Change HVAC Heated Seat 3 > 2 Time
andyhud
C?ID=32695
Hey Guys,
I own a new Q7 (4M) and I'm looking for the coding for the HVAC piece that drops the heat from 3 to 2 as per here: (This information was from an A6/A7 2016 Forum Post on another site). I figured it may be possible on the Q7 4M.
Change the time before the heated seats auto-change from level 3 to level 2
When the heated seat is set to full (level 3) it will only stay on full power (level 3) for 10 minutes before automatically dropping to level 2. To increase (or decrease) the amount of time this takes, go to
Module 08 (HVAC) -> Adaptation -> drop in down box select the option 'time until heated seat stage withdrawal from 3-2'.
Enter a new value. Save.
The default is 10, which is 10 minutes. I set it to 15 minutes. Change it to zero to prevent it from auto-switching from level 3 to level 2.
I have a HEX-NET and Ross Tech VCDS 15.7 but the option "time until heated seat stage withdrawl from 3-2" is not listed in the drop down in "Adaptation" when I connected upto the car.
Does anyone know what Long Coding (Byte/Bit) this change does and I can try it directly in Long Coding instead? Is that even possible?
Cheers
Andy
Looking through the adaptation channels for your HVAC module (which seems rather different than the 4G types) I don't see anything promising looking either, nor in the coding data...
andyhud
C?ID=32695
Uwe, thanks for info. I guess it might be possible, as other new Audi models do it, just not the Q7 4M. Be great if we could find those cars and get a scan done, would that help in any way?
Just because some models allow for something doesn't mean other models do, even if they are newer or more advanced.
jocamero
Denver, CO, USA
C?ID=133121
Does anyone know if this tweak is possible on a 2014 Audi A4 allroad? My girlfriend likes her seat really toasty and is constantly having to switch from level 2 to 3.
Monday,21,March,2016,21:52:14:59056
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(VMWare)
VCDS Version 15.7.4.1 (x64)
Data version: 20160216
VIN: WA1UFAFL2EA118988   License Plate:
Mileage: 33420km-20766mi   Repair Order:
Chassis Type: FL (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 36 3C 42 44 46 47 52 53 56 5F
          62 6C 6D 72
VIN: WA1UFAFL2EA118988   Mileage: 33420km-20766miles
Address 01: Engine (DET-CPMB)       Labels: 06H-907-115-CDN.clb
   Part No SW: 8K5 907 115 J    HW: 8K2 907 115 L
   Component: 2.0l R4/4V TF H09 0002
   Revision: ECH09---
   Coding: 722A0013242600062000
   ASAM Dataset: EV_ECM20TFS0118K5907115J 001003
   ROD: EV_ECM20TFS0118K5907115J.rod
   VCID: 393AE96CB8BF22F679-806D
Readiness: 1110 0101
Address 02: Auto Trans (J217)       Labels: 0BK-927-156.clb
   Part No SW: 8K1 927 158     HW: 0BK 927 156 AL
   Component: 0BK 20TFSIUSA H16 1005
   Revision: --H16---
   Coding: 000002
   ROD: EV_TCMAL551211_AU48.rod
   VCID: 74A41858DF5D9F9E6A-8021
Address 03: ABS Brakes (J104)       Labels: 8K0-907-379-V2.clb
   Part No SW: 8K9 907 379 P    HW: 8K9 907 379 P
   Component: ESP8 quattro  H09 0020
   Coding: 0E1D1801
   Shop #: WSC 06335 000 00000
   VCID: 4FEEB7B41E3B9C46B7-801B
   Part No SW: 8K0 907 064 JP    HW: 8K0 907 064 JP
   Component: BCM2 2.0      H14 0650
   Coding: 0D824040000000000000
   VCID: 075E5F94B6CB84063F-8053
   Part No SW: 8K1 820 043 T    HW: 8K1 820 043 T
   Revision: C1000000    Serial number: 01130220140673
   Coding: 6480208000
   VCID: 393AE96CB0BF22F679-806D
   Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 DH
   Revision: 08016001    Serial number: 00000061301701
   Coding: 26000091863CAFC00000400300003D0D4F1C4708A2090221000008004000030100000030000000
   Shop #: WSC 11886 002 104857
   VCID: 78BC2C68CB35FBFE46-802D
   Subsystem 1 - Part No SW: 8K1 955 119 B    HW: 8K1 955 119 B
   Component: MITSUBA170114  H18 0461
   Coding: 004577
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Component: USHL4.2  H30 0030
Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
   Part No SW: 8K0 959 655 M    HW: 8K0 959 655 M
   Component: AirbagVW-AU10 H47 0610
   Serial number: 003KEDB02UW$
   Coding: 303844354A32303030304A55304C384B3053
   Shop #: WSC 03010 002 1048576
   ROD: EV_AirbaECUVWAUDI010_AU48.rod
   VCID: 47DE9F94FE4B4406FF-8013
   Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
