VCDS reports "Unable to find a ROD file". Whazzat mean?
PanEuropean
Toronto, Canada
C?ID=11844
Hello All:
I encountered the message shown below when using VCDS (current stable release, version 12.something) today. I have never seen such a message before. Can someone tell me what it means?
Also, what the heck is a '.ROD' file? Is ROD an acronym for something?
Michael
Uncommon Application Message
PanEuropean
Toronto, Canada
C?ID=11844
I have attached the Autoscan file below. The car is a model year 2014 Italian version of a Volkswagen. Subsequent to this scan, I cleared all the faults and no faults persisted. I am still trying to find the muffler controller so I can turn the noise level down.
Thursday,22,May,2014,16:54:56:25683
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
VIN: ZHWCC1ZD1ELA02890   License Plate: LAMBORGHINI
Mileage: 500km-310mi   Repair Order: AVENTADOR
Chassis Type: ZD (8R0)
Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 42 46 52 53 56 5F 65
          6B 6C
VIN: ZHWCC1ZD1ELA02890   Mileage: 500km/310miles
17-Instruments -- Status: Sporadic communication error 1000
6B-Aerodynamics -- Status: OK 0000
Address 01: Engine (----)       Labels: None
   Part No SW: 470 909 049 AL    HW: 470 907 552 A
   Component: LIE 2010      H01 1482
   Revision: --------    Serial number: 3371
   Coding: 00000000
   VCID: 67D7DE64960987263AD-8032
000352 - Oxygen (Lambda) Sensor B2 S2
               P0160 - 000 - No Activity - Intermittent - MIL ON
                    Fault Status: 10110000
                    Reset counter: 201
                    Mileage: 288 km
                    Date: 2014.05.13
                    Time: 17:21:56
012835 - Oxygen (Lambda) Sensor B3 S2
               P3223 - 000 - No Activity - Intermittent - MIL ON
                    Reset counter: 201
                    Mileage: 288 km
                    Date: 2014.05.13
                    Time: 17:21:56
000320 - Oxygen (Lambda) Sensor B1 S2
               P0140 - 000 - No Activity - Intermittent - MIL ON
                    Reset counter: 201
                    Mileage: 288 km
                    Date: 2014.05.13
                    Time: 17:21:56
Address 02: Auto Trans        Labels: None
   Part No SW: 470 927 256 B    HW: 470 927 156 A
   Component: SL750 Lambo E-Gear  0935
   Revision: 00H01000    Serial number: 100048
   Shop #: WSC 02391 785 00200
   VCID: 1C3DB188DFCF94FE67F-8049
   Part No SW: 470 614 517 A    HW: 470 614 517 A
   Component: ESP8 quattro  H04 0160
   Coding: 020504
   Shop #: WSC 02311 785 00200
   VCID: 142DD9A8F71FDCBE2FF-8041
   Part No SW: 8K0 907 064 JM    HW: 8K0 907 064 JM
   Component: BCM2 2.0      H14 0650
   Coding: 0B201000000000000000
   VCID: 840D69E8077FCC3E3FF-80D1
   Subsystem 1 - Part No SW: 470 959 754 A    HW: 470 959 754 A
   Part No SW: 470 820 043 G    HW: 470 820 043 G
   Component: KLIMA 1 ZONE  H09 0110
   Revision: A1010000    Serial number: 01290120140032
   Coding: 4C322000
   VCID: 132FDAB4F211DB86365-8046
   Part No SW: 8K0 907 063 BE    HW: 8K0 907 063 P
   Component: BCM1 1.0      H30 0400
   Revision: 10030001    Serial number: 00000001688607
   Coding: 0428105800208F210700080300797900855C47C806030121000000
   VCID: 73EFBA34D2D17B86965-8026
   Subsystem 1 - Part No SW: 471 955 119     HW: 955 119
   Component: WWS83x ??????  H35 0010
   Coding: 000071
   Component: RLS  H04 0003
   Coding: 024237
   Subsystem 3 - Part No SW: 470 941 531 B    HW: 470 941 531 B
   Component: LCU  H02 0011
   Subsystem 4 - Part No SW: 8K0 907 410 C    HW: 8K0 907 410 C
   Component: HOMELINK  H01 0010
03674 - Indicator Lamp for Start-Stop Operation
                    Fault Status: 01101100
                    Reset counter: 0
                    Mileage: 103 km
                    Date: 2014.05.01
                    Time: 14:50:00
Address 10: Park/Steer Assist (J446)       Labels: None
   Part No SW: 470 919 475     HW: 8P0 919 475 N
   Component: PARKHILFE 8K  H01 0012
   Revision: 11001001    Serial number: 12561405600278
   Coding: 300101
   VCID: DEB97B80C95346EE49B-808B
Address 14: Susp. Elect. (J197)       Labels: None
   Part No SW: 470 907 376 B    HW: 470 907 376
   Component: Niveau-LB     H01 0009
   Serial number: WP5CFUBCN
   VCID: 1D3BBC8C04D59DF6901-8048
