Hi All,
I have a 2010 1.6TDI VW Golf Bluemotion, engine CAYC with 99K miles on the clock. I have had an issue with this car engine recently and hope someone can assist please.
Until today, the car engine (when cold) started and then the idle revs fluctuated occasionally between 800-1200rpm until the engine has warmed up a little (2 minutes or so). Here's what I did today whilst investigating the issue...
All the output tests were completed successfully in 01-Engine module with Passes where appropriate.
I then went into Basic Settings and cycled through the various options and ran them.
Unfortunately by doing this I have made the problem a whole lot worse. The car now starts, shoots up to 1200rpm, down to around 600rpm, up and down and often stalls at idle when cold before attempting a restart. Oh dear.
No fault codes are present before or after my messing.
I am wondering what I have done wrong and if there is any way to back-track on what I did. One of the things I clicked on was 'adapting injector minimum deviation quantity'. This just revved the engine constantly between approx 2000-3200rpm for 10 minutes or so before I gave up on this and went to the next option. Would I mess up settings for injection deviation by doing this? The measuring values show negligible deviations on all 4 cylinders but I am looking for anything right now before I go down the mechanical route
My engine ECU software is up to date at version 9970. I have also checked with the dealer whether there are any outstanding workshop campaigns on my engine part number (03L 906 023 DQ) and VIN including TPI 23F7 and the dealer said that TPI doesn't affect my vehicle. This TPI addresses misfires and juddering at idle and I believe it involves changing the ECU which to me would cost plenty of $$$. Before I become committed to going down this route (and since the dealer says my VIN is not part of the recall), I am trying to figure out if it's something else I have done to make it worse...
Any help would be great. Thanks.
VCDS Version: 12.12.2.0
Data version: 20140212
VIN: WVWZZZ1KZBWxxxxxx License Plate:
Chassis Type: 1K (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 2E 42 44 46 52 56 61 62 72 77
Address 01: Engine (J623-CAYC) Labels: 03L-906-023-CAY.clb
Part No SW: 03L 906 023 DQ HW: 03L 906 023 A
Component: 1,6l R4 CR td H23 9970
Revision: --H23--- Serial number: 00000000000000
Coding: 00114034032501080000
ASAM Dataset: EV_ECM16TDI02103L906023DQ 003011
ROD: EV_ECM16TDI02103L906023DQ.rod
VCID: 78D9DB3DC3D22BDEA37-802D
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AT HW: 1K0 907 379 AT
Component: ESP MK60EC1 H30 0105
Revision: 00H30001
Coding: 133B200D09230002C81004EA90200091310000
VCID: 84213FCD071AFF3E3FF-80D1
Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
Part No SW: 3C8 907 336 AB HW: 3C8 907 336 AB
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000000003
ROD: EV_ClimaBasis_SE36.rod
VCID: 6DF7FA69BC909E76401-8038
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 084 D HW: 1K0 937 084 D
Component: BCM PQ35 B 103 0615
Revision: 00103 AD
Coding: 48180A3A8823F1C040080080340000E443510088436D8160648087200041
VCID: 2F4B20617E1C2C6632D-807A
Subsystem 1 - Part No: 1K2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 27051 21 0512
Coding: 009F95
Component: RLS 040610 05 54 0403
Coding: 0330AD
Component: LIN BACKUP HO H11 9004
Address 10: Park/Steer Assist (J446) Labels: 3C8-919-475.clb
Part No SW: 5K0 919 475 C HW: 5K0 919 475
Component: PARKHILFE 8K H07 0008
Revision: -------- Serial number: 12991009638098
Coding: 100001
VCID: 3645150581461DAE71B-8063
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5K0 959 655 D HW: 5K0 959 655 D
Component: AirbagVW10 037 0606
Serial number: 003FKRA8NJXT
Coding: 00003133
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3B530431B264C0C68E5-806E
Serial number: 3572MSME32216253ZZZH
Serial number: 3582MSME49596553ZZZ/
Serial number: 3512QSME3C306029ZZZQ
Serial number: 3522QSME3635614EZZZY
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 507 BC HW: 5K0 953 549 E
Component: Lenks.Modul 007 0080
Revision: -------- Serial number: 90440JF4000XU
Coding: 1082140000
ROD: EV_SMLSNGKUDS_SE36.rod
VCID: 72CDE915A5AE418E9D3-8027
Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D
Component: E221__MFL-TK6 H06 0022
Serial number: 70000000000000012586
Coding: E20000
Part No SW: 5K0 920 971 A HW: 5K0 920 971 A
Component: KOMBI H03 0406
Coding: 170B00
ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
VCID: 2D773A697C105E76001-8078
Address 19: CAN Gateway Labels: 7N0-907-530-V1.clb
Part No SW: 7N0 907 530 A HW: 1K0 907 951
Component: J533 Gateway H25 0602
Revision: H25 Serial number: 290510F2000109
Coding: E9A07F0600061204000003
VCID: 2E753D65B916256E39B-807B
Component: IMMO H03 0406
ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
VCID: EAFD71750D7E094EA53-80BF
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 C HW: 5N0 035 342 C
Revision: A1001003 Serial number: 7668119412
VCID: 277BC84156EC7426FAD-8072
Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
Component: Tuer-SG 009 2114
Coding: 0131764
VCID: 314F2619A8283A96249-8064
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 69 3001
Revision: 00H17000
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 5K0 959 702 C HW: 5K0 959 702 C
Coding: 0132020
VCID: 33432C1152340886565-8066
Address 56: Radio (J0503) Labels: 5M0-035-1xx-56.clb
Part No SW: 3C8 035 195 A HW: 3C8 035 195 A
Component: Radio RCD510 040 0166
Revision: 00000001 Serial number: VWZ1Z3K6478048
Coding: 0100040004
VCID: 2665C54551E66D2EC1B-8073
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H25 0602
Coding: 030B185A
VCID: F1CF661928A8FA96E49-80A4
Subsystem 1 - Part No SW: 1K0 915 181 C HW: 1K0 915 181 A
Component: J367-BDM H07 0125
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 5K0 959 703 C HW: 5K0 959 703 C
Component: Tuer-SG 007 2101
Coding: 0131216
Shop #: WSC 01357 011 1012552
VCID: 34412F0D573A0FBE4FF-8061
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 5K0 959 704 C HW: 5K0 959 704 C
Coding: 0131216
VCID: 354712095C4016B6781-8060
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 B HW: 7P6 035 730 B
Component: TELEFON H05 0440
Revision: 1B001001 Serial number: 00007668036283
Coding: 0A01000000010101
ASAM Dataset: UHVNA A01007
ROD: UHVNA.rod
VCID: 314F261960283A96249-8064
End ---------------------------------------------------------------------
