Timing stuck on 38 after engine work and timing kit install
vijay2019
Hi all,
Hoping someone can shed some light as I'm desperately out of my depth. My car is a 2004 Skoda Octavia 1.9 TDi 110 81kw asv 1u5.
After a head gasket replacement, piston rings and bearings etc and timing belt change, I'm trying to set the timing using the graph in VCDS. No matter what I do with the pump, the graph will only show 38 and on the bottom it says "timing within spec: slightly retarded. Nothing I do changes that.
I have adjusted the pump to retarded where it won't start and advanced where it clatters. I've tried in between those points but can't change that graph from 38.
The car drives well enough but has some slight hesitation under 2000rpm but fine after that. Idle is a horrible, feels like the engine wants to shake itself out.
I believe my G81 fuel temp sensor is lazy so I've changed that.
I had the injectors refurbed. I've tested the needle lift wire and get a resistance reading of 117 so that's fine from what I've read.
I have a very low injection quantity reading which bounces from 0 through to under 2 and back. I tried changing the adaptation number but that didn't make much difference. When I first looked it was set to 32668. I've read the iq number should be between 3 & 5 and the "hammer mod" may be required?
Duty cycle was 44.6% with engine idle at 1092, start of ignition specified was 0.2 BTDC and start of injection actual was 0.0 BTDC
I've wondered if I'm a tooth out on the timing, but AI says the car wouldn't run if it was a tooth out. Can anyone confirm that??
Any ideas on where to look and what to check would be massively appreciated.
Cheers
Vijay
Viking
C?ID=151455
Please post a complete unedited Autoscan.
vijay2019
Hi Viking,
Hope this works:
Chassis Type: 1U (1U - Skoda Octavia I (1997 > 2011))
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 56 76
VIN: TMBFP21U448752777   Mileage: 416580km-258850miles
Address 01: Engine        Labels: 038-906-012-ASV.clb
   Part No: 038 906 012 HC
   Component: 1,9l R4 EDC G550SG  4923
   Coding: 00002
   Shop #: WSC 31480
   VCID: 58BFE639B8C3A35D58-4AE4
   TMBFP21U448752777     SKZ7Z0D2446540
Readiness: 0 0 1 1 1
Address 03: ABS Brakes        Labels: 1C0-907-37x-ASR.lbl
   Part No: 1C0 907 379 K
   Component: ASR FRONT MK60      0103
   Coding: 0021505
   Shop #: WSC 31480 000 00000
   VCID: 326B7491AEFFA90D86-5122
Address 08: Auto HVAC        Labels: 1Ux-907-044.lbl
   Part No: 1U1 907 044 A
   Component: CLIMATRONIC     C 2.0.0
   Coding: 11000
   Shop #: WSC 31480
   VCID: 306F7E99F0F39B1DF0-515E
00603 - Footwell/defroster Flap Positioning Motor (V85)
            37-10 - Faulty - Intermittent
00281 - Vehicle Speed Sensor (G68)
01271 - Positioning Motor for Temperature Flap (V68)
   Part No: 1C0 909 605
   Component: 1M AIRBAG VW51 0B   0008
   Coding: 12621
   Shop #: WSC 31480
   VCID: 61C9CBDDEB9962952F-5104
Address 17: Instruments        Labels: 1U0-920-xxx-17.lbl
   Part No: 1U0 920 921 K
   Component: KOMBI+WEGFAHRSP VDO V11
   Coding: 31412
   Shop #: WSC 31480
   VCID: 387F46B91883435DB8-5104
00771 - Fuel Level Sensor (G)
00476 - Control Module for Fuel Pump (J538)
            49-00 - No Communications
01304 - Radio
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 31480
   VCID: 70EFBE993073DB1DB0-5104
01304 - Radio
Address 29: Left Light        Labels: 1U0-941-651-29.lbl
   Part No: 1U0 941 651
   Component: EVG GDL + AutoLWR   0002
   Coding: 00005
   Shop #: WSC 20021
   VCID: 70EFBE993073DB1DB0-4B7C
01344 - HID (Xenon) Headlight