   Serial number: 5810000R130000FF1B
   Serial number: 6334MSME433B664FP
   Serial number: 6344MSME435E2E70N
   Serial number: 6352QSME4D3D2560N
   Serial number: 6362QSME5740447CL
   Serial number: 63732SME7E3C4748F
   Serial number: 63832SME7E3C4464B
   Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
   Component: Lenks.Modul   H03 0003
   Revision: C0062331    Serial number: 90862NBF000N7
   Coding: 000037
   VCID: 48DC9CA8FB554B7EF6-801D
Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
   Part No SW: 8K0 920 983 F    HW: 8K0 920 983 F
   Component: KOMBIINSTR.   H35 0564
   Revision: 00100000    Serial number: ZAA75Y72F
   Coding: 8FBF29020301D705020000
   VCID: 383CEC688BB53BFE86-806D
   Part No SW: 8R0 907 468 P    HW: 8R0 907 468 D
   Component: GW-BEM 5CAN-M H11 0060
   Revision: 1Z120030    Serial number: 3041Z1420505EE
   Coding: 80C303FF00
   VCID: 4CD4A0B8EF2DA75ED2-8019
Address 36: Seat Mem. Drvr (J136)       Labels: 8T0-959-760.clb
   Component: MEM-FS        H06 0077
   Revision: AA000000    Serial number: 00000090243072
   Coding: 00581B00000000000000
   VCID: 3B36F364BA8310E66B-806F
Address 3C: Lane Change (J769)       Labels: 5Q0-907-566.clb
   Part No SW: 8T0 907 566 B    HW: 8T0 907 566 B
   Serial number: 0326753766
   Coding: 010211
   Shop #: WSC 06334 000 00000
   VCID: 3FCE8774A69B0CC647-806B
   Lane Change Assistant 2:
Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
   Component: TSG FA        H02 0510
   Revision:             Serial number: 0000091072765
   Coding: 011C13205E00410001
Address 44: Steering Assist (J500)       Labels: 8K0-909-144.clb
   Part No SW: 8K0 909 144 G    HW: 8K0 909 144 B
   Component: RCEPS         H40 0508
   Revision: 00001000    Serial number: 0001271611
   Coding: 100000000001
   Shop #: WSC 49920 001 104857
   ASAM Dataset: EV_RCEPSAU48X 008015
   ROD: EV_RCEPSAU48X.rod
   VCID: 3522E55C94A7C6969D-8061
   Revision: 00002001    Serial number: 0326961970
   Coding: 0126063A20BA709583B0023200000000
   Shop #: WSC 06334 123 12345
   Component: GTO BF  H01 0080
   Subsystem 3 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
   Component: J245 PS150  H08 0043
   Subsystem 4 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
   Component: J394 PS240  H08 0043
Address 47: Sound System (J525)       Labels: 8T0-035-223-BOM.clb
   Revision: 00005001    Serial number: 94813025634404
   VCID: 2D12CD3C74F78E56E5-8079
   Component: TSG BF        H02 0510
   Revision:             Serial number: 0000091191629
   VCID: 4ED0AAB01931954EBC-801B
   Component: EPB-4         H01 0005
   Revision: --------    Serial number: 20000000403137
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3A38F660BDB929EE70-806F
   Revision: AB001007    Serial number: 156B60E7966836
   Coding: 020007010000000001
   VCID: 24042818273D4F1E3A-8071
   Part No SW: 8R1 035 746 E    HW: 8R1 035 746 D
   Component: H-BNT-NA      H41 0756
   Revision: --------    Serial number: 204B00E7639956
   Coding: 010200050006A1EF51028B5E00000403140000000000000000
   Shop #: WSC 49920 001 1048576
   Subsystem 1 - Part No: 8R0 060 884 BL
   Component: NAR 2014  0902
   Component: DU7 High  H42 0104
   Subsystem 3 - Part No SW: 8T0 919 611 L    HW: 8T0 919 611 C
   Component: CD-Database  5571
Address 62: Door, Rear Left (J388)       Labels: 8K0-959-795.clb
   Component: TSG HL        H01 0510
   Revision:             Serial number: 0000090996505
   Coding: 010C13204000210001
   VCID: 46C09290F1415D0E04-8013
   Revision: --H09---    Serial number: 525PA8-J3Y910O
   Coding: 1000007
   VCID: 383CEC684BB53BFE86-806D
   Part No SW: 8K9 827 851 C    HW: 8K9 827 851 C
   Component: J605  Master  H53 0330
   Revision: --------    Serial number: 8K9827851C
   VCID: 3E30FA70A99105CE4C-806B
   Subsystem 1 - Part No SW: 8K9 827 852 C    HW: 8K9 827 852 C
   Component: J756  Slave  H53 0330
Address 72: Door, Rear Right (J389)       Labels: 8K0-959-795.clb
   Component: TSG HR        H01 0510
   Revision:             Serial number: 0000090989187
End-------------------------(Elapsed Time: 02:37)--------------------------
Checked German-language sources and I'm not seeing anything in there either, sorry.
andyhud
C?ID=32695
Yep, totally understand Uwe, just figured it might be worth a shot. I'll keep on hunting
Andy
