EF2019F108E54-8022
Address 44: Steering Assist Labels: 5N1-909-144.clb
Part No SW: 5N1 909 144 L HW: 5N1 909 148 G
Component: J500__APA-BS KL.292 0802
Revision: 1AH03729 Serial number: 00103000424001
Coding: 0000258
VCID: 3B755FC67A3D8DE66B-806E
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1T0 959 702 S HW: 1T0 959 702 S
Component: Tuer-SG 009 2111
Coding: 0004535
VCID: 489F300A3BEBD67EF6-801C
Address 55: Headlight Range (J745) Labels: 5M0-907-357-V3.clb
Part No SW: 5M0 907 357 F HW: 7L6 907 357 C
Component: AFS-ECU H04 0111
Coding: 089200000B000200
Shop #: WSC 01383 790 50316
ROD: EV_HeadlRegulVWAFSPt_SE36.rod
VCID: 377D43F68E15A9868F-8062
Subsystem 1 - Part No SW: 1T0 941 329 A HW: 1T0 941 329 A Labels: 3D0-941-329.CLB
Component: LeiMo links H06 0007
Coding: 390000
Subsystem 2 - Part No SW: 1T0 941 329 A HW: 1T0 941 329 A Labels: 3D0-941-329.CLB
Component: LeiMo rechts H06 0007
Coding: 390000
U1014 00 [137] - -
Reset counter: 231
Mileage: 273177 km
Date: 2016.04.05
Time: 20:31:56
5276145 - Power Output Module for Left Headlamp
C1081 F1 [137] - Incorrectly Coded
Reset counter: 231
Mileage: 273177 km
Date: 2016.04.05
Time: 20:31:56
5276401 - Power Output Module for Right Headlamp
C1082 F1 [137] - Incorrectly Coded
Reset counter: 231
Mileage: 273177 km
Date: 2016.04.05
Time: 20:31:56
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
00467 - TV Tuner (R78)
Reset counter: 231
Mileage: 273177 km
Date: 2016.04.05
Time: 20:47:35
Reset counter: 231
Mileage: 273177 km
Date: 2016.04.05
Time: 20:47:36
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 7N0 907 534 HW: 7N0 907 530 AL
Component: Batt.regelung H58 1663
Coding: 330F1873
VCID: 71E9BDEEA8F137B681-8024
02071 - Local Databus
Fault Status: 01101100
Reset counter: 231
Mileage: 273177 km
Date: 2016.04.05
Time: 20:38:53
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 5K0 959 703 A HW: 5K0 959 703 A
Component: Tuer-SG 007 2104
Coding: 0000144
Shop #: WSC 01324 020 1012552
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 5K0 959 704 A HW: 5K0 959 704 A
Coding: 0000144
VCID: 336577E6526D45A6B3-8066
Address 77: Telephone (J412) Labels: 3C8-035-730-A.clb
Part No SW: 3C8 035 730 B HW: 3C8 035 730 B
Component: Telefon 011 0723
Revision: -------- Serial number: 35909603157103
Coding: 080100010100010000000501
ASAM Dataset: EV_UHVPremi A02003
ROD: EV_UHVPremi_SE36.rod
VCID: 224B82A23597DC2E48-8076
End-------------------------(Elapsed Time: 03:02)--------------------------
