Audi Q7 2016 3.0TDI (4M Chassis)
Gavra
Melbourne/Belgrade
C?ID=240855
Just went to check this car and I was not able to read more then half of modules. Thought it was my interface, but another one had same problem. Address 46 not available no response from controller . Is this a known issue with newer cars?
rlarsen
Copenhagen, Denmark
C?ID=78998
Are you using the beta VCDS 16.3.1 which should work with the new Q7 (4M) - or are you using VCDS 15.7.4 which doesn't support the new Q7 (4M) ??
Gavra
Melbourne/Belgrade
C?ID=240855
Just installed 16.3.1 and Gateway is now accessible, however CV2 at 46 still not available. With ODIS I have full accessibility to 46.
Andy
Sector 7G
HC424490
Please post a complete AutoScan.
FYI, here's a scan from an MLBevo Q7:
http://forums.ross-tech.com/showthread.php?5633
I don't see 46 in the Gateway list. Sometimes ODIS uses different address numbers compared to VCDS. What is the part number of the controller you can read with ODIS?
Gavra
Melbourne/Belgrade
C?ID=240855
Yes there is no 46 in gateway but module exist. I will try to get car back to me for more testing as it's Saturday and customer had to go.
autoscan here :
Saturday,02,April,2016,23:56:25:04865
VCDS Version: 16.3.1.1
Data version: 20160325
VIN: WAUZZZ4M1GD001432   License Plate:
Chassis Type: 4M (4M2)
Scan: 01 02 03 06 08 09 13 15 16 17 18 19 28 36 3C 42 44 52 5F 69
          6C 6D 81 8B A5 AC CB
CB-Rear Axle Steering -- Status: OK 0000
Address 01: Engine (J623-CRTC)       Labels: None
   Part No SW: 4M0 907 401     HW: 059 907 309 B
   Component: 3.0TDI EDC17  H45 0003
   Revision: 91H45---
   Coding: 2A2A403A057E050335380000000000000000000000000000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_ECM30TDI0114M0907401 001007
   ROD: EV_ECM30TDI0114M0907401.rod
   VCID: 66C84A289974CC0C2E-8032
Address 02: Auto Trans (J217)       Labels: None
   Part No SW: 4M0 927 158 J    HW: 0D5 927 156 H
   Component: 0D5  30TDIRdW H03 1008
   Revision: --H03---
   Coding: 100000
   ASAM Dataset: EV_TCMALX52011 002010
   ROD: EV_TCMALX52011.rod
   VCID: 3B7ECB5CB276A1E4A1-806E
   Part No SW: 4M0 907 379 K    HW: 4M0 907 379 K
   Component: ESP9 Premium  H08 0514
   Coding: 1C9830B230A20A97D6A25894187F56AAE6A6DA380C0C506B1A186A5567655B
   ASAM Dataset: EV_ESP9BOSCHAU736 011006
   ROD: EV_ESP9BOSCHAU736_AU73.rod
   VCID: 3F86BF4CA66EBDC48D-806A
   Part No SW: 4M0 959 760 E    HW: 4M0 959 760 E
   Component: MEM-BFS       008 0014
   Serial number: 00000143640801
   Coding: 000010000000B0410000210101010000110000313100000000000000000000
   ASAM Dataset: EV_SCMPasseSideCONTIAU736 006007
   ROD: EV_SCMDriveSideCONTIAU736_AU73.rod
   VCID: 3A70CE58BD4C98ECBA-806E
Address 08: Auto HVAC (E87)       Labels: None
   Part No SW: 4M0 820 043 K    HW: 4M0 820 043 K
   Component: Klima Zone 4  H52 0052
   Coding: 6618481C5548401102620180800000000000000000000000000000000000
   ASAM Dataset: EV_AirCondiFrontBHTCAU736 001012
   ROD: EV_AirCondiFrontBHTCAU736.rod
   VCID: 2D5AF5047C023F542F-8078
   Subsystem 1 - Part No SW: 4M1 820 021     HW: 4M1 820 021
   Component: J216 FLuftV  H05 0001
   Part No SW: 8W0 907 063 G    HW: 4M0 907 063 G
   Component: BCM1 MLBevo   H12 0215
   Coding: 07501943E16900CD010D8714583F00F9130331009000000000000000E20016810A4501AB32B706
   ASAM Dataset: EV_BCM1BOSCHAU736 014003
   ROD: EV_BCM1BOSCHAU736_AU49.rod
   Subsystem 1 - Part No SW: 4M1 955 119 A    HW: 4H2 955 119 C
   Component: WWS536 140901  042 0792
   Serial number:         140904150530
   Coding: 1BC7F7
   Serial number: 20174789
   Coding: 02006C
   Subsystem 3 - Part No SW: 4M0 941 531 N    HW: 4M0 941 531 N