            16-10 - Signal Outside Specifications - Intermittent
Address 39: Right Light        Labels: 1U0-941-651-39.lbl
   Coding: 00005
   Shop #: WSC 31480
   VCID: 70EFBE993073DB1DB0-4B62
   Part No: 1C0 959 799 B
   Component: 4Q Komfortgerát HLO 0004
   Coding: 00259
   Shop #: WSC 31480
   VCID: 366348811297B52DAA-4AE4
   Subsystem 1 - Part No: 1U6959802D
   Component: 4Q Tõrsteuer.FS KLO 0202
   Subsystem 2 - Part No: 1U6959801D
   Component: 4Q Tõrsteuer.BF KLO 0202
   Subsystem 3 - Part No: Steuerger
   Component: t HL    antwortet nicht
   Subsystem 4 - Part No: 1U0959812D
   Component: 4Q Tõrsteuer.HR KLO 0202
            37-00 - Faulty
            35-00 - -
00935 - Electric Window Motor; Rear Right (V27)
            62-10 - No or Incorrect Adjustment - Intermittent
            27-00 - Implausible Signal
End-------------------------(Elapsed Time: 03:46)--------------------------
------------------------------20 Faults Found------------------------------
Monday,02,November,2026,16:41:04:53448
VCDS Version: 26.9.0.3 (x64)
VIN: TMBFP21U448752777   License Plate:
Mileage: 416580km-258850mi   Repair Order:
   Coding: 00002
   Shop #: WSC 31480
   VCID: 58BFE639B8C3A35D58-4ACC
   Coding: 0021505
   VCID: 326B7491AEFFA90D86-5140
   Coding: 11000
   Shop #: WSC 31480
   Coding: 12621
   Shop #: WSC 31480
   VCID: 61C9CBDDEB9962952F-5122
   Coding: 31412
   Shop #: WSC 31480
01304 - Radio
   Coding: 00006
   Shop #: WSC 31480
01304 - Radio
   Coding: 00005
   Shop #: WSC 20021
   Coding: 00005
   Shop #: WSC 31480
   VCID: 70EFBE993073DB1DB0-4B96
   Coding: 00259
   Shop #: WSC 31480
vijay2019
Not sure what I did wrong and how to fix it, but it's not showing the codes in a list. Maybe co I copy and pasted from the text file rather than straight from VCDS (different laptop)
I ended up doing a hammer mod and that has sorted the idle out. Car has major hesitation now mainly between 1000 and 2000rpm.
Saw "00476 - Control Module for Fuel Pump (J538) 49-00 - No Communications" in the scan which I'm guessing could be my problem??
Or might be a big red herring -
The underlying reason for this fault code on your vehicle is that your 2004 Skoda Octavia 1.9 TDi (Mk1, 1U5 chassis) with the ASV engine code does not actually possess a Fuel Pump Control Module (J538). [1, 2]
The 81kW ASV engine uses a purely mechanical Bosch VP37 distributor injection pump. It does not feature a low-pressure lift pump in the fuel tank, nor does it have an electronic driver module for it. Because the physical hardware does not exist, VCDS reports No Communications. [1, 2, 3]
Why is the Fault Code Present?
This error code occurs because the CAN Gateway (Address 19) or the Instrument Cluster (Address 17) has been miscoded. Either during a module swap, battery replacement, or custom diagnostic work, the gateway configuration was modified to believe that a digital fuel pump control module is installed on the drivetrain CAN network. [1, 2]
vijay2019
ran a new scan
Thursday,05,November,2026,16:03:25:53448
VIN: TMBFP21U448752777   Mileage: 416740km-258950miles
   Coding: 00002
   Shop #: WSC 31480
   Coding: 0021505
   Coding: 11000
   Shop #: WSC 31480
   Coding: 12621
   Shop #: WSC 31480
   Coding: 31412
   Shop #: WSC 31480
01304 - Radio
   Coding: 00006
   Shop #: WSC 31480
01304 - Radio
   Coding: 00005
   Shop #: WSC 20021
   Coding: 00005
   Shop #: WSC 31480
   Coding: 00259
   Shop #: WSC 31480
   VCID: 366348811297B52DAA-4AFE
End-------------------------(Elapsed Time: 04:18)--------------------------
------------------------------9 Faults Found-------------------------------
