Hello all. First post here but long time user of VCDS. I've owned VAG vehicles since i passed my test nearly 20 years ago!
I'm currently building a 2018 Audi TTRS race car. This is made out of a 2018 TTS that i purchased with a blown turbo. I removed that engine and put in a DAZA from a 2018 RS3 (along with a lot of other things) to make the vehicle into a TTRS.
During the build, i removed the whole wiring loom and stripped out anything that was not required, but i did leave a few comfort things in that don't weigh a lot. I've managed to satisfy the system mostly but there are a few persistent faults that will need deeper coding.
Here is the current scan of where i'm at with it....it's a long list!
The majority of these errors are airbag related as the whole system has been removed completely. It's interesting to see an airbag fault on most of the modules, even the air-con for example. Why those two would need to talk to each other i have no idea.
Let's go down the list and put in some notes.
Airbag fault. I can flash the ECU to remove this DTC. I have the file but not flashed it yet.
This also requires a flash, i'm just waiting for a cable to arrive.
All databus/Airbag messages
Airbag
Pressue too low (its currently empty) and airbag faults
Airbag, but also alarm as it's all been removed. The rain/light sensor will be fixed when the windscreen is put back in!
No faults
ECU incorrectly coded. I'm not sure why as it is coded correctly, but as this has had the immobiliser removed i guess its going to kick up a fuss.
Control unit for information electronics - This has been removed completely, however i now have no controls on the steering wheel working so i'm running an aftermarket dash as well as the factory dash.
No comms with front sensor package...Not sure on this one. The car didn't come with front sensors unless this will fix itself with the windscreen module plugged back in.
Lighting and airbags missing
Not sure on this one. CAN timeout?
Databus.
A5-Frt Sens. Drv. Assist -- Status: Cannot be reached 0100
So, as you can see quite a few errors!
I think to narrow it down i will focus on the ones in theory should be easy to fix.
1) Is there a more intrusive way to remove the airbag system? (It wont let me untick airbags in the engine ECU). I cannot remember if it's in the central electrics CAN installation list. If it is i would have already removed it from there.
2) One of the faults on the dash when i turn the car on is a TPMS fault. Is there a way to remove the TPMS completely? The only way to set the TMPS on these is via the menu system, which i can now no longer access due to removing the MMI module which obviously sent the commands from the steering wheel buttons to the dash screen.
3) Is there a way to remove the alarm system completely?
That's enough to work on at the moment. I don't want to make this post any longer than it is!
Cheers
Mat
Saturday,31,October,2026,15:56:22:42783
VCDS Version: 26.9.0.3 (x64) HEX-V2 CB: 0.4713.4
Workshop Code: 210 01369 040505
VIN: TRUZZZFV4H1015780 License Plate:
Mileage: 154165km-95793mi Repair Order:
Chassis Type: FV-AU37 (8S0)
Scan: 01 02 03 05 08 09 10 16 17 19 22 2B 42 44 52 55 A5
VIN: TRUZZZFV4H1015780 Mileage: 154165km-95793miles
Address 01: Engine (------DAZA) Labels:. 07K-907-309-V1.clb