                    Fault Status: 00100001
                    Fault Frequency: 17
                    Mileage: 84 km
                    Date: 2014.05.01
                    Time: 14:33:15
                    Battery Volts: 15.5 V
                    RPM: 2040 /min
                    Speed: 30.6 km/h
                    Temperature: 13.5°C
                    (no units): 227.0
                    Mileage: 358 km
                    Date: 2014.05.21
                    Time: 12:06:50
                    Battery Volts: 14.5 V
                    RPM: 2346 /min
                    Speed: 35.7 km/h
                    Temperature: 18.5°C
                    (no units): 298.0
Address 15: Airbags (J234)       Labels: None
   Part No SW: 470 959 655 A    HW: 470 959 655 A
   Component: AirbagVW-AU10 H13 0100
   Serial number: 003M0D091ME+
   Coding: 303133313130303030304A55304C56303353
   ASAM Dataset: EV_AirbaAU10SMELB83X 001001
   ROD: N/A
   VCID: 234F8A742AB1AB06A65-8076
   Subsystem 1 - Part No SW: 470 959 339 B    HW: 470 959 339 B
   Serial number: 5810000R140000JF41
   Subsystem 2 - Serial number: 6334MSME416E022BD
   Subsystem 3 - Serial number: 6344MSME416E0336B
   Subsystem 4 - Serial number: 6352QSME1C422D64L
   Subsystem 5 - Serial number: 6362QSME0A41346EK
   Subsystem 6 - Serial number: 63732SME673E567CG
   Subsystem 7 - Serial number: 63832SME583D226EA
No ASAM data for: "EV_AirbaAU10SMELB83X" (AU48)
9446407 - ROD - Unknown Error Code
          - 00 [137]
                    Fault Frequency: 15
                    Reset counter: 0
                    Mileage: 83 km
                    Date: 2014.05.01
                    Time: 14:25:12
Address 16: Steering wheel (J527)       Labels: None
   Part No SW: 470 953 513 A    HW: 8K0 953 568 L
   Revision: --------    Serial number: 90815NC3000FD
   Coding: 000012
   VCID: 1629A3A0E1E3CEAE51B-8043
Address 17: Instruments (J285)       Labels: None
   Part No SW: 470 920 900 E    HW: 470 920 900 E
   Component: KOMBIINSTR.   H07 0060
   Revision: AA001001    Serial number:       10400023
   Coding: 0108329381B60080020000
   Part No SW: 8R0 907 468 N    HW: 8R0 907 468 C
   Component: GW-BEM 4CAN-M H11 0060
   Revision: 1Y080030    Serial number: 3041Y1421407A2
   Coding: 00E503FF00
   VCID: 4A9107D0E5DB5A4E053-801F
   Subsystem 1 - Part No SW: 8X0 915 181     HW: 8X0 915 181
   Component: J367-BDM  H07 0141
                    Mileage: 83 km
                    Date: 2014.05.01
                    Time: 11:32:24
                    Bin. Bits:    00000
                    Voltage: 12.10 V
                    Count: 7
                    Bin. Bits:    10000
                    Time: 0.40 s
   Part No SW: 01S 907 554 A    HW: 01S 907 554 A
   Component: HLSC 737 Lambo 4WD  0104
   Revision:   H45       Serial number:
   Coding: 0000001
   VCID: 336F7A3452513B86565-8066
   Part No SW: 470 959 793 A    HW: 4F0 959 793 AB
   Component: TSG FA        H11 0702
   Revision:             Serial number: 0000093995502
   Coding: 01064B025000420102
   VCID: 2649936051835E2EC1B-8073
                    Mileage: 117 km
                    Date: 2014.05.01
                    Time: 20:52:16
   Revision: 00002001    Serial number: 0328075571
   Coding: 011E029A18324081209000B600000000
   Subsystem 1 - Part No SW: 8F0 959 719 B    HW: 8K0 959 719
   Component: GTO BF  H01 0080
   Subsystem 2 - Part No: 8J0 951 177
   Component: DWA-Sensor  H03 0030
00526 - Brake Light Switch-F
                    Mileage: 83 km
                    Date: 2014.05.01
                    Time: 11:21:25
01699 - Motor for Central Locking; Hatch/Trunk (V53)
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 0
                    Mileage: 448 km
                    Date: 2014.05.21
                    Time: 19:32:25
   Part No SW: 470 959 792 A    HW: 4F0 959 792 AB
   Component: TSG BF        H11 0702
   Revision:             Serial number: 0000050448129
   Coding: 01064B825000420102
   VCID: 254B946C2C855536C81-8070
                    Mileage: 117 km
                    Date: 2014.05.01
                    Time: 20:52:16
Address 53: Parking Brake (J540)       Labels: None
   Part No SW: 470 907 801     HW: 8K0 907 801 H
   Component: EPB Audi B8   H09 0003
