it is possible to encode the PLA module?
rojas
Spain
C?ID=261996
it is possible to encode the PLA module stg10 for not attempt to establish communication with EPB?
I have adapted park assist "PLA 12 ch." in a seat leon 5F MQB, which has no EPB. The system works perfectly but there is always an error is present.
I can do to fix this error?
Tuesday,08,December,2015,00:28:56:22717
VCDS Version: 15.7.2.0 (x64)
Data version: 20151124
VIN: VSSZZZ5FZER117826   License Plate:
Mileage: 26870km-16696mi   Repair Order:
Chassis Type: 5F (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 3C 42 44 52 55 5F 65 A5
VIN: VSSZZZ5FZER117826   Mileage: 26870km-16696miles
Address 01: Engine (J623-CLHA)       Labels: 04L-907-309-V1.clb
   Part No SW: 04L 906 021 M    HW: 04L 907 309 B
   Component: R4 1,6L EDC   H22 6545
   Revision: 84H22---
   Coding: 01110032032401090000
   ASAM Dataset: EV_ECM16TDI01104L906021M 002011
   ROD: EV_ECM16TDI01104L906021M_SE37.rod
   VCID: 2F43E82D7645F146C2-807A
   Part No SW: 5Q0 907 379 R    HW: 5Q0 907 379 F
   Component: EMB8 EHCB     H31 0356
   Revision: 00000000    Serial number: 60834000000768
   Coding: 20EE629214210973007F060241C9240446289000608224F20061F0024009
   Shop #: WSC 00049 770 00106
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
   ROD: EV_Brake1UDSContiMK100ESP_SE37.rod
   VCID: 4BBB9CBDE29DAD66CE-801E
   Part No SW: 5F0 907 044 D    HW: 5F0 907 044 D
   Component: Climatronic   H03 0705
   Revision: 00001K07
   Coding: 01000104202100011105004000101000
   ASAM Dataset: EV_ACClimaBHBVW37X 003017
   ROD: EV_ACClimaBHBVW37X_SE37.rod
   VCID: 2773000D5EB5A9060A-8072
   Part No SW: 5Q0 937 084 AE    HW: 5Q0 937 084 AE
   Component: BCM MQBAB H   H16 0124
   Serial number: 00011408501699
   Coding: 08000B42424102FB4BE4400051040308100E000000000000000000000000
   Shop #: WSC 27574 001 104857
   ROD: EV_BCMBOSCH_SE37.rod
   VCID: 7BDB0C7DF2BDDDE63E-802E
   Slave 1:
   Subsystem 1 - Part No SW: 5F1 955 119     HW: 5F1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 140325  041 0574
   Serial number:         140326073449
   Coding: 0BC5FD
   Slave 2:
   Component: RLFS  024 0042
   Serial number: Y14M03D27H02M52S25S7
   Coding: 06885D
   Subsystem 3 - Part No SW: 5Q0 951 605     HW: 5Q0 951 605
   Serial number: 00000000000031592682
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-298.clb
   Part No SW: 5Q0 919 298 A    HW: 5Q0 919 298
   Component: PARKHILFE PLA 011 0029
   Coding: 0031163041
   Shop #: WSC 00123 123 12345
   ASAM Dataset: EV_EPHVA2CAU3700000 003014
   ROD: N/A
   VCID: 3D5FC265AC2913D640-8068
No ASAM data for: "EV_EPHVA2CAU3700000" (SE37)
12658704 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 188
                    Mileage: 26870 km
                    Date: 2015.12.07
                    Time: 23:45:23
   Part No SW: 3Q0 959 655 AC    HW: 3Q0 959 655 AC
   Component: Airbag VW20   012 0189
   Revision: --------    Serial number: 003P4P79TV59
   Coding: 98CCC000000000005C0000CC000800000065
   ROD: EV_AirbaVW20TS6VW48X_SE37.rod
   VCID: 7F23F86DE6A5C1C612-802A
   Subsystem 1 - Part No SW: -----------    HW: 454 000 304 14
   Serial number: 3576U000000947145F0A
   Subsystem 2 - Part No SW: -----------    HW: 454 000 404 14
   Serial number: 3586U000000945814F0C
   Subsystem 3 - Part No SW: -----------    HW: 454 802 703 14
   Serial number: 3516R0B2D4D030000002
   Subsystem 4 - Part No SW: -----------    HW: 454 802 703 14