Part No SW: 8S0 907 404 E HW: 07K 907 309 E
Component: R5 2.5l TFSI H22 0005
Revision: 53H22000 CVN: 632D7534
Coding: 1A250032242601033600
Shop #: WSC 01369 210 40505
ASAM Dataset: EV_ECM25TFS0118S0907404E 001005
ROD: EV_ECM25TFS0118S0907404A.rod
VCID: 382A20D112D9FA3A1F0-806C
VINID: 92296AAAA5A61180400451C800FC7AFA27
4710 - No Communications with Airbag Control Module
U0151 00 [00100111] - -
Mileage: 154165 km
Date: 2024.05.15
Time: 00:42:53
Engine speed: 0.00 /min
Coolant temperature: 12 C
Intake air temperature: 12 C
Voltage terminal 30: 11.840 V
selected gear-Bits 0-7: 0
Cruise control switch actuation-Bits 0-7: 49
Cruise control switch actuation-Bits 0-7: 1
Readiness: 1110 0001
Part No SW: 0DL 300 012 E HW: 0GC 927 711 G
Component: GSG DQ500 H06 2012
Revision: 00H06V07 CVN: 1121B76A
ROD: EV_TCMDQ500021.rod
VCID: 2B000F9DD38F41A2622-807E
21197 - Transmission Control Unit
P1701 00 [00101111] - Locked
Mileage: 154165 km
Date: 2024.05.15
Time: 00:42:53
Clutch: primary stat: New
selected gear: GANG_R
Position: P
Engine torque: -56 Nm
Control Module temperature: 14 C
Accelerator pedal position: 15.2 %
DTC memory status: 244
Part No SW: 8S0 907 379 F HW: 8S0 907 379 F
Component: ESC H42 0530
Revision: 00000000 Serial number: 63476000000080
Coding: 24AA608D1A9A15AE4198086CC291970633240658A8821043E960CC
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_Brake1UDSContiMK100IPB 060017
ROD: EV_Brake1UDSContiMK100IPB_060.rod
VCID: 44D244215E11AEDA838-8010
8200 - Databus
[FCAN: Airbag_01 message is not received]
Reset counter: 254
Date: 2024.05.15
Time: 00:42:53
8204 - Databus
[FCAN: Airbag_02 message is not received]
Reset counter: 254
Mileage: 154165 km
Date: 2024.05.15
Time: 00:42:56
8206 - Databus
[FCAN: Airbag_03 message is not received]
Reset counter: 254
Mileage: 154165 km
Date: 2024.05.15
Time: 00:42:59
8216 - Databus
[FCAN: Fahrwerk_01 message is not received]
Reset counter: 254
Date: 2024.05.15
Time: 00:42:53
32869 - Databus
U1123 00 [10001001] - Received Error Message
[IPB-BUS: Airbag_02 / AB_Gurtschloss_FA invalid]
Reset counter: 254
Date: 2024.05.15
Time: 00:42:53
Part No SW: 3Q0 959 435 D HW: 3Q0 959 435 D
Component: VWKESSYMQB 026 0811
Revision: 00026000 Serial number: 0424191947 Dataset Number: 8S0909577F 0026
Coding: 000F0F1720
ASAM Dataset: EV_KessyHellaMQBAB 004039
VCID: 3B203FDD23EFD122F22-806E
Power rear lid opening control module:
12718084 - Databus
U1121 00 [10001001] - Missing Message
[Message Airbag_02 missing]
Reset counter: 254
Mileage: 154165 km
Date: 2024.05.15
Time: 00:42:52
Terminal_15_Kessy_specified_value: On
Terminal_15_Kessy_actual_value: On
Terminal_15_central electric_actual_value: On
Terminal_15red_Kessy_specified_value: On
Terminal_15red_Kessy_actual_value: On
Terminal_S_Kessy_specified_value: On
Terminal_S_Kessy_actual_value: On
Terminal_S_central electric_actual_value: On
Terminal_50_Kessy_specified_value: OFF
Terminal_50_Kessy_actual_value: OFF
ZAT_pressed: OFF
Request active: Condition not met
Enabling Steering Column Lock: Condition not met
Enabling immobilizer: Condition not met
Control Module Voltage: 11.876 V
Vehicle speed: 0.0 km/h
Engine speed: 0.0 /min
Status of vehicle locking: Vehicle unlocked
Coding information: Not coded
Driver s door: Open
Passenger s door: Open