   Component: E1 - LDS  H05 0007
   Serial number: 18 03 2015  00015678
   Subsystem 4 - Part No SW: 4M0 857 511 A    HW: 4M0 857 511 A
   Component: Y7_Innenspieg  H08 0001
   Serial number: GX1CE124021511520120
   Coding: 030000
   Interior Light Module:
   Subsystem 5 - Part No SW: 4M0 947 135 AB    HW: 4M0 947 135
   Component: J528-Dachele  H12 0061
   Serial number: Q00006868
   Subsystem 6 - Part No SW: 4M0 925 301 B    HW: 4M0 925 301 B
   Component: SL-Q7NF/AU736  H09 0006
   Serial number: 00000000000000001577
Address 13: Auto Dist. Reg (J428)       Labels: None
   Part No SW: 4M0 907 561 C    HW: 4M0 907 561
   Component: LRR4          H08 0160
   Coding: 3477E7FB70FFEC08949880A4
   ASAM Dataset: EV_ACCBOSCHAU736 001016
   ROD: EV_ACCBOSCHAU736.rod
   VCID: 3064EC706B3052BC04-8064
Address 15: Airbags (J234)       Labels: None
   Part No SW: 4M0 959 655     HW: 4M0 959 655
   Component: Airbag10.44   H50 0084
   Serial number: 003L100027WN
   Coding: AAFCF0C00C80000098F600F3C00C00000000
   Shop #: WSC 52399 001 1048576
   ASAM Dataset: EV_AirbaAU10BPAAU736 005012
   ROD: EV_AirbaAU10BPAAU736_AU73.rod
   VCID: 78F41450C3C04AFC8C-802C
   Belt Pretensioner left:
   Subsystem 1 - Part No SW: 4M0 980 945     HW: 4M0 980 945
   Component: BeltPretRevFL  205 2033
   Serial number: 4M0857705D0093P00517
   Coding: 88001B
   Belt Pretensioner right:
   Subsystem 2 - Part No SW: 4M0 980 946     HW: 4M0 980 946
   Component: BeltPretRevFR  205 2033
   Serial number: 4M0857706D0093P00580
   Coding: 88001B
   Subsystem 3 - Part No SW: -----------    HW: 442 062 603 15
   Serial number: 3577Y00A517C3232923T
   Subsystem 4 - Part No SW: -----------    HW: 442 062 603 15
   Serial number: 3587Y00A517C3231415P
   Subsystem 5 - Part No SW: -----------    HW: 442 0B2 603 15
   Serial number: 3517700B91A14CE6317G
   Subsystem 6 - Part No SW: -----------    HW: 442 0B2 603 15
   Serial number: 3527700B91A14CE0A32F
   Subsystem 7 - Part No SW: -----------    HW: 442 0C2 603 15
   Serial number: 3557500A7196FF96830S
   Front Sensor Passenger:
   Subsystem 8 - Part No SW: -----------    HW: 442 0C2 603 15
   Serial number: 3567500A5196FF91834Q
   Pedestrian Protection Center:
   Subsystem 9 - Part No SW: -----------    HW: 442 0C2 605 14
   Serial number: 2307500C115397B3C1D9
   Subsystem 10 - Part No SW: -----------    HW: 442 420 611 14
   Component: PedPSensor_D2  21E 0887
   Serial number: I0M8U00A313216A4A7FL
   Subsystem 11 - Part No SW: -----------    HW: 442 420 611 14
   Component: PedPSensor_P2  21E 0887
   Serial number: I0N8U009D13216A2A4CN
   Central Sensor XY:
   Subsystem 12 - Part No SW: -----------    HW: 410 201 401 15
   Component: CentrSensorXY  1C8 0108
   Serial number: I0O7800A11196633E21S
Address 16: Steering wheel (J527)       Labels: None
   Part No SW: 4M0 907 129 HL    HW: 4M0 907 129 HL
   Component: Lenks.Modul   H11 0008
   ROD: EV_SMLSKLOAU736_AU49.rod
   VCID: 010279B4901A0B34BB-8054
Address 17: Instruments (J285)       Labels: None
   Part No SW: 4M0 920 781     HW: 4M0 920 781
   Component: TDIeRDWACC    H14 0243
   Coding: 040400E47C98000800A3E9603000600000000000
   ASAM Dataset: EV_DashBoardAU736 001018
   ROD: EV_DashBoardAU736.rod
   VCID: 6CDC38008798F65C78-8038
Address 18: Aux. Heat (J364)       Labels: None
   Part No SW: 4M0 265 105 A    HW: 4M0 265 105 A
   Component: HSG           H08 0040
   Coding: 0D0F01
   ASAM Dataset: EV_AuxilParkHeateEBEAU736 001014
   ROD: EV_AuxilParkHeateEBEAU736.rod
   VCID: 254A0D2424F20714E7-8070
   Part No SW: 4M2 907 468 A    HW: 4M2 907 468 A
   Component: Gateway       H13 0078
   Revision: 3C110040    Serial number: 4043C003D15322
