- Sep 9, 2024
- 29
- 1
- Sydney, Australia
- C?ID=594937
Hi all,
I have been suspicious about the quality of the work done on the front suspension of my A4 B8 for a while. And today I had to change the shock absorbers so I checked the bushings.
The front upper control arm bushings on my Audi A4 B8 were replaced at 103,332 km in March 2024. They have now covered 29,668 km of careful driving.
The right-side upper arm bushings have curved cracks and tears around the central rubber sections, as shown in the photos.
With the outer ball joints disconnected from the wheel-bearing housing, both arms rest low, close to the position they occupy with the suspension fully unloaded and the wheel removed. Pushing them up towards normal ride height produces a clear spring force returning them downwards. These are small, lightweight arms; they are springing down, not simply dropping under their own weight.
I would expect their neutral position to be around the position at which the bushings were tightened, corresponding to normal ride height. Instead, their resting position is near full droop.
Could tightening the inner mounting bolts with the suspension unloaded explain this downward preload and the cracking after fewer than 30,000 km?
Vin
Vin