Rear left door: closed
Rear right door: closed
Active_LF_scans: Init
ID-sensor 1 authentication: status: No response
ID-sensor 2 authentication: status: No response
ID-sensor 3 authentication: status: No response
ID-sensor 4 authentication: status: No response
SPN_Byte 0: 00
SPN_Byte 1: 00
SPN_Byte 2: 00
Address 08: Auto HVAC (E87) Labels:* None
Part No SW: 8S0 820 043 HW: 8S0 820 043
Component: AC Automat H05 0040
Revision: 20010000 Serial number: 16080000009000
Coding: 410040000011101100
ASAM Dataset: EV_AirCondiVAPrehAU33x 003011
ROD: EV_AirCondiVAPrehAU33x.rod
VCID: 6C82CC811601869A2B8-8038
Humidity sensor: exterior:
Rear A/C Control Head 2:
Subsystem 2 - Part No SW: 8S0 820 359 A HW: 8S0 820 359 A
Component: E775 BuA_2 H07 0020
Serial number: 00000000000000036024
Rear A/C Control Head 3:
Subsystem 3 - Part No SW: 8S0 820 359 HW: 8S0 820 359
Component: E776 BuA_3 H07 0020
Rear A/C Control Head 4:
Subsystem 4 - Part No SW: 8S0 820 359 B HW: 8S0 820 359 B
Component: E777 BuA_4 H07 0020
262914 - Refrigerant Pressure
B10AB F0 [00001001] - Too Low
Reset counter: 254
Mileage: 154165 km
Date: 2024.05.15
Time: 00:42:52
Outside temperature: 12.5 C
Compressor current: actual value: 0.00 A
Temperature downstream of evaporator: 13.8 C
Refrigerant pressure: 0.8 bar
459009 - Databus
[Airbag_01 - SG f r Airbag - Datenbus fehlende Botschaft]
Reset counter: 254
Mileage: 154165 km
Date: 2024.05.15
Time: 00:42:52
459015 - Databus
[Klima_Sensor_01 - Body Control Module - Datenbus fehlende Botschaft]
Reset counter: 254
Mileage: 154165 km
Date: 2024.05.15
Time: 00:43:04
459526 - Databus
[Klima_Sensor_01 - Feuchtesensor - Datenbus empfangener Fehlerwert]
Reset counter: 254
Mileage: 154165 km
Date: 2024.05.15
Time: 00:42:52
414978 - A/C Display/Control Head 1
B1494 31 [00001001] - No Signal
Reset counter: 254
Mileage: 154165 km
Date: 2024.05.15
Time: 00:42:56
Voltage terminal 30: 11.8 V
414996 - A/C Display/Control Head 5
B1498 31 [00001001] - No Signal
Reset counter: 254
Mileage: 154165 km
Date: 2024.05.15
Time: 00:42:56
Part No SW: 5Q0 937 084 CF HW: 5Q0 937 084 CF
Component: BCM MQBAB M+ H34 0236
Serial number: 02001700200321 Dataset Number: 8S0909514N 0025
ROD: EV_BCMBOSCH_017.rod
VCID: 7EA6F6C9707D040A95C-802A
Subsystem 1 - Part No SW: 8S2 955 119 B HW: 8S2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: 43x RL 161122 038 0371
Serial number: 00000001611210425784
Coding: 1BC7F7
Subsystem 2 - Part No SW: 8V0 941 531 AA HW: 8V0 941 531 AA
Serial number: 18 09 2016 00000192
7 Faults Found:
263435 - Glass Breakage Sensor
B145F 13 [00001001] - Open Circuit
Reset counter: 254
Mileage: 154165 km
Date: 2024.05.15
Time: 00:42:52
Terminal 15 status: On
Terminal 50 status: OFF
CAN-Bus_aktiv: On
OFF: operated
Position lamps: Not operated
Low beams: Not operated
Voltage: 11.8 V
264452 - No Communications with Anti-Theft Sensor
U10F4 00 [00001001] - -
[Sensor-DWA->kein Signal/ Kommunikation]
Reset counter: 254
Mileage: 154165 km
Date: 2024.05.15
Time: 00:42:55
CAN-Bus_aktiv: On
OFF: operated
Voltage: 11.8 V
267012 - No Communications with Anti-Theft Siren / Alarm Horn
U10F3 00 [00001001] - -
[Sirene-DWA->kein Signal/Kommunikation]
Reset counter: 254
Mileage: 154165 km
Date: 2024.05.15
Time: 00:42:55
CAN-Bus_aktiv: On
OFF: operated
Voltage: 11.8 V
