P17C5 on 2015 Golf TSI
Dascc
Anyone have experience with this code? P17C5?
The owner has been getting an intermittent "Transmission Error" on the dash.
The car will be going to the dealer soon. I wanted to help them get some info on what the problem might be. The dealership that they go to has been dismissive in the past.
Address 02: Auto Trans (J217) Labels: 09G-927-749.clb
Part No SW: 09G 927 749 D HW: 09G 927 749 D Component: AISIN AG6 G3 109 2866
Coding: 010200000C000000000000000000000000000000 Shop #: WSC 00066 790 00145
ASAM Dataset: EV_TCMAQ250031 002009 ROD: EV_TCMAQ250031_AU37.rod
VCID: 3A7B8DE3BD2B61EE7F-806E
28269 - Gear Selector
P17C5 00 [104] - Implausible Signal
Reset counter: 82
Mileage: 16731 km
Date: 2016.03.03
Time: 10:50:48
Wednesday,16,March,2016,20:18:49:29944
 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 15.7.3.0 (x64)
 Data version: 20151216
 Dealer/Shop Name:
 VIN: License Plate: Mileage: 17103km-10627mi Repair Order:
 Chassis Type: AU (5Q0)
 Scan: 01 02 03 08 09 15 16 17 19 42 44 52 55 5F 75
 VIN: 3VW217AU4FM011280 Mileage: 17103km-10627miles
 09-Cent. Elect. -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000
 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000
 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000
 52-Door Elect, Pass. -- Status: OK 0000 55-Headlight Range -- Status: OK 0000 5F-Information Electr. -- Status: Malfunction 0010 75-Telematics -- Status: OK 0000
 Address 01: Engine (J623-CXBA) Labels: 06K-907-425-V1.clb
 Part No SW: 8V0 906 264 D HW: 06K 907 425 B Component: 1.8l R4 TFSI H13 0002
 Revision: --H13---
 Coding: 091A00122424002F0000
 Shop #: WSC 00066 790 00218
 ASAM Dataset: EV_ECM18TFS0208V0906264D 001003 ROD: EV_ECM18TFS0208V0906264D_VW37.rod
 VCID: 3D7186FFAC0556D65A-8068
 Reset counter: 82
 Mileage: 16731 km
 Date: 2016.03.03
 Time: 10:50:48
 Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-ESP-V1.clb
 Part No SW: 5Q0 907 379 K HW: 5Q0 907 379 F
 Component: ESC H31 0371
 Revision: 00000000 Serial number: 51364000001064
 Coding: 01FA6AA12421096D0079020881C3298056249000408194B400 430050C002 Shop #: WSC 01383 790 50316
 ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001 ROD: EV_Brake1UDSContiMK100ESP_VW37.rod
 VCID: 4487F31BCFEF271E15-8010
 Address 08: Auto HVAC (J301) Labels: 5G0-907-426.clb
 Part No SW: 5G0 907 426 R HW: 5G0 907 426 R Component: AC Manuell H02 0907
 Revision: 00001K06
 Coding: 00020004200100000000000000000000
 ASAM Dataset: EV_ACManueBHBVW37X 003019 ROD: EV_ACManueBHBVW37X_SE37.rod
 Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
 Part No SW: 5Q0 937 087 K HW: 5Q0 937 087 K
 Component: BCM PQ37BOSCH 026 0097
 Revision: -------- Serial number: 86580606140178
 Coding: 00101A464041A26969E4400000140700100000000000000000 0000000000 Shop #: WSC 00066 790 00145
 ASAM Dataset: EV_BodyContrModul1UDSBosc 012003 ROD: EV_BCMBOSCH_AU37.rod
 VCID: 4385F007CAE120262C-8016
 Slave 1:
 Subsystem 1 - Part No SW: 5GM
 5QX-955-119-V1.CLB
 Component: WWS 140529 043
 Serial number: 140624075354
 Slave 2:
 Subsystem 2 - Part No SW: 5Q0 955 559 A 5Q0-955-547.CLB
 Component: RLS 037 0059
 Serial number: S3Y14M02D18H01M37S09 Coding: 00A8DD
 Subsystem 3 - Part No SW: 8V3 959 591 Component: J245 PS73.014 H02 0007 Serial number: WOO28367044 Coding: 181801
 955 119
 HW: 5GM 955 119
 Labels:
 0581
 B1806 F0 [008] - Safety Shut-Off due to Occupant Detection Intermittent - Confirmed - Tested Since Memory Clear
 Reset counter: 139
 Mileage: 15251 km
 Date: 2016.02.07
 Time: 13:49:04
 Part No SW: 5Q0 959 655 T HW: 5Q0 959 655 T Component: AirbagVW20 009 0825
 Serial number: 003MHM00BJZ0
 Coding: 8CCCFC00000000005000001AC24800000065 Shop #: WSC 01383 790 50316
 HW: 5Q0 955 559 A Labels:
 HW: 8V3 959 591
 ROD: EV_AirbaVW20SMEVW37X_AU37.rod VCID: 51A9CA4F009DC2B6AE-8004
 Seat occupant detection; front passenger side:
 Subsystem 1 - Part No SW: 4M0 959 339 A HW: 4M0 959 339 A Component: BF-Gewichtss. H05 0016
 Serial number: IBH0000J140000RV6W0.
