Auto Scan Testing: 2007 RS4
AmoTHS
C?ID=215720
I bought a Hex Net device and finally got my car back from the dealer today to run a scan. Running Windows 7 with IE 9 (can't update IE, can try with Chrome next time). Wireless Infrastructure mode, connected to my iPhone. Autoscan hung on 0F. I tried to update and the update process crashed, I will try again tomorrow connecting to my home wifi as opposed to my phone.
Chassis Type:8E
Scan:
	 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
	 69 75 76 77
VIN: WUARU78E27N900712
Address 01: Engine	Labels:079-910-560-BNS1.lbl
	Part Number SW: 8E1-910-560-A	HW: 8E1907560
	Component: 4.2L V8/4V FSI     ª0060
	Revision: --H09---	Serial Number: XXXXXXXXXXXXXX
	Coding: 01040009180F0160
	Shop #: WSC 08307 444 91149
	VCID: 240B7F93B5EBEFF4216A8FA-8071
000547 - Angle Sensor 2 for Throttle (G188)
	P0223 - 001 - Signal Too High - Intermittent
000289 - Throttle Position Sensor (G69)
	P0121 - 008 - Implausible Signal - Intermittent
Address 03: ABS Brakes	Labels:8E0-910-517.lbl
	Part Number SW: 8E0-910-517-G	HW: 8E0614517BD
	Component: ESP8 quattro    H06  0150
	Revision: 00000000	Serial Number: 00000000000000
	Coding: 0004533
	Shop #: WSC 06335 000 00000
	VCID: 2B1994AFD835208CE0B0DCE-807E
18265 - Load Signal
	P1857 - 000 - Error Message from ECU - Intermittent
Address 09: Cent. Elect.	Labels:8E0-907-279-8EC.lbl
	Part Number SW: 8E0-907-279-N
	Component: int. Lastmodul  USA 0907
	Coding: 01023
	VCID: 3D3DAAF73641AF3C4E64A26-4B3C
No fault codes found.
I downloaded the 14.5.2 App and was able to complete a scan
Wednesday,21,May,2014,22:01:34:08204
VCDS Version: 14.5.2.0
Data version: 20140520
VIN: WUARU78E27N900712   License Plate:
Mileage: 71430km-44384mi   Repair Order:
          67 69 75 76 77
VIN: WUARU78E27N900712   Mileage: 71430km-44384miles
Address 01: Engine        Labels: 079-910-560-BNS1.lbl
   Part No SW: 8E1 910 560 A    HW: 8E1 907 560
   Revision: --H09---    Serial number: XXXXXXXXXXXXXX
   VCID: 24042BE3E7FBF31BFF-8071
                    Fault Status: 00100001
                    Mileage: 71332 km
                    RPM: 2043 /min
                    Load: 22.7 %
                    Speed: 27.0 km/h
                    Temperature: 96.0°C
                    Temperature: 30.0°C
                    Absolute Pres.: 1020.0 mbar
                    Voltage: 13.335 V
                    Mileage: 71340 km
                    RPM: 3370 /min
                    Load: 16.9 %
                    Speed: 53.0 km/h
                    Temperature: 96.0°C
                    Temperature: 30.0°C
                    Voltage: 12.192 V
   Part No SW: 8E0 910 517 G    HW: 8E0 614 517 BD
   Coding: 0004533
   VCID: 2B16C0DF8A253C633E-807E
                    Fault Status: 00101101
                    Fault Frequency: 12
                    Reset counter: 36
                    Hex Value: 0x0000
                    Hex Value: 0x4002
                    Hex Value: 0x0025
                    Hex Value: 0x0194
                    Hex Value: 0x0001
18265 - Load Signal
                    Reset counter: 35
                    Hex Value: 0x3600
                    Hex Value: 0x6206
                    Hex Value: 0x0028
                    Hex Value: 0x01A5
                    Hex Value: 0x0001
   Part No: 8E0 907 279 N
   Coding: 01023
   Shop #: WSC 06335
   VCID: 3D32FE873551A2D390-4B3C
   Part No SW: 8E0 035 593 F    HW:
   Component: SDAR SIRIUS
   Revision:             Serial number: AUZ4Z7F2027350
   VCID: 2C14C3C38D2B3B5B37-51A8