528405 - Databus
[Airbag_01 Datenbus fehlende Botschaft]
Reset counter: 254
Mileage: 154165 km
Date: 2024.05.15
Time: 00:42:52
CAN-Bus_aktiv: On
OFF: operated
Voltage: 11.8 V
558101 - Databus
[Airbag_02 Datenbus fehlende Botschaft]
Reset counter: 254
Mileage: 154165 km
Date: 2024.05.15
Time: 00:42:55
CAN-Bus_aktiv: On
OFF: operated
Voltage: 11.8 V
934148 - No Communications with Rain/Light Sensor
U10F6 00 [00001001] - -
[Sensor f r Regen- und Lichterkennung->kein Signal/ Kommunikation]
Reset counter: 254
Mileage: 154165 km
Date: 2024.05.15
Time: 00:42:57
CAN-Bus_aktiv: On
OFF: operated
Voltage: 11.8 V
939524 - No Communications with Humidity Sensor
U10F5 00 [00001001] - -
[Sensor f r Feuchteerkennung->kein Signal/ Kommunikation]
Reset counter: 254
Mileage: 154165 km
Date: 2024.05.15
Time: 00:42:55
CAN-Bus_aktiv: On
OFF: operated
Voltage: 11.8 V
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-283.clb
Part No SW: 5Q0 919 283 F HW: 5Q0 919 283
Component: PARKHILFE 4K H10 0054
Revision: -------- Serial number: 39261635702957 Dataset Number: 8S0909526C 0018
Coding: 0000040011
ROD: EV_EPHVA14AU3700000_002_AU37.rod
VCID: 3C223CC126E1D61AFB8-8068
Part No SW: 8S0 907 129 AL HW: 8S0 907 129 AL
Component: Lenks. Modul H07 0150
Revision: -------- Serial number: 91335QA600973
Coding: 281C
ASAM Dataset: EV_SMLSKLOMQB 050001
ROD: EV_SMLSKLOMQB_050.rod
VCID: 045284211E916EDAC38-8050
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 8S0 920 790 B HW: 8S0 920 790 B
Component: FBenRDW H40 0296
Coding: 20AD085028000600012188808000000000000000
ASAM Dataset: EV_DashBoardBOSCHAU33X 001023
ROD: EV_DashBoardBOSCHAU33X.rod
U1014 00 [00001001] - -
[ECU incorrectly coded]
Reset counter: 254
Mileage: 154165 km
Date: 2024.05.15
Time: 00:42:52
16777026 - Control unit for information electronics 1
U1054 00 [00001001] - No Communication
[MFL_Jokerfunktion_0x34 communication error bap_error_timeout heartbeat]
Reset counter: 254
Mileage: 154165 km
Date: 2024.05.15
Time: 00:42:52
16776962 - Databus
[Airbag_01 communication error can_error_timeout]
Reset counter: 254
Mileage: 154165 km
Date: 2024.05.15
Time: 00:42:52
16776998 - Databus
[MMI_Display_Status_01 communication error can_error_timeout]
Reset counter: 254
Mileage: 154165 km
Date: 2024.05.15
Time: 00:42:55
Part No SW: 8S0 907 468 E HW: 8S0 907 468 E
Component: GW MQB TT3 021 0286
Serial number: 03011710800159 Dataset Number: 8S0909515D 0029
Coding: 030100042F025A004B000268BC0B00000000000000000000000000000001
GVL: 01D41C0000000600408C10000000C00000000000000000000000000000000000
ASAM Dataset: EV_GatewContiAU33X 013005
ROD: EV_GatewContiAU33X_013.rod
VCID: 42DE42394405A0EAB14-8016
Generator:
Subsystem 2 - Part No SW: 8S0 951 523 C HW: 8S0 951 523 C
Component: J453 MFL H07 0002
Serial number: 20161110123346 01114
131663 - No Communications with Front Sensor Package for Driver Assist. Systems
U10E0 00 [00001001] - -
[Timeout Knoten 0x4F / A5 - Frontsensorik f r Fahrerassistenzsysteme]
Reset counter: 254
Mileage: 154165 km
Date: 2024.05.15
Time: 00:42:52
Terminal 30 power supply: 11.7 V
Terminal 15: On
197175 - Control unit for battery monitoring
U1050 00 [00001001] - No Communication
[BDM (LIN#1) Timeout]
Reset counter: 254
Mileage: 154165 km
Date: 2024.05.15
Time: 00:42:52
Terminal 15: On
