VW Polo 6C 1.4 TDI missing ROD
automech
Poland
C?ID=14925
I'm just reporting that VCDS misses ROD file for Delphi ECU.
I will have this car for couple more days, so I can make some channel maps for RT, just tell me what controllers to scan.
PS. Do anyone of you know how to code second key?? (customer bought car with just one).
Saturday,19,March,2016,13:28:50:49923
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
Workshop Code: 444 00001 012345
VIN: WVWZZZ6RZFY232070   License Plate:
Mileage: 5723km-3556mi   Repair Order:
Chassis Type: 6R (6C0)
Scan: 01 03 08 09 10 15 17 19 44 5F
VIN: WVWZZZ6RZFY232070   Mileage: 5723km-3556miles
Address 01: Engine (J000-CUSB)       Labels: None
   Part No SW: 04B 997 027 B    HW: 04B 907 445
   Component: R3 1.4l TDI   H07 2771
   Revision: 21003001
   Coding: 01114032422401080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM14TDI03004B997027B 003003
   ROD: N/A
   VCID: 2A516BD44D3C2A6E00-807E
No ASAM data for: "EV_ECM14TDI03004B997027B" (VW26)
Readiness: N/A
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP90.clb
   Part No SW: 6C0 907 379 G    HW: 6R0 907 379 BA
   Component: ESP9.0i       H03 0003
   Serial number: 08513502141218
   Coding: 21DD2885892633C2091410700051841491CC90080007C9098F00
   ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100018
   ROD: EV_Brake1ESP90iBOSCHPQ26.rod
   VCID: 336F76B09AF66BA6B3-8066
Address 08: Auto HVAC (J255)       Labels: 6C0-907-044.clb
   Part No SW: 6C0 907 044 A    HW: 6C0 907 044 A
   Component: Climatronic   H02 0105
   Serial number:  1412193A-0033
   Coding: 201000001001000201
   ASAM Dataset: EV_ACClimaValeoPQ26 003001
   ROD: EV_ACClimaValeoPQ26_SK25.rod
   VCID: 224183F4350CF22E48-8076
1048833 - Function Limitation due to Compressor Shut-Off Request By Engine
          B10F0 00 [008] -  -
                    Reset counter: 138
                    Mileage: 4616 km
                    Date: 2015.11.16
                    Time: 16:58:42
Address 09: Cent. Elect. (J519)       Labels: 6C0-937-089-V1.clb
   Part No SW: 6C0 937 089 B    HW: 6C0 937 089
   Component: BCM PQ26 Hi4R H07 0065
   Serial number: 001098000745
   Coding: 0000085042130AFB4B044000402F07480000590253010000000000000000
   ASAM Dataset: EV_BCMA0 004008
   ROD: EV_BCMA0_SE25.rod
   VCID: 2F677AC076DE4F46D7-807A
   Slave 2:
   Subsystem 1 - Part No SW: 5Q0 955 547 A    HW: 5Q0 955 547 A  Labels: 5Q0-955-547.CLB
   Component: RLHS  037 0059
   Serial number: S4Y15M01D03H03M51S51
   Coding: 0038DD
   Subsystem 2 - Part No SW: 6R0 959 801 CA    HW: 6R0 959 801 CA  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8620
   Serial number: KU0KU015121443493031
   Coding: 0400A0
   Subsystem 3 - Part No SW: 6R0 959 802 CD    HW: 6R0 959 802 CD  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8620
   Serial number: KU0KU026111443300754
   Coding: 1400A0
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-294.clb
   Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0048
   Revision: --------    Serial number: 39391435003746
   Coding: 0011051001
   ROD: EV_EPHVA18AU3700000_AU37.rod
   VCID: 3D7B5088ACB2ADD655-8068
1079601 - Rear Right Parking Aid Sensors
          B1079 31 [008] - No Signal
                    Reset counter: 97
                    Mileage: 4413 km
                    Date: 2015.11.15
                    Time: 19:23:07
Address 15: Airbags (J234)       Labels: 6C0-959-655.clb
