2016 Golf MK7 GTE Hybrid
Drive
Norway
C?ID=177241
Saturday,19,March,2016,04:35:01:04413
VCDS Version: 16.3.0.0 (x64)
Data version: 20160216
VIN: xxxxxxxxxxxxxxxxxx   License Plate:
Chassis Type: AU (5QE)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 23 2B 3C 42 44 51 52
          55 5F 75 8C A5 A9 C6
VIN: xxxxxxxxxxxxxxxxxx   Mileage: 12626km-7845miles
Address 01: Engine (J623-CUKB)       Labels: 04E-907-309-V1.clb
   Part No SW: 04E 906 023 AG    HW: 04E 907 309 F
   Component: 1.4l TFSI hy  H21 1603
   Revision: X3H21---
   Coding: 011D0012636405083000
   ASAM Dataset: EV_ECM14TFS01104E906023AG 005004
   ROD: EV_ECM14TFS01104E906023AF.rod
   VCID: 65C163B96470FB143C-8030
Readiness: 0010 0000
Address 02: Auto Trans (J743)       Labels: None
   Part No SW: 0DD 300 045 L    HW: 0DD 927 770 B
   Component: GSG DQ400E    H31 1109
   Revision: 00031033    Serial number: TFK01504110187
   ROD: EV_TCMDQ400021.rod
   VCID: 306FC2ED6B326EBC1F-8064
7 Faults Found:
10893 - Implausible Data Received from Battery Energy Control Module 2
          U0413 00 [002] - -
60354 - ROD - Unknown Error Code
          - 00 [002]
60355 - ROD - Unknown Error Code
          - 00 [002]
60357 - ROD - Unknown Error Code
          - 00 [002]
60360 - ROD - Unknown Error Code
          - 00 [002]
60368 - ROD - Unknown Error Code
          - 00 [002]
60369 - ROD - Unknown Error Code
          - 00 [002]
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-OMG-V1.clb
   Part No SW: 5Q0 907 379 AK    HW: 5Q0 907 379 H
   Component: ESC           H31 0809
   Revision: 00000000    Serial number: 61155000000386
   Coding: 01FA40A13820316C037A060741C92980021C8CC0608294F3F8A150FAC282
   ASAM Dataset: EV_Brake1UDSContiMK100OMG 001001
   ROD: EV_Brake1UDSContiMK100OMG_VW37.rod
   VCID: 0501433984301B149C-8050
   Revision: 00021000    Serial number: 0368957488
   Coding: 030C0C
   ROD: EV_KessyHellaMQBAB_VW37.rod
   VCID: 3A7BE0C5BD4EA4ECA1-806E
   Part No SW: 5GE 907 044 AD    HW: 5GE 907 044 AD
   Component: Climatronic   H02 1104
   Revision: 00001K07
   Coding: 00021014200100010105000000101002
   ASAM Dataset: EV_ACClimaBHBVW37X 005134
   ROD: EV_ACClimaBHBVW37X_VW37.rod
   VCID: 7EF32CD5E1E648CCDD-802A
   Subsystem 3 - Part No SW: 12E 963 231 F    HW: 12E 963 231 F
   Component: J848 HV-PTC  H09 0206
   Serial number:  T151403003807000115
H02
   Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
   Component: BCM MQBAB H   H24 0173
   Serial number: 01061513900527
   Coding: 00111B46C35102F36BEC5000001C07281800000000000000000000000000
   ROD: EV_BCMBOSCH_VW37.rod
   VCID: 09194F09A8287F74F8-805C
   Slave 1:
   Component: WWS    150506  043 0551
   Serial number:         150512082629
   Slave 2:
   Component: RLHS  037 0059
   Serial number: S4Y15M05D22H20M43S43
   Coding: 90A8DD
   Subsystem 3 - Part No SW: 8V3 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS73.403  H03 0004
   Serial number: 0000CGQ0004CAJR00000
   Coding: 181901
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-298.clb
   Part No SW: 5Q0 919 298 K    HW: 5Q0 919 298
   Component: PARKHILFE PLA H12 0054
   Revision: --------    Serial number: 39491514000328
   Coding: 1031165051
   ASAM Dataset: EV_EPHVA2CAU3700000 003021
   ROD: EV_EPHVA2CAU3700000_VW37.rod
   VCID: 479D8931FEBCC9042E-8012
Address 13: Auto Dist. Reg (J428)       Labels: 5Q0-907-572.clb
   Part No SW: 5Q0 907 572 E    HW: 5Q0 907 572 E
   Component: ACC Bosch MQB H05 0312
   Serial number: 28041503210412
   Coding: 001C1700FE0739
   ASAM Dataset: EV_ACCMRRBoschVW372 001016
   VCID: 3979FFC9B848AFF4A8-806C
   Part No SW: 5Q0 907 376 A    HW: 5Q0 907 376 A
   Component: DAEMPFUNGS-SG H16 0120
   Serial number: 08051541350313
   ROD: EV_DRCONTITEMIC.rod
