Audi RSQ3 Start-Stop system
Richard Hamilton
Maidenhead, UK
C?ID=271942
Hello All! Newbie here, so be gentle.
I have just bought a 2015 Audi RSQ3 (Model Year 2014 - UK Spec) and, like others, I'm finding the start-stop system annoying. It seems like no one has found the answer to changing the properties of the stop-start button to 'remember last setting' on the Q3/RSQ3, but others have found the solution for the Q5. This involves getting into the 09-Central Electronics > 16-Security Access. I have tried a few security access codes gleaned from Internet searches (20113, 31347, 12345) but none work. Anyone have a code specifically for the Q3/RSQ3 I could try? Here is the scan log:
Thursday,31,March,2016,18:31:51:60236
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
VIN: WUAZZZ8U6ER******   License Plate:
Mileage: 12420km-7717mi   Repair Order:
Chassis Type: 8U (8U0)
Scan: 01 02 03 08 09 10 15 16 17 19 20 22 25 42 44 46 47 52 53 55
          56 5F 62 72
VIN: WUAZZZ8U6ER******   Mileage: 12420km-7717miles
Address 01: Engine (CTS)       Labels: 07K-907-404-CEP.clb
   Part No SW: 8U0 907 404 A    HW: 8U0 907 404 A
   Component: 2.5l R5/4V TFSI  07 0003
   Revision: NIH53---    Serial number:
   Coding: 0161000C244F0160
   Shop #: WSC 00049 770 00009
   VCID: 36634B8441AC318E94-8062
Address 02: Auto Trans (J743)       Labels: 0BH-927-711.clb
   Part No SW: 0BH 300 012 C    HW: 0BH 927 711 C
   Component: DSG DQ500-7A  H08 2230
   Revision: 00H08V01
   ROD: EV_TCMDQ500021_AU21.rod
   VCID: 234582D02A3EB42643-8076
   Part No SW: 8U0 614 109 B    HW: 8U0 614 109 B
   Component: J104   C6 450M VDE3 0401
   Revision: --H07---    Serial number: 00000006356034
   Coding: 0057274
   Shop #: WSC 00049 770 00188
   VCID: 3467718C57D0239EAA-8060
   Part No SW: 8U0 820 043 E    HW: 8U0 820 043 E
   Component: E87  Klimavoll      0100
   Revision: 00H04000    Serial number: 8U0820043E
   VCID: 3365729052DE24A6B3-8066
Address 09: Cent. Elect. (J519)       Labels: 8X0-907-063.clb
   Part No SW: 8X0 907 063 N    HW: 8X0 907 063 N
   Component: BCM PQ35  M   112 0771
   Revision: AG112771
   Coding: 0E000A2CA805F1C0241841C82100084C53F785AA216F912BE408878400C5
   VCID: 479D3640F646B806FF-8012
   Subsystem 1 - Part No SW: 8U2 955 119     HW: 8U2 955 119
   Component: WWS316 130716  H36 0085
   Coding: 0047F7
   Coding: 02006E
   Subsystem 3 - Part No: 8X0 951 177
   Component: DWA-Sensor H0  H01 0020
Address 10: Park/Steer Assist (J446)       Labels: 8X0-919-475.clb
   Part No SW: 8X0 919 475 AB    HW: 4H0 919 475 AG
   Component: PARKHILFE 8K  H01 0060
   Revision: 11001001    Serial number: 61031323802121
   Coding: 88C307
   ASAM Dataset: EV_EPHVA18AU21X0000 003007
   ROD: EV_EPHVA18AU21X0000.rod
   VCID: 0603FB44B9CC610E44-8052
Address 15: Airbags (J234)       Labels: 8X0-959-655.clb
   Part No SW: 8U0 959 655 B    HW: 8U0 959 655 B
   Component: AirbagVW-AU10 H08 0520
   Serial number: 003LRR065NN6
   Coding: 30483132323030303030554A305238553053
   Shop #: WSC 00049 770 00119
   ASAM Dataset: EV_AirbaAU10SMEAU316 001005
   ROD: EV_AirbaAU10SMEAU316.rod
   VCID: 46833B44F94CA10E04-8012
   Subsystem 1 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
   Serial number: 3496KSME621F7A27ZZZ3
   Subsystem 2 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
   Serial number: 3506KSME620D7A27ZZZZ
   Serial number: 3516KSME561C7A27ZZZ$
   Serial number: 3526KSME0F167A27ZZZ
   Subsystem 5 - Part No SW: 8U0 959 651     HW: 8U0 959 651
   Serial number: 3555USME0D726125ZZZ
Address 16: Steering wheel (J527)       Labels: 8X0-953-569.clb
   Part No SW: 8X0 953 521 D    HW: 5K0 953 569 B
   Revision: FF010018    Serial number: 20130913301791
   Coding: 1894204000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 3D7154A8AC9AE2D655-8068
   Subsystem 1 - Part No SW: 8U0 951 528 H    HW: 8U0 951 528 H
Address 17: Instruments (J285)       Labels: 8X0-920-xxx-17.clb
   Part No SW: 8U0 920 990 F    HW: 8U0 920 990 F
   Component: KOMBI_COLOUR  H02 0231
   Coding: 44CF01
   ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04399
   VCID: 408F2D5CDB688F3E3E-8014
   Part No SW: 8U0 907 468 Q    HW: 8U0 907 468 G
   Component: GAT 4CAN 1L M H13 0063
   Revision: 1P120037    Serial number: 3741P139050606
   Coding: FBCF125A000100610353
   VCID: 50AF1D1C03087FBEAE-8004
   Subsystem 1 - Part No SW: 8U0 915 181 A    HW: 8U0 915 181 A
   Component: J367-BDM  H08 0190
   Subsystem 2 - Part No SW: 8K0 959 663 B    HW: 8K0 959 663 B
Address 20: High Beam Assist. (J844)       Labels: 8K0-857-511.clb
   Part No SW: 8U0 857 511 B    HW: 8U0 857 511 B
   Component: FLA           H03 0012
   Revision: AA002001
   Coding: 02020A64747464545425363E00
   VCID: 3A7B5FB4B5B4D5EE70-806E
   Part No SW: 0BS 907 554 D    HW: 0BS 907 554 D
   Component: Haldex 4Motion      4017
   Coding: 0000005
   VCID: 479D36403646B806FF-8012
   Component: IMMO          H02 0231
   Coding: 000002
   ROD: EV_Immo_UDS_VDD_AU10.rod
Address 42: Door Elect, Driver (J386)       Labels: 8X0-959-793.clb
   Part No SW: 8X0 959 793 H    HW: 8X0 959 793 H
   Component: TSG FA        H10 0415
   Coding: 011E06205C01000000
   VCID: 52AB17140D040DAE98-8006
   Part No: 5N0 909 144 R
   Component: EPS_ZFLS Kl. 295    3501
   Revision: 00H22000
   Shop #: WSC 00049 770 00193
   VCID: 408F2D5C13688F3E3E-8014
Address 47: Sound System (J525)       Labels: Redir Fail!
