VW Touran xenon retrofit high beams not working
automech
Poland
C?ID=14925
I have a friend who mounted xenon headlights to 2011 Touran, everything in 09 seems coded OK, because it's based on second Touran with factory xenon.
The problem is high beams are not working and I cannot code the 55 module (message 31 request out of range).
Can somebody help me solve problem?? I have updated the BCM to newest SW but still no changes.
Also I should mention that cluster is swaped from Tiguan Color TFT.
Tuesday,05,April,2016,20:48:43:22573
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
Workshop Code: 444 00001 012345
VIN: WVGZZZ1TZBW043181   License Plate:
Mileage: 273170km-169739mi   Repair Order:
Chassis Type: 1T (7N0)
Scan: 01 03 08 09 10 15 16 17 18 19 25 2E 37 42 44 46 52 55 56 61
          62 72 77
VIN: WVGZZZ1TZBW043181   Mileage: 273170km-169739miles
Address 01: Engine (J623-CAYC)       Labels: 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 AR    HW: 03L 906 023 A
   Component: 1,6l R4 CR td H23 9615
   Revision: --H23---    Serial number: 00000000000000
   Coding: 00194016032400080000
   Shop #: WSC 01324 020 00200
   ASAM Dataset: EV_ECM16TDI02103L906023AR 003007
   ROD: EV_ECM16TDI02103L906023AQ.rod
   VCID: 76E38EF2C99F108E54-8022
Readiness: 1110 1000
   Revision: 00H31001
   Coding: 323B401609260EFD4C0C02EC901A7041310000
   VCID: 76E38EF2C19F108E54-8022
   Part No SW: 5K0 907 044 DT    HW: 5K0 907 044 DT
   Component: Climatronic   H17 1010
   Revision: 00003001
   Coding: 0000000002
   VCID: 000FE82A9B5B2E3E7E-8054
9481988 - Air Quality Sensor
          B10AF 04 [009] - Internal System Fault
                    Reset counter: 231
                    Mileage: 273177 km
                    Date: 2016.04.05
                    Time: 20:36:52
   Part No SW: 5K0 937 087 M    HW: 5K0 937 087 M
   Component: BCM PQ35 H    011 1048
   Revision: BE011001
   Coding: 40180A3888251AE0400800C0540011E44B559008626DA120E484C7000049
   Shop #: WSC 04941 123 12345
   VCID: 3F8D2BD6AE2591C647-806A
   Subsystem 1 - Part No: 1T1 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer 25101  26  0512
   Coding: 009795
   Component: RLS 291010 05  54  0403
   Coding: 0330ED
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 231
                    Mileage: 273177 km
                    Date: 2016.04.05
                    Time: 20:34:28
                    Voltage: 13.75 V
03384 - Windshield Washer Jet Heating
                    Reset counter: 231
                    Mileage: 273177 km
                    Date: 2016.04.05
                    Time: 20:34:29
                    Voltage: 13.75 V
Address 10: Park/Steer Assist (J446)       Labels: 1Q0-919-475.clb
   Part No SW: 5N0 919 475 D    HW: 1Q0 919 475
   Component: PARKHILFE 4K  H02 0045
   Revision: --------    Serial number: 65031030106567
   Coding: 108001
   ASAM Dataset: EV_EPHVA14VW3680000 001005
   ROD: EV_EPHVA14VW3680000.rod
   VCID: 3A7B5AC2BD07B4EE70-806E
Address 15: Airbags        Labels: 1T0-909-605.lbl
   Part No SW: 1T0 909 605 E    HW: 1T0 909 605 E
   Component: 02 AIRBAG VW8   022 0100
   Revision: 02022000    Serial number: 003K4D017UPH
   Coding: 0012338
   VCID: 377D43F64615A9868F-8062
   Subsystem 1 - Serial number: 6332QSME41754D12C
   Subsystem 2 - Serial number: 6342QSME427514087
   Subsystem 3 - Serial number: 6352QSME4F7B2814T
   Subsystem 4 - Serial number: 6362QSME4B7A2E2C/
   Part No SW: 5K0 953 501 BH    HW: 5K0 953 569 L
   Component: LENKS.MODUL   009 0136
   Revision: FF010039    Serial number: 20101109200011
   Coding: 118A140000
   VCID: 71E9BDEEA0F137B681-8024
   Component: E221__MFL-TAS  H07 0013
   Coding: 820000
   Part No SW: 5N0 920 883 C    HW: 5N0 920 883 C
   Component: KOMBI         H04 0611
   Coding: 181900
   VCID: 346774FA9F63429EAA-8060
   Part No: 7N0 963 271 A
   Component: Zuheizer        051 2630
   Revision: 00051000    Serial number: 09022126000000
   Coding: 0000011
   VCID: 326B72E2AD774CAEB8-8066
   Part No SW: 7N0 907 530 BA    HW: 7N0 907 530 AL
   Component: J533  Gateway H58 1663
   Revision:   H58       Serial number: 150714F2000023
   Coding: 358002
   Shop #: WSC 45655 001 104857
   VCID: 70EFB8EAA3FB3EBE8E-8024
03406 - Control Module for Battery Monitoring
                    Reset counter: 231
                    Mileage: 273177 km
                    Date: 2016.04.05
                    Time: 20:32:56
   Component: IMMO          H04 0611
   VCID: 6ADBAA828D27C46EC0-803E
   Part No SW: 5N0 035 342 C    HW: 5N0 035 342 C
   Revision: A1001003    Serial number: 7668842272
   Coding: 020000
   VCID: 275D93B656B539061F-8072
   Part No SW: 1T0 035 680 D    HW: 1T0 035 680 D
   Component: RNS-MID       H55 3980
   Revision: AB001001    Serial number: VWZ6Z7L4288563