   VCID: 377DF9F18E5CB9845E-8062
   Part No SW: 5Q0 959 655 S    HW: 5Q0 959 655 S
   Component: AirbagVW20    009 0870
   Serial number: 003MFR00UDN4
   Coding: 98CCC000002000005C0000CF004800000065
   VCID: 50AFA26D0BF20EBC7F-8004
   Belt Pretensioner left:
   Serial number: 34169667B19051540424
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34169668B19051541275
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 002 005 15
   Serial number: 3570000000039B71B41J
   Subsystem 4 - Part No SW: -----------    HW: 480 002 005 15
   Serial number: 35800000000184B8941J
   Subsystem 5 - Part No SW: -----------    HW: 480 401 105 15
   Serial number: 3510002B51A14CC3317
   Subsystem 6 - Part No SW: -----------    HW: 480 401 105 15
   Serial number: 3520002A71A14CC2D266
   Subsystem 7 - Part No SW: -----------    HW: 480 401 805 15
   Serial number: 3550002BF1A91E0202B5
   Part No SW: 5Q0 953 507 HN    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0110
   Revision: --------    Serial number: 04051504400397
   Coding: 0C10
   ROD: EV_SMLSKLOMQB_VW37.rod
   Part No SW: 5G1 920 754 A    HW: 5G1 920 754 A
   Component: KOMBI         302 6420
   Coding: 072D1B187FDC000800886A1B5600000000000000
   ROD: EV_DashBoardVDDMQBAB_VW37.rod
   VCID: 29592F8948E81F74D8-807C
Address 19: CAN Gateway (J533)       Labels: Redir Fail!
   Part No SW: 5QE 907 530 D    HW: 5QE 907 530 A
   Component: GW MQB EV     312 3225
   Revision: --------    Serial number: 24041510800895
   Coding: 0201001726F16400FB00527CDC1F00000001050100010000000300000000
   ASAM Dataset: EV_GatewEVConti 013020
   ROD: EV_GatewEVConti.rod
   Subsystem 1 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N
   Component: E221__MFL-DC1  H10 0040
   Serial number: 29150000947010025197
   Coding: 2DFFFF
   Subsystem 2 - Part No SW: 5QE 915 181     HW: 5QE 915 181
   Serial number: 4449626303
   Part No SW: 5QE 909 059 A    HW: 5QE 909 059 A
   Component: EBKV          H12 0160
   Serial number:   085430010279
   Coding: 02720100331900020002060500
   ASAM Dataset: EV_BrakeBoostBoschMQBOMG 002014
   ROD: EV_BrakeBoostBoschMQBOMG_VW37.rod
   VCID: 4C97B61DE7DA2A5C03-8018
   Subsystem 2 - Part No SW: 5QE 909 057 A    HW: 5QE 909 057 A
   Component: VX70BrakeAssi  H04 0140
   Serial number: 05802861200515045510
   Revision: 00000000    Serial number: 15000127659001
   Coding: 7900000000000000
   ROD: EV_ELVMarquMQB_VW37.rod
   VCID: 3467CEFD9F2A529C7B-8060
Address 3C: Lane Change (J1086)       Labels: None
   Component: HRE_Master    H11 0071
   Serial number: 0365988384
   Coding: 02011103
   ROD: EV_HREntryHella.rod
   VCID: 3C77E6DDB77A9ADCB3-8068
   Lane Change Assistant 2:
   Serial number: 290415BDS14275
   Coding: 003F1720D000048000001000
   VCID: 43859D21CA84E524F2-8016
   Subsystem 1 - Part No SW: 5Q0 959 811     HW: 5Q0 959 811
   Serial number: 00000000000006204225
   Coding: 110000
   Component: EPS_MQB_ZFLS  126 1061
   Coding: D302
   ROD: EV_SteerAssisMQB_VW37.rod
   Part No SW: 5G0 907 080 D    HW: 5G0 907 080 D
   Component: VW370P3815010 H06 4492
   Revision: 00H06000
   Coding: C0020000000000000000
   ASAM Dataset: EV_DMCM09550115G0907080D 001018
   ROD: EV_DMCM09550115G0907080D.rod
   VCID: 285F2A8D53E2267CC7-807C
   Serial number: 010515BDU07551
   Coding: 003F1120DE00048000801000
   VCID: 428B9825D59EEC2CF9-8016
   Subsystem 1 - Part No SW: 5Q0 959 812     HW: 5Q0 959 812
   Serial number: 00000000000006145795
   Coding: 090000
Address 55: Headlight Range (J431)       Labels: 5Q0-907-357.clb
   Coding: 0292020001010000
   ROD: EV_HeadlRegulVWLWRMQB_VW26.rod
   VCID: 75E133F9D4D00B948C-8020
   Part No SW: 3G0 035 020 B    HW: 3G0 035 020
   Component: MU-H-ND-EU    H42 0317