   Part No SW: 6C0 959 655 A    HW: 6C0 959 655 A
   Component: VW20Airbag01A 001 0330
   Revision: --------    Serial number: 003LM007J9C7
   Coding: 88C0C000000000005C0000CA000800000000
   ROD: EV_AirbaVW20BPAVW26X_SE25.rod
   VCID: 31637CB860EA59B6C1-8064
   Subsystem 1 - Part No SW: -----------    HW: 410 822 711 14
   Component: SideSensor_Df  151 0800
   Serial number: 3575H009D17ADDC2620$
   Subsystem 2 - Part No SW: -----------    HW: 410 822 711 14
   Component: SideSensor_Pf  151 0800
   Serial number: 3585H00A516CCCC021AZ
   Subsystem 3 - Part No SW: -----------    HW: 442 150 512 14
   Component: SideSensor_Dr  1CA 0148
   Serial number: 3517A00BF1746243F14D
   Subsystem 4 - Part No SW: -----------    HW: 442 150 512 14
   Component: SideSensor_Pr  1CA 0148
   Serial number: 3527A00C11746244307Z
   Part No SW: 6C0 920 741 A    HW: 6C0 920 741 A
   Component: KOMBI         211 0290
   Coding: 072401002180000800080A001000000000000000
   ROD: EV_DashBoardVDDMQBAB_VW26.rod
   VCID: 21438CF8300AE93651-8074
Address 19: CAN Gateway (J533)       Labels: 6C0-909-901-V1.clb
   Part No SW: 6C0 909 901     HW: 6C0 937 089
   Component: GW MQB A0     H07 0065
   Revision: --------    Serial number: 001098000745
   Coding: 030000045F0A590071000000000000010001010000000000000000000000
   ASAM Dataset: EV_GatewA0Lear 001001
   ROD: EV_GatewA0Lear_SE26.rod
   VCID: 65CBD8E864A2C516ED-8030
   Subsystem 1 - Part No SW: 6C0 915 181 A    HW: 6C0 915 181 A
   Component: J367-BDM  H08 0223
   Serial number: 51353B36512821272323
Address 44: Steering Assist (J792)       Labels: 6Rx-909-144-V2.clb
   Part No SW: 6C1 909 144 M    HW: 6C1 909 144 D
   Component: EPS_TRW_ALow  312 3211
   Serial number: PF1E0682
   Coding: 0007
   ASAM Dataset: EV_SteerAssisUDSTRW 011021
   ROD: EV_SteerAssisUDSTRW_VW26.rod
   VCID: 326173B465EC62AEB8-8066
   Part No SW: 6C0 035 867 B    HW: 6C0 035 867 B
   Component: MU-E--ER      820 6220
   Serial number: 30101400010408
   Coding: 02620000BE0000004011000100000000000000040000010000
   ASAM Dataset: EV_MUEnt4CGen2LGE 001017
   ROD: EV_MUEnt4CGen2LGE_VW26.rod
   VCID: 285591DC5330187E16-807C
End-------------------------(Elapsed Time: 02:02)--------------------------
automech
Poland
C?ID=14925
UPDATE
I did a scan with test 16.3
Saturday,19,March,2016,20:28:50:49923
VCDS Version: 16.3.0.0 (x64)
   Revision: 21003001
   ROD: EV_ECM14TDI03004B997027B.rod
   VCID: 2A516BD44D3C2A6CD1-807E
Readiness: N/A
   VCID: 336F76B09AF66BA462-8066
   ROD: EV_ACClimaValeoPQ26_VW26.rod
   VCID: 224183F4350CF22C99-8076
   ROD: EV_BCMA0_VW26.rod
   VCID: 2F677AC076DE4F4406-807A
   Slave 2:
   Coding: 0038DD
   Coding: 0400A0
   Coding: 1400A0
   Coding: 0011051001
   ROD: EV_EPHVA18AU3700000_VW26.rod
   VCID: 3D7B5088ACB2ADD484-8068
                    Reset counter: 104
                    Mileage: 5723 km
                    Date: 2016.03.19
                    Time: 15:09:14
   ROD: EV_AirbaVW20BPAVW26X.rod
   VCID: 31637CB860EA59B410-8064
   VCID: 21438CF8300AE93480-8074
   ROD: EV_GatewA0Lear_VW26.rod
   VCID: 65CBD8E864A2C5143C-8030
   Coding: 0007
   VCID: 326173B465EC62AC69-8066
   ROD: EV_MUEnt4CGen2LGE_VW12.rod
   VCID: 285591DC5330187CC7-807C
End-------------------------(Elapsed Time: 02:01)--------------------------
Sebastian
Magdeburg, Germany
HN0-nnnnnn
#01 and #5F will be properly covered label wise with the next update.