   Coding: 0301000100000F407F000000005900325C9200070C0000000100000000000000
   ASAM Dataset: EV_GatewCONTIAU736 002040
   ROD: EV_GatewCONTIAU736.rod
   VCID: 3668DA6889547C8C5E-8062
   Subsystem 1 - Part No SW: 4M0 951 523     HW: 4M0 951 523
   Component: J453 MFL  H06 0002
   Serial number: 20141128141428 RD094
   Subsystem 2 - Part No SW: 8S0 915 181     HW: 8S0 915 181
   Component: J367-BDMHella  H10 9041
   Serial number: 1031866303
Address 28: HVAC, Rear (E265)       Labels: None
   Part No SW: 4M0 919 158 D    HW: 4M0 919 158 D
   Component: Klima Zone 2  H52 0051
   Coding: 000040000000000100820080000000000000000000000000000000000000
   ASAM Dataset: EV_AirCondiFondBHTCAU736 001012
   ROD: EV_AirCondiFondBHTCAU736.rod
   Component: MEM-FS        008 0014
   Serial number: 00000143640227
   ASAM Dataset: EV_SCMDriveSideCONTIAU736 006007
Address 3C: Lane Change (J769)       Labels: None
   Part No SW: 4M0 907 566     HW: 4M0 907 566
   Component: MRR1Rear      H13 0140
   Revision: --------
   Coding: 1EE002
   ASAM Dataset: EV_RearRadarS1BoschAU736 001015
   VCID: 72E02678A5BC20ACB2-8026
   Part No SW: 4M0 959 793 C    HW: 4M0 959 793 C
   Component: TSG FS        009 0020
   Serial number: 0000141711036
   Coding: 001F9B0050000480000130B0
   ROD: EV_DCU2DriveSideMAXHCONT.rod
   VCID: 3E78C248A164B4CC86-806A
Address 44: Steering Assist (J500)       Labels: None
   Part No SW: 4M0 909 144 E    HW: 4M0 909 144 B
   Component: EPS_MLBEVO1BS H17 0003
   Revision: --------    Serial number: 0000649758
   Coding: B0150101000101
   ASAM Dataset: EV_EPSVWBSAU736 006014
   ROD: EV_EPSVWBSAU736_AU49.rod
   VCID: 3162E974603A5BB40B-8064
   Part No SW: 4M0 959 792 C    HW: 4M0 959 792 C
   Component: TSG BFS       009 0020
   Serial number: 0000143699602
   Coding: 001F9B005C000480000130B0
   ROD: EV_DCU2PasseSideMAXHCONT.rod
   VCID: 3D7AC544AC62AFD49F-8068
   Part No SW: 4M0 035 021 B    HW: 4M0 035 021
   Component: MU-H-LND-EU   041 0358
   Serial number: A283C0FB000487
   Coding: 01370601FF0A000013111101000A00332F001BE5017001009E
   Shop #: WSC 23931 002 1048576
   VCID: 1E3822C801A4D4CCA6-804A
   Subsystem 1 - Part No SW: V03 959 802 CA    HW: -----------
   Component: ECE 2015  --- 0118
   Subsystem 2 - Part No SW: 4M0 919 605     HW: 4M0 919 605
   Component: AU536_DU_HIGH  H43 0008
   Serial number: AUZ8Z9FJ4003H5
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 4M0 919 615 D    HW: 4M0 919 615 D
   Component: ControlUnit_P  H14 0161
   Serial number: 23031500000000000026
   Compact Disc Database:
   Component: Gracenote2  --- 1008
Address 69: Trailer (J345)       Labels: None
   Part No SW: 4M0 907 383 D    HW: 4M0 907 383 B
   Component: Anhaenger     H18 0211
   Revision: 9A001002    Serial number: 0361756843
   Coding: 0110000202010000
   VCID: 336EE37C9A2669A479-8066
   Trailer Articulation Angle Sensor:
   Subsystem 1 - Part No SW: 4M0 907 811     HW: 4M0 907 811
   Component: G820 KNWINSEN  H18 0019
   Serial number: 2704
Address 6C: Back-up Cam. (J772)       Labels: None
   Part No SW: 4M0 980 556     HW: 4M0 980 556
   Component: RVC Compact   H08 0130
   Coding: 0237060113002025000044
   ASAM Dataset: EV_CamSysRVRVCPANAMLBEv 004008
   ROD: EV_CamSysRVRVCPANAMLBEv_AU49.rod
Address 6D: Trunk Elect. (J605)       Labels: None
   Part No SW: 4M0 959 107     HW: 4M0 959 107
   Component: HDSG-Modul    H12 0142
   Revision: --------    Serial number: 29911353300000
   Coding: 00F0
   ASAM Dataset: EV_DeckLidCONTIAU736 001010
   VCID: 70E42C70ABB012BC44-8024
   Part No SW: 4M1 713 041 D    HW: 4M1 713 041 D
   Component: GSM-LL        H07 0066
