passat B6 retrofit bi-xenon
martijn v o
C?ID=138199
All,
I have retrofitted bi-xenon in my car and it is not working properly at this moment.
Car:
B6, 2.0 TDI, front wheel drive, left hand drive, stationwagon, 2006 modelyear 2007.
Headlights:
driver (right side) 3C0-941-751-G
Passenger side (left side) 3C0-941-752-G
AFS module (glove box) 5M0-907-357-C
fault codes:
   Component: AFS-Steuergeraet    0133
   Coding: 2311169
   Shop #: WSC 05311 000 00000
   VCID: 346D185257AD699EAA-8060
   Subsystem 1 - Part No: ID-L fehlt    Labels: ID-55-01.CLB
   Component: AFS-Lst.-Modul l    ....
   Coding: 00000255
   Subsystem 2 - Part No: 7L6 941 330
   Component: AFS-Lst.-Modul r    X018
   Coding: 00000035
02233 - Left Headlight Power Output Stage (J667)
                    Fault Status: 11100100
                    Reset counter: 132
                    Mileage: 276741 km
                    Date: 2016.03.20
                    Time: 02:52:02
                    Voltage: 11.93 V
                        ABS 1
            000 -  -  - MIL ON
                    Fault Status: 11100000
                    Reset counter: 131
                        Invalid
                        Invalid
                        Invalid
02656 - Power Output Stage for Left Headlight (J667); Not Coded
            000 -  -  - MIL ON
                    Reset counter: 131
                        Invalid
                        Invalid
                        Invalid
02657 - Power Output Stage for Right Headlight (J668); Not Coded
            000 -  -  - MIL ON
                    Reset counter: 131
                        Invalid
                        Invalid
                        Invalid
                    Fault Status: 11100101
                    Reset counter: 131
                        Invalid
                        Invalid
                        Invalid
02234 - Right Headlight Power Output Stage (J668)
                    Reset counter: 171
                    Mileage: 276741 km
                    Date: 2016.03.20
                    Time: 02:53:53
                    Voltage: 11.93 V
                        ABS 1
I made a testing cable:
There is something strange, to exclude wiring and wrong pin issues, I have made a test cable only with pin-1 can bus high, pin 2 can bus low, pin 4 power 12 volt directly from battery and pin 14 earth (how do you say That in English mass or earth??) The can bus wires are both connected to the AFS module behind the glove box.
During this test the both light fitting where not connected to each other. Left is drivers side and right is passenger side.
Then I tested the individual lamp fittings.
Test1:
I thought the left fitting was malfunctioning but when I put the cable on the left fitting the readings where : right x-018 and left -------
Then I put the cable on to the right fitting.
Test2:
Right ------- left ---------
No readings at all.
So that’s strange, how can de 55 module say (test1) that the right is x018 when it's not connected? And when it is connected (test 2) it gives no readings at all. I'm confused right know. The computer says the left is not all right, according to my test the right one is not all right.
prako
Zagreb Cro
C?ID=116509
Have you paid attention to the electrical scheme, these lights are until 2007, maybe you're looking for Passat scheme since 2007!
Left headlight
pin
1- can H(in headlight wiring harness) > T26/4 to AFS control unit
2- can L(in headlight wiring harness) > T26/5 to AFS control unit
3- empty
4- SC5 Fuse 5 on fuse holder C
5- eatrh
6- L13 - Left gas discharge (xenon) bulb > Bordnetz T11a/4 11-pin connector, brown
7- earth
8- empty
9- empty
10- Left side light bulb > Bordnetz T11/7 11-pin connector, black
11- Left dip beam screen motor > Bordnetz T11a/6 11-pin connector, brown
12- empty
13- empty
14- earth
Right headlight
pin
3- empty
4- SD5 Fuse 5 on fuse holder D
5- earth
6- L14 Right gas discharge (xenon) bulb > Bordnetz T11/2 11-pin connector, black AND T26/8 26-pin connector at AFS control unit
7- earth
8- empty
9- empty
10- Right side light bulb > Bordnetz T11a/10 11-pin connector, brown
11- Right dip beam screen motor > Bordnetz T11/5 11-pin connector, black
12- empty
13- empty
14- earth
martijn v o
C?ID=138199
Yes i did, worked with the electrical scheme from my type car (from Elsawin). Or do you mean that de inside of the lights are different?
