Passat 2011 BCM coding byte 18
Ardi
C?ID=41958
can you help with passat 09 central electronic coding i have so many
problem when i put light in position the position light no light only
little and left rivers light are on can you give my factory coding. and
CCS (cruise control) not working they replace steering wheel they put
with buttons and steering column here is auto scan
regards Ardi
Log-PASAT-WVWZZZ3CZBP358468.txt
Tuesday,20,May,2014,19:52:00:20848
VCDS Version: 12.12.2.0
Data version: 20140212
VIN: WVWZZZ3CZBP358468   License Plate: PASAT
Chassis Type: 3C (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 37 42 44 46 4F 52 53 56 61 62
          72
Address 01: Engine (J623-CFFB)       Labels: 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 BF    HW: 03L 907 309 N
   Component: R4 2,0L EDC   H24 7852
   Revision: 47H24---    Serial number: VWZCZ000000000
   Coding: 00190012042401080000
   Shop #: WSC 00028 028 00032
   ASAM Dataset: EV_ECM20TDI01103L906018BF 003005
   ROD: EV_ECM20TDI01103L906018BE.rod
   VCID: 6FE67E00B6CC7C6672D-803A
10065 - Mass Air Flow Sensor (G70)
          P0104 00 [032] - Intermittent
                    Mileage: 148326 km
                    Date: 2034.14.10
                    Time: 18:16:48
4483 - Function Restriction due to Faults in Other Modules
          U1113 00 [039] - -
                    Fault Frequency: 15
                    Mileage: 148326 km
                    Date: 2034.14.10
                    Time: 18:16:47
   Part No SW: 3AA 614 109 M    HW: 3AA 614 109 M
   Component: J104   C2 450M V43E 0005
   Revision: --H07---    Serial number: 00000004188749
   Coding: 0002480
   Shop #: WSC 00028 028 00001
   VCID: 37768660461CF4A66AD-8062
   Part No SW: 5K0 907 044 DT    HW: 5K0 907 044 DT
   Component: Climatronic   H17 1010
   Revision: 00003001
   Coding: 0000000003
   Shop #: WSC 00028 028 00302
   ROD: EV_ClimaAutoBasis_SE36.rod
   VCID: 8004ADBC1B52F31E1B7-80D5
Address 09: Cent. Elect. (J519)       Labels: 3AA-937-087.clb
   Part No SW: 3AA 937 087 A    HW: 3AA 937 087 A
   Component: BCM PQ47 H    413 0452
   Revision: BB413001
   Coding: 000000000000000000180080140083E403510088406C8160E480C7200041
   Shop #: WSC 22611 123 22611
   VCID: 3874855C8B02FBDE637-806D
   Subsystem 1 - Part No SW: 3AB 955 419     HW: 3AB 955 419   Labels: 1KX-955-119.CLB
   Component: Wischer 16041  10  0603
   Coding: 00B795
   Component: RLS 160511 05  54  0403
   Coding: 033028
Address 10: Park/Steer Assist (J446)       Labels: 3AE-919-475.clb
   Part No SW: 3AE 919 475     HW: 7N0 919 475
   Component: PARKHILFE 8K  H04 0009
   Revision: --------    Serial number: 77631113105301
   Coding: 108001
   ASAM Dataset: EV_EPHVA18VW47X0000 001003
   ROD: EV_EPHVA18VW4280000_SE36.rod
   VCID: FCFCD94C77BA97FE47F-80A9
   Part No SW: 5N0 959 655 R    HW: 5N0 959 655 R
   Component: J234__101 VW10 HI   1918
   Revision: 22014000    Serial number: 003K0P8ZKNRW
   Coding: 0012337
   VCID: 4C9CC98C2F9A677E37F-8019
   Subsystem 1 - Serial number: 6332MTS622911171
   Subsystem 2 - Serial number: 6342MTS647911091
   Subsystem 3 - Serial number: 6351HTS68CFB1AKJ
   Subsystem 4 - Serial number: 6361HTS67RJQ0AKJ
   Part No SW: 5K0 953 569 AR    HW: 5K0 953 569 AR
   Revision: --X01---    Serial number: 20140419201325
   Coding: 0182250000
   VCID: 8814B59C3362CB5E537-80DD
   Subsystem 1 - Part No SW: 3C8 959 537 D    HW: 3C8 959 537 D
   Coding: E20000
Address 17: Instruments (J285)       Labels: 3C8-920-xxx-17.clb
   Part No SW: 3AA 920 870 A    HW: 3AA 920 870 A
   Coding: 160D00
   ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
   VCID: 3064BD7C6B72239E2B7-8065
   Part No SW: 7N0 907 530 G    HW: 1K0 907 951
   Component: J533  Gateway H41 1614
   Revision:   H41       Serial number: 080511F2003672
   Coding: 461006
   VCID: 346CB16C976A1FBE4FF-8061
   Part No SW: 3AA 959 433     HW: 3AA 959 433
   Component:    IMMO         043 0399
   Revision: 00043000    Serial number: VWZCZ000000000
   VCID: F6E8CB648196CDAE31B-80A3
Address 37: Navigation (J794)       Labels: 1K0-035-27x-37.clb
   Part No SW: 3C0 035 279     HW: 3C0 035 279
   Component: RNS315        H05 0010
   Serial number: VWZAZ2L3341985
   Coding: 000004110400000000011000
   ASAM Dataset: EV_RNS315VWEUV1UDS A01005
   ROD: EV_RNS315VWEUV1UDS.rod
   VCID: E0C48D3CFB12531E7B7-80B5
   Part No SW: 3AA 959 701 A    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0533
   Revision: 12110009    Serial number: 0002851616
   Coding: 0210B7
   ROD: EV_TSGFPQ35BRFVW46X.rod
   VCID: 356A8C68941006B6781-8060
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 703     HW: 3C0 959 795   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0408
   Serial number: 00000002153496
   Coding: 000090
   Part No SW: 5N1 909 144 L    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.309 0802
   Revision: 1AH03729    Serial number: 00111220205501
   Coding: 0000258
   VCID: 3B7E9A507A34D0C68E5-806E
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Component:    KSG PQ47 ELV 043 0631
   Coding: 00910A0002860E76300494157C084F0B607C01
   Component: EZE_2         H41 1614
   Coding: 00000008
   VCID: EFE6FE003ECCFC66F2D-80BA
   Subsystem 1 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
   Component: Analoguhr  004 0003
   Part No SW: 3AA 959 702 A    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0533
   Revision: 14110009    Serial number: 0002856521
   Coding: 0210B6
   ROD: EV_TSGBPQ35BRFVW46X.rod
   VCID: 36688B6489160DAE71B-8063
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 704     HW: 3C0 959 794   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0408
   Serial number: 00000002156023
   Coding: 000090
   Part No SW: 3AA 907 801 E    HW: 3AA 907 801 E
   Component: J540 EPB4  VW-55183 0007
   Revision:   H18       Serial number: 00000000345932
   Coding: 0022067
   VCID: 336EB27052641886565-8066
   Component: Batt.regelung H41 1614
   Coding: 030B185A
   VCID: F1E2F87828F8EA96E49-80A4
   Subsystem 1 - Part No SW: 1K0 915 181 F    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0150
Ardi
C?ID=41958
Can somebody help with byte 18
Ardi
C?ID=41958
Hi
i finish coding with byte 18 i put 64
Hi Ardi,
Thanks for the update! The 3AA series BCM isn't used on many NAR models so the feedback is limited but I'm sure this will help RoW customers in the future.
-Dana
