VCDS use on VW TRansporter 1.9 TDI (AXC)
Trade Member
C?ID=271231
Sorry if this post is in the wrong place, but it is about "Product Support" and the title of the thread seems to suggest I am in the right place.
Looking at a section of my auto scan;
Saturday,02,April,2016,15:11:04:61979
VCDS -- Windows Based VAG/VAS Emulator Running on Windows Vista x64
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
VIN: WV1ZZZ7HZ6H036014 License Plate: LD55 WZB
Mileage: 207500km-128934mi Repair Order: 001
57 6E 76 77 78 7D
VIN: WV1ZZZ7HZ6H036014 Mileage: 207500km-128934miles
Address 01: Engine Labels: Redir Fail!
Part No SW: 038 906 016 M HW: 028 101 185 6
Component: R4 1,9L EDC 0000SG 6278
Revision: 12345678 Serial number: VWZ7Z0E2628424
Coding: 0101031
Shop #: WSC 02756 785 00200
VCID: 1E33B01ECA45CECE6C-5124
17978 - Engine Start Blocked by Immobilizer
P1570 - 000 - - Intermittent
Torque: 156.0 Nm
Voltage: 12.08 V
Bin. Bits: 00000100
Bin. Bits: 00000000
(no units): 0.0
Readiness: 0 0 X X X (This section I have already been advised it's emissions related) by Jack thanks for that.
The sections in bold I would be interested in more detailed information, what does it mean, where is it leading me in a diagnosis, where do I find that additional information, and why have I got an engine above with ignition on only (not running) producing torque of 156 Nm, is this a display of maximum torque the engine can produce when running?
Added information; Found VCDS User manual in ROSS TECH and downloaded, hopefully will answer many questions I have.
Coding: 0101031
This first section is Control Module ID" data. It tells us what ECU you have, what software it has in it, how it's coded, etc..
Torque: 156.0 Nm
This tells you that at the time the fault was set, the engine was producing (or requesting?) 156.0 Nm (Gross, including what it needs to drive accessories). I'm not sure why this is stored in combination with an Immo fault, since it seems somewhat irrelevant to that type of fault.
Bin. Bits: 00000100
Bin. Bits: 00000000
This tells you the bitwise value of two undocumented bytes at the time the fault code was set. I'm pretty confident that the factory tool would show these to you the same way, and be able to give you just as much detail about their meaning, i.e. none. :(
See also:
The anatomy of the fault code.
Trade Member
C?ID=271231
Thinking about them now they look like Hexadecimal notation to me, very long time since I was studying that type of information, but I do remember that 1111 = 15 :)
