No ASAM data !!!
Steve62
Canada
C?ID=273846
Hello all,
Not sure if this is the correct place to post this or not, very new to all this. A little background on my car. 2015 Jetta 1.8 TSI SE with Connectivity package, Phone, Sat, Media, no Nav. Bought this car with minor front damage.... left fender, bumper, rad, intercooler, condenser, active grille. Repaired damage and all is well....so far. Posting 2 Auto scans, first scan is before any repairs were made, the second scan was after all repairs were done, including a software update at the dealer for the camshaft issue. After doing the second scan VCDS asked to make sure I was using the latest version of software as it could not find ASAM data for something. If using the most recent version please email copy of scan to Ross-Tech. Both scans were done with the same version of VCDS 15.7.4
Hope the "code" thing works.
First Scan
Saturday,12,March,2016,10:03:23:09767
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
VIN: 3VWD07AJXFM287254   License Plate:
Mileage: 18370km-11414mi   Repair Order:
Chassis Type: AJ (6N0)
Scan: 01 02 03 08 09 15 17 19 25 2E 44 56 77 0B
VIN: 3VWD07AJXFM287254   Mileage: 18370km-11414miles
Address 01: Engine (J623-CPKA)       Labels: 06K-907-425-V2.clb
   Part No SW: 06K 906 071 B    HW: 06K 907 425 C
   Component: Simos18.2     H13 8099
   Revision: --H13---
   Coding: 001A0012242400164000
   Shop #: WSC 00066 790 00016
   ASAM Dataset: EV_ECM18TFS02006K906071B 001004
   ROD: EV_ECM18TFS02006K906071B.rod
   VCID: 2A5B6B304DD90E6E00-807E
23949 - Active Radiator Shutter 1
          P05A2 00 [175] - Open Circuit
                    Mileage: 18375 km
23176 - Sensor for Ambient Air Temperature (G17)
          P0070 00 [032] - Malfunction
                    Mileage: 18375 km
23955 - Active Radiator Shutter 1
          P05A3 00 [036] - Implausible Signal
                    Mileage: 18375 km
                    Date: 2016.02.28
                    Time: 13:05:57
24558 - Implausible Data Received from Instrument Panel Control Module
          U0423 00 [032] - -
                    Mileage: 18375 km
                    Date: 2016.02.28
                    Time: 13:05:54
Readiness: 1110 0101
Address 02: Auto Trans (J217)       Labels: 09G-927-749.clb
   Part No SW: 09G 927 749 A    HW: 09G 927 749 A
   Component: AISIN AG6 G3  129 2856
   Coding: 000348
   ASAM Dataset: EV_TCMAQ250031 001004
   ROD: EV_TCMAQ250031_AU37.rod
   VCID: 377D42448E6BA3868F-8062
   Part No SW: 1K0 907 379 BS    HW: 1K0 907 379 BS
   Component: ESP MK60EC1   H46 0166
   Revision: 00H46001
   Coding: A14B400C492A0001850D02E9921D0041A1100010
   Shop #: WSC 00066 000 00000
   VCID: 0407E588873D381E5A-8050
                    Fault Status: 00101101
                    Reset counter: 84
                    Mileage: 18373 km
                    Date: 2015.12.12
                    Time: 04:47:29
                    Count: 32768
                    Count: 4608
                    Count: 8193
                    Count: 51539
                    Count: 1022
   Part No SW: 1K8 907 044 E    HW: 1K8 907 044 E
   Component: Climatronic   H05 0102
   Revision: 00001K02
   Coding: 001000C002
   Shop #: WSC 00066 000 00119
   VCID: 31697C5C600F7DB6C1-8064
13701968 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Fault Frequency: 41
                    Reset counter: 84
                    Mileage: 18371 km
                    Date: 2015.11.23
                    Time: 23:08:52
          B10AB F0 [009] - Too Low
                    Reset counter: 44
                    Mileage: 18375 km
                    Date: 2016.03.12
                    Time: 09:24:44
9480469 - Control Circuit for A/C Compressor
          B10A9 15 [008] - Open or Short to Plus
                    Reset counter: 84
                    Mileage: 18375 km
                    Date: 2016.02.17
                    Time: 00:00:22
Address 09: Cent. Elect. (J519)       Labels: 7H0-937-08x-09.clb
   Part No SW: 7H0 937 090 E    HW: 7H0 937 090 A
   Component: BCM PQ25 Max3 H78 0725
   Revision: B8078001    Serial number: 78003352140538
   Coding: 7B994B9A082B0F0008382080240884C50FC6702E60000050B00010022844
   VCID: 306F7958630574BECE-8064
   Subsystem 1 - Part No SW: 6R0 959 801 AN    HW: 6R0 959 801 AN  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  006 5461
   Coding: 820000
   Subsystem 2 - Part No SW: 6R0 959 802 AS    HW: 6R0 959 802 AS  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  006 5461
   Coding: 820000
   Subsystem 3 - Part No: 5K0 959 591 A
   Component: J245 PS41.402  H02 0003
   Coding: 180000
   Subsystem 4 - Part No SW: 6C0 959 442 A    HW: 6C0 959 442 A
   Component: E221__MFL-TAT  H04 0019
   Coding: 280000
   Subsystem 5 - Part No SW: 6R0 959 811 M    HW: 6R0 959 811 M
   Component: J388__TSG_HL  006 5460
   Coding: 800000
   Subsystem 6 - Part No SW: 6R0 959 812 M    HW: 6R0 959 812 M
   Component: J389__TSG_HR  006 5460
   Coding: 800000
                    Fault Status: 00100001
                    Fault Frequency: 15
                    Reset counter: 84
03591 - Control Circuit for Horn
                    Reset counter: 44
                    Mileage: 18371 km
                    Date: 2015.11.23
                    Time: 23:08:47
                    Fault Status: 00101010
                    Reset counter: 84
                    Mileage: 18375 km
                    Date: 2016.02.17
                    Time: 00:00:08
                    Reset counter: 84
                    Mileage: 18375 km
                    Date: 2016.02.17
                    Time: 00:00:08
   Part No SW: 5C0 959 655 AB    HW: 5C0 959 655 AB
   Component: AirbagVW10    500 0975
   Serial number: 003LZD042G9H
   Coding: 00005046
   ASAM Dataset: EV_AirbaVW10SMEVW360 001030
   ROD: EV_AirbaVW10SMEVW360_SE36.rod
   VCID: 72EBB350A58906AE78-8026
   Serial number: IBH0000J1400025VOY0.