   Serial number: A598E0F7505503
   Coding: 02730001FF0000005111110100880A001F0209D4012001009E
   VCID: 16231475E996A08C65-8042
   Media Player Position 1:
   Radio Tuner - Digital:
   Subsystem 2 - Part No SW: 5G0 919 606     HW: 5G0 919 606
   Component: ABT_High  H62 0031
   Serial number: VWZ8Z9RU301FWV
   Engine Control Module 2:
   Subsystem 3 - Part No SW: -----------    HW: -----------
   Component: -------------  --- ----
   Seat Adjustment Driver Side:
   Subsystem 4 - Part No SW: V03 959 800 QN    HW: -----------
   Component: ECE 2016  --- 0134
   Air Conditioning Compressor:
   Diesel Pump Control Unit:
   Door Electronics Driver Side:
   Subsystem 7 - Part No SW: -----------    HW: -----------
   Brake Assistance:
   Subsystem 8 - Part No SW: -----------    HW: -----------
   Interior Monitoring:
   Subsystem 9 - Part No SW: -----------    HW: -----------
   Sound System:
   Door Electronics Rear Left:
   Subsystem 12 - Part No SW: -----------    HW: -----------
   Subsystem 13 - Part No SW: -----------    HW: -----------
   Subsystem 14 - Part No SW: V03 959 800 EG    HW: -----------
   Component: Gracenote2  --- 1011
Address 75: Telematics (J949)       Labels: None
   Part No SW: 5QE 035 284 A    HW: 5QE 035 284 A
   Component: OCULowMQBEU   008 0561
   Coding: 027390011082BA0100F800000000
   ROD: EV_OCULowMQB.rod
   Part No SW: 5Q0 915 182 C    HW: 5Q0 915 182 C
   Component: BECM          H05 0652
   Serial number: T1220044
   Coding: 00000000
   ASAM Dataset: EV_BECM09620115Q0915182 006036
   ROD: EV_BECM06020115C6915182_VW37.rod
   VCID: 3365CDE19A2455A462-8066
   Subsystem 2 - Part No SW: 5Q0 915 250 D    HW: 5Q0 915 250 D
   Component: BJB  H27 0240
   Subsystem 3 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D1  H14 0472
   Serial number: V013C1540330568
   Subsystem 4 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D2  H14 0472
   Serial number: V013C1540330575
   Subsystem 5 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D3  H14 0472
   Serial number: V013C1540330503
   Subsystem 6 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D4  H14 0472
   Serial number: V013C1540330567
   Subsystem 7 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D5  H14 0472
   Serial number: V013C1540330383
   Subsystem 8 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D6  H14 0472
   Serial number: V013C1540330504
   Subsystem 9 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D7  H14 0472
   Serial number: V013C1540330542
   Subsystem 10 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D8  H14 0472
   Serial number: V013C1540330565
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 5Q0-980-653.clb
   Part No SW: 5Q0 980 653 G    HW: 5Q0 980 653
   Component: MQB_MFK       H06 0060
   Serial number: 10000362696
   Coding: 0101010001020308000500010100000100
   ROD: EV_MFKBoschAU370.rod
   Part No SW: 5G0 907 159 C    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0017
   Serial number: 150424201217
   VCID: 2E53DC957106784C0D-807A
Address C6: Batt. Chrg. (J1050)       Labels: None
   Part No SW: 5QE 915 682 AA    HW: 5QE 915 682 AA
   Component: OBC KOSTAL    H61 3017
   Revision: --------    Serial number: 1005150E8000JO
   Coding: 115068222000
   ASAM Dataset: EV_OBCSinglPhaseKLOVW3709 004001
   ROD: EV_OBCSinglPhaseKLOVW3709_VW37.rod
   VCID: 0C17761DA75A6A5CC3-8058
14746880 - LED Module for Charging Socket A
          P31C9 00 [009] - Electrical Malfunction
                    Fault Frequency: 56
                    Reset counter: 10
                    Mileage: 12252 km
                    Date: 2016.03.03
                    Time: 17:08:01
End-------------------------(Elapsed Time: 06:07)--------------------------