   Serial number: 3526R55ED44030000005
   Subsystem 5 - Part No SW: -----------    HW: 454 801 903 14
   Serial number: 3556VCFA02D03000000J
   Part No SW: 5Q0 953 507 DK    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 05041408490170
   Coding: 2C00
   ROD: EV_SMLSKLOMQB_SE37.rod
   VCID: 022571999557AC2E7D-8056
   Part No SW: 5F0 920 871 A    HW: 5F0 920 871 A
   Component: KOMBI         303 2210
   Coding: 07ED1280689C000800087E0E440000
   ROD: EV_DashBoardVDDMQBAB_SE37.rod
   Part No SW: 5Q0 907 530 Q    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1164
   Revision: --------    Serial number: 0001886578
   Coding: 030100F40B087300DF040658081F00010001000000000008000000000000
   ASAM Dataset: EV_GatewLear 010015
   ROD: EV_GatewLear.rod
   VCID: 3FA3B86DA62501C652-806A
   Subsystem 2 - Part No SW: 5F0 959 537 B    HW: 5F0 959 537 B
   Component: E221__MFL-PR6  H03 0120
   Serial number: 000000000A0311070314
   Coding: 002000
   Serial number: 4475232803
Address 3C: Lane Change (J769)       Labels: 5Q0-907-566.clb
   Part No SW: 5Q0 907 566     HW: 8T0 907 566
   Component: SWA Master    H16 0046
   Serial number: 0162026687
   Coding: 030311
   ROD: N/A
   VCID: 77D3104DCE95F9865A-8022
No ASAM data for: "EV_LaneChangAssis" (SE37)
   Part No SW: 5Q4 959 593 B    HW: 5Q4 959 593 B
   Component: TSG FS        009 0014
   Serial number: 0000097358999
   Coding: 00100320DE00040000001000
   Shop #: WSC 00049 770 00125
   ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
   VCID: 44A9B781CFC3621E0F-8010
   Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A
   Serial number: 00000000000002245433
   Coding: 310000
   Component: EPS_MQB_ZFLS  123 1043
   Coding: 1303
   ROD: EV_SteerAssisMQB.rod
   VCID: 41A7BE95D0D1773624-8014
   Part No SW: 5Q4 959 592 B    HW: 5Q4 959 592 B
   Component: TSG BFS       009 0014
   Serial number: 0000097584970
   ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
   VCID: 43ABB49DCACD652636-8016
   Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A
   Serial number: 00000000000002203632
   Coding: 290000
Address 55: Headlight Range (J431)       Labels: 5Q0-907-357.clb
   Coding: 048A000009000000
   ROD: EV_HeadlRegulVWLWRMQB_SE25.rod
   VCID: 75CF1A45D4998B9648-8020
   Part No SW: 5F0 035 846 A    HW: 5F0 035 846 A
   Component: MU-S-N-ER     040 0425
   Serial number: E1F00204140353
   Coding: 04731001FF0A000021110001000800002F0210100100010046
   ASAM Dataset: EV_MUStd6C1PASE 002030
   ROD: EV_MUStd6C1PASE_SE37.rod
   VCID: 266D0D0959BFB00E31-8072
   Media Player Position 1:
   Subsystem 1 - Part No SW: 5F0 919 603 A    HW: 5F0 919 603 A
   Component: ABTmin_Std_Nv  H60 0030
   Serial number: SEZ8Z9PT90028K
   Engine Control Module 2:
   Subsystem 2 - Part No SW: 5F0 060 884 J    HW: -----------
   Component:  ECE 2015/16  --- 0051
Address 65: Tire Pressure (J502)       Labels: None
   Serial number: 30000000009036
   ROD: N/A
   VCID: 3449E7419F63D29EBF-8060
No ASAM data for: "EV_RDKBERU30" (SE37)
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 5Q0-980-653.clb
   Part No SW: 5Q0 980 653 F    HW: 5Q0 980 653
   Component: MQB_MFK       H05 0052
   Serial number: 10000060385
   Coding: 0101010001020304010500010000000100
   ROD: EV_MFKBoschAU370_SE37.rod
   VCID: 3B5BCC7DB23D1DE67E-806E
End-------------------------(Elapsed Time: 03:02)--------------------
any ideas ?
very thank you :)
