MY15 Golf mk7 R type - RoW (Australia)
Monday,04,April,2016,13:37:06:03521
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
VIN:               License Plate:
Mileage: 8242kms   Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 2B 42 44 52 55 5F A9
VIN:                    Mileage: 8242km-5121miles
Address 01: Engine (J623-CJXB)       Labels: 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 E    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0005
   Revision: --H13---
   Coding: 091D00322426050B3004
   ASAM Dataset: EV_ECM20TFS0205G0906259E 001005
   ROD: EV_ECM20TFS0205G0906259E_VW37.rod
   VCID: 306FFC786B2E92BECE-8064
21406 - EVAP Emission Control Sys
          P0441 00 [096] - Incorrect Flow
   Part No SW: 0D9 300 012 L    HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H53 4522
   Revision: 05853104    Serial number: TFK01504090311
   ROD: EV_TCMDQ250021_AU37.rod
   VCID: 1F4D0FC406B01DC667-804A
   Part No SW: 3Q0 907 379 Q    HW: 3Q0 907 379 F
   Component: ESC           H42 0610
   Revision: 00000000    Serial number: 61075000005637
   Coding: 01FA93A15424296E077F070341C66980C92A94E0E08296F7004200B8C208
   ROD: EV_Brake1UDSContiMK100IPB_VW37.rod
   VCID: 489FB498F3BE3A7EF6-801C
   Revision: 00021000    Serial number: 0366809149
   Coding: 030C0C
   ROD: EV_KessyHellaMQBAB_AU37.rod
   VCID: 3A7BDE50BD5258EE70-806E
   Part No SW: 5G0 907 044 BC    HW: 5G0 907 044 BC
   Revision: 00001K08
   Coding: 00120004200100001005004012101400
   ROD: EV_ACClimaBHBVW37X_SK37.rod
   VCID: 69D9511C88742376C9-803C
   Part No SW: 5Q0 937 084 AJ    HW: 5Q0 937 084 AJ
   Component: BCM MQBAB H   H18 0137
   Serial number: 01011511400367
   Coding: 03011A42C24122F30BA44080B10C07281800000000000000000000000000
   ROD: EV_BCMBOSCH_AU37.rod
   VCID: 000F6CB89B0EC23E7E-8054
   Slave 1:
   Component: WWS    150412  042 0551
   Serial number:         150416084041
   Slave 2:
   Component: RLHS  037 0059
   Serial number: S4Y15M04D28H01M52S19
   Coding: 90A8DD
   Serial number: 000000000ZY150753C9N
   Serial number: 00000000000032299698
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-294.clb
   Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0048
   Revision: --------    Serial number: 39331511701111
   Coding: 0031151011
   ROD: EV_EPHVA18AU3700000_SK48.rod
   VCID: 3D71D54CAC7C6FD655-8068
   Part No SW: 5Q0 907 376     HW: 5Q0 907 376
   Component: DAEMPFUNGS-SG H16 0115
   Serial number: 22031541350465
   ROD: EV_DRCONTITEMIC.rod
   VCID: 76E30A60C9CAFC8E54-8022
   Part No SW: 5Q0 959 655 D    HW: 5Q0 959 655 D
   Serial number: 003F6R0JHX8%
   Coding: 98CCC000000000005C00000000C800000065
   VCID: 4189A9BCD0840B3631-8014
   Subsystem 1 - Part No SW: -----------    HW: 480 002 804 15
   Serial number: 357670000006B195441Q
   Subsystem 2 - Part No SW: -----------    HW: 480 002 004 15
   Serial number: 3586700000018D61141L
   Subsystem 3 - Part No SW: -----------    HW: 480 401 604 15
   Serial number: 3516502C11A91E7193BF
   Subsystem 4 - Part No SW: -----------    HW: 480 401 704 15
   Serial number: 3526502B51A91E750257
   Subsystem 5 - Part No SW: -----------    HW: 480 401 604 15
   Serial number: 3556502BF1A91E74C33U
   Part No SW: 5Q0 953 507 EA    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 18041504220626
   Coding: 0410
   ROD: EV_SMLSKLOMQB_SE37.rod
   VCID: 79F9015CF8D493F639-802C
   Part No SW: 5G1 920 758     HW: 5G1 920 758
   Component: KOMBI         304 4310
   Coding: 27AD08183B80000800086A001400000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009043
   VCID: 6CD728088786365EB2-8038
   Part No SW: 5Q0 907 530 AC    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1204
   Revision: --------    Serial number: 0003410014
   Coding: 030100042F085900EF00026A9C0F00010001050000000000000000000000
   ASAM Dataset: EV_GatewLear 011020
   ROD: EV_GatewLear.rod
   VCID: 72EB3670A5A2E0AE78-8026
   Subsystem 2 - Part No SW: 5G0 959 442 M    HW: 5G0 959 442 M
   Component: E221__MFL-DC1  H10 0101
   Serial number: 29150000768660085166
   Coding: 29FFFF
   Serial number: 5521636303
   Part No SW: 0CQ 907 554 D    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7082
   Serial number: HA1-00020.03.15
   Coding: 0001
   ASAM Dataset: EV_AllWheelContrHA1VW37X 002013
   ROD: EV_AllWheelContrHA1VW37X_AU21.rod
   VCID: 4683BAA0F9AA2C0E04-8012
   Revision: 00000000    Serial number: 15000101934005
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB_AU37.rod
   VCID: 3467F0689F36AE9EAA-8060
   Serial number: 040415BD408656
   Coding: 003E12208001040000000000
   ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
   VCID: 428BA6B0D582102E28-8016
   Subsystem 1 - Part No SW: 5Q0 959 812     HW: 5Q0 959 812
   Serial number: 00000000000005992987
   Coding: 0D0000
   Part No SW: 3Q0 909 144 H    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5061
   Coding: 8103
   ROD: EV_SteerAssisMQB.rod
   VCID: 377DC7648E4045868F-8062
   Serial number: 090415BD90161A
   Coding: 003E12208E01040000800000
   ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
   Subsystem 1 - Part No SW: 5Q0 959 811     HW: 5Q0 959 811
   Serial number: 00000000000005890469
   Coding: 150000
   Coding: 02A602000B000200
   ROD: EV_HeadlRegulVWAFS_SE26.rod
   VCID: 408FACB8DB8E023E3E-8014
   Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD1.clb
   Part No SW: 5G0 035 846 A    HW: 5G0 035 846 A
   Component: MU-S-N-ER     041 0450
   Serial number: V1F02304153447
   Coding: 02730008FF00000011510001000900001F0207960100010245
   ROD: EV_MUStd4CPASE_SK37.rod
   VCID: 275D17245EE0D5061F-8072
   Media Player Position 1:
   Subsystem 1 - Part No SW: 5G0 919 605 D    HW: 5G0 919 605 D
   Component: ABT_Std_Nav  H60 0030
   Serial number: VWZ8Z9RS4084KP
   Engine Control Module 2:
   Subsystem 2 - Part No SW: 5G0 919 866 R    HW: -----------
   Component:  ROW 2015  --- 0031
   Part No SW: 5G0 907 159 B    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0006
   Serial number: 150228202010
   VCID: 2D51E50C7C1CFF56E5-8078
End-------------------------(Elapsed Time: 04:34)--------------------------