   Revision: 00000003    Serial number: 30000000010862
   VCID: D4AD99A8B79F9CBEEFF-8081
   Part No SW: 4G0 035 080 E    HW: 4G0 035 080
   Component: Radio U SIRIU H60 0121
   Revision: AB001007    Serial number: 158C40E7506688
   Coding: 020007020100000001
   VCID: 2045857833A7B01EBB7-8075
   Part No SW: 470 035 664 A    HW: 470 035 664
   Component: H-BN-NA       H51 0179
   Revision: --------    Serial number: 023CT0E7505275
   Coding: 010200020206816F01000306000000010000
   Subsystem 1 - Part No: 470 919 859 B
   Component: NAR 2010  0407
   Component: DU7 High  H42 0104
   Subsystem 3 - Part No SW: 470 919 609 B    HW: 470 919 609 B
   Component: E0380 Bedient  H01 0100
   Subsystem 4 - Part No: 8R0 060 961 A
   Component:   CD-Database  2712
Address 65: Tire Pressure        Labels: None
   Part No SW: 470 907 273     HW: 470 907 273
   Component: TPMS                0329
   Revision: 00H03000    Serial number: 00000000021270
   Coding: 0002891
   VCID: D7B76EA46669B7A60AD-8082
Address 6B: Aerodynamics (J920)       Labels: None
   Part No SW: 470 959 433 D    HW: 470 959 433 D
   Component: GFA 2012      H01 0004
   Serial number: 16100306400110
   Coding: 01006111
Address 6C: Back-up Cam.        Labels: None
   Part No SW: 470 907 441     HW: 8F0 907 441
   Component: J772__Rearview      0020
   Revision: --H09---    Serial number: 525PA8-J42B08S
   Coding: 4020012
   VCID: D4AD99A8779F9CBEEFF-8081
golfi_vend
Tartu, Estonia
C?ID=195131
I guess, the problem is that this car is so new, vcds doesn't have a file made for it.
Just wait and see, if geniuses of Ross-Tech can make a file for you.
But seriously 14 Aventador? How cool is that!
PanEuropean
Toronto, Canada
C?ID=11844
I dunno - I don't think it's all that impressive - the thing has more angles than a geometry teacher, and it makes an awful racket when it is running. It converts fuel to noise with efficiency that rivals Harley-Davidson.
I need to find the muffler controller and turn the sound down.
Michael
Well, the new-fangled UDS/ODX/ASAM protocol that VWAG started using in the B8 chassis Audis in 2007 or so, and that has now become pervasive is heavily data-driven. It's not possible to do very much with such a module without a data file that describes it. ROD files are our (proprietary, much more efficient) containers for such data. The error message you posted means that the version of VCDS you're using has no data for that module.
Although HDs do that very well, they do it without making absurd amounts of horsepower as a byproduct.
PanEuropean
Toronto, Canada
C?ID=11844
Thanks for explaining that Uwe.
Is a ROD file sort of like a replacement for a label file?
FYI I managed to get about 75% of the controllers on this car scanned at the 'debug level 2' setting this afternoon before I ran out of time to finish. I've already sent the PLB and PLA files in to the 'support' email. Are PLA and PLB files what you need to create ROD files, or do you need additional data? If you need additional data, is that something that I can suck out of the car with my VCDS application? If so, let me know and I will do that for you.
Also, I think it would be helpful to add this vehicle family to the "List of Supported Vehicle Families" within the PDF at this URL: VCDS Compatibility Charts.
Michael
No, it's not exactly a replacement. There are some similarities, but there's lower level stuff in there too. And the fact that a ROD file is needed for a particular module doesn't preclude there also being a label file for the same module.
Thank you!
No. However, PLA and PLB files continue to be useful for making Label files.
I can't think of anything else right now, but if Sebastian or anyone else can, they should chime in here.
Thanks again!
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Well, I think Michael officially won the first world problems meme. Turn out the lights on that one, we can all go home.
I need to be one of Michael's neighbors. What do the immigration laws look like for Americans moving to Canada? :)
Jason
Rick Scott
C?ID=245498
Glad I Found Ross-Tech
I was looking for information in all the wrong places. I think all "You Guy's" are Amazing and I Have a lot of catching up to do!! Thank You for creating this. Rick Scott