   Revision: 0L0D5012    Serial number: 20150304000523
   ASAM Dataset: EV_GSMWaehlZFAU736 001013
   ROD: EV_GSMWaehlZFAU736_AU49.rod
   VCID: 26480A2859F40C0CEE-8072
Address 8B: Adaptive Cruise 2 (J850)       Labels: None
   Part No SW: 4M0 907 541 C    HW: 4M0 907 541
   ASAM Dataset: EV_ACC2BOSCHAU736 001016
   ROD: EV_ACC2BOSCHAU736_AU73.rod
   VCID: 2E58F2087104444C16-807A
Address A5: Frt Sens. Drv. Assist (R242)       Labels: None
   Part No SW: 4M0 907 217 B    HW: 4M0 907 217 A
   Component: BVS           H11 0023
   Coding: 0407030600000402032023A7CD0000B4B0F0C020C020
   ASAM Dataset: EV_BVSMLBevKOSTAAU736 002020
   ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
Address AC: Reductant Control (J880)       Labels: None
   Part No SW: 4M0 907 355     HW: 4M0 907 355
   Component: SCR-Stg-G3H10 0003
   ASAM Dataset: EV_RDCMINERGAU736 005009
   ROD: EV_RDCMINERGAU736.rod
   VCID: 6ED83208B184044C56-803A
Address CB: Rear Axle Steering (J1019)       Labels: None
   Part No SW: 4M0 909 145 G    HW: 4M0 909 145 D
   Component: HAL_MLBevoH07 0607
   Revision: --------    Serial number: CCC_007_D_07_03
   Coding: 00852C
   ASAM Dataset: EV_RearAxleSteerZFAU736 005010
   ROD: EV_RearAxleSteerZFAU736_AU73.rod
   VCID: 346CE0609F286E9C60-8060
End-------------------------(Elapsed Time: 06:49)--------------------------
On display it have message Engine start error , yellow triangle and key icon. However car start and runs up to 3000rpm. Little confusing do.......and in 46 is key data stored , so there is 46 definitively. I will post HW number soon
Changed thread title to reflect 2016 model year (not 2015 as originally stated) and (brand new) 4M Chassis.
Gavra
Melbourne/Belgrade
C?ID=240855
I will probably have car with me next week for whole one day. Is there something you may use from this car? Should I use full scan with all channels in all modules?
Gavra
Melbourne/Belgrade
C?ID=240855
I am waiting for answer please, should I use standard Controller Channel map or something different on this vehicle?
andyhud
C?ID=32695
I couldnt find module 46 on my Q7 (4M) using 15.7.4. Are we saying its there and accesible for coding under the Beta version?
I need to find the link to download that and test with my Hex-Net interface!
Gavra
Melbourne/Belgrade
C?ID=240855
No mate, I am saying car have 46 but VCDS can't see it (yet) , you can see auto-scan result above ;)
andyhud
C?ID=32695
Got it, but your saying you can see it with ODIS v2.3.3?
Andy
Sector 7G
HC424490
Gavra
Melbourne/Belgrade
C?ID=240855
As soon he comes back..... 8W0907064AH Here u go , hope it's helpful for final version 16.x.x :)
andyhud
C?ID=32695
Fingers crossed we can read that module with v16.x.x.x
Would help if I can get my module 46 part number? If someone can tell me how I don't mind doing it!
Andy
Gavra
Melbourne/Belgrade
C?ID=240855
I asked local dealer to give me part number by VIN number.......fastest way for HW number . Or remove rear right panel in trunk and read it :)
andyhud
C?ID=32695
what exactly did you ask?
Gavra
Melbourne/Belgrade
C?ID=240855
Central convenience module for my VIN
Eric
HC800000
Andy
It won't work with the Beta either. This uses a new type of CAN addressing and I'm hopeful we'll have this working with the HEX-NET soon after we get a hold of a 2017 A4 here. No promise at all with the HEX+CAN.
andyhud
C?ID=32695
Thanks Eric, Uwe alluded to that also. I have the Hex-Net interface with latest firmware and a Q7 4M, so if its any benefit and you want a remote session etc to connect to look around, then please ask.
I'm happy to assist in its development.
Andy
automech
Poland
C?ID=14925
TCP/IP CAN bus??