Address 22: AWD (J492) Labels:| 0CQ-907-554-V1.clb
Part No SW: 0CQ 907 554 K HW: 0CQ 525 130
Component: Haldex4Motion H52 7762
Serial number: HA1-00002.01.18 Dataset Number: v1260x015G0 0000
Coding: 0601
Shop #: WSC 06314 790 00021
ROD: EV_AllWheelContrHA1VW37X_002_VW37.rod
VCID: 4DC461058D5B6F925C6-8018
Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0032
Serial number: 16000337800003
Coding: 0900000000000000
ROD: EV_ELVMarquMQBB_VW37.rod
VCID: 71BCDDF531236B7218E-8024
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-DCD-V1.clb
Component: TSG FS 020 0041
Serial number: 151216ELE17851 Dataset Number: 8S0909872E 0021
Coding: 001F42225C01040100001402
VCID: 43D0473D5B1FA9E2BA2-8016
65799 - Door Warning / Entry Lighting
B1775 01 [00001001] - Electrical Failure
Reset counter: 254
Mileage: 154165 km
Date: 2024.05.15
Time: 00:42:52
65649 - Lamp for Ambient Illumination
B1325 13 [00001001] - Open Circuit
Reset counter: 254
Mileage: 154165 km
Date: 2024.05.15
Time: 00:42:52
458752 - Databus
Reset counter: 254
Mileage: 154165 km
Date: 2024.05.15
Time: 00:42:52
Part No SW: 3Q0 909 144 K HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 506 5072
Dataset Number: 8S0909852D 0011
Coding: 9107
ROD: EV_SteerAssisMQB_013.rod
VCID: 3A2E3AD92CD5E82AE94-806E
21760 - Databus
[HCA_01 Botschaft - CAN-Timeout]
Reset counter: 254
Mileage: 154165 km
Date: 2024.05.15
Time: 00:42:52
Motor status: 00
Supply voltage: 11.75 V
Temperature: 25.0 C
KFC: 55
KFA: 00 00
Freeze frame conditions: 5F
uioUdNotFilt_xdu16: 11.78 V
uAdSensI_SwitchedKl30_xdu16: 11.79 V
RP_VALCNTSAV: not activated
RP_DIAGJOB: not activated
RP_RPS: not activated
RP_STARTUP: not activated
RP_L2PLAUSI: not activated
RP_INDEXPLAUSI: not activated
RP_RUKUCNTR: not activated
RP_UNDERVOLT: not activated
RP_CNTERR: not activated
Component: TSG BFS 020 0041
Serial number: 161216ELF43929 Dataset Number: 8S0909873E 0021
Coding: 001F42225E01040100001402
Reset counter: 254
Mileage: 154165 km
Date: 2024.05.15
Time: 00:42:52
Reset counter: 254
Mileage: 154165 km
Date: 2024.05.15
Time: 00:42:52
458752 - Databus
Reset counter: 254
Mileage: 154165 km
Date: 2024.05.15
Time: 00:42:52
Part No SW: 4H4 907 357 G HW: 7P6 907 357 B
Component: MxB-ECU 001 0115
Revision: -------- Serial number: -------------- Dataset Number: 8S0909865F 0025
Coding: 03E600102B230200
ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005012
VCID: 36362EE918CD0C4A0DC-8062
Coding: E01800
Coding: E01800
Subsystem 3 - Part No SW: 8S0 941 329 HW: 8S0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H02 S002
Coding: E01800
Subsystem 4 - Part No SW: 8S0 941 329 HW: 8S0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H02 S002
Coding: E01800
13705485 - Databus
[Timeout CAN-Message Airbag_02]
Reset counter: 254
Mileage: 154165 km
Date: 2024.05.15
Time: 00:42:54
13705736 - Databus
[RLS_01 Datenbus fehlende Botschaft]
Reset counter: 254
Mileage: 154165 km
Date: 2024.05.15
Time: 00:42:54
13705473 - Databus
[Fahrwerk_01 Datenbus fehlende Botschaft]
Reset counter: 254
Mileage: 154165 km
Date: 2024.05.15
Time: 00:42:53
Address A5: Frt Sens. Drv. Assist
End----(Elapsed Time: 01:11, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
------------------------------37 Faults Found------------------
Airbag
No faults
Databus.
Cheers
Mat