I light are working fine (ON/Off) and blinking with the additional wires from the BCM.
prako
Zagreb Cro
C?ID=116509
I lokk in 3C Passat 2006year coding 0000001 and 0000007, not 2311169!
VW Passat B6
2006 BMP
5M0 907 357
AFS-Steuergeraet X016 0000001 7L6 941 329 / AFS-Lst.-Modul l X018 / 00000035 * 7L6 941 330 / / AFS-Lst.-Modul r X017 / 00000035
VW Passat B6
2006 BLV
5M0 907 357
AFS-Steuergeraet X016 0000007 7L6 941 329 / AFS-Lst.-Modul l X017 / 00000035 * 7L6 941 330 / AFS-Lst.-Modul r X017 / 00000035
and since 2007
VW Passat B6
2007 BKP
5M0 907 357 A
AFS-Steuergeraet X014 2302977 7L6 941 329 / AFS-Lst.-Modul l X018 / 00000035 * 7L6 941 330 / AFS-Lst.-Modul r X018 / 00000035
VW Passat B6
2008 BWS
5M0 907 357 B
AFS-Steuergeraet X024 2343937 7L6 941 329 A / AFS-Lst.-Modul l 0004 / 00000035 * 7L6 941 329 A / AFS-Lst.-Modul r 0004 / 00000035
VW Passat B6
2009 CBBB
5M0 907 357 C
AFS-Steuergeraet 0136 2311169 7L6 941 329 A / AFS-Lst.-Modul l 0004 / 00000035 * 7L6 941 329 A / AFS-Lst.-Modul r 0004 / 00000035
martijn v o
C?ID=138199
Thanks, i will check the wiring again.
The codes are clear but i can not change coding due to the faults. First the both lights have to communicate with the AFS controller (behind the glove box).
Can you explain why there are two wires on the right headlight? 6- L14 Right gas discharge (xenon) bulb > Bordnetz T11/2 11-pin connector, black AND T26/8 26-pin connector at AFS control unit
martijn v o
C?ID=138199
Left headlight
pin
3- empty
5- eatrh
7- earth
8- empty
9- empty
12- empty
13- empty
14- earth
Right headlight
pin
3- empty
5- earth
7- earth
8- empty
9- empty
12- empty
13- empty
14- earth
Thanks this is what i have used. Only forgotten to do the last wire to de AFS module: 6- L14 Right gas discharge (xenon) bulb > Bordnetz T11/2 11-pin connector, black AND T26/8 26-pin connector at AFS control unit
martijn v o
C?ID=138199
Has somebody an idea which AFS modules (in the lamphousing) are exchangeable?
headlightunits:
driver (left side) 3C0-941-751-G module 7l6941229 x018
Passenger side (right side) 3C0-941-752-G, module 7l6941330 x018
i found several units
7l6941229A r004 for example. Can these been swapped witout problems to the 751G headlights?
martijn v o
C?ID=138199
Solution found!
Somebody else also wants to retrofit bi xenon in his car. We met and tested his equipment on to my cables and AFS module.
His equipment as well as my wiring seems to work fine.
We found out that someone fitted a right (330) module into the left headlight (329). Therefore it was confusing to me. The car told me the left module was not communicating and right was ok, but with a separate testcable (only one headlight at the time) it told me the right one was found on the left headlight. On the right headlight he did not find any module at all.
I ordered en new left module and will reinstall the current left into the right. I think that all issues will be solved.
United States
Hi Martijn,
I missed this thread and a handful of email updates while I was out of the office so thanks for posting the details above!
martijn v o
C?ID=138199
All previous isses are solved when the correct module is installed.
Right 330 en left 329.
clear all errors and perform a basic setting.
The controller is communicating withe the headlightsmodules.
Only now i have new faultcodes swivel right and left. I will perform an output test to move the headlights in all directions to see if the error dissapears.