   Part No SW: 8X0 035 223 D    HW: 8X0 035 223 B
   Component: BOSE-G3-A1Q3  H05 0160
   Revision: CK005201    Serial number: 00000000002758
   Coding: 030000
   VCID: 3365729092DE24A6B3-8066
Address 52: Door Elect, Pass. (J387)       Labels: 8X0-959-792.clb
   Part No SW: 8X0 959 792 H    HW: 8X0 959 792 H
   Component: TSG BF        H10 0415
   Coding: 011E06205E01000000
   VCID: 51A91818080276B6A1-8004
   Revision:   H19       Serial number: 00000001431129
   Coding: 0025167
Address 55: Headlight Range (J431)       Labels: 8X0-907-357.clb
   Part No SW: 8X0 907 357 C    HW: 8X0 907 357 B
   Serial number: 130916-0002-046
   Coding: 1157A4101000A500
   ROD: EV_HeadlRegulBasic.rod
   VCID: 428B2754D5649D2E28-8016
   Part No SW: 4G0 035 061 L    HW: 4G0 035 061
   Component: Radio U DAB   H60 0133
   Revision: AB001007    Serial number: 109H/0D7703277
   Coding: 010105010000000002
   VCID: 26439BC4510C410E24-8072
   Part No SW: 8U0 035 666 H    HW: 8U0 035 666 D
   Component: H-BN-EU       H45 0732
   Revision: --------    Serial number: 199IA0D7518528
   Coding: 21010106030AE0E90580033600000001E00000020000000000
   VCID: 3F8D2EA0AE96F0C647-806A
   Subsystem 1 - Part No: 8R0 060 884 BC
   Component: EUR 2013/2014  1603
   Subsystem 2 - Part No SW: 8U0 919 604     HW: 8U0 919 604
   Component: DU High AU316  H41 0018
   Subsystem 3 - Part No: 8R0 060 961 F
   Component: CD-Database  5298
   Part No SW: 8X0 959 795 C    HW: 8X0 959 795 C
   Component: TSG HL        H07 0415
   Coding: 010E06200001000000
   VCID: 4FAD1E601E366046B7-801A
   Component: TSG HR        H07 0415
End-------------------------(Elapsed Time: 03:41)--------------------------
Richard
I don't have the answer for you but the A4/A5/Q5 is an entirely different animal in the BCM department. Based on your module type (Component: BCM PQ35) I would search for Mk6 Golf based VW model feedback. The closest may be the 2010+ Tiguan but close siblings could include the Mk6 Golf/Gti, Eos, Jetta and even the 2010+ 8P A3 or the R8 from that 2010+ time frame.
Richard Hamilton
Maidenhead, UK
C?ID=271942
Many thanks Dana. I found a code for the Mk6 Golf (40168) but that didn't work either.
"gienol" on this forum and the Audi Q3 Owners Club forum has changed the coding of the Central Electronics module, and deactivated the system. Here is a screenshot of Byte 26 of the CE system:
He de-selected Bit 0, which de-activated the system, albeit that he gets the DIS icon showing the start-stop system is inactive.
I am reluctant to do this, and would prefer to change the default button operation to 'default is off' or 'remember last setting' as others have done on other models.
Is there a way of finding out what Bits 4, 5, and 6 do?
pronet
Romania
C?ID=157414
It's not posible to set it off by default. Try to alterate the voltage for S&S in adaption-can gateway. Or unplug the socket fitted on battery.
Richard Hamilton
Maidenhead, UK
C?ID=271942
Maybe not possible, or maybe nobody has worked it out yet. :)
Is this the procedure you are recommending (taken from another forum)?
[De Activation of Start-Stop]
Select STG 19 (can gateway)
STG adjustment -> function 10
Start-Stop Voltage Limit>12V (New Value)
So, as a temporary measure, would someone mind explaining how I add the new value to the CAN Adaptation
I can't work out what I have to do from the Adaptation screen.
