Retrofit 2012 RCD-510 into 08 Passat that had RCD-310, Get Fault Code
VWBob
Rochester, NY
C?ID=55547
I recently replaced the RCD-310 in my 08 Passat with a 2012 RCD-510-AE version radio, everything seems to be working well except when I do a VCDS scan I get the following fault.
Log-WVWAK73C28E251629-174130km-108199mi.txt
Friday,16,May,2014,16:21:45:31878
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
VIN: WVWAK73C28E251629 License Plate:
Mileage: 174130km-108199mi Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 52 53 56 62 65 72
VIN: WVWAK73C28E251629 Mileage: 174130km/108199miles
Address 01: Engine (CCT) Labels: 06J-906-026-CCT.clb
Part No SW: 06J 906 026 AG HW: 06J 906 026 AF
Component: MED17.5 TFSI 2,0 3319
Revision: AAH03--- Serial number: VWZCZ000000000
Coding: 0404010A19070160
Shop #: WSC 05313 115 20155
VCID: 6FE74C297EE18A6672D-803A
Address 02: Auto Trans Labels: 09G-927-750.lbl
Part No SW: 09G 927 750 HD HW: 09G 927 750 HD
Component: AQ 250 6F 1176
Revision: 00H76000 Serial number:
Coding: 0000840
Shop #: WSC 05311 000 00000
VCID: 7AF16D7D35A3DFCED53-802F
Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 K HW: 3C0 614 109 K
Component: J104 C4 440 V2 0005
Revision: --020--- Serial number: 00000785605291
Coding: 0000348
VCID: 2649690D919B8B2EC1B-8073
Part No SW: 1K0 820 047 HS HW: 1K0 820 047 HS
Component: Climatic PQ35 142 1111
Revision: 00142031 Serial number: 00000000000000
VCID: 7CFD6B653F97E1FEC7F-8029
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 01000008390239
Coding: 14848F0340041A00470000000F000000000859435C00010000 0000000000
Shop #: WSC 05124 000 00000
VCID: 71E34A5168D59C96649-8024
Subsystem 1 - Part No: 3C1 955 419 A Labels: 1KX-955-119.CLB
Component: Wischer 310308 003 0205
Coding: 00046997
Shop #: WSC 05124
Part No SW: 5N0 959 655 HW: 5N0 959 655
Component: J234__01F VW10 HI 1815
Revision: 19013000 Serial number: 0039BP8NME6Z
Coding: 0012614
VCID: FAF1ED7DB5A35FCE553-80AF
Subsystem 1 - Part No: 3C0 959 339 D
Component: BF-Gewichtsens. 001 0002
Subsystem 2 - Serial number: 00000000000PQ5
Subsystem 3 - Serial number: 0028.02.080000100000650059ÿ†63
Subsystem 4 - Serial number: 650059ÿ†6333FTS640980948 ÿ†63
Subsystem 5 - Serial number: 80948 ÿ†6343FTS672391048 ÿ†63
Subsystem 6 - Serial number: 91048 ÿ†6353ETS686H9TVNH ÿ†63
Subsystem 7 - Serial number: 9TVNH ÿ†6363ETS69HN9TVNP ÿ†63
Subsystem 8 - Serial number: 9TVNP ÿ†6374CTS6DF0VSVNH ÿ†63
Subsystem 9 - Serial number: VSVNH ÿ†6384CTS69T1VSVNH ÿ
Subsystem 10 - Serial number: VSVNH ÿ
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 AC HW: 3C0 953 549 AC
Component: J0527 0020
Revision: 00026000 Serial number: 3C5953507AR
Coding: 0001111
VCID: 6DDB562174ED7876401-8038
Component: E0221 002 0010
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 971 F HW: 3C0 920 971 F
Component: KOMBIINSTRUMENT VD1 1216
Revision: V0002000 Serial number: 00000000000000
Coding: 0007205
Shop #: WSC 08149 444 54434
VCID: 285567359B8F9D5EF37-807D
Address 19: CAN Gateway Labels: 3C0-907-530-V2.clb
Part No SW: 3C0 907 530 E HW: 3C0 907 951
Component: J533__Gateway H10 0080
Revision: H10 Serial number: 1200P08505072D
Coding: FD807F070012021002
VCID: 234F7019E2A97E06A65-8076
Part No SW: 3C0 919 965 HW: 3C0 919 965
Component: Kompass 005 0003
Revision: 00005000 Serial number: 1166279TSDQ806
VCID: EDDBD621F4EDF876C01-80B8
Part No SW: 3C0 959 433 AK HW: 3C0 959 433 AK
Component: IMMO 051 0383
Revision: 00051000 Serial number: VWZCZ000000000
Shop #: WSC 08149 444 83815
VCID: 73EF405912C9AE86965-8026
Subsystem 1 - Part No: 3C0 905 861 H
Component: ELV 028 0380
3C0905861H ELV 028 0380
Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1131
Revision: 32008001 Serial number: 00000006379030
Coding: 0001205
VCID: 3B7FA8797A1926C68E5-806E
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.135 H08 1901
Shop #: WSC 02069 000 90108
VCID: 356BBE415C3DF0B6781-8060
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Component: KSG PQ46 RDK 051 0221
Coding: 13910F8001862E521004141FF08A0F0E085801
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1131
Revision: 32008001 Serial number: 00000608888316
Coding: 0001204
VCID: 3C7DAB657F1721FE87F-8069
Address 53: Parking Brake Labels: 5N0-907-801.clb
Part No SW: 3C0 907 801 J HW: 3C0 907 801 J
Component: J540 EPB3 VW-09393 0009
Revision: 008 Serial number: 00000000468112
Coding: 0000057
VCID: 295362318085A456EC9-807C
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 180 AE HW: 1K0 035 180 AE
Component: Radio Prem-8 H02 0016
Revision: -----16S Serial number: VWZ4Z7M3307685
Coding: 01000400040007
Shop #: WSC 00066 000 00000
VCID: 63CF301962293E06E65-8036
Reset counter: 56
Mileage: 174136 km
Date: 2014.05.16
Time: 16:17:37
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 AD HW: 1K0 959 795 P
Component: J388 TUER-SG HL 0308
Revision: 42004101 Serial number: 00000000347175
Coding: 0001168
VCID: 72E1455D6DD3A78E9D3-8027
Component: RDK 0450
Coding: 0100101
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 AD HW: 1K0 959 794 P
Component: J389 TUER-SG HR 0308
Revision: 42004101 Serial number: 00000000360051
Coding: 0001168
End ---------------------------------------------------------------------
VWBob
Rochester, NY
C?ID=55547
Answer from Ross-Tech
Got a response from tech support at Ross-Tech that I will share.
BTW all the radio functions on steering wheel work and radio info shows up in MFD.
"In this case that RCD-510 is a 2010 and newer BAP exclusive protocol control module that was designed to be installed in newer vehicles with the White/UDS instrument clusters. Unlike the RNS-510 unit, you cannot modify the communication protocol to DDP for compatibility with Red/CAN controllers via coding. For this reason you will not be able to resolve the fault code - but I wouldn't really worry about it if you aren't experiencing functionality concerns."