 Coding: 303335
 Subsystem 2 - Part No SW: ----------- HW: 480 002 Component: SideSensor_Df 001 0887
 Serial number: 35700000000D24956F0Q
 304 14
 504 14
 405 14
 704 14
 504 14
 205 14
 Subsystem 3 - Part No SW: ----------- HW: 480 Component: SideSensor_Pf 001 0887
 Serial number: 35800000000AB75C6F0$
 Crash sensor for side airbag; rear; driver side: Subsystem 4 - Part No SW: ----------- HW: 480 Component: SideSensor_Dr 001 6149
 Serial number: 3510002BB156E9F3C3AP
 401
 Crash sensor for side airbag; rear; passenger side: Subsystem 5 - Part No SW: ----------- HW: 480 401 Component: SideSensor_Pr 001 6149
 Serial number: 3520002C3157E9D25355
 Crash sensor for front airbag; driver side: Subsystem 6 - Part No SW: ----------- HW: 480 402 Component: FrontSensor_D 001 6149
 Serial number: 3550002B7157E9D4B18K
 Crash sensor for front airbag; front passenger side: Subsystem 7 - Part No SW: ----------- HW: 480 400 Component: FrontSensor_P 001 6149
 Serial number: 3560002B715C4211825W
 Address 16: Steering wheel (J524) Labels: 5Q0-953-549.clb
 Part No SW: 5Q0 953 521 P HW: 5Q0 953 569 A Component: Lenks.Modul 075 0155
 Revision: FF028028 Serial number: 20140509500326 Coding: 0410
 Shop #: WSC 66564 385 16448
 ASAM Dataset: EV_SMLSVALEOMQB 001015 ROD: EV_SMLSVALEOMQB.rod
 VCID: 3F8DFCF7A60944C648-806A
 Part No SW: 5G1 920 840 HW: 5G1 920 840 Component: KOMBI 243 4270
 Coding: 0BB5190A2980CF05020868001000000000000000 Shop #: WSC 00066 790 00218
 ASAM Dataset: EV_DashBoardVDDMQBAB 009037 ROD: EV_DashBoardVDDMQBAB_AU37.rod
 VCID: 64C7139B6F2F471EF5-8030
 Part No SW: 5Q0 907 530 T HW: 5Q0 907 530 M
 Component: GW MQB High 212 2186
 Revision: -------- Serial number: 10061410000245
 Coding: 0101000820085900EF00000A1C0F0000000105000000000000 0000000000 Shop #: WSC 00066 790 00199
 ASAM Dataset: EV_GatewConti 011017 ROD: EV_GatewConti.rod
 VCID: 428BF503D5FB292E27-8016
 Multifunction unit control module: Subsystem 2 - Part No SW: 5G0 959 442 P Component: E221__MFL-DC1 H14 0101 Serial number: 29140000814460024191 Coding: 29FFFF
 HW: 5G0 959 442 P
 Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B Component: TSG FS 020 0025
 Serial number: 080614060500PB
 Coding: 003A03200000040000000000
 ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003 ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
 VCID: 408FFF0BDBF73B3E31-8014
 Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A Component: FOND_FHSG_DRV 005 0005
 Serial number: 00000000000002497140
 Coding: 011000
 Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P Component: EPS_MQB_ZFLS 122 1043
 Coding: 0102
 ASAM Dataset: EV_SteerAssisMQB 010031 ROD: EV_SteerAssisMQB.rod
 VCID: 4189FA0FD0FD32363E-8014
 Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B Component: TSG BFS 020 0025
 Serial number: 080614060503BQ
 ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003 ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