   Coding: 04000400030000910000
   VCID: 2F6D7B967E456146D7-807A
   Part No SW: 1T0 959 701 AA    HW: 1T0 959 701 AA
   Component: Tuer-SG         009 2121
   Coding: 0004279
   VCID: 76E38EF2019F108E54-8022
   Part No SW: 5N1 909 144 L    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.292 0802
   Revision: 1AH03729    Serial number: 00103000424001
   Coding: 0000258
   VCID: 3B755FC67A3D8DE66B-806E
   Part No SW: 1T0 959 702 S    HW: 1T0 959 702 S
   Component: Tuer-SG         009 2111
   Coding: 0004535
   VCID: 489F300A3BEBD67EF6-801C
Address 55: Headlight Range (J745)       Labels: 5M0-907-357-V3.clb
   Component: AFS-ECU       H04 0111
   Coding: 089200000B000200
   Shop #: WSC 01383 790 50316
   ROD: EV_HeadlRegulVWAFSPt_SE36.rod
   VCID: 377D43F68E15A9868F-8062
   Subsystem 1 - Part No SW: 1T0 941 329 A    HW: 1T0 941 329 A  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H06 0007
   Coding: 390000
   Subsystem 2 - Part No SW: 1T0 941 329 A    HW: 1T0 941 329 A  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H06 0007
   Coding: 390000
          U1014 00 [137] - -
                    Reset counter: 231
                    Mileage: 273177 km
                    Date: 2016.04.05
                    Time: 20:31:56
5276145 - Power Output Module for Left Headlamp
          C1081 F1 [137] - Incorrectly Coded
                    Reset counter: 231
                    Mileage: 273177 km
                    Date: 2016.04.05
                    Time: 20:31:56
5276401 - Power Output Module for Right Headlamp
          C1082 F1 [137] - Incorrectly Coded
                    Reset counter: 231
                    Mileage: 273177 km
                    Date: 2016.04.05
                    Time: 20:31:56
00467 - TV Tuner (R78)
                    Reset counter: 231
                    Mileage: 273177 km
                    Date: 2016.04.05
                    Time: 20:47:35
                    Reset counter: 231
                    Mileage: 273177 km
                    Date: 2016.04.05
                    Time: 20:47:36
   Component: Batt.regelung H58 1663
   Coding: 330F1873
   VCID: 71E9BDEEA8F137B681-8024
02071 - Local Databus
                    Fault Status: 01101100
                    Reset counter: 231
                    Mileage: 273177 km
                    Date: 2016.04.05
                    Time: 20:38:53
   Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
   Component: Tuer-SG         007 2104
   Coding: 0000144
   Shop #: WSC 01324 020 1012552
   Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
   Coding: 0000144
   VCID: 336577E6526D45A6B3-8066
Address 77: Telephone (J412)       Labels: 3C8-035-730-A.clb
   Part No SW: 3C8 035 730 B    HW: 3C8 035 730 B
   Component: Telefon       011 0723
   Revision: --------    Serial number: 35909603157103
   Coding: 080100010100010000000501
   ASAM Dataset: EV_UHVPremi A02003
   ROD: EV_UHVPremi_SE36.rod
   VCID: 224B82A23597DC2E48-8076
End-------------------------(Elapsed Time: 03:02)--------------------------
martijn v o
C?ID=138199
If this is the same as the VW passat:
First erase fault codes, then adjust headlights in 10- adaption. You have to install a levelsensor on the rear axle.
Installed the xenon with pinning the new connector or with an adapter?
For the high beam connect the right wires to the BCM module. or connect the right wires from the old high beam to the new high beam.
Also coding on the BCM installed xenon with shutter.
automech
Poland
C?ID=14925
All sensors are mounted, wiring checked three times from BCM to the lamps. Connection is made with new 14 pin connector.
I tried code 09 as xenon with shutter and bi-xenon headlights with high beam, still same result.
Also when trying to code 55 i tried the erasing faults, adjusting and then coding in one ignition cycle.
martijn v o
C?ID=138199
position wiring high beam from BCM to lights on position 11?
automech
Poland
C?ID=14925
All wires connected as WD says. Today we reconnected old cluster to see if it change anything, but no effect.
vioelectric
Romania
C?ID=11248
What type of headlight do you have? Is pin 11 fitted on headlight? If you have pin 11 and you connect correctly to BCM try this in BCM
40180A3888251AE0400800C0540009E44B559008626DA120E484C7000041
or same codding but with 00 on byte 18.
automech
Poland
C?ID=14925
Sorry for delay but I forgot about this thread. Xenons now works all good, I needed to upload proper dataset to 55 module, and then it allowed to code.
Piotr
Poland
C?ID=167156
Cześć,
Czy rozwiązałeś problem ze światłami drogowymi, bo mam ten sam problem z plikiem zdc który wrzuciłeś i jaki kod dostępu do kodowania 55.
Westbury, UK
Cześć,
The language of this forum is English, please only post in English.
