VW t5 06 - sliding electric door
jack69bis
Italy
C?ID=271652 (NRRT)
my problem is sliding electric door.
In the morning left and right door dead.
No light on the dashboard, and no response from the doors.
In the afternoon I've opened my T5: all seats, and rear door (left&right) panel and luggage panel (rear&left).
I exchange the door control unit (7H0 959 243G year 2005 maybe dead) with the right one (7H0 959 243L year 2012).
Now the RIGHT door with the newer control unit is OK, open, close, perfectly and right light on dashboard.
The LEFT door, with the newer or older control unit is always KO, no light on dashboard for her.
This is the autoscan:
Friday,25,March,2016,19:25:09:07432
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86(VMWare)
VCDS Version 15.7.4.1
Data version: 20160216
VIN: WV2ZZZ7HZ6H069187   License Plate:
Mileage: 142080km-88284mi   Repair Order:
          57 6E 76 77 78 7D
VIN: WV2ZZZ7HZ6H069187   Mileage: 142080km-88284miles
   Part No SW: 070 906 016 AP    HW: 028 101 160 6
   Component: R5 2,5L EDC G000SG  7001
   Revision: 12345678    Serial number: VWZ7Z0E3043312
   Coding: 0001172
   Shop #: WSC 02756 785 00200
   VCID: 5EB431A08A2A9DCE2C-5165
Readiness: 0 0 X X X
Address 03: ABS Brakes        Labels: 7H0-907-37x-ESP-A.lbl
   Part No: 7H0 907 379 M
   Component: ESP ALLRAD MK25     0203
   Coding: 0006815
   Shop #: WSC 02771 785 00200
   VCID: 3F8AEC246D60B4C647-5149
Address 08: Auto HVAC        Labels: Redir Fail!
   Part No: 7H5 907 040 B
   Component: CLIMAtronic T5    X 3717
   Coding: 0000040
   Shop #: WSC 02757 785 00200
   VCID: 2A5CAD7086E2216E00-5149
   Subsystem 1 - Part No: 7H5 907 049 D
   Component: Display_2_ClimaT5 X 0307
Address 09: Cent. Elect.        Labels: 7H0-937-049.lbl
   Part No: 7H0 937 049 P
   Component: BORDNETZ SGVER 1.0  1901
   Coding: 0000359
   Shop #: WSC 02737 785 00200
   Part No: 1C0 909 605 F
   Component: 11 AIRBAG VW61 0R   0003
   Coding: 12593
   Shop #: WSC 02756
   VCID: 275A5444C5F01C061F-5149
01217 - Side Airbag Igniter; Driver Side (N199)
            32-00 - Resistance Too High
01218 - Side Airbag Igniter; Passenger Side (N200)
01228 - Airbag Cut-Off Switch for Passenger Side (E224)
            25-00 - Unknown Switch Condition
Address 17: Instruments        Labels: 7Hx-920-xxx-17.lbl
   Part No: 7H5 920 872 JX
   Component: KOMBI+WEGFAHRSP VDO V03
   Coding: 05112
   Shop #: WSC 00946
   VCID: 122C15905E7289AED8-5149
   WV2ZZZ7HZ6H069187     VWZ7Z0E3043312
01304 - Radio
            49-00 - No Communications
Address 18: Aux. Heat        Labels: 7H0-819-008.lbl
   Part No: 7H0 815 071 E
   Component: Standheizung        0207
   Part No: 6N0 909 901
   Coding: 00022
   Shop #: WSC 30429
   VCID: 70E87F1830BE1BBE8E-5149
01304 - Radio
   Part No: 7H0 907 554 D
   Component: HALDEX 4Motion      2108
   Coding: 0000001
   VCID: 316EBA1CAB3452B6C1-5149
Address 45: Inter. Monitor        Labels: 7Hx-951-171.lbl
   Part No: 7H5 951 171 A
   Component: Innenraumueberw.    2814
   Coding: 0000012
   Shop #: WSC 30429 264 95865
   VCID: 2D56A66CB70C3656E5-51BF
   Subsystem 1 - Part No: 7H5 951 178
   Component: Innenraumueberw.    1607
Address 46: Central Conv.        Labels: 7H0-959-433.lbl
   Part No: 7H0 959 433 B
   Component: C2B Komfortger·t     0004
   Coding: 00078
   Shop #: WSC 02756
   VCID: 326CB510FE3269AEB8-4B27
   Subsystem 1 - Part No: 7H1959801
   Component: Tırsteuer.FS KLO 0203
   Subsystem 2 - Part No: 7H1959802
   Component: Tırsteuer.BF KLO 0203
            36-10 - Open Circuit - Intermittent
00912 - Window Regulator Switch; Front Left (E40)
Address 78: Slide Door, Right        Labels: Redir Fail!
   Part No: 7H0 959 243 L
   Component: Schiebetuer-SG  404 0321
   VCID: 3B7298347978A8E66B-5149
End-------------------------(Elapsed Time: 06:32)--------------------------
V8DUB
Chelsea, Australia
HUC-2H
Hey mate, did you sort this out?
our van is also playing up.
Ewald
C?ID=303130
jack69bis left door control unit was not responding on can bus.
What fault codes do you have?
V8DUB
Chelsea, Australia
HUC-2H
ive not scanned it, my cable only has a licence for the touareg. its going in this week for a mirror repair which requires coding, ill get them to scan it.
I'm not sure what you mean by "only has a licence for the touareg". You do not need to use a VIN to scan another vehicle for fault codes.
See:
V8DUB
Chelsea, Australia
HUC-2H
I purchased a 3 vin cable and i think it has zero vins remaining, i don't know how to check it.
V8DUB
Chelsea, Australia
HUC-2H
See:
ill get in have a look. thanks. can i clear codes without using the vin also.
