Service still or past after reset?
Moxnix
C?ID=212386
Trying to figure out what I'm doing wrong. Tried to reset SRI after the work but I am still getting dashboard message "service due 10 days ago"
Saturday,02,April,2016,17:26:43:21746
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
Mileage: 44990km-27955mi   Repair Order: Audi SRI reset
VCDS Release 15.7.4:  SRI Reset
Control Module Part Number: 8K0 920 982 D       Labels:  8T0-920-xxx-17.clb
Component:KOMBIINSTR.   H35 0556, Coding:8BB409000301D705020000
Channel  	Description                                       	Unit      	Current val.  	New val.
02       	Service Reminder Status                           	          	1             	---
40       	Distance since Service                            	km x100   	3             	---
41       	Time since Service                                	Days      	26            	---
42       	Minimum Distance to Service                       	km x100   	150           	---
43       	Maximum Distance to Service                       	km x100   	150           	---
44       	Maximum Time to Service                           	Days      	365           	---
45       	Oil Quality                                       	          	1             	---
47       	Soot Quantity                                     	DIST x100 	0             	---
48       	Thermal Load                                      	DIST x100 	4             	---
49       	Minimum Time to Service                           	Days      	365           	---
50       	Basic Distance Value for Oil Change               	km x100   	160           	---
51       	Basic Time Value for Oil Change                   	Days      	365           	---
52       	Basic Distance Value for Inspection               	km x100   	160           	---
53       	Distance since Inspection                         	km x100   	126           	---
54       	Basic Time Value for Inspection                   	Days      	365           	---
55       	Time since Inspection                             	Days      	384           	---
56       	Day Counter                                       	Days      	1160          	---
Time since inspection (channel 55) exceeds Basic Time Value for Inspection (Channel 54). This will result in the service reminder being active.
Moxnix
C?ID=212386
Thanks, is there some way I can resolve this with?
Sure, perform all the maintenance required for a time-based inspection (brake fluid change, etc) and then set the Time Since Inspection channel to 0 days.
Moxnix
C?ID=212386
Hi Uwe, can you tell me where i might find the time since inspection channel to reset it to 0?
[Select]
[17-Instruments]
[Adaptation]
Channel 55
Put 0 in New Value
[Test]
[Save]
Moxnix
C?ID=212386
Got it many thanks, do I do a SRI reset after I "0" this value out? Thanks for taking the time.
The rest of your values look OK. At worst, you'll may have to put a 0 into channel 02.
Moxnix
C?ID=212386
Should I just go ahead and do both values and do a reset or does does entering the new values reset the reminder?
I'm not certain on your cluster.
What I'd do is set 55 to 0, then cycle the ignition (leave it off for 60 seconds), and go to the SRI Reset screen to get a fresh overview.
If Channel 02 is at 0, you should be good to go. If not, I'd set 02 to zero manually, cycle the ignition again, to verify it stays there, and then I'd set 40 and 41 to their current values (reflecting how long it's presumably been since the oil was changed).
Moxnix
C?ID=212386
Cool, let me get out in the garage and do this right now and I will let you know. Thanks for the advice!
Moxnix
C?ID=212386
Uwe, I believe we have success! Let me know if this is what it should look like. The message is gone so super thanks for the help.
Monday,04,April,2016,15:33:24:21746
VIN: WAUHFAFL2DA195461   License Plate:
Mileage: 27956   Repair Order: reset
Operation: Service Reset (USA only)
02       	Service Reminder Status                           	          	1             	0
40       	Distance since Service                            	km x100   	0             	---
41       	Time since Service                                	Days      	0             	---
45       	Oil Quality                                       	          	1             	1
48       	Thermal Load                                      	DIST x100 	0             	---
50       	Basic Distance Value for Oil Change               	km x100   	160           	160
51       	Basic Time Value for Oil Change                   	Days      	365           	365
52       	Basic Distance Value for Inspection               	km x100   	160           	160
53       	Distance since Inspection                         	km x100   	126           	0
54       	Basic Time Value for Inspection                   	Days      	365           	365
55       	Time since Inspection                             	Days      	0             	0
56       	Day Counter                                       	Days      	1162          	---
Well, channel 02 "Service Reminder Status" is still 1...
Moxnix
C?ID=212386
Uwe, I think that was a snafu with the copy paste . Here is what I see (the new value is "0")
45       	Oil Quality                                       	          	1             	1
BTW, Jetta 97 wrote that I didn't specify an operation which was true for that scan but that was just to show what was going on. I did do the "US" models only 2X before that.
Current Value is what's in there now.
New Value is what VCDS will attempt to put in when you click the [Perform SRI] button.
Moxnix
C?ID=212386
I will hook up again tonight. The dash message is gone so maybe I saved the log file before I performed the reset.
Moxnix
C?ID=212386
Thinking this is right?
02 Service Reminder Status 0 ---
53 Distance since Inspection km x100 0 ---
55 Time since Inspection Days 0 ---
56 Day Counter Days 1163 ---
Yup!
But to really do it right, you should go back and put the correct values in 40 and 41, so the car doesn't think it had service done today. ;)
Moxnix
C?ID=212386
Well let me ask you, i did all the work but it has just sat in the garage and only driven maybe 180 miles since. I really don't do much time based service, more on the actual mileage and usually early. Is this a bad protocol? I can certainly go back in now and put new values in those fields in but is it crucial if i do all my maintenance early? The car is only driven from downstate NY to the Adirondacks. 95+% highway. Only time I take it out.