Address 11: Engine II        Labels: 079-910-560-BNS2.lbl
   Part No SW: 8E0 959 655 H    HW: 8E0 959 655 H
   Component:    Airbag 9.41  H12 3840
   Revision: 91H12384    Serial number: 0036N001XUU/
   Coding: 0432607
   VCID: 3C34F3837F4BABDBA7-8069
   Subsystem 1 - Part No: 8E0 910 339 B
   Component: BF-Gewichtsens. 002 0070
   Subsystem 2 - Serial number: 3BVDF
   Subsystem 3 - Serial number: 0001.01.000000200000000000ÿ†63
   Subsystem 4 - Serial number: 000000ÿ†6332DRB4032DC891Vÿ†63
   Subsystem 5 - Serial number: DC891Vÿ†6342DRB4035107B1Cÿ†63
   Subsystem 6 - Serial number: 107B1Cÿ†6352ARB4014663CFTÿ†63
   Subsystem 7 - Serial number: 663CFTÿ†6362ARB401423629Aÿ†63
   Subsystem 8 - Serial number: 23629Aÿ†63729RB40149B10DMÿ†63
   Subsystem 9 - Serial number: 9B10DMÿ†63829RB40149B5F1Uÿ
   Subsystem 10 - Serial number: 9B5F1Uÿ
   Part No SW: 8E0 920 981 S    HW: 8E0 920 981 S
   Component: KOMBI+WFS 4     H14 0040
   Revision: 0040        Serial number: 00000000000000
   Coding: 0023261
   VCID: 3D32FE876551A2D390-5184
Address 36: Seat Mem. Drvr        Labels: 8E0-959-760.lbl
   Part No: 8E0 959 760
   Component: Sitzmemory R2 F     0305
   Coding: 00002
   VCID: 71AA12B73A8916B344-4B3C
   Part No SW: 4F0 910 357 E    HW: 4F0 907 357 E
   Coding: 0000019
   VCID: 281C3FD39BD3177BD3-807D
   Subsystem 1 - Part No: 8E0 941 329
   Component: AFS-Modul links H03 0020
   Subsystem 2 - Part No: 8E0 941 329
   Component: AFS-Modul rechtsH03 0020
Address 56: Radio        Labels: 8E0-035-192-RNSE.lbl
   Part No SW: 8E0 035 192 J    HW: 8E0 035 192 J
   Component: RNS-E US3       H72 0110
   Revision:      03S    Serial number: AUZBZ7F2446940
   Coding: 0309637
   Shop #: WSC 08353 444 57634
   VCID: 2B16C0DF88253C633E-51A8
                    Reset counter: 71
                    Date: 2005.08.26
                    Time: 00:00:30
                    Voltage: 11.90 V
                    Mileage: 655350 km
                    Count: 65535
                    Clock: 255:255
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
                    Reset counter: 31
                    Date: 2011.06.12
                    Time: 12:00:13
                    Mileage: 655350 km
                    Count: 2105
                    Clock: 21:36
Address 65: Tire Pressure        Labels: 8E0-907-273.lbl
   Part No SW: 8E0 907 273 A    HW: 8E0 907 273 A
   Component: Reifendruck 3   H04 0130
   Coding: 0062523
   VCID: 2A18C5DB87DF256BC5-5184
   Part No SW: 8P0 862 335 J    HW: 8P0 862 335 J
   Component: FSE_255x BT     H21 0290
   Revision: 00000001    Serial number: 00000000456536
   Coding: 0011877
End-------------------------(Elapsed Time: 07:18)--------------------------
- Chris
What happens when you go to 0F directly in VCDS-Mobile?
AmoTHS
C?ID=215720
I updated the Hex Net successfully when connected to my home wifi and then directly accessed 0F and received this message:
The message would then disappear and the fields on the page were blank.
- Chris
Please do the following in VCDS-Mobile: [Options] -> Put 001f in the Debug Level field, click [Submit]. Then [Done, Go Back], [Select], [0F - Digital Radio]. I would expect it to fail in the manner above. Exit the module. Go to [View Saved Files]. There should be a new file at the bottom of the list named 'debuglog.edl'. Synch it to the Cloud and post the docid here.
Note: Shaun is out today (his sister is getting married this weekend) and won't be able to look at it and work whatever is causing this until next week.
AmoTHS
C?ID=215720
File is uploaded and docid is: 000003E4