   Coding: 303144
   Serial number: 3572MSME79276849ZZZ2
   Serial number: 3582MSME250F7A49ZZZ3
   Serial number: 3516KSME31424732ZZZF
   Serial number: 3526KSME67790933ZZZY
   Serial number: 3556LSME57077531ZZZT
   Serial number: 3566LSME6D047531ZZZY
9443861 - Driver's Front Airbag Crash Sensor
          B101A 15 [136] - Open or Short to Plus
                    Mileage: 18375 km
                    Date: 2016.02.17
                    Time: 00:00:07
9444117 - Front Passenger's Front Airbag Crash Sensor
          B101B 15 [136] - Open or Short to Plus
                    Mileage: 18375 km
                    Date: 2016.02.17
                    Time: 00:00:07
   Part No SW: 5C6 920 854 B    HW: 5C6 920 854 B
   Component: KOMBI         H04 0806
   Coding: 370E00
   VCID: 2C576D28472D105EF2-8078
9453330 - Outside temperature sensor
          B103F 1B [008] - Resistance Too High
                    Fault Frequency: 12
                    Reset counter: 84
                    Mileage: 18371 km
                    Date: 2015.11.23
                    Time: 23:08:45
Address 19: CAN Gateway (J533)       Labels: 6N0-909-901-6R.clb
   Part No SW: 6N0 909 901     HW: 7H0 937 090 A
   Component: GW-K-CAN TP20 H78 0725
   Revision: B8078001
   Coding: 102200
   VCID: 70EFB958A38534BE8E-8024
   Component: IMMO          H04 0806
   VCID: 6ADBAB308D59CE6EC0-803E
Address 2E: Media Player 3
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 306    3501
   Revision: 00H22000
   Shop #: WSC 02069 000 90108
   VCID: 3979447C707FB5F679-806C
Address 56: Radio (J503)       Labels: None
   Part No SW: 1K0 035 188 H    HW: 1K0 035 188 H
   Component: Radio Prem-8  H07 0009
   Revision: -----12S    Serial number: VWZ4Z7P3649072
   Coding: 21000440020006
   VCID: 2D51602C74371956E5-8078
            000 -  -
                    Reset counter: 44
                    Mileage: 2060 km
                    Date: 2015.07.28
                    Time: 03:37:51
                    Reset counter: 69
                    Mileage: 16220 km
                    Date: 2015.11.15
                    Time: 05:07:54
Address 77: Telephone (J412)       Labels: 5N0-035-729.clb
   Part No SW: 5N0 035 729 E    HW: 5N0 035 729 E
   Component: TELEFON       H07 0593
   Revision: 1B001001    Serial number: 00007666789215
   Coding: 0210030080010110
   Shop #: WSC 01383 790 50316
   ROD: EV_UHVUMI.rod
   VCID: 326B7350650946AEB8-8066
End-------------------------(Elapsed Time: 03:17)--------------------------
Second Scan
Monday,28,March,2016,16:05:02:09767
VIN: 3VWD07AJXFM287xxx   License Plate:
Mileage: 19420km-12067mi   Repair Order:
VIN: 3VWD07AJXFM287254   Mileage: 19420km-12067miles
Address 01: Engine (J623-CPKA)       Labels: None
   Part No SW: 06K 997 071 B    HW: 06K 907 425 C
   Component: R4 1.8l TFS   H13 2976
   Revision: --H13---
   ASAM Dataset: EV_ECM18TFS02006K997071B 001002
   ROD: N/A
   VCID: 346775489F1D489EAA-8060
No ASAM data for: "EV_ECM18TFS02006K997071B" (VW36)
Readiness: 0000 0100
   Coding: 000348
   Revision: 00H46001
   Revision: 00001K02
   Coding: 001000C002
   Coding: 820000
   Coding: 820000
   Coding: 180000
   Coding: 280000
   Coding: 800000
   Coding: 800000
   Coding: 00005046
   Coding: 303144
   Coding: 370E00
   Revision: B8078001
   Coding: 102200
   Revision: 00H22000
            000 -  -
                    Reset counter: 63
                    Mileage: 19343 km
                    Date: 2016.03.28
                    Time: 01:22:53
   ROD: EV_UHVUMI.rod
End-------------------------(Elapsed Time: 03:13)-
Car seems to work fine, I guess the question is did I do something different between the scans?
OK, that's because the ASAM dataset name changed as a result of the software update your dealer did.
It went from:
EV_ECM18TFS02006K906071B to:
Should be covered again in an upcoming version.