 Subsystem 1 - Part No SW: 5Q0 959 812 A Component: FOND_FHSG_PSG 005 0005 Serial number: 00000000000002586522 Coding: 191000
 HW: 5Q0 959 812 A
 Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
 Part No SW: 7P6 907 357 D HW: 7P6 907 357 A Component: AFS-ECU H07 0090
 Revision: -------- Serial number: -------------- Coding: 021A00010B000400
 ASAM Dataset: EV_HeadlRegulVWAFSMQB 001120 ROD: EV_HeadlRegulVWAFS_SE26.rod
 Subsystem 1 - Part No SW: 3D0 941 329 HW: 3D0 941 329 Labels: 3D0-941-329.CLB
 Component: LeiMo links H05 0012
 Coding: 2E0000
 Subsystem 2 - Part No SW: 3D0 941 329
 3D0-941-329.CLB
 Component: LeiMo rechts H05 0012
 Coding: 2E0000
 HW: 3D0 941 329
 Labels:
 Address 5F: Information Electr. (J794) Labels: 5G0-035-MIB-STD1.clb
 Part No SW: 5G0 035 844 HW: 5G0 035 844
 Component: MU-S-S-US 013 0645
 Serial number: V7B00305142509
 Coding: 027300000000000021220002001800001F0100340100010002 Shop #: WSC 00066 790 00199
 ASAM Dataset: EV_MUStd4CPASE 002040 ROD: EV_MUStd4CPASE_SK37.rod
 Media Player Position 1:
 Subsystem 1 - Part No SW: 5G0 919 605 H Component: ABT_Std_Plus H60 0030 Serial number: VWZ8Z9PS5005XL
 0020 - Tuner for Satelite Radio
 HW: 5G0 919 605 H
 B11CF 53 [009] - Deactivated Confirmed - Tested Since Memory Clear
 Reset counter: 31
 Mileage: 15224 km
 Date: 2016.02.05
 Time: 14:42:54
 Address 75: Telematics (J949) Labels: 5QE-035-285.clb
 Part No SW: 5QE 035 285 HW: 5QE 035 285 Component: OCULowMQBUS 006 0528
 ASAM Dataset: EV_OCULowMQB 001003 ROD: EV_OCULowMQB.rod
 VCID: 020B3503957BE92E67-8056
 End-------------------------(Elapsed Time: 03:43)------------------------ --
Moni
C?ID=288542
Hi Dascc,
Curious what came out of this.
Same car, same year, same error, same dealer attitude.
They originally told me that the dashboard camera was the problem.
Their explanation was - you connected to vacant fuse boxes for the constant(+) and camera is interfering with the CAN signals.
I pulled the wires all together - sure thing - transmission error would continue flashing (at least 2 x week).
Then I connected the camera to ONLY the power-socket fuse boxes (for both the constant and power-on wires).
The dealer now says they will not look at it unless I not only disconnect the wires but also pull out the cables completely from the upholstery.
I asked if I should also remove the fishing rod from the trunk ... cause you never know ... :)
In my case it happens almost exclusively when I move from parking to drive, the car was turned off and was driven for a while before ... plug in here joke for a full moon but at least that is my overall perception. Then again it sometimes flashes briefly on the highway without me touching it.
Also, twice already, right after I move out of the parking and drive slowly the computer tells me that I should always be leaving the gear in P (I guess it is thinking that I am standing).
Any tips you can share would be most sincerely appreciated!
